 Old 05-07-2009, 02:00 PM   #81
Element's Avatar
Posts: 240   (View Stats)
Element has a reputation beyond reputeElement has a reputation beyond reputeElement has a reputation beyond reputeElement has a reputation beyond reputeElement has a reputation beyond reputeElement has a reputation beyond reputeElement has a reputation beyond reputeElement has a reputation beyond reputeElement has a reputation beyond reputeElement has a reputation beyond reputeElement has a reputation beyond repute
Originally Posted by Poet-Tek View Post
I've had my Medieval Rear Mount in for about 2 weeks and probably 600-700 miles city/highway/mountain bomb runs. I am getting a little squeek at start up and when I take off from a stop.
Of more concern is that I'm getting a loud rattle from underneath the car at certain times on idle while sitting at a light or just parking the car. This isn't like cabin vibes, it's a loud stacato noise almost like an air wrench ratchet sound. Seems to be more likely to occur if it's cooler in the evenings (45-50 degrees) and it's been a longer drive 45 minutes to an hour. It seems to be increasing in both volume and regularity, which concerns me. I can make the noise disappear bumping the idle from ~750 to ~1000 RPMs with the throttle.
When we installed it, we torqued it to 60 ft/lbs and used lock-tite.
When I first heard the rattle (about a week ago), I got it up on ramps the next day and checked the bolts and they seem fine. But at that time, I couldn't get it to make the noise, so I couldn't isolate the source.
Is this something that should just go away with time or should I try to reset the upright bolt or something?
Thanks for any suggestions. I don't mind letting it settle in, but I can't have my new car sounding like an old time gatling gun .
Well glad someone else is having this issue. I am swapping out my Medievil mount for my stocker to see if the noise goes away. I have the EXACT same noises you are describing. It was fine at first and then this noise just started up. I also notice that it gets a lot worse as the length of drive time increases. I also checked the bolts and everything was nice and tight.
I have the smaller sleeve, and am hoping that the longer sleeve will somehow alleviate the problem. I requested the longer sleeve a month ago and hoping it arrives soon.
Element is offline   Reply With Quote
 Old 05-07-2009, 11:09 PM   #82
darkstarmotorsports's Avatar
Posts: 882   (View Stats)
darkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the world
Groaned at 6 Times in 2 Posts
I had a customer have the same issues you guys are having. It wasn't the mount that is causeing the noise. Check you heat shields and exhuast/DP bolts, they were the case on his car. And from the sounds from what you guys are describing, it might be the same thing.
darkstarmotorsports is offline   Reply With Quote
 Old 05-08-2009, 01:08 AM   #83
Poet-Tek's Avatar
Posts: 82   (View Stats)
Poet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond repute
Thanks for the heads up, DS. I'll check it out over the weekend.
Poet-Tek is offline   Reply With Quote
The Following User Says Thank You to Poet-Tek For This Useful Post:
darkstarmotorsports (05-09-2009)
 Old 05-08-2009, 08:09 AM   #84
Element's Avatar
Kinf of ironic that it started with the MM install. I swapped out the mount for my stock mount, and the noise went away. I will keep waiting for the longer sleeve...
 Old 05-09-2009, 12:29 PM   #85
Poet-Tek's Avatar
Yesterday I discovered a new piece of this puzzle. I can be sitting at a light and no rattle noise. If I turn the wheel just a bit, the noise starts and I can usually make it stop by turning the wheel back. May have something to do with the rack and subframe which I'll have to educate myself on.
 Old 05-09-2009, 07:42 PM   #86
How long have you been waiting? Send me a PM.
 Old 05-09-2009, 10:32 PM   #87
bombermanx's Avatar
Posts: 1   (View Stats)
bombermanx is an unknown quantity at this point
When you turn the wheel, the power steering pump puts load on the engine and drop the revs a tiny bit. It will continue to put load on the engine if the wheels are not rolling to take out the tension. That could be all it needs to cause the engine to vibe enough for the rattle.
bombermanx is offline   Reply With Quote
 Old 05-16-2009, 02:56 PM   #88
Element's Avatar
Originally Posted by babypetit View Post
did you ever get the longer sleeve...and did it fix your issue?
Still no sleeve...
Stock mount is now back in and no more noises.
 Old 05-16-2009, 05:28 PM   #89
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
maybe yall arent tq'ed enough.
i tq'ed my Med. MM to 80lbs.
no noises
2015 Mazda 6
 Old 05-17-2009, 04:44 AM   #90
Element's Avatar
Torque was fine. Loctite used as well.
