Like Tree5Likes
 Old 07-14-2011, 02:48 PM   #1
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
Default How Would You Fix This FAIL?
Ok, some of you may have followed my fail awhile ago... Here's a link if you feel like sifting through my epic fail... Feel free to flame, as I deserve it. BUT PLEASE HELP
Need help with DP install
Short Version
I have a leaky DP due to the fact I broke a bolt off in my turbo.... with an impact gun BTW. It is the most accessable stud/bolt on the turbo, but it is REALLY in there, and I'm gonna have to tap the hole and find a stud to fit.
Apparently taking the turbo on/off is a huge PITA. I researched each part of the shop manual pertaining to turbo/ex mani removal. I really wish I had 3 grand right now so I could just say fuck it and grab a new manifold/3071!! LOL
I'm exploring my options...
a) take whole mainifold off w/turbo
b) removing turbo w/o mani
c) trying to get at it where it is (really don't see that happening)
d) ANYTHING BETTER THAT SOMEONE CAN RECOMMEND!
So... like the title says... What would you do to fix it if you were in this situation?
Here are crappy cell pics of said fuck-up....
 Old 07-14-2011, 02:50 PM   #2
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Is that the end of the bolt we are looking @?
 Old 07-14-2011, 02:51 PM   #3
Fatguy729's Avatar
Groans: 82
That is where the bolt snapped off!
 Old 07-14-2011, 02:52 PM   #4
rfinkle2's Avatar
Groans: 298
Can you get @ it with this?
Amazon.com: Alden 8440P Pro Grabit Broken Bolt and Damaged Screw Extractor 4 Piece Kit: Home ImprovementAmazon.com: Alden 8440P Pro Grabit Broken Bolt and Damaged Screw Extractor 4 Piece Kit: Home Improvement
 Old 07-14-2011, 02:54 PM   #5
mazdaspdmike's Avatar
Posts: 784   (View Stats)
mazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the world
Groaned at 50 Times in 30 Posts
yeah i would agree try an extractor. although if its stubborn like my stock TMIC was you wont get anywhere... one of the cover bolts for the plastic cover snapped off in my TMIC, god knows how, but we broke an extractor trying to get it out.
'12 Ford Focus SEL
mazdaspdmike is offline   Reply With Quote
 Old 07-14-2011, 02:55 PM   #6
SilverDemon's Avatar
Posts: 3,034   (View Stats)
I hate to say it, but in order to get at the broken bolt with out generating more fail, the turbo will have to be removed to drill it out on a drill press. The studs are a high grade steel that is not easily drilled, and trying to do it with it on the car will only end up in breaking bits, or worse, breaking a bit off in the stud.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 6 Users Say Thank You to SilverDemon For This Useful Post:
Chimmike (07-31-2011), jtspells (07-14-2011), kmac (07-14-2011), mtnrunner (08-02-2011), rfinkle2 (07-14-2011), sellers (07-30-2011)
 Old 07-14-2011, 02:56 PM   #7
Fatguy729's Avatar
Groans: 82
well, I definately think its gonna be stubborn, but it may be worth a try...?
 Old 07-14-2011, 02:56 PM   #8
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
I did something similar, elsewhere. A mechanic with tools can get that will prolly just need dp off.
 Old 07-14-2011, 02:58 PM   #9
kmac's Avatar
Posts: 1,792   (View Stats)
Get a bottle of map gas and a turbo torch tip. Drill the center first , heat the the ear it broke off in and then when the ear is cherry red use the extractor to remove the bolt.
The Following 3 Users Say Thank You to kmac For This Useful Post:
Fatguy729 (07-14-2011), rfinkle2 (07-14-2011), silvapain (07-14-2011)
 Old 07-14-2011, 03:01 PM   #10
Fatguy729's Avatar
Groans: 82
@SilverDemon I know you know your shit, so I would realy like your opinion..... its not a stud, it is a crappy bolt that CNT sent with their DP. When I was getting the stud out to install the DP (only 1 that the stud came with the nut), the stud spun a SHITLOAD inside the turbo, and got stripped obviously.... so I tried just using one of the bolts that were supplied.
