I'm a Fucking Believer! So I was quite skeptical of the infamous XT-M5-QS tranny fluid but holy fucking cow! I spent $60 bucks on 3 quarts..a rape fest with my inner asshole as the target. But god damn! I was never one of those people that experienced much "grind" especially after following Jaime's (JBR) 'How-to' on cable adjustment. But my shifting was knotchy as fuck! And with a quarter-mile track event coming up, I couldn't see myself trying to jam down a gear in the middle of a pull...I'd probably just give up and take a hard right into the other car, crowd or wall.. With that said, I can't say it'll work everyone but it did however work for me and work well it did. Go Go Go! tl;dr: eat a dick! buy synthetic!:baby: |
Hard right. |
:burnout::yup::drive: |
I think I'm almost due for new fluid. This has been a good reminder :) |
You should drive into the stadium where the celtics play, while they are playing whenever that will be |
when is it recommended to change the tranny fluid? i'm probably due and i think i'm gonna go this route as well, can't hurt. |
Yeah I'll be throwing some of the ford honey into my trans at 5k miles. |
ie: When you start grinding..:slomo: |
I think trans fluids need to be changed alot more often than the book says, im running 20k changes now. |
30k IIRC |
I believe the book is 24k for the "severe" service, which we should all be running. This gear lube is apparently a bit thinner than the factory stuff and its recommended to change it sooner, especially if you are doing any track days. I need to call my local dealer and see what they are asking for it. I want to get it in before it gets too cold. |
what were you running before the magical ford unicorn cum? |
I started on stock fluid and then switched to the Ford fluid. It felt much better. I then went back to stock fluid about 15k later and it felt... much better. I think the key is just changing your fluid. I know that goes against all that is holy around here, but that has been my experience. |
i tried this shit too, maybe the car had it in before i bought it but it did sweet fuck all, nice peace of mind though |
When I switched mine in the spring I noticed no difference. Now that it's getting colder, I don't have the stereotypical effort laden first couple shifts. It shifts the same as when it's warm so far. We're not into the minuses yet mind you. |
i'm well past due. |
OP have you tried any other tranny fluid before? This and MT-90 definitly get the most mention here, I'm approaching the 30K mark and suppose I can't go wrong with either. If I go XT-M5-QS I'll have to hunt it down or ask where everyone is getting theirs though. I shudder whenever I find out the best deals are at walmart... uggh... |
Sent from my DROIDX using Tapatalk |
Just read the transmission cured sticky, I'm convinced, will give it a try for my next 30K miles. |
I switched out my factory fill with MT-90 at about 22k, and then I replaced it with the Magic Motorcraft (MM) fluid at 51k because the LSD whine was driving me nuts. |
The service guy at the stealership told me that it's recommended every 30K, and that's required to keep the lifetime warranty on the tranny. He said that as long as i replaced the fluid every 30K, they would cover up to 2K in tranny repairs. Has anyone else heard this? I haven't checked the manual yet. I did put the magical motorcraft fluid in at the 30K change. |
Lol he said tranny. |
**UPDATE** After more miles into, I believe I've got to adjust my shifter cables again, getting into first is my only residual issue. It was not present right after swapping fluids but has become more noticeable with time. All in all, I would still say it was definitely worth the $60 Quote:
Voodoo is never a definite. |
There is no "lifetime warranty" on your transmission, unless it's some sort of weird dealer warranty. |
Lifetime tranny warranty? Wtf? |
Just so you guys know, there is no performance difference between Redline MT-90 and Ford's magical god piss. It's all a bunch of hype, peppered with some placebo effects. |
changing this weekend yayy am excite to put in the jizz. |
Just sayin'. :dunno: |
sorry to take the thread kind of OT. |
There's definitely a difference between MT-90 and MM, tho. MT-90 made my LSD whine every single day in the parking garage, XT-M5-QS never has once. I personally didn't notice a difference in the way the transmission shifted between OEM, MT-90, and MM, but others say they have. Maybe that's placebo, I can't say. Whether you call noise and shifting feel "performance" or not is up to you, I suppose. It's not part of the central mission of tranny fluid, but it is part of its operating characteristics. What isn't known is whether Ford's MM is anything but seriously overpriced cheap-ass dino oil + friction modifier. For $60, they take the guesswork out of whether and how much friction modifier to add, tho, and for me that's worth it. |
Personally, i can't compare. I've only tried the MT-90. That was a big improvement over the standard fluid. But, after my recent tire purchasing fiasco based off of member recommendations, I tend to be more skeptical of peoples ability to accurately differentiate real world performance from placebo effect. It's been my experience thus far that most people, even some track racers, don't truly "feel" their car. That's not something you can practice, though. That's more related to your overall sense of touch and feel. Not everyone is the same in that aspect. Some are more sensitive than others. |
Dude, you're part of the problem that you're complaining about - people giving advice when they have no business doing so... |
I use mm and still have LSD whine. |
Don't jump me for this, but... Quote:
The 4oz. of "fish oil" replaces 4oz. of the XT-M5-QS. Transmission shifts perfectly... and zero LSD "rasping" (whining) noise. Am almost 8k miles into it and all is well in Speed3 city. And @Dash08, there is a perceptable difference between MT-90 & the Ford "god-piss". |
My dealer has it for $ 20.xx a bottle Hmm... order online and save 2 bucks over 3 bottles w/ shipping to portland? meh |
don't forget tax |
I just had my transmission fluid changed at the dealer for the first time. At 106k miles. car has always run like a fucking champ. I'm not sure how the new fluid feels as the car is just sitting now while i wait to replace my broken transmission mount. I have the cp-e mount on the way. |
meh, even with the magical ford fluid, I still get 3rd gear grind, but I'm also in an MS6. I really need to adjust my linkages :(. Or find someone down here in SC thats a pro cause I have no time, yay nuke school ><. |
| All times are GMT -7. The time now is 06:42 AM. |
