Like Tree3Likes
 Old 03-10-2013, 01:52 PM   #41
BlueStreak's Avatar
Posts: 1,467   (View Stats)
How many conclusive ringland failures have we had leading to these symptoms? I know of 2 (Dano, BlueStreak) yet I know of lots of cars with low compression numbers. Who else can chime in with the failure when they pulled the motor apart with low compression?
@BlueStreak; did you guys take that motor apart yet that had low compression numbers?
Yessir. Confirmed ringland failure on the most recent build.
I believe phate can chime in with more counts of ringland failure.
EDIT: We also have a pu that was driven hard at many time attack events last year. Cyl 4 is down on compression with 20% leakdown. The motor will be coming apart soon for a forged build. Chances are, it's another cracked ringland case.
'07 CWP MS3
Forged.
The Following 5 Users Say Thank You to BlueStreak For This Useful Post:
atvfreek (03-10-2013), Dano (03-11-2013), Lex (03-10-2013), mrQQ (03-11-2013), phate (03-10-2013)
 Old 03-10-2013, 01:57 PM   #42
Do you have pics and a story behind the motor and circumstances in which it failed?
mrQQ (03-11-2013)
 Old 03-10-2013, 02:10 PM   #43
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Tore down one last year and I believe all ring lands were cracked (the 3 remaining, anyway). It was evident the engine had sustained fairly heavy detonation for quite a while, which was the likeliest culprit.
-06 MS6
-Corn fed 07 MS3 - Sold
atvfreek (03-10-2013), BlueStreak (03-10-2013), Dano (03-11-2013), Lex (03-10-2013), mrQQ (03-11-2013)
 Old 03-10-2013, 02:12 PM   #44
BlueStreak's Avatar
I don't have pics unfortunately. The failure was confirmed by the engine builder over email and I left it at that. They may have taken though and I can find out.
This motor has seen a few years of K04 autocross and time attack and then one season of time attack on big turbo.
Didn't pinpoint the time of failure on this one.
The failure in the pu, on the other hand, was identified at the end of last year's time attack season.
'07 CWP MS3
Forged.
The Following User Says Thank You to BlueStreak For This Useful Post:
mrQQ (03-11-2013)
 Old 03-10-2013, 02:15 PM   #45
Are these cars seeing high oil/coolant temps during time attack Detonation? Are they using any sort of cooling such as WMI, oil cooler, radiator, etc?
 Old 03-10-2013, 06:38 PM   #46
BlueStreak's Avatar
The pu has an oil temp gauge and reaches 260*F within 2 laps on the track. Don't know about deto.
When mine cracked, I had no counts of KR (had it logging the whole time) during time attack and was spraying meth. I do recall coolant temps in the 230*F. No oil temp gauge at the time.
'07 CWP MS3
Forged.
 Old 03-11-2013, 02:41 AM   #47
mrQQ's Avatar
Posts: 1,164   (View Stats)
mrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the world
ok, so I'll have the motor taken apart eventually, just to see how that looks, but for now..
which are the parts that definitely need replacement each time you rebuild?
i know this is basic question, but I have no knowledge whatsoever, and I doubt the shop will have any with MZR either, so I might aswell figure it out myself..
if noone is replacing sleeves, then what are they doing?
mrQQ is offline   Reply With Quote
 Old 03-11-2013, 04:04 AM   #48
mrQQ's Avatar
going through @Dano thread.. tis long :O
The Following User Says Thank You to mrQQ For This Useful Post:
btstarcher (03-11-2013)
 Old 03-11-2013, 08:58 AM   #49
BlueStreak's Avatar
I recommend reading engine build threads to see what is required. I have one as well titled "Time To Go Forged". @Dano;'s is more comprehensive w.r.t. parts and part numbers. @silvapain;'s too.
I believe only one person replaced sleeves with iron units. AFAIK, the motor hasn't seen much run time tho. What has been done so far is just a hone for standard sized forged piston (if bores are still ok) or a "20 over" or "40 over" bore piston with appropriate bore and honing.
'07 CWP MS3
Forged.
atvfreek (03-11-2013), Dano (03-11-2013), phate (03-11-2013), silvapain (03-15-2013), TiGraySpeed6 (03-11-2013)
 Old 03-11-2013, 09:22 AM   #50
Posts: 9,484   (View Stats)
Looks like ringland failures are becoming a mainstream failure mode now that we are better at TQ management and are saving the rods.
is it time to start swapping in cooler thermostats and or get better fan control? Oil coolers. What is the first least troublesome step?
Don't think this is necessary, yet, for a forged motor but the uber tight OEM ring gaps need some better heat management for sure.
Tappin
atvfreek (03-11-2013), BlueStreak (03-11-2013), TiGraySpeed6 (03-11-2013)
 Old 03-11-2013, 10:44 AM   #51
mrQQ's Avatar
I might have overheated it once, to think about it. It was some drifting on winter lake, with lots of high rpm.
Not gonna trash the car a lot, its a DD with no track time, so would prefer as little investment as possible.
