 Old 10-11-2011, 12:38 PM   #1
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Default I'm a Fucking Believer!
So I was quite skeptical of the infamous XT-M5-QS tranny fluid but holy fucking cow!
I spent $60 bucks on 3 quarts..a rape fest with my inner asshole as the target.
But god damn! I was never one of those people that experienced much "grind" especially after following Jaime's (JBR) 'How-to' on cable adjustment. But my shifting was knotchy as fuck! And with a quarter-mile track event coming up, I couldn't see myself trying to jam down a gear in the middle of a pull...I'd probably just give up and take a hard right into the other car, crowd or wall..
With that said, I can't say it'll work everyone but it did however work for me and work well it did.
Go Go Go!
tl;dr: eat a dick! buy synthetic!
jonspeed3 likes this.
The Following 14 Users Say Thank You to helmetface For This Useful Post:
06Speed6 (10-12-2011), asall667 (10-12-2011), atvfreek (10-11-2011), AZSPEED3 (10-12-2011), breakfstincluded (10-17-2011), kmac (10-11-2011), Lex (10-11-2011), MS6FL (10-11-2011), Nliiitend1 (10-13-2011), redmnsterut (10-14-2011), SpeedSixxx (10-14-2011), Swagerwagon03 (10-17-2011), Tokay444 (10-11-2011)
 Old 10-11-2011, 01:08 PM   #2
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Hard right.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 10-11-2011, 01:09 PM   #3
helmetface's Avatar
Groans: 219
The Following User Says Thank You to helmetface For This Useful Post:
 Old 10-11-2011, 02:29 PM   #4
I think I'm almost due for new fluid. This has been a good reminder
helmetface (10-11-2011), SpeedSixxx (10-14-2011)
 Old 10-11-2011, 03:26 PM   #5
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
DONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the world
Groans: 266
Groaned at 83 Times in 60 Posts
You should drive into the stadium where the celtics play, while they are playing whenever that will be
Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next.
DONOTBUGME is offline   Reply With Quote
The Following User Says Thank You to DONOTBUGME For This Useful Post:
 Old 10-11-2011, 03:29 PM   #6
shawn.'s Avatar
Posts: 541   (View Stats)
shawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the world
Groans: 29
when is it recommended to change the tranny fluid? i'm probably due and i think i'm gonna go this route as well, can't hurt.
ATP GTX3071r// Cobb 3 Port EBCS // 3 Bar MAP // Cobb Accessport Freek Tuned // E85 Mix // JBR 3.5" Intake/TIP // Treadstone TR8C FMIC // Autotech HPFP Internals // Ported IM //C-pe Catted Downpipe // TRZ RMM // Corksport CBE // ISC Coilovers // EBC Slotted Rotors--Redstuff Pads // TWM shifter bushings // Dashhawk v2 // 6000k HIDs
Built engine--Manley H Beam Rods--Wiseco Pistons
shawn. is offline   Reply With Quote
 Old 10-11-2011, 03:30 PM   #7
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Yeah I'll be throwing some of the ford honey into my trans at 5k miles.
 Old 10-11-2011, 03:33 PM   #8
helmetface's Avatar
Groans: 219
Check your book
ie: When you start grinding..
 Old 10-12-2011, 02:28 PM   #9
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
I think trans fluids need to be changed alot more often than the book says, im running 20k changes now.
2006 Mazdaspeed 6
SLOWHATCH (10-12-2011)
 Old 10-12-2011, 07:52 PM   #10
shadesofgray19's Avatar
Posts: 794   (View Stats)
30k IIRC
2006 Black Mica MS6 - Sold 10/15
shadesofgray19 is offline   Reply With Quote
 Old 10-12-2011, 07:59 PM   #11
franz's Avatar
Posts: 1,258   (View Stats)
franz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the world
I believe the book is 24k for the "severe" service, which we should all be running.
This gear lube is apparently a bit thinner than the factory stuff and its recommended to change it sooner, especially if you are doing any track days. I need to call my local dealer and see what they are asking for it. I want to get it in before it gets too cold.
2007 MS3 Black Mica. Stock. 235whp/244wtq Dynojet
FREEKtuned 277/316 Dynojet
Corksport SRI/TIP/FMIC/GFB BPV/AT Internals/EBCS/Gutted 2nd Cat
Bilstein B8/Swift Spec-R/ST120s/Nitto 555
JBR 70dur. RMM-TMM-PMM/SSP+Bushings/TIGs/OCC
franz is offline   Reply With Quote
 Old 10-12-2011, 08:22 PM   #12
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
what were you running before the magical ford unicorn cum?