 Old 05-17-2009, 09:48 AM   #91
IshiKage's Avatar
Groans: 278
i used Permatex threadlocker. i originally tq'ed mine down to 65lbs and it felt loose. so i tq'ed it down to 80lbs.
tightened her up nicely
2015 Mazda 6
 Old 05-17-2009, 10:26 AM   #92
IshiKage's Avatar
Groans: 278
i have the very first version of the Medieval Dog bone.
i was apart of the GB.
damn all of their new MM's look hot with the red bushings
2015 Mazda 6
 Old 05-17-2009, 09:47 PM   #93
filphil's Avatar
Posts: 203   (View Stats)
filphil has much to be proud offilphil has much to be proud offilphil has much to be proud offilphil has much to be proud offilphil has much to be proud offilphil has much to be proud offilphil has much to be proud offilphil has much to be proud offilphil has much to be proud offilphil has much to be proud of
I believe I was one of the first to install and post about their redesigned mount on MSF. I had zero problems with mine. It's a rear mount that doesn't bear the weight of the engine. It's easily removeable(just use alot of PB blaster or WD-40) if you want to go back to stock or another mount.
The lead car is absolutely unique, except for the one behind it which is identical
| Sok07's Gas Pedal | Cobb Shifter Weight | TRZ Polyurethane Rear Mount | BC Racing BR Coilovers | SPC Adjustable Rear Camber Links | CP-E Xcel NANO Intake | CP-E Nviscid Pipe | Turbosmart Bypass Valve | Street Unit Test Pipe | Hawk HPS Pads |
filphil is offline   Reply With Quote
 Old 05-17-2009, 11:21 PM   #94
IshiKage's Avatar
Groans: 278
ive had my mm for a month but havent installed it and all of these people complaining about squeaks and noises are making me worried..
dont worry, throw it in. if there is a problem, you will know.
I havent had any problems and totally dig Medievals Prooducts. will be buying plenty more products from them in the near future
2015 Mazda 6
 Old 05-18-2009, 03:50 AM   #95
Still no sleeve...
I sent a request to medieval to send you a sleeve when you sent me that PM. This disappointing.
Please PM the Medieval Rep on this forum, and I will contact them again on Monday to make sure you get one.
 Old 05-19-2009, 06:53 PM   #96
Element's Avatar
The Medieval Rep was contacted on the forum and I was instructed to send an email. Emails were sent and I was told that they probably got stuck in customs. Weird how items ordered from China and Japan after these sleeves arrived already.
I was told a second set was sent out via USPS. I asked for an item number to track but got no response.
 Old 05-20-2009, 01:38 AM   #97
How long ago did you email them? Medieval is currently having issues shipping out orders, but they are working ongetting them fixed ASAP.
I know you're weren't the only one waiting for the longer sleeve. I'm sorry.
 Old 05-20-2009, 12:15 PM   #98
Element's Avatar
First email was now 6-7 weeks ago, 2nd email was 2-3 weeks ago.
Not your fault, so no need to apologize. However a little honesty would have been better than a string of lies about shipping dates and times.
The Following User Says Thank You to Element For This Useful Post:
darkstarmotorsports (05-21-2009)
 Old 05-20-2009, 01:03 PM   #99
Poet-Tek's Avatar
I wouldn't worry about installing the mount. Last week I reset the main upright bolt and for the most part the loud clang has gone away. I'm gonna drive it for another week to see what happens and then I'll probably grease the bushing to address the squeek. Maybe go to 80 ft/lbs like someone mentioned in this thread.
I still get the loud clang if I turn the wheel when stopped or sometimes if the wheel is turned as I stop. Vibes at idle are smooth as can be normally, but a little rough and noisy with the AC on.
Overall, the mount is a vast improvement as far as the feel of the car, especially when accelerating hard and upshifting quick or rev matching/heel toe/double clutching downshifts.
My only mods are shifter bushings, MM, Cobb SRI, RX-8 Wheels with Potenza RE01R Track/Street Tires and I can really put the power down and throw the car around alot more than stock.
Go ahead and do it. You can always change it out if you don't like it after a few weeks. I'm pretty noob when it comes to modifying cars and it's just working out the kinks and getting used to tradeoffs. But I love the improved drivability and I think it's worth a little noise and futzing around with it.
I'm not really sure how loud it is outside, but with the SRI/Turbo making whooshing noises and the mount increasing engine noise in the cabin, the car feels very sporty. Some people understand that, some don't, so if I have a woman in the car or biz associates, I keep it under 2500 and the mods effects aren't as pronounced.
Around town in traffic I drive fairly sedately and the car does that fine, but get it out on the open road or in the mountains and the mods really come together with the OEM engineering to make it fun as hell.
 Old 05-25-2009, 04:44 PM   #100
Element's Avatar
Still no sleeve...
 Old 05-25-2009, 05:43 PM   #101
Still no sleeve...
You're not the only who hasn't receive their replacment parts from them yet.
I'm sending you PM for a solution to this.
 Old 05-31-2009, 10:30 PM   #102
darkstar i finally installed the motor mount and its great....feels really solid and there are hardly any vibes...i love it!
Thats awesome to hear!