Reading through the threads, but they are long.
K1+Wiseco is what everyone is doing?
What other parts need absolute replacement? Head, cover, manifold gaskets?
Should I be touching VVT/timing at 40k?
What valve works need to absolutely be done? valve cleaning, valve seats?
@Dano, in your pricing excel, what was the tremendous amount for some kind of lube?
 Old 03-11-2013, 11:07 AM   #52
just guessing but it was probably all the lubricants/additives for the 4 oil changes that were planned/occurred in the 1st 1500 miles.
a lot of good it did lol
 Old 03-11-2013, 11:26 AM   #53
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
Tappin
Have you seen @superskatexes; fan control mod? I don't know how much it actually dropped temps, but you could use a thermostat that opens sooner than the 190° he used.
EDIT: Well, I fucked up his name, but you know what I meant.
2006 Mazdaspeed6
The Following 2 Users Say Thank You to sidekick For This Useful Post:
btstarcher (03-11-2013), Dano (03-11-2013)
 Old 03-11-2013, 11:27 AM   #54
I have heard about it but not researched it in detail...yet. is our OEM tstat 200*?
hold that answer until I get a thread up regarding heat management in a day or two. Don't want to derail OPs thread any more
sidekick (03-11-2013)
 Old 03-11-2013, 11:45 AM   #55
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Thought I would add in my current failure. Compression in cyl 4 was half of what the other cylinders were. 180,175,180,90. Did a wet test and shot the compression up to 150. Car has exactly 95k miles. Most of its life at or around 400tq.
The motor will be coming apart this weekend by Pablo so I will have more info after that.
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
The Following 4 Users Say Thank You to taf0422 For This Useful Post:
BlueStreak (03-11-2013), Dano (03-11-2013), Lex (03-11-2013), TiGraySpeed6 (03-11-2013)
 Old 03-11-2013, 11:59 AM   #56
mrQQ's Avatar
add to above questions:
do i need all gasket overhaul kit (its expensive..)
 Old 03-11-2013, 12:03 PM   #57
MZR DISI Heat Management
 Old 03-11-2013, 03:31 PM   #58
BlueStreak's Avatar
Gasket kit is highly recommended.
'07 CWP MS3
Forged.
 Old 03-12-2013, 10:36 AM   #59
mrQQ's Avatar
ok.. so it might take 3-4 months till i get parts in place.
on idiot scale of 1 to 10, how unwise it is to mildy drive the car around, to and back from work at the time?
 Old 03-12-2013, 10:50 AM   #60
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Idiot scale is easy- just check price & availability of a new short block from Mazda, compare against your credit card available balance.
Temper by the general rule that if you have to ask, it's probably better to park it.
jseams likes this.
340hp / 371tq
The Following 3 Users Say Thank You to TiGraySpeed6 For This Useful Post:
atvfreek (03-12-2013), BlueStreak (03-12-2013), Dano (03-12-2013)
 Old 03-12-2013, 11:11 AM   #61
mrQQ's Avatar
got it
 Old 03-12-2013, 01:51 PM   #62
haha
FWIW I probably put 2-3K miles on my motor with the broken ringland, and probably 10-15 WOT pulls with VD charts to prove I was not making power...lol This before I discovered the issue.
It is a gamble either way but def not as bad as a bent rod. BTW have you measured rod height to rule that out as a possible cause for your lower compression?
BlueStreak (03-12-2013), btstarcher (03-12-2013)
 Old 03-12-2013, 02:25 PM   #63
mrQQ's Avatar
Yea, they're all equal. Bent rod shouldn't cause leak in leak-down test either, correct?
2k miles puts me at.. 266 days worth of trips to work LOL
 Old 03-12-2013, 03:54 PM   #64
atvfreek's Avatar
Posts: 7,787   (View Stats)
Honestly there is probably more people than we know of that have broken ringlands and don't even know it. Long block isn't that much more from Mazda. I would even consider that route. Then you get new chain, vvt etc. Then part out what you can from your old motor to get back some of the money
Sent from your couch
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 4 Users Say Thank You to atvfreek For This Useful Post:
ASHMS3 (03-12-2013), BlueStreak (03-12-2013), Dano (03-12-2013), taf0422 (03-12-2013)
 Old 03-12-2013, 09:58 PM   #65
Sooooo true. Now that we are past throwing rods the next weak link is rearing its ugly head and we are right there with the scoobie guys. Lol.
