![]() | | #41 | ![]() |
![]() Join Date: Sep 2008 Location: Toronto, Ontario, Canada
Rep Power: 2202 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,767
| Not Ranked : 0 score
I believe phate can chime in with more counts of ringland failure. EDIT: We also have a pu that was driven hard at many time attack events last year. Cyl 4 is down on compression with 20% leakdown. The motor will be coming apart soon for a forged build. Chances are, it's another cracked ringland case. Sent from my iPhone using Tapatalk
__________________ '07 CWP MS3 Forged. | |
![]() | | #42 | ![]() |
| Not Ranked : 0 score Do you have pics and a story behind the motor and circumstances in which it failed?
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following User Says Thank You to Lex For This Useful Post: | mrQQ (03-11-2013) |
![]() | | #43 | ![]() |
| Not Ranked : 0 score Tore down one last year and I believe all ring lands were cracked (the 3 remaining, anyway). It was evident the engine had sustained fairly heavy detonation for quite a while, which was the likeliest culprit.
| The Following 5 Users Say Thank You to phate For This Useful Post: | atvfreek (03-10-2013), BlueStreak (03-10-2013), Dano (03-11-2013), Lex (03-10-2013), mrQQ (03-11-2013) |
![]() | | #44 | ![]() |
This motor has seen a few years of K04 autocross and time attack and then one season of time attack on big turbo. Didn't pinpoint the time of failure on this one. The failure in the pu, on the other hand, was identified at the end of last year's time attack season. Sent from my iPhone using Tapatalk
| The Following User Says Thank You to BlueStreak For This Useful Post: | mrQQ (03-11-2013) |
![]() | | #45 | ![]() |
![]() | | #46 | ![]() |
When mine cracked, I had no counts of KR (had it logging the whole time) during time attack and was spraying meth. I do recall coolant temps in the 230*F. No oil temp gauge at the time.
![]() | | #47 | ![]() |
![]() Join Date: Nov 2010 Location: Kaunas, Lithuania
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 144
(Thread Starter) | Not Ranked : 0 score ok, so I'll have the motor taken apart eventually, just to see how that looks, but for now.. which are the parts that definitely need replacement each time you rebuild? i know this is basic question, but I have no knowledge whatsoever, and I doubt the shop will have any with MZR either, so I might aswell figure it out myself.. if noone is replacing sleeves, then what are they doing? |
![]() | | #48 | ![]() |
(Thread Starter) | Not Ranked : 0 score going through @Dano thread.. tis long :O |
| The Following User Says Thank You to mrQQ For This Useful Post: | btstarcher (03-11-2013) |
![]() | | #49 | ![]() |
I believe only one person replaced sleeves with iron units. AFAIK, the motor hasn't seen much run time tho. What has been done so far is just a hone for standard sized forged piston (if bores are still ok) or a "20 over" or "40 over" bore piston with appropriate bore and honing.
| The Following 5 Users Say Thank You to BlueStreak For This Useful Post: | atvfreek (03-11-2013), Dano (03-11-2013), phate (03-11-2013), silvapain (03-15-2013), TiGraySpeed6 (03-11-2013) |
![]() | | #50 | ![]() |
| Not Ranked : 0 score Looks like ringland failures are becoming a mainstream failure mode now that we are better at TQ management and are saving the rods. is it time to start swapping in cooler thermostats and or get better fan control? Oil coolers. What is the first least troublesome step? Don't think this is necessary, yet, for a forged motor but the uber tight OEM ring gaps need some better heat management for sure. Tappin
| The Following 3 Users Say Thank You to Dano For This Useful Post: |
![]() | | #51 | ![]() |
(Thread Starter) | Not Ranked : 0 score I might have overheated it once, to think about it. It was some drifting on winter lake, with lots of high rpm. Not gonna trash the car a lot, its a DD with no track time, so would prefer as little investment as possible. Reading through the threads, but they are long. K1+Wiseco is what everyone is doing? What other parts need absolute replacement? Head, cover, manifold gaskets? Should I be touching VVT/timing at 40k? What valve works need to absolutely be done? valve cleaning, valve seats? @Dano, in your pricing excel, what was the tremendous amount for some kind of lube? |
![]() | | #52 | ![]() |
a lot of good it did lol
![]() | | #53 | ![]() |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
EDIT: Well, I fucked up his name, but you know what I meant.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() | |
| The Following 2 Users Say Thank You to sidekick For This Useful Post: | btstarcher (03-11-2013), Dano (03-11-2013) |
![]() | | #54 | ![]() |
hold that answer until I get a thread up regarding heat management in a day or two. Don't want to derail OPs thread any more
| The Following User Says Thank You to Dano For This Useful Post: | sidekick (03-11-2013) |
![]() | | #55 | ![]() |
![]() Join Date: Jan 2009 Location: Andover, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,936
Groans: 192
| Not Ranked : 0 score Thought I would add in my current failure. Compression in cyl 4 was half of what the other cylinders were. 180,175,180,90. Did a wet test and shot the compression up to 150. Car has exactly 95k miles. Most of its life at or around 400tq. The motor will be coming apart this weekend by Pablo so I will have more info after that.