 Old 06-07-2009, 09:01 PM   #103
Dismember
KaiserSoze's Avatar
Posts: 611   (View Stats)
KaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the world
Groaned at 27 Times in 13 Posts
I just put my Medieval rear mount in. That thing was a BITCH!!! REALLY should have come with a small tube of grease or something. I got it ALMOST all the way in and it just stopped. I could get the bolt in the bottom hole, but it wouldn't go all the way through. So I had to pull and pray and pull some more and almost couldn't get it back out. But I put some more oil on it (for the third time) and it FINALLY slid in. I haven't really driven it yet, just out of the garage and back into the driveway. But the vibes aren't nearly as bad as I thought they'd be. And if they're supposed to lessen after a little while then I think this mount is going to be awesome.
2012 Nissan Titan 4x4
KaiserSoze is offline   Reply With Quote
 Old 06-23-2009, 02:34 AM   #104
5_Alive's Avatar
Posts: 66   (View Stats)
5_Alive is just really nice5_Alive is just really nice5_Alive is just really nice5_Alive is just really nice
covered by a LIFE WARRANTY
Holy crap.. that's f'in amazing!
Toppin' out is not an option..
5_Alive is offline   Reply With Quote
 Old 07-10-2009, 07:07 PM   #105
Poet-Tek's Avatar
So I was still getting a little unwanted noise and I went to tighten the bolt to 80 ft/lbs. The front edge of the upper bushing was torn away from the bushing that is within the cross member. I looked it over and tightened it down anyway. Darkstar, can I get a replacement for just that piece? It's only been on the car for a few thousand miles.
Given the other issues with Medeival that I have seen recently, maybe I should get a whole different mount. I'll drive it like this for a few days, but not entirely comfortably.
 Old 07-11-2009, 01:03 AM   #106
we don't carry any replacements, you would have to go directly to MEdieval themselves.
 Old 07-11-2009, 07:41 AM   #107
sleeperstang1994's Avatar
Posts: 569   (View Stats)
sleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the world
Groaned at 7 Times in 5 Posts
lol good luck with that DS. i have had a paypal and ebay dispute with him for some time now. seems since the shit hit the fan in here with medievalREP he is MIA
sleeperstang1994 is offline   Reply With Quote
 Old 07-12-2009, 10:29 PM   #108
you're not the only one. I have over ten disputes and claims with them now.
 Old 08-06-2009, 11:01 AM   #109
Sport6's Avatar
Posts: 427   (View Stats)
Sport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the world
That video a while back of the first medieval mount is mine, but Darkstar took care of it for me!
I installed the dogbone (black bushings) right after that and its been on ever since. It was a bitch to get on, even marked up the paint/powdercoating. Oh well on that. But I installed it to the 85ft lbs that the factory manual states (68.7-85.9ft-lbs). I haven't had a problem yet (knock on wood).
Maybe the 40ft-lbs was too little and allowed the mount to move too much and caused some of the noises/ripping?
Sport6 is offline   Reply With Quote
The Following User Says Thank You to Sport6 For This Useful Post:
darkstarmotorsports (08-06-2009)
 Old 09-17-2009, 04:37 PM   #110
Dismember
KaiserSoze's Avatar
My mount was making a thunk sound on start-up. I tightened the rear bolt and it made it all nice again. Is anyone else still using the Medieval dogbone RMM? I don't want to have to shell out more money for an AWR or other mount when I've already spent $75 between the Corksport inserts and now this mount that I bought 2nd hand (before all the Medieval shit was hitting the fan).
 Old 09-17-2009, 05:06 PM   #111
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
i still have the rear mount, and also trans mount. i'm planning to replace both in the next few months.
i also recently tightened the bolt on the rear mount. the mediephail-recommended 40ft-lb for the rear bolt was seriously not working.
 Old 09-17-2009, 11:22 PM   #112
Dismember
KaiserSoze's Avatar
Well, as long as the metal doesn't fail on me or something stupid, I'll just leave it in now that it's torqued properly. I think I did 60 ft*lbs at first since I'd read about some people having problems at 40.
 Old 09-18-2009, 04:07 AM   #113
aspiring turbo guru
08_ms3_gt's Avatar
i torqued it to 75ft-lb. i noticed an increase in engine vibration, but i actually like the difference.
the bushing is probably going to fail before the metal. of course, mediephail claimed they had no failures on the rear mount. but there were bushing failures on the side mount.
SU mounts in my near future...
 Old 09-18-2009, 11:21 AM   #114
Dismember
KaiserSoze's Avatar
Yeah, I haven't really seen anyone have probs with the rear mount. The guy I bought my rear off of also had teh passenger and tranny mounts for sale. Boy am I glad I only went after the rear.
 Old 09-18-2009, 12:17 PM   #115
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
still have my rear mount in. torqued to 75ft-lbs i think, still works fine and no issues
'08 CWP MS3 w/ T3 3071r
Pics: New CPE rear mount next to SU mount, and is it defective? Zeya MazdaSpeed 3 - Engine, Transmission & Driveline 16 12-19-2008 11:04 AM
Just installed hood stripes and made my own rear Death-From-A-Mile MazdaSpeed 3/6 - Appearance 10 09-01-2008 11:52 PM
Rear Mount Thud popecruz Mazdaspeed3/6 General Discussion 7 07-15-2008 05:38 PM
Page generated in 0.52613 seconds with 32 queries
