 Old 11-01-2008, 03:11 PM   #1
Death-From-A-Mile's Avatar
Posts: 1,371   (View Stats)
Death-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the world
Groans: 87
Default I think its toast.....
Well here it goes. I was accelerating onto the freeway in 3rd gear last night. Nothing out of the ordinary happened. I did not over rev the motor or miss a shift! Boost hit 19psi as normal but when I went to shift into 4th I felt a vibration through my clutch pedal. It immediately reminded me of MS3guy22's post. I pulled over and shut the car off. Went to start it again and if fired right up. Car is in neutral and I press in the clutch. As soon as I begin to press it in I feel the vibration. When its all the way depressed the vibration is gone. I then got out and listened to the engine. I can here a clicking noise...definitely not a normal noise. It grows more audible at lower RPMs and less at higher. Any ideas? The car is currently up on jackstands right now. I have drained the oil and am about to take off the oil pan. I checked spark plugs there is nothing abnormal there. I can not find any holes in the block....yet. HELP.....so much for my dyno day today.
On a lighter not I lowered the car on H&Rs last night and threw a set of 17x8.5 Rpf1s wrapped in 235-45-17s......it looks mean as hell
Death-From-A-Mile is offline   Reply With Quote
 Old 11-01-2008, 03:13 PM   #2
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
damm that SUCKS! sorry to hear man. I hope its nothing..
 Old 11-01-2008, 03:18 PM   #3
Groans: 87
Yeah I dont know...I need to talk to MS3guy22 and find out some specific details. Mine sounds like a similar situation to his. Its something though.
 Old 11-01-2008, 03:20 PM   #4
red07's Avatar
Posts: 290   (View Stats)
red07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant future
Just reading your description, sounds like trans or clutch? Seems like to me based on the fact that the vibes change with clutch travel and no load on the engine.
Is there any smoking?
That sucks man, keep us posted.
red07 is offline   Reply With Quote
 Old 11-01-2008, 03:20 PM   #5
Lymerock's Avatar
Posts: 1,436   (View Stats)
by your description i was thinking transmission
what has you thinking engine?
 Old 11-01-2008, 03:28 PM   #6
Groans: 87
Thats the thing though it does change with idle....
 Old 11-01-2008, 03:31 PM   #7
Lymerock's Avatar
bad throw out bearing? does it make a squeek when depressing the clutch
 Old 11-01-2008, 03:42 PM   #8
Groans: 87
Nope
 Old 11-01-2008, 03:48 PM   #9
danesti's Avatar
Posts: 4,186   (View Stats)
danesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the world
Groans: 137
hey its a long shot but the way the ticking is described it sounds like the tensioner on teh timing chain. slack in that chain would make that noise i would think.
i dont know thats likely far off but anything seems worth a shot.
i guess that doesnt fit in much with the clutch feeling though...
2008 STi
Intake
Turboback
AP
danesti is offline   Reply With Quote
 Old 11-01-2008, 03:55 PM   #10
twisted99's Avatar
Posts: 50   (View Stats)
twisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant future
Groaned at 6 Times in 2 Posts
Sounds like a clutch issue maybe a throw out bearing. Clutch noise would change with revs.
twisted99 is offline   Reply With Quote
 Old 11-01-2008, 04:04 PM   #11
DreSEL's Avatar
Posts: 35   (View Stats)
DreSEL is a jewel in the roughDreSEL is a jewel in the roughDreSEL is a jewel in the roughDreSEL is a jewel in the rough
My vote is for a broken clutch disc or TO bearing. I think your engine is fine. Good luck .
Car looks sick with that wheel/tire combo !!!!
DreSEL is offline   Reply With Quote
 Old 11-01-2008, 05:01 PM   #12
Groans: 87
Tore off the oil pan and inspected the rods/pistons from the underside. No broken rods and it all seems to be intact. Checked spark plugs for any evidence of anything......not oil.....they werent running lean. I am baffled. I was half expecting to see a chunk of metal just fall in my face....nope didnt happen. I am just really worried based on what others have experienced. Any more suggestions?