__________________ precision gen2 5862 coming soon [SIZE="1"]07 MS3 GT.. Engine:Cobb V3,GTX3076r EWG,Wiseco Pistons/Manley Rods, L19's,JMF, Bosch 3.5bar MAP,CS cat-back,M2 DP, full race manifold,FP internals,FREEK 4",CP-E flange HKS,DO Stage II ss lines,Cobb piping,TR8L,MD RMM&TMM,JBR RSB & FSB,JBR SST,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,JBR BSD,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint,CS wheelSuspension/Wheels:Enkei RPF1 17x9,Eibach 5mm spaces H&R springs,koni yellows. GTX3076r --- 479/412 S4-460/400 Highest HP BNR S3 BNR-S3 424/397 |
| The Following 4 Users Say Thank You to taf0422 For This Useful Post: |
![]() | | #56 | ![]() |
(Thread Starter) | Not Ranked : 0 score add to above questions: do i need all gasket overhaul kit (its expensive..) |
![]() | | #57 | ![]() |
| The Following 2 Users Say Thank You to Dano For This Useful Post: | silvapain (03-15-2013), TiGraySpeed6 (03-11-2013) |
![]() | | #58 | ![]() |
| Not Ranked : 0 score Gasket kit is highly recommended.
![]() | | #59 | ![]() |
(Thread Starter) | Not Ranked : 0 score ok.. so it might take 3-4 months till i get parts in place. on idiot scale of 1 to 10, how unwise it is to mildy drive the car around, to and back from work at the time? |
![]() | | #60 | ![]() |
![]() Join Date: Jun 2009 Location: Tally, FL
Rep Power: 3058 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,683
| Not Ranked : 0 score Idiot scale is easy- just check price & availability of a new short block from Mazda, compare against your credit card available balance. Temper by the general rule that if you have to ask, it's probably better to park it.
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq |
| The Following 3 Users Say Thank You to TiGraySpeed6 For This Useful Post: |
![]() | | #61 | ![]() |
(Thread Starter) | Not Ranked : 0 score got it |
![]() | | #62 | ![]() |
FWIW I probably put 2-3K miles on my motor with the broken ringland, and probably 10-15 WOT pulls with VD charts to prove I was not making power...lol This before I discovered the issue. It is a gamble either way but def not as bad as a bent rod. BTW have you measured rod height to rule that out as a possible cause for your lower compression?
| The Following 2 Users Say Thank You to Dano For This Useful Post: | BlueStreak (03-12-2013), btstarcher (03-12-2013) |
![]() | | #63 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yea, they're all equal. Bent rod shouldn't cause leak in leak-down test either, correct? 2k miles puts me at.. 266 days worth of trips to work LOL |
| The Following User Says Thank You to mrQQ For This Useful Post: | atvfreek (03-12-2013) |
![]() | | #64 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score Honestly there is probably more people than we know of that have broken ringlands and don't even know it. Long block isn't that much more from Mazda. I would even consider that route. Then you get new chain, vvt etc. Then part out what you can from your old motor to get back some of the money Sent from your couch
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
| The Following 4 Users Say Thank You to atvfreek For This Useful Post: |
![]() | | #65 | ![]() |
| Not Ranked : 0 score Sooooo true. Now that we are past throwing rods the next weak link is rearing its ugly head and we are right there with the scoobie guys. Lol. Tappin
| The Following 2 Users Say Thank You to Dano For This Useful Post: | atvfreek (03-13-2013), BlueStreak (03-12-2013) |
![]() | | #66 | ![]() |
Groans: 47
![]() | | #67 | ![]() |
| Not Ranked : 0 score At least we have semi-respectable transmissions
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | BlueStreak (03-13-2013) |
![]() | | #68 | ![]() |
![]() Join Date: Oct 2009
Rep Power: 188 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 72
![]() you can barely notice the cracks in the ringland if you weren't looking for it | |
| The Following 3 Users Say Thank You to MajesticBlueNTO For This Useful Post: |
![]() | | #69 | ![]() |
(Thread Starter) | Not Ranked : 0 score can someone with knowledge describe the pic? |
![]() | | #70 | ![]() |
(Thread Starter) | Not Ranked : 0 score reading through Dano's thread, I get the same with my car:
![]() | | #71 | ![]() |
| Not Ranked : 0 score Here's a more obvious portrayal of a cracked ringland. The same issue exists with the photo provided by @MajesticBlueNTO; except the ringland is still holding onto the rest of the piston. See the chunk missing out of the piston below the top ring? That's the ringland. ![]() Here it is in my hand. ![]() Makes sense now?