 Old 10-12-2011, 08:30 PM   #13
kabobulate's Avatar
Posts: 1,146   (View Stats)
kabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the world
I started on stock fluid and then switched to the Ford fluid. It felt much better. I then went back to stock fluid about 15k later and it felt... much better. I think the key is just changing your fluid. I know that goes against all that is holy around here, but that has been my experience.
2012 CWP MS3: Tuned by Phate - 50/50 E85 | Cobb AP | SURE Intake, TIP | Corksport Racepipe, TMM Inserts | ITV22's | AT Intl's | ACT Sprung 6Puck & Prolite Flywheel | CP-E Stg2 RMM | JBR SSB, EGR Plate
2008 Silver MS3: Sold
kabobulate is offline   Reply With Quote
The Following User Says Thank You to kabobulate For This Useful Post:
zpele (10-17-2011)
 Old 10-12-2011, 08:35 PM   #14
HARPER306's Avatar
Posts: 444   (View Stats)
HARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the world
IIRC, technically, the trans fluid should not be changed very often at all (80k ish), something about the way it breaks down that it actually gets better in time. I dunno, i think its horseshit.
i tried this shit too, maybe the car had it in before i bought it but it did sweet fuck all, nice peace of mind though
'12 Evo X
HARPER306 is offline   Reply With Quote
 Old 10-13-2011, 03:49 AM   #15
Tokay444's Avatar
Groans: 793
When I switched mine in the spring I noticed no difference.
Now that it's getting colder, I don't have the stereotypical effort laden first couple shifts.
It shifts the same as when it's warm so far. We're not into the minuses yet mind you.
Demodded.
The Seals
 Old 10-14-2011, 03:52 PM   #16
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
I put some of this white fluid in today.
Etipp98 is offline   Reply With Quote
 Old 10-14-2011, 03:59 PM   #17
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
ah fuck... i changed mine at like 23k and i'm at 82k now... =(
i'm well past due.
The Following User Says Thank You to SpeedSixxx For This Useful Post:
Chriscote (10-17-2011)
 Old 10-17-2011, 01:37 AM   #18
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Groans: 261
OP have you tried any other tranny fluid before?
This and MT-90 definitly get the most mention here,
I'm approaching the 30K mark and suppose I can't go wrong with either.
If I go XT-M5-QS I'll have to hunt it down or ask where everyone is getting theirs though. I shudder whenever I find out the best deals are at walmart... uggh...
 Old 10-17-2011, 02:15 AM   #19
Matrix311's Avatar
Posts: 2,133   (View Stats)
Matrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the world
Local ford dealership around $19-$20 a qt
Sent from my DROIDX using Tapatalk
Eric Schlaht - Arizona Phoenix Photographer
http://www.esimaging.net - http://www.facebook.com/esimaging
2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14**
**9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp
**11/19/13** Forged engine built and started up the car for the first time, success!
**3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno
**6/24/15** Sold the Mazdaspeed 3
**7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package
Matrix311 is offline   Reply With Quote
The Following User Says Thank You to Matrix311 For This Useful Post:
 Old 10-17-2011, 03:02 AM   #20
Groans: 261
Just read the transmission cured sticky, I'm convinced, will give it a try for my next 30K miles.
 Old 10-17-2011, 06:33 AM   #21
fooqr's Avatar
Posts: 559   (View Stats)
fooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the world
Originally Posted by helmetface00 View Post
Check your book
Originally Posted by shadesofgray19 View Post
30k IIRC
I believe the book is 24k for "severe" service
ok, I just looked it up, and the manual doesn't call for the transmission fluid to be changed at all. Over on BITOG, I've read that the main reason to change the tranny fluid is to get rid of whatever wear particles end up in it, and they say that most of the wear occurs in the first 20 k miles. In other words, if you're really paranoid, change it once at 20k and then you're good to go until you have some reason to need new fluid.
I switched out my factory fill with MT-90 at about 22k, and then I replaced it with the Magic Motorcraft (MM) fluid at 51k because the LSD whine was driving me nuts.