Tappin
atvfreek (03-13-2013), BlueStreak (03-12-2013)
 Old 03-12-2013, 10:51 PM   #66
sidekick's Avatar
Groans: 47
Tappin
Advancing the community one fail at a time
2006 Mazdaspeed6
 Old 03-13-2013, 06:11 AM   #67
At least we have semi-respectable transmissions
340hp / 371tq
BlueStreak (03-13-2013)
 Old 03-13-2013, 09:56 PM   #68
MajesticBlueNTO's Avatar
Posts: 77   (View Stats)
MajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the world
since the motor became my forged motor, we asked the engine builder to check the ring end gap and the ringlands on cylinder 3..here's a pic we grabbed
you can barely notice the cracks in the ringland if you weren't looking for it
MajesticBlueNTO is offline   Reply With Quote
The Following 3 Users Say Thank You to MajesticBlueNTO For This Useful Post:
BlueStreak (03-14-2013), Celestspeed3 (03-13-2013), phate (03-13-2013)
 Old 03-14-2013, 02:40 AM   #69
mrQQ's Avatar
can someone with knowledge describe the pic?
 Old 03-14-2013, 03:19 AM   #70
mrQQ's Avatar
reading through Dano's thread, I get the same with my car:
The problem is high KR under very light loads, say .45 load right at the point of acceleration and deceleration. We've all heard the CDFP rattle on throttle lift and this occurs right at the same time/load but if you just barely hold the throttle steady around 3K RPMs, slightly accelerating the KR will remain constant and an audible rattle is heard. I sounds very similar to a CDFP rattle but perhaps just a tad louder. Now this may have been the case all along but I don't think so. Log attached.
edit: except I can't hear anything
 Old 03-14-2013, 07:38 AM   #71
BlueStreak's Avatar
Here's a more obvious portrayal of a cracked ringland. The same issue exists with the photo provided by @MajesticBlueNTO; except the ringland is still holding onto the rest of the piston.
See the chunk missing out of the piston below the top ring? That's the ringland.
Here it is in my hand.
Makes sense now?
'07 CWP MS3
Forged.
The Following 2 Users Say Thank You to BlueStreak For This Useful Post:
fooqr (11-11-2013), silvapain (03-15-2013)
 Old 03-14-2013, 08:06 AM   #72
Eth Fiend
phate's Avatar
You guys want to start a thread to document ring land failures? I finally uploaded all of the pictures from a tear down last year, and the pistons were pretty rough.
-06 MS6
BlueStreak (03-14-2013), silvapain (03-15-2013)
 Old 03-14-2013, 08:10 AM   #73
BlueStreak's Avatar
^^^ If it adds value to the community, sure.
'07 CWP MS3
Forged.
phate (03-14-2013)
 Old 03-14-2013, 08:11 AM   #74
Eth Fiend
phate's Avatar
It looks to be the next big failure mode
If we don't have a thread by this evening, I can make one. Linking all those pics from my phone is no fun.
-06 MS6
BlueStreak (03-14-2013), taf0422 (03-14-2013)
 Old 03-14-2013, 08:15 AM   #75
BlueStreak's Avatar
Ok. I'll start one. Give me a few.
'07 CWP MS3
Forged.
The Following 3 Users Say Thank You to BlueStreak For This Useful Post:
phate (03-14-2013), taf0422 (03-14-2013), TiGraySpeed6 (03-14-2013)
 Old 03-14-2013, 08:23 AM   #76
good idea. I haz pictuars as well.
 Old 03-14-2013, 08:53 AM   #77
taf0422's Avatar
Groans: 192
I will have some pictures as well this weekend hopefully as mine will probably be a ring land issue
If thread is posted can it be linked in here as well?
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
phate (03-14-2013)
 Old 03-14-2013, 11:22 AM   #78
Is this exactly how the piston came out of the block with the top ring oriented like that or was it moved? Also under what circumstances did this blow?
Don't rotate the rings when you pull it out and get pictures exactly as the pistons come out of the block if you can as these will show where the ring gaps are.
The next step is to measure the rings gaps.
Last edited by Lex; 03-14-2013 at 11:22 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-14-2013, 11:39 AM   #79
taf0422's Avatar
Groans: 192
Pablo is doing the motor this weekend. I will see what I can do with the pictures. I have a brand new built bottom end going in that he already completed early this week so we will see how detailed I can get the photos or I will do it when I get the old bottom end back.
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 03-14-2013, 12:00 PM   #80
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Groans: 52
My head gasket was bad and It did not leak coolant or oil, it was burning coolant in the engine so small amount you cant see in exhaust or any other signs
i had to keep refilling coolant and i was getting alot of unwanted pressure built up in my coolant tank, i was also losing oil very badly about quart every 2-3 weeks
it almost sounds like u got bent valves to me or ringland
had anyone seen a FORGED piston do this in MS3/6 ?
i have a hard time seeing my wisecos doing this
Tune almost finished but having small issue ztnedman1 2010 MS3 - ECU Computer Tuning 16 09-22-2012 03:49 PM
Report: Volkswagen recalling small number of 2012 Beetle models over tire issue Haltech Automotive News 1 07-23-2012 05:43 PM
Ford recalls 20,000 small pickups for light issue Haltech Automotive News 0 07-20-2011 10:00 PM
Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon Haltech Automotive News 3 04-17-2010 08:40 PM
Small recall for big suspension issue on 2008 Honda Element Haltech Automotive News 0 08-19-2008 12:50 PM
Page generated in 0.59839 seconds with 31 queries
