 Old 03-30-2010, 06:34 AM   #41
Qtip's Avatar
Posts: 410   (View Stats)
Qtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond repute
I am going to check the mount today, I looked at the shop manual and no where did I see 70 ft/lbs for the torque spec. I think it was something like 56 to 64 ft/lbs if I remember correctly.
I did put some loctite on the bolts so I doubt it's coming loose but will double check anyway.
I don't think the vibrations at idle are caused by detonation, it's normal for the engine to run rougher at low RPMs. Most people raise their idle speed a bit because these aftermarket mounts like to vibrate at 650 - 700rpm.
Originally Posted by donightwolfdo View Post
I have the same mount with street bushing and so far I put around 150 miles on it. Vibrations are almost none, but if you look for them, you can hear them. Only thing I can hear is half to one second long metal to metal clatter when I start and shutoff engine. I torqued bolts to 70 ft/lbs of torque and I also used locktite to make sure it won't loosen up. Overall I love this mount, cause shifts are easier and I can feel more power to wheels.
With the upgraded mount it sounds like I've got bolts loose in the engine on shut-down, sounds embarrassing.
Last edited by Qtip; 03-30-2010 at 06:34 AM. Reason: MSF Database - Automerged Doublepost
Qtip is offline   Reply With Quote
 Old 03-30-2010, 07:54 AM   #42
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Groans: 166
i thought this racket on shut down was normal. Ive heard quite a few people complain about it. including me.
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
Originally Posted by Say Chi Sin Lo View Post
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
 Old 03-30-2010, 08:03 AM   #43
letzleta's Avatar
Posts: 385   (View Stats)
letzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the world
Groans: 33
I have the SU (Street) version. Only about 75 miles on it, but I barely notice any vibes. I had the "thump" sound when starting and shutting off the motor, so I got under the car and torqued the bolts again. I have not noticed the "thump" since then, but I just tightened it yesterday.
2010 Mazdaspeed 3 Tech - Sort of Fast
some stuff
2008 Triumph Daytona 675 - Actually Fast
GB Racing Slider Kit - DDM 35w 6000k HID - TechSpec Snakeskins
letzleta is offline   Reply With Quote
 Old 03-30-2010, 08:17 AM   #44
Qtip's Avatar
Yup, it's normal except that an aftermarket engine mount amplifies it.
Good to know, I'm hoping that the bolt just needs to be tightened but I somehow doubt it. I have a feeling that the bushing in the mount is moving, we'll find out after work.
 Old 03-30-2010, 07:21 PM   #45
BolvangaR's Avatar
Posts: 117   (View Stats)
BolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the world
Groans: 113
Groaned at 91 Times in 89 Posts
I just picked up a CP-E 60 duro mount..... Installing it next week!
'07 MS3 GT - CS SRI - CS TIP - TP - CP-E RMM - JBR SSP - E4 Knob - Amsoil MTG
BolvangaR is offline   Reply With Quote
 Old 03-30-2010, 08:14 PM   #46
Qtip's Avatar
Thumbs up
I feel like a real doorknob... Turns out that the bolt that holds the rear engine mount to the transmission mount was not tight enough. It needs to be really tight so that the mount actually bends and locks down on the transmission mount. Mine was tight but not tight enough so this joint was able to move a good 1/8" before the rear mount even engaged. Took everything apart and re-torqued to 70 ft/lbs.
Took it for a test drive and what a difference. No more vibrations and it runs just awesome. Street Unit, I love you!
The thumping at start up is gone, my shutdown no longer sounds like I've got bolts loose in my engine, and no more vibrations at idle. The vibrations are maybe 5 - 10% more than stock, and most of this is when you are engaging the clutch at initial start up around 800 - 1000 rpm.
Very happy.
 Old 03-30-2010, 08:57 PM   #47
Night Wolf's Avatar
Posts: 894   (View Stats)
Night Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the world
Groans: 38
Very happy.
Hm, When I installed it first time I torqued it down to 70ft/lb and still have that loose nuts sound and shut off. I guess I'll have to recheck it.
2008 Mazdaspeed 3GT
Wiseco pistons || K1 rods || GT3076 at 21 PSI (for now) || Built by Pablo and tuned by Dustin || Steedspeed exhaust mani || TIAL 38mm EWG || Custom dump tube || Grimmspeed EBCS
CP-e safe seals || CP-e 4" TIP || CP-e big maf || CP-e catless DP || CP-e HPFP || CP-e gauge pod with Prosport gauges || COBB FMIC || COBB XLE BPV || COBB STS || COBB AP
Matt Damond OCC || CNT exhaust || BSD || EGR del || DENSO ITV22 || TRZ RMM || TRZ TMM || JBR PMM || JBR shift knob || Stoptech slotted rotors || KONI FSD || ROTA GRID 18 x 8.5
NATOR NJ FTW
Night Wolf is offline   Reply With Quote
 Old 03-31-2010, 06:23 AM   #48
Qtip's Avatar
Some of that noise is normal, mine was excessively loud. You should expect around the same level of noise on shutdown as with the stock engine mount.
 Old 03-31-2010, 08:42 AM   #49
nynhex's Avatar
Posts: 922   (View Stats)
nynhex is the leader of the worldnynhex is the leader of the worldnynhex is the leader of the worldnynhex is the leader of the worldnynhex is the leader of the worldnynhex is the leader of the worldnynhex is the leader of the worldnynhex is the leader of the worldnynhex is the leader of the worldnynhex is the leader of the worldnynhex is the leader of the world
Agreed, that's why I said idle/rough will do that, however if you are having knock/detonation you would definitely hear it reverberate because of the mount.
Yea, you should do it. Just in case. You have the same looking mount as CP-e mount, right? Do you hear some metal to metal clutter (louder than normal vibrations) while starting/shutting off car?