![]() | | #72 | ![]() |
| Not Ranked : 0 score You guys want to start a thread to document ring land failures? I finally uploaded all of the pictures from a tear down last year, and the pistons were pretty rough.
| The Following 2 Users Say Thank You to phate For This Useful Post: | BlueStreak (03-14-2013), silvapain (03-15-2013) |
![]() | | #73 | ![]() |
| Not Ranked : 0 score ^^^ If it adds value to the community, sure.
| The Following User Says Thank You to BlueStreak For This Useful Post: | phate (03-14-2013) |
![]() | | #74 | ![]() |
| Not Ranked : 0 score It looks to be the next big failure mode ![]() If we don't have a thread by this evening, I can make one. Linking all those pics from my phone is no fun.
| The Following 2 Users Say Thank You to phate For This Useful Post: | BlueStreak (03-14-2013), taf0422 (03-14-2013) |
![]() | | #75 | ![]() |
| Not Ranked : 0 score Ok. I'll start one. Give me a few.
| The Following 3 Users Say Thank You to BlueStreak For This Useful Post: |
![]() | | #76 | ![]() |
| Not Ranked : 0 score good idea. I haz pictuars as well.
![]() | | #77 | ![]() |
Groans: 192
| Not Ranked : 0 score I will have some pictures as well this weekend hopefully as mine will probably be a ring land issue If thread is posted can it be linked in here as well?
| The Following User Says Thank You to taf0422 For This Useful Post: | phate (03-14-2013) |
![]() | | #78 | ![]() |
The next step is to measure the rings gaps.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. Last edited by Lex; 03-14-2013 at 11:22 AM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to Lex For This Useful Post: | BlueStreak (03-14-2013) |
![]() | | #79 | ![]() |
Groans: 192
| Not Ranked : 0 score Pablo is doing the motor this weekend. I will see what I can do with the pictures. I have a brand new built bottom end going in that he already completed early this week so we will see how detailed I can get the photos or I will do it when I get the old bottom end back.
| The Following User Says Thank You to taf0422 For This Useful Post: | BlueStreak (03-14-2013) |
![]() | | #80 | ![]() |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
Groans: 52
| Not Ranked : 0 score My head gasket was bad and It did not leak coolant or oil, it was burning coolant in the engine so small amount you cant see in exhaust or any other signs i had to keep refilling coolant and i was getting alot of unwanted pressure built up in my coolant tank, i was also losing oil very badly about quart every 2-3 weeks it almost sounds like u got bent valves to me or ringland had anyone seen a FORGED piston do this in MS3/6 ? i have a hard time seeing my wisecos doing this |
| Tune almost finished but having small issue | ztnedman1 | 2010 MS3 - ECU Computer Tuning | 16 | 09-22-2012 03:49 PM |
| Report: Volkswagen recalling small number of 2012 Beetle models over tire issue | Haltech | Automotive News | 1 | 07-23-2012 05:43 PM |
| Ford recalls 20,000 small pickups for light issue | Haltech | Automotive News | 0 | 07-20-2011 10:00 PM |
| Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon | Haltech | Automotive News | 3 | 04-17-2010 08:40 PM |
| Small recall for big suspension issue on 2008 Honda Element | Haltech | Automotive News | 0 | 08-19-2008 12:50 PM |