Do you guys really think it could be the clutch? Maybe a chunk broke off under acceleration? Sounds unlikely because the noise it is making. Maybe it is the flywheels smaking the clutch pieces?
 Old 11-01-2008, 05:12 PM   #13
Groans: 87
BTW no CEL.....what the heck.
 Old 11-01-2008, 05:21 PM   #14
SgtP's Avatar
Posts: 2,130   (View Stats)
Groans: 106
good luck. hope you find out what the hell is wrong.
13.2@111
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline   Reply With Quote
 Old 11-01-2008, 05:40 PM   #15
Sounds like the throwout bearing or the pressure plate "fingers" where the TO bearing contacts it.
 Old 11-01-2008, 06:46 PM   #16
DreSEL's Avatar
I still say clutch disc. However, I do remember reading somewhere about a cracked flywheel on a MS3.
The only way to find out is to drop the tranny.
 Old 11-01-2008, 06:59 PM   #17
Groans: 87
Yeah I am going to be researching that. I wonder how hard it would be to do. I have done Honda motors and trannys for years. Maybe this is more complicated.
 Old 11-01-2008, 10:21 PM   #18
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
Sounds like a bad throwout bearing to me.
 Old 11-01-2008, 11:04 PM   #19
itzl0l's Avatar
Posts: 462   (View Stats)
itzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond repute
im thinking throwout bearing as well
07 cb Ms3 - MS cai / Vibrant exhaust / TurboXS DP / Cobb AP - trapped 107
TOTALED 11/2/09
04 SRT4 - sold - trapped 120+
itzl0l is offline   Reply With Quote
 Old 11-02-2008, 12:05 AM   #20
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
I'm thinking fly wheel shit the bed. Thats me though.
Carry on citizens....
10.7 @ 133 auto 1G DSM
 Old 11-02-2008, 05:51 PM   #21
Groans: 87
Well the car is back together and headed to the shop on Tuesday. I cant isolate the clicking noise. I did further inspect the rods and found no damage in that area. It is no where near loud enough to be something engine related unless it is a valve....highly doubtfful. Anyways I am looking at a Spec 3+ clutch to replace the stocker...even if it is just the flywheel.
 Old 11-02-2008, 06:25 PM   #22
builthatch's Avatar
Posts: 616   (View Stats)
builthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond repute
if you had a catastrophic internal engine failure, you'd not be able to fire the engine up, unless it was something like a smacked valve or cracked ring, etc. the idle would be totally whacked though, or it would sound like it had a miss upon rev-up.
anyway, would anyone agree that it sounds like possibly a bent pressure plate finger? without re-reading it, TO bearing could be responsible as well, unless there is something i'm missing.
неприкасаемый / '08 Mazdaspeed3 GT / '07 Si sedan / END OF AN ERA / 6'4", 333lbs
***week old AP FOR SALE!!!! click here*** SOLD SOLD SOLD
builthatch is offline   Reply With Quote
 Old 11-02-2008, 06:48 PM   #23
Groans: 87
Something like this?
http://forums.focaljet.com/shift/574...te-finger.html
 Old 11-02-2008, 07:09 PM   #24
danesti's Avatar
Groans: 137
gnarly looking at that link...
good luck slo... you have my best wishes.
if it was that, then at least you get a new clutch :-)
2008 STi
Intake
Turboback
AP
 Old 11-02-2008, 07:25 PM   #25
Groans: 87
LOL yeah I already thought of the positive side. I really wish I had the F2 balance delete kit today. I would have left that damn chunk of metal out. I am eyeing up the clutch kit. 750......ouch. I will wait to order it until the problem is 100% discovered.
 Old 11-02-2008, 07:42 PM   #26
danesti's Avatar
Groans: 137
ooo thats a hit man...
youll be stoked once its in though..
feel bad for this happening to you, especially after you were thinking of parting the thing out and selling it.
you seem like a fairly resourceful person though so i think you can handle a bump in the road...
you took the whole pan off???
was it messy?
sorry to go off topic but i was thinking about the balance shaft delete.