08 MS3 GT (SSM). JBR WP intake, CS boost tubes, Forge v2 BPV, JBR TB/IM TIG, JBR TB coolant bypass, JBR EGR block-off, 3-bar MAP, PTP pill, bnoon bolt, SM OCC (MD kit) w/ Kat's heater, UR DP (ceramic cat), UR resonated TP/CBE, JBR SSP, SU shift bushings, JBR trilogy mounts (CRMO 88 RMM, 70 PMM/TMM), Koni yellows, JBR RSB, 2nd Fiamm, Stoptech SS lines, Hawk HPS, spin-on CX-9 oil filter, Fumoto valve, PP 5W-30, XT-M5-QS, tints, clear bra, Continental DWS, ITV22, DashHawk, AP, AT internals
There are no stupid questions, but there are stupid people and some of them ask questions.
- A. Funicello
fooqr is offline   Reply With Quote
 Old 10-17-2011, 06:44 AM   #22
Uberfly's Avatar
Posts: 773   (View Stats)
Uberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the world
The service guy at the stealership told me that it's recommended every 30K, and that's required to keep the lifetime warranty on the tranny. He said that as long as i replaced the fluid every 30K, they would cover up to 2K in tranny repairs.
Has anyone else heard this? I haven't checked the manual yet. I did put the magical motorcraft fluid in at the 30K change.
2008 MS3 GT - Guardian Angel, Cobb Acessport, hacked up mazda CAI converted to SRI, Turbosmart BPV
Uberfly is offline   Reply With Quote
 Old 10-17-2011, 06:49 AM   #23
zpele's Avatar
Posts: 1,654   (View Stats)
zpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the world
Groans: 354
Groaned at 213 Times in 109 Posts
Lol he said tranny.
2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now)
2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy
zpele is offline   Reply With Quote
The Following User Says Thank You to zpele For This Useful Post:
thehead (10-17-2011)
 Old 10-17-2011, 07:10 AM   #24
helmetface's Avatar
Groans: 219
I know there are a few other brands that are revered to be "magical" fixes, although the Ford stuff is the first I've used in the Speed3.
**UPDATE** After more miles into, I believe I've got to adjust my shifter cables again, getting into first is my only residual issue. It was not present right after swapping fluids but has become more noticeable with time. All in all, I would still say it was definitely worth the $60
Fuck the manual! I'm joking, but tranny fluid in my opinion falls into the "buy when needed" category. If you're having issues with shifting and you've exhausted the easier options (ie: shifter cable adjustment, inspecting for bent cables etc) this is a great place to start. Not necessarily a cheap one, but seems to work more often than not.
Voodoo is never a definite.
Last edited by helmetface; 10-17-2011 at 07:10 AM. Reason: MSF Database - Automerged Doublepost
 Old 10-17-2011, 08:58 AM   #25
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
Your service guy is an idiot.
There is no "lifetime warranty" on your transmission, unless it's some sort of weird dealer warranty.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
helmetface (10-17-2011)
 Old 10-17-2011, 09:59 AM   #26
Tokay444's Avatar
Groans: 793
Lifetime tranny warranty?
Wtf?
Demodded.
The Seals
 Old 10-17-2011, 10:12 AM   #27
Etipp98's Avatar
got mine here for 58 shipped. came in a few days. Motorcraft MTX-75 IB5 transmission fluid XT-M5-QS
 Old 10-17-2011, 11:28 AM   #28
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Just so you guys know, there is no performance difference between Redline MT-90 and Ford's magical god piss.
It's all a bunch of hype, peppered with some placebo effects.
this forum serves 2 purposes
 Old 10-17-2011, 11:52 AM   #29
alphasaur's Avatar
Posts: 2,847   (View Stats)
alphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the world
Groans: 235
Groaned at 60 Times in 48 Posts
changing this weekend yayy am excite to put in the jizz.
/91 miata with basic suspension bits
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/possessed speed 6- dead ((((((
/lol nator.
alphasaur is offline   Reply With Quote
 Old 10-17-2011, 12:30 PM   #30
Nliiitend1's Avatar
Groans: 67
While I've never used MT-90 in my MS3, I tried it back-to-back against the Ford Honey in my second Focus and there was definitely a perceptible difference (in the Ford fluid's favor).
Just sayin'.
2008 MS3 GT
2016 MX-5 Club
 Old 10-17-2011, 12:36 PM   #31
Uberfly's Avatar
Yeah, that's kind of how it sounded. I'm going to ask for it in writing, because i think he just wants me to buy new transmission fluid every 30K.
sorry to take the thread kind of OT.
 Old 10-17-2011, 12:48 PM   #32
fooqr's Avatar
Depends on what you mean by performance. The job of transmission fluid is to protect your transmission against wear, and both Ford's MM (XT-M5-QS) and RedLine's MT-90 are supposed to do a good job there. But, presumably so do a lot of others.