Does this change your opinion? and what about the below option?
Are you suggesting torching it while still in the car? would that be safe? I could see that working...
Last edited by Fatguy729; 07-14-2011 at 03:10 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-14-2011, 03:03 PM   #11
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
IMO, to not generate even more fail, do it right, take the turbo out to work on it.
Good luck..sucks..just got my CNT DP+CBe...Hope I don't run into anything remotely similar.
The Following User Says Thank You to helmetface For This Useful Post:
memin (07-14-2011)
 Old 07-14-2011, 03:14 PM   #12
Fatguy729's Avatar
Groans: 82
LOL NO SHIT! I don't wish fail upon anyone.
 Old 07-14-2011, 03:22 PM   #13
Fatguy729's Avatar
Groans: 82
Damn, there are more people reading my fail thread than this 1 LOL
 Old 07-14-2011, 03:28 PM   #14
1. In the future, never use those cheap-ass bolts; use an OE or similar quality stud.
2. Do what kmac said; drill it out, then heat it up with MAPP gas and use PB blaster a couple times, then use an extractor. It will come out without pulling the turbo. I would pull the DP out first, though. I would also use a thread chaser on the turbo exhaust housing threads before putting a new stud in. Do NOT use a thread tap - they are for cutting new threads, not for cleaning out existing threads. I bought a full thread chaser set from Sears for ~$60 if I remember correctly.
Fatguy729 (07-14-2011), kmac (07-14-2011), rfinkle2 (07-14-2011)
 Old 07-14-2011, 03:33 PM   #15
kmac's Avatar
If u have a right angle drill , remove your down pipe and you're not retarded you can do it in the car. If you're afraid take it out.
The Following 2 Users Say Thank You to kmac For This Useful Post:
 Old 07-14-2011, 04:04 PM   #16
Well, if it is a grade 8.8 (similar to a grade 5) then it might be possible to drill in the car, and take Kmac's advice, heating it up (very carefully and have a fire extinguisher handy) then use a remover that was mentioned earlier. But, if you cannot achieve a straight shot at the bolt with a drill, and have enough leverage to use the drill, then it might be worth it to remove the turbo. Which ever direction you take, just take your time and get in no hurry.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 2 Users Say Thank You to SilverDemon For This Useful Post:
 Old 07-14-2011, 04:16 PM   #17
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
helmetface and redmnsterut like this.
The Following User Says Thank You to karl-hungus For This Useful Post:
 Old 07-14-2011, 04:22 PM   #18
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
If you end up deciding to pull the turbo it may be worth trying to find a good k04 (are there any) I have seen some on here for cheap, and just swapping it out. It would keep you from trying to rush drilling the bolt out and screwing it up more. You could always fix your turbo and sell it later.
kmac (07-14-2011)
 Old 07-14-2011, 07:10 PM   #19
Fatguy729's Avatar
Groans: 82
LOL the only k04 that I've seen recently that wasn't just good for a core charge, had the exact same hole fucked up and needed retapped. I think I will try to do it with turbo in car. If that doesn't work I may just have to drive my car like a grandma for awhile to save money for a 3071. I can't see going through 2 days of bullshit to stick the k04 back on!
Only problems I'm seeing right now (not at WOT) are afr's around 14.1-14.4, at least its not lean! And every attempt to do a MAF Cal has resulted in fail as well... But I'm seeing between -5 and +3, so..... As of now, its not a deadly fail.
I will update when I get it done
The Following User Says Thank You to Fatguy729 For This Useful Post:
kmac (07-14-2011)
 Old 07-14-2011, 07:13 PM   #20
kmac's Avatar
I still have my stock ko4 with 8k on it.
 Old 07-14-2011, 07:18 PM   #21
Fatguy729's Avatar
Groans: 82
I edited while you were posting, but how much?