2008 STi
Intake
Turboback
AP
 Old 11-02-2008, 07:59 PM   #27
tagkat's Avatar
Posts: 269   (View Stats)
tagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to behold
How many miles do you have on your ride? Are these clutches that fragile?
tagkat is offline   Reply With Quote
 Old 11-02-2008, 08:15 PM   #28
Groans: 87
28,000 miles
It wsant too messy. You do need rags and cardboard on the ground to catch the drips. The delete kit would be a super easy install.
The Following User Says Thank You to Death-From-A-Mile For This Useful Post:
danesti (11-02-2008)
 Old 11-02-2008, 08:20 PM   #29
tagkat's Avatar
How fragile are these clutches??
 Old 11-02-2008, 08:29 PM   #30
danesti's Avatar
Groans: 137
SLO... thanks for the info..
you need an engine bay pic in your sig too though. seeing that L/A IC on every post was something i looked forward to...
nice pic none the less...
2008 STi
Intake
Turboback
AP
 Old 11-02-2008, 08:33 PM   #31
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
Don't forget to check the springs on the clutch (not the lever ones), see if any are broken or shifted out and/or sheared. Look at the center shaft opening where the splines line up for centering on the clutch (might be off center). Wished I had a pic to show you what I'm talking about. When you take down the tranny, look at the clutch on both sides.
 Old 11-02-2008, 09:09 PM   #32
builthatch's Avatar
right, you mean the springs that dampen the disk....very possible one of them could have dislodged, or broken. i've seen that a few times with performance disks. i can't recall any from stockers.
i dunno about the center shifting though, that would not be something that would just 'occur', is it? never seen that just happen....
 Old 11-03-2008, 12:38 AM   #33
redrocketz's Avatar
Posts: 1,122   (View Stats)
redrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond repute
I would say definitely trans related. I would say clutch. if it's more of a chattering noise I would point towards the dampening springs on the friction disc itself. If it was the throw-out bearing I would say a growling or rattling noise depending on the exact issue. I have seen more than a few throw-out bearings fall apart when I took them out on these cars now.
It wouldn't be engine related or valve train related since it goes away at higher rpm's not gets faster.
redrocketz is offline   Reply With Quote
 Old 11-04-2008, 11:22 AM   #34
Groans: 87
UPDATE: The shop called me and they are pulling the trans right now. They put the car on the lift and started it in neutral. They said they observed the clutch arm moving back and forth. He says there is about a 95% chance it is the pressure plate. Should know for sure by the end of the day.
 Old 11-04-2008, 11:30 AM   #35
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
i hope its whatever is cheapest for you bro take care good luck.
"Go find your own enterprise, and get the fuck off my bridge!"
2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard"
1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action"
skeeter149 is offline   Reply With Quote
 Old 11-04-2008, 02:03 PM   #36
builthatch's Avatar
no. if he damaged his clutch, it was a fluke...even the most high performance, precision, custom disks and pressure plates fail, sometimes with no outside cause. nothing is totally impervious to the chance of failure, nothing.
IDRVSLO, can't wait for the news.
 Old 11-04-2008, 03:11 PM   #37
Groans: 87
I cant wait either.....the suspense is killing me.
 Old 11-04-2008, 03:14 PM   #38
Alittle Faster
bioevolve's Avatar
Forgot you are 3 hours behind some of us lol.
 Old 11-06-2008, 09:41 AM   #39
bnoon's Avatar
Posts: 1,770   (View Stats)
Any news?
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
bnoon is offline   Reply With Quote
 Old 11-06-2008, 11:19 AM   #40
ElBartoRex's Avatar
Posts: 1,186   (View Stats)
ElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the world
FWIW, a ticking sound is normal from a DI motor.
ElBartoRex is offline   Reply With Quote
Is this donut gasket toast??? 94jedi MazdaSpeed 3/6 - Turbo Induction 9 08-11-2008 02:59 PM
Page generated in 0.53645 seconds with 38 queries
