  • 1 Post By mituc
 Old 01-05-2019, 12:40 PM   #1
Russell141's Avatar
Posts: 4   (View Stats)
Russell141 is an unknown quantity at this point
Default HPFP Data Logs
Right now in my 2013 Mazdaspeed 3, I'm running a Corksport induction system (same MAF size as stock) and a cobb stage 1+ tune. I wanted to check my HPFP's psi through peak boost, and I read on cobbs webpage to do a 2k-6k rpm WOT 3rd gear pull. I did multiple logs and my psi stayed above 1600. I recently logged a WOT 2k-6k rpm 2nd gear pull and saw my fuel pressure dropped to 1450 psi (I then went back and did a 3rd gear log and everything seemed peachy). Should this 2nd gear pull be a cause for concern or is it normal because it's a lower gear?
2nd Gear WOT.csv
3rd Gear WOT.xlsx
Russell141 is offline   Reply With Quote
 Old 01-05-2019, 01:19 PM   #2
shamie's Avatar
Posts: 922   (View Stats)
Your fuel pressure doesn't drop during WOT (Throttle Position (%) =74) - I'm not sure what your looking at.
It's never a bad idea to upgrade your HPFP, especially in a gen2 though.
2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, 51R Battery Box & Raider's AD / StopTech Brakes
 Old 01-05-2019, 01:30 PM   #3
Russell141's Avatar
Well I am defentally pushing my throttle as far it can go, so what does this mean?
 Old 01-11-2019, 12:03 PM   #4
LenSpeed6's Avatar
Posts: 110   (View Stats)
LenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to behold
I would say that you should one, acquire either a corksport or auto tech HPFP that way you'd know that you will be safe and B, get a proper tune from Freektune, Nishan or other reputable mazda shop. A tuner would be able to tell you if anything funky is going on and have your car run the best that it can, OTS tunes are not the best but good to get you from home to a dyno if need be IMO.
I can look but I don't think that in any of my logs the TP was at 100% which I do agree is weird but I have no knowledge on how the computer reads that sensor in terms of WOT if there is anything different from other makes.
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump
 Old 01-11-2019, 12:48 PM   #5
Bertospeed3's Avatar
Posts: 56   (View Stats)
Bertospeed3 is a name known to allBertospeed3 is a name known to allBertospeed3 is a name known to allBertospeed3 is a name known to allBertospeed3 is a name known to allBertospeed3 is a name known to all
even in the 2nd gear log, every thing looks fine to me.
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
 Old 01-12-2019, 05:10 AM   #6
mituc's Avatar
Posts: 3,504   (View Stats)
Groans: 111
It means that even if the acceleration pedal (APP) is close to or 100%, the actual throttle plate in the throttle plate will not go over 74-78% (depending on the car) because it doesn't make any more gap past that.
LenSpeed6 likes this.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
HPFP Data Logs Russell141 MazdaSpeed 3/6 - ECU Computer Tuning 2 01-05-2019 06:57 PM
DATA LOGS how do they look... BankShot MazdaSpeed 3/6 - ECU Computer Tuning 4 12-03-2015 08:38 PM
New Data Logs neofandango 2010 MS3 - ECU Computer Tuning 2 11-23-2011 05:38 PM
WTF IS UP WITH MY DATA LOGS Fatguy729 MazdaSpeed 3/6 - ECU Computer Tuning 14 05-27-2011 03:46 PM
Page generated in 0.24642 seconds with 25 queries