No metal to metal clutter. But there is a shaking/clunking sound on shutoff. That's normal even with the stock mount but it's more pronounced with the solid mount.
Last edited by nynhex; 03-31-2010 at 08:42 AM. Reason: MSF Database - Automerged Doublepost
nynhex is offline   Reply With Quote
 Old 03-31-2010, 09:30 AM   #50
dachtler's Avatar
Posts: 170   (View Stats)
dachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond repute
No they were not torque, the shop tighened down fully by an impact wrench.
FYI, torque specs are VERY important to the NVH performance of a motor mount like these. I have yet to install a RMM on my '10 MS3, but will likely be doing that shortly based on this thread (I couldn't figure out what the issue was with the RMM, but the firewall impact comment cleared that right up!).
On my previous car (1993 Saab 900T), I had replaced the stock hydraulic front motor mount (which might be considered the RMM, as the engine is in backwards in that car) with a billet aluminum unit that had a thick rubber insulator between the engine and the mount. I torqued down the mounting bolt too tight, and thus compressed the rubber which defeated its ability to reduce vibration. I lived with this for a while, but eventually swapped back to the stock mount as the vibration was too much for me to live with. I could see there being a similar issue with the various designs of the replacement RMMs, where if you torque them down too much, then any dampening ability is defeated.
dachtler is offline   Reply With Quote
 Old 04-07-2010, 01:31 PM   #51
dr_banano's Avatar
Posts: 502   (View Stats)
dr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the world
Groaned at 22 Times in 8 Posts
Very happy.
why is it soo rustyy down there in the pics ??
Dr_banano
Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP V3 - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- FALKEN AZENIS tires - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- corksport rear bumper lights - TWM short shifter - JBR TB/IM TI - EGR block - Njspeed pnp IM - K&W V3 coilover - Rear Carbon Fiber Spoiler - corksport hood scoop - WORK wheels 18 x 9.5 + 38 rear and 18 x 8 +38 front
ptp studs/seals pending
mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car
dr_banano is offline   Reply With Quote
 Old 04-07-2010, 02:20 PM   #52
KR....i haz it
Blackspeed's Avatar
Groans: 166
Very happy.
what about with the a/c on? I use it a lot here in florida which is why im running the CS inserts right now.
 Old 04-07-2010, 04:55 PM   #53
Qtip's Avatar
I don't recall any increase in vibrations but I'll keep an eye out for it the next time I'm in the car.
No idea, I was surprised to see that much rust on a car that is only two years old but I guess it's all the crap on the roads. Oh well.
 Old 04-07-2010, 11:26 PM   #54
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
If you remember the vibration levels when your car was new... well, that's the level of vibrations with the soft SU mount after about 1000 miles. The car actually became significantly more quiet and the vibration level decreased after a 400 miles trip that included about 80 miles of bended road, the perfect road for hill climb competitions with good asphalt, sharp turns and long enough straights to accelerate from 40 to 90mph.
The only still noticeable difference is that it vibrates more when you launch gently around 800-1200rpm and, of course, when you back park your car (it's basically the same situation).
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Blackspeed (04-08-2010)
 Old 04-08-2010, 05:56 AM   #55
KR....i haz it
Blackspeed's Avatar
Groans: 166
i bought my car with 3000 miles and a few hunded miles later I had the cs inserts in, so I dont know what the initial vibes are when the car was new. I know I have no vibes right now with a/c on.
 Old 04-08-2010, 06:25 AM   #56
Qtip's Avatar
Exactly what Mituc said... No increase in vibration with the A/C on and only a slight increase in vibration when starting off around the 1000rpm range. Although this vibration has greatly decreased as the mount is being broken in. Doesn't bother me at all.
 Old 04-08-2010, 11:10 AM   #57
letzleta's Avatar
Groans: 33
The vibes are not bad at all. Anyone who says they are, given it is installed correctly, is either overly sensitive or bought the wrong car. Seriously, there is no difference from stock once you are going over 5 MPH or so. The only times I ever notice more vibration are very slight at idle (barely enough to mention) and when starting from a complete stop (which lasts all of a second or two). If either of these situations create too much vibration, I have no idea how you handle driving this car on pavement that is not perfect.
Also, my mount isn't even broken in yet.
some stuff
 Old 04-14-2010, 07:56 AM   #58
Qtip's Avatar
UPDATE #3:
Put a good 1000 miles on the mount so far and vibrations are nearly completely gone. Still have a bit of vibrations when starting from a standstill around the 800 - 1000 rpm but the vibrations have decreased substantially.
I also noticed that the engine is rocking back and forth a bit more now. I'm still happy in comparison to the stock mount but this would definitely be too soft for you performance nuts.
The Following User Says Thank You to Qtip For This Useful Post:
Blackspeed (04-15-2010)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/impression-new-su-solid-motor-mount-soft-51562/
Impression of new SU Solid motor mount (Soft Bushing) - Page 2 - Mazdaspeed Forums This thread Refback 04-22-2010 12:16 AM
Motor Mount Inserts vs. Rear Motor Mount Pro's n Con's Dre 2010 MS3 - Engine, Transmission & Driveline 23 05-21-2016 08:47 AM
weakest motor mount..? what mount takes a dump first? Lvis MazdaSpeed 3 - Engine, Transmission & Driveline 29 03-02-2009 11:39 PM
Can you overnight me a TRZ (Soft) Rear mount for the MS3? speed3 Mazdaspeed3/6 General Discussion 2 12-30-2008 05:15 PM
Solid Motor Mounts phantom3 MazdaSpeed 3 - Engine, Transmission & Driveline 13 11-10-2008 03:20 AM
Page generated in 0.39991 seconds with 29 queries