 Old 07-14-2011, 07:26 PM   #22
Brian MP5T's Avatar
Posts: 1,101   (View Stats)
Brian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the world
You might be able to simply remove the turbo and bring it to a shop...
You will know right away by looking at the machinists face when you show him what you need done if he is able to do it or not..
Trust the face... not the WORDS...
or.
Buy a new half snail and toss the other away..
Brian MP5T is offline   Reply With Quote
 Old 07-14-2011, 07:29 PM   #23
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
i broke that same bolt, only mine sticks out of the turbo more, but i've never been able to get it out. it's been broke for almost 2 years now and i've never had a leak there at all.
Brian MP5T (07-14-2011)
 Old 07-14-2011, 07:31 PM   #24
Brian MP5T's Avatar
Originally Posted by bova80 View Post
i broke that same bolt, only mine sticks out of the turbo more, but i've never been able to get it out. it's been broke for almost 2 years now and i've never detected the leak that is there.
fixed
Keemo577 likes this.
 Old 07-14-2011, 07:37 PM   #25
I'm a caveman
gtlaw's Avatar
Posts: 758   (View Stats)
gtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the world
Groans: 68
use a left handed drill bit, and one of these
Amazon.com: IRWIN 53228 15 piece Multi Spline Extractor Set: Home ImprovementAmazon.com: IRWIN 53228 15 piece Multi Spline Extractor Set: Home Improvement
2015 MUSTANG GTPP
gtlaw is offline   Reply With Quote
 Old 07-14-2011, 07:54 PM   #26
bova's Avatar
Groans: 45
Originally Posted by Brian MP5T View Post
fixed
i'ved looked and there is no marks from soot and the car runs fine. i've also taken the downpipe off there to look and i don't see any leak marks on the gasket. so yeah.
 Old 07-14-2011, 08:03 PM   #27
Brian MP5T's Avatar
I would like to suggest that you think about fixing it even though it "Seems Fine"
Having only three bolts holding three corners of a 4 corner flange, will cause stress every time the part is heat cycled... that could be every time you drive it, or every time you accelerate.
Eventually it will fail, or fail sooner than it should..
 Old 07-14-2011, 08:09 PM   #28
jtspells's Avatar
Posts: 634   (View Stats)
jtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the world
I was working on a forklift last week and had the same problem.
1st get have access to a MIG welder
2nd weld a "tit" on the bolt so you can get a set of vice grips on it like so,
3rd heat the area with an Oxy-acetylene torch till cherry red then remove.
jtspells is offline   Reply With Quote
The Following User Says Thank You to jtspells For This Useful Post:
karl-hungus (07-26-2011)
 Old 07-14-2011, 08:39 PM   #29
bova's Avatar
Groans: 45
i have the stud to fix it but just don't feel like taking it all apart to get it out after several failed attempts. there is gasket sealer as well, one day when i feel like taking the downpipe off i'll have at it again but for now it doesn't bother me only have 4 of 5, so don't bother suggesting i fix it again.
 Old 07-15-2011, 01:41 PM   #30
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Good time to get a bigger turbo...
 Old 07-26-2011, 10:45 AM   #31
Fatguy729's Avatar
Groans: 82
Sorry I haven't updated... I have been collecting tools/gasket sealers/ new dp gasket.... etc. The new DP gasket gets here tomorrow, but I may not need to deal with it. I might be getting into a 08 CWP MS3 LOL. THe stealership has already said that if I put everything back to stock, they will do the trade, already looked the car over and gave me an appraisal...... So it might just end up being their problem.... IF i do the trade!
Its an 08 sport, I LOVE CWP, 43k miles, clean carfax, NO SIGNS OF MODDING!
Mine is an 07 GT, silver, 44k miles, fully bolted... 2 accidents on carfax... The dealership has to make money, but they are offering me a lower intrest rate, and my payment will only go up $19 a month. I keep my mods obviously, and an added bonus is I won't have to deal with my fail, even though the new turbo->DP gasket comes in tomorrow
 Old 07-26-2011, 03:35 PM   #32
Fatguy729's Avatar
Groans: 82
maybe someone who is following this thread could chime in???
