![]() | | #41 | ![]() |
![]() Join Date: Jul 2008 Location: Raeford, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 154
| Not Ranked : 0 score
__________________ 2012 Mazdaspeed3 LSM Should have gotten a speed6 2008 Mazdaspeed3 GT Black Mica [sold] Built motor, Etc. 383 hp 401 tq GTX2867R @ 25 psi |
![]() | | #42 | ![]() |
![]() Join Date: Dec 2008 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score when swapping out the tranny fluid, how many bottles do we need to do the swap? I'm going to use Redline MT-90. |
![]() | | #43 | ![]() |
![]() Join Date: Sep 2008 Location: Lynchburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,559
Groans: 157
Groaned at 29 Times in 16 Posts
| Not Ranked : 0 score wow...just wow.
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s |
![]() | | #44 | ![]() |
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,310
Groans: 102
__________________ |
| The Following User Says Thank You to gsrtype1 For This Useful Post: | breakfstincluded (10-17-2011) |
![]() | | #45 | ![]() |
Groans: 102
| Not Ranked : 0 score There are not huge expolsions going on in ther that get the oil dirty if it gets dark it just residue form the seals in the tranny It gets kinda warm but it s motor oil. The tranny is sealed off so dirt doens't get in ther so why need to change?
![]() | | #46 | ![]() |
Groans: 157
| Not Ranked : 0 score Eventually all oils lose their lubrication abilities and need to be replaced. Their viscosity and what not gets degraded over time. Plus theirs millions of microns of metal from the gears and other moving parts trapped in the oil...
| The Following User Says Thank You to Addikted To Boost For This Useful Post: | breakfstincluded (10-17-2011) |
![]() | | #47 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: Gaithersburg, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 335
| Not Ranked : 0 score You'd probably be fine changing the fluid every 50k if you weren't tracking or draggin the car. I generally stick to 35k changes with synthetic, unless I'm going to the road course, then the standard rule is before you track each year. (Also do brake fluid at the same time). 6k, even 15k, is beyond overkill. Gear oil doesn't encounter any real degrading factors other then heat, and even then, it's pretty unlikely our transmission will even encounter stressful heat scenarios if you aren't going to the drag strip or road course. Now of course, if you're running the car hard, and working the LSD, then sure, stepping up your change interval is a good idea. As for BG Syncromesh...my friend Kyu is running it in his speed6, and still has grinding/cold shift issues in the morning. (We are in MD/VA) |
![]() | | #48 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 179
Groans: 57
| Not Ranked : 0 score The Ford Full Synthetic MT Fluid I used improved the shift action to an amazing degree- hot or cold.
__________________ Cosmic Blue Mica 2007 MS3 GT- MSCAI, HT, E-Focus RMM, FSDs, JBR Rear ARB and billet mounts Hellrot 1995 318ti Club Sport- Turner/Conforti chip, Turner SS clutch line, UUC Motorwerks pedal bushings, clutch stop, and RK II Desert Sand Pearl 1999 Wrangler Sahara- Banks SS Exhaust manifold, Hella H4 E-Codes, Bilstein HDs Fireball Orange 1996 Speed Triple 900- Alcon six-pot front calipers, Sebring 3 into 1 "Off Road" exhaust |
| The Following User Says Thank You to div2 For This Useful Post: | 7mileshome (02-22-2009) |
![]() | | #49 | ![]() |
Groans: 57
| Not Ranked : 0 score You'll need three quarts.
![]() | | #50 | ![]() |
Groans: 57
Good advice. My track rats get 30K changes, but it's probably overkill...
__________________ Cosmic Blue Mica 2007 MS3 GT- MSCAI, HT, E-Focus RMM, FSDs, JBR Rear ARB and billet mounts Hellrot 1995 318ti Club Sport- Turner/Conforti chip, Turner SS clutch line, UUC Motorwerks pedal bushings, clutch stop, and RK II Desert Sand Pearl 1999 Wrangler Sahara- Banks SS Exhaust manifold, Hella H4 E-Codes, Bilstein HDs Fireball Orange 1996 Speed Triple 900- Alcon six-pot front calipers, Sebring 3 into 1 "Off Road" exhaust | |
![]() | | #51 | ![]() |
![]() Join Date: Apr 2008 Location: San Diego
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 577
Groans: 38
| Not Ranked : 0 score |
| Tranny pix | franciscoescn | MSP - Engine, Transmission & Driveline | 12 | 09-26-2012 04:24 PM |
| tranny fluid change how to? | bombdotcom | MazdaSpeed 3 - Engine, Transmission & Driveline | 4 | 05-01-2009 09:53 PM |
| Man buys truck with change, LOTS of change | Haltech | Automotive News | 1 | 08-14-2008 09:15 AM |
| when do i change the tranny fluid? | skeeter149 | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 06-21-2008 12:22 PM |