There's definitely a difference between MT-90 and MM, tho. MT-90 made my LSD whine every single day in the parking garage, XT-M5-QS never has once. I personally didn't notice a difference in the way the transmission shifted between OEM, MT-90, and MM, but others say they have. Maybe that's placebo, I can't say. Whether you call noise and shifting feel "performance" or not is up to you, I suppose. It's not part of the central mission of tranny fluid, but it is part of its operating characteristics.
What isn't known is whether Ford's MM is anything but seriously overpriced cheap-ass dino oil + friction modifier. For $60, they take the guesswork out of whether and how much friction modifier to add, tho, and for me that's worth it.
- A. Funicello
The Following User Says Thank You to fooqr For This Useful Post:
 Old 10-17-2011, 01:11 PM   #33
I <3 your mom
Dash08's Avatar
Groans: 293
Personally, i can't compare. I've only tried the MT-90. That was a big improvement over the standard fluid.
But, after my recent tire purchasing fiasco based off of member recommendations, I tend to be more skeptical of peoples ability to accurately differentiate real world performance from placebo effect.
It's been my experience thus far that most people, even some track racers, don't truly "feel" their car. That's not something you can practice, though. That's more related to your overall sense of touch and feel. Not everyone is the same in that aspect. Some are more sensitive than others.
 Old 10-17-2011, 02:40 PM   #34
Nliiitend1's Avatar
Groans: 67
So wait, you come into a thread and tell people that there is no difference between Redline MT-90 and Motorcraft XT-M5-QS and then a few posts later admit that you can't really compare them because you've only tried one of them?!
Dude, you're part of the problem that you're complaining about - people giving advice when they have no business doing so...
2008 MS3 GT
2016 MX-5 Club
Dash08 (10-17-2011)
 Old 10-17-2011, 02:44 PM   #35
Tokay444's Avatar
Groans: 793
I use mm and still have LSD whine.
Demodded.
The Seals
 Old 10-17-2011, 02:56 PM   #36
MoparGo
Lurkers
MoparGo's Avatar
Posts: n/a
Arrow Don't jump me for this, but...
I use the the Ford Synth. with 4oz. of their "fish oil" limited slip additive. My Mazda dealer did the fluid change.
The 4oz. of "fish oil" replaces 4oz. of the XT-M5-QS. Transmission shifts perfectly... and zero LSD "rasping" (whining) noise.
Am almost 8k miles into it and all is well in Speed3 city. And @Dash08, there is a perceptable difference between MT-90 & the Ford "god-piss".
 Old 10-17-2011, 03:06 PM   #37
Groans: 261
My dealer has it for $ 20.xx a bottle
Hmm... order online and save 2 bucks over 3 bottles w/ shipping to portland? meh
 Old 10-17-2011, 03:10 PM   #38
Etipp98's Avatar
don't forget tax
 Old 10-17-2011, 03:14 PM   #39
X4 SRT's Avatar
Posts: 157   (View Stats)
X4 SRT has a reputation beyond reputeX4 SRT has a reputation beyond reputeX4 SRT has a reputation beyond reputeX4 SRT has a reputation beyond reputeX4 SRT has a reputation beyond reputeX4 SRT has a reputation beyond reputeX4 SRT has a reputation beyond reputeX4 SRT has a reputation beyond reputeX4 SRT has a reputation beyond reputeX4 SRT has a reputation beyond reputeX4 SRT has a reputation beyond repute
Groaned at 33 Times in 17 Posts
I just had my transmission fluid changed at the dealer for the first time. At 106k miles. car has always run like a fucking champ. I'm not sure how the new fluid feels as the car is just sitting now while i wait to replace my broken transmission mount. I have the cp-e mount on the way.
X4 SRT is offline   Reply With Quote
 Old 10-17-2011, 03:27 PM   #40
thehead's Avatar
Posts: 1,141   (View Stats)
thehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the world
Groans: 143
meh, even with the magical ford fluid, I still get 3rd gear grind, but I'm also in an MS6. I really need to adjust my linkages . Or find someone down here in SC thats a pro cause I have no time, yay nuke school ><.
2016 BMW M235i
[Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles
Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals
Electrical - GS EBC - Cobb AP Richtune in progress
Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's
Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40.
thehead is offline   Reply With Quote
Wall Street's EV believer Haltech Automotive News 0 06-05-2011 10:10 PM
Jay Leno, A Firm Believer in Restomodding Haltech Automotive News 0 12-21-2010 05:40 AM
Page generated in 0.58261 seconds with 43 queries