Is my leaky DP the cause of this?
 Old 07-29-2011, 11:21 PM   #33
WorstEpEver's Avatar
Posts: 418   (View Stats)
WorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the world
If it looks and runs clean, I'd say go for it. $19 a month aint bad - guessing you only would have few years of payment left so <$1000 to not stress over your DP. Plus, once it comes time to sell your car, the 2 accidents on your car will hurt the value (probably equal to or more than $1k)
That is unless you fuck up the DP install again...
09 MGM Sport
AP (MIA ) / Internals / TMIC / CAI / TIH / Downpipe / CBE / Short shifter / RMM / RSB
WorstEpEver is offline   Reply With Quote
 Old 07-29-2011, 11:55 PM   #34
x09MS3GT's Avatar
Posts: 409   (View Stats)
x09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the world
Groaned at 92 Times in 11 Posts
Just as kmac said, best way to get studs out, Acetylene Torch man. I had problems getting studs that snapped off in the head of another project car long ago. I heated the hell out of the area with an Acetylene Torch , drilled into the stud with a smaller bit, and twisted it out.
Your best bet imo, is to pull that turbo off, and get up front and close with that nasty problem.
x09MS3GT is offline   Reply With Quote
 Old 07-31-2011, 08:13 AM   #35
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
$19k for an 08? Seems uh.....pricey?
anyways GL
07 MS3
The original Genpoo Hater
 Old 07-31-2011, 08:26 AM   #36
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
anyways GL
No, he is going to pay an extra $19 a month on it. I would assume his current car would be paid off in 2-3 years and if the new one is a 5 year loan he is dicking himself over bad.
403whp/451ft/lb Dry Shot
 Old 07-31-2011, 08:33 AM   #37
Eth/Meth Junkie
cld12pk2go's Avatar
LOL...
"Don't tell me how much it costs...tell me how much it costs a month."
Hopefully, it actually isn't a bad deal...
Bucker (07-31-2011)
 Old 07-31-2011, 09:47 AM   #38
If it's $19 extra a month, and same amount of payments, thats not a bad deal... If he is refinancing for another 5-6 years.... OP is raping himself hard
09 MGM Sport
The Following 2 Users Say Thank You to WorstEpEver For This Useful Post:
Bucker (07-31-2011), Chimmike (07-31-2011)
 Old 07-31-2011, 09:59 AM   #39
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Groans: 52
you guys should use anti seize on those bolts and make sure you dont over torque them
if you do it will mess up the threads and stretch bolt and after extreme heat on turbo bolts will break on removal
may also consider buying grade 8 bolts instead of the grade 5 they may of used
and i agree with everyone else on removing turbo, i had a bolt break off in my exhaust manifold i took it to the guy who fabricated it and he drilled it out and retapped hole and it works fine.
XRJoe likes this.
 Old 08-09-2011, 03:42 PM   #40
Fatguy729's Avatar
Groans: 82
Update... I'm going to attempt to fix this tomorrow. If I can't get it out w/o taking the turbo off, I'm gonna say fuck it and get a bigger turbo (gt/gtx3071). I can't see myself taking the time to do all that shit, just to stick the K04 back on!
I have PB blaster, a new DP gasket, RTV high heat (incase I can't fix it, hopefully it will create a temporary seal), stud extractor.... Going now to buy the torch and thread chaser (honestly don't know what that is).
So with the thread chaser, will I still need to re tap it? and will I be able to fit the stock M10x1.50 studs in there?
Super fail, followed by epic win, followed by shit eating grin fail superskaterxes Mazdaspeed3/6 General Discussion 9 03-06-2011 04:12 PM
FAIL! TURBINETECH L/A IC FAIL! bioevolve MazdaSpeed 3/6 - Turbo Induction 50 07-21-2009 04:25 PM
Page generated in 0.61856 seconds with 39 queries
