Like Tree4Likes
 Old 07-25-2012, 05:15 PM   #41
mzr0818's Avatar
mzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the world
Groans: 221
I will take a pic of the machine tomorrow.
I was ok until 4500 rpm and then Jeff Raped my face
EMWNM 2013
Beating Black women one 5.0 at a time...
2008 mazdaspeed 3 true red
Tuned by Nishan
, 33% E85, GTX3067r Boost?, Yeah I got some., Port and polish manifold, XS power Tubular Exhaust Manifold, Wiesco pistons, K1 rods, L19 head studs, ARP crank studs, Cobb three port EBCS, Forge BPV, CXRacing FMIC with TR8 core, cobb AP V2, EBC redstuff full, DBA 4000 rotors 6x6 slotted, HTP 3" full intake, JBR 88d rmm, JBR 80d pmm, JBR 80d tmm, CNT catted DP, Magnaflow CBE, KMD internals, Koni Yellows, Moog endlinks, Moog lower control arms, OZ ultraleggera 18x8, Mich Pilot Super Sports 235/40/18, Hotchkis RSB, NGK step colder plugs.
Build in progress. Track whore in the making.
mzr0818 is offline   Reply With Quote
 Old 07-25-2012, 05:19 PM   #42
Cheeto's Avatar
Posts: 762   (View Stats)
Cheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the world
Alright I hate to say it but if you keep on posting in this same thread the Hell Hounds will come after you. TRUST ME THERE ARE A LOT of thread and sticky's for DYI with pics. We all have given you our takes.....I would do it right and complete HEAD/TOE. Either take a stance list what your going to do and do it already or Bounce Yo....
But Pics Please
Chad Erwin -ATX
06 MazdaSpeed6 Gt AWD/Turbo/#5994
MODS:
COBB AP // MSD Dashhawk // Street Unit TMIC // Street Unit Test Pipe // CorkSport Power Series Catless DP // COBB SRI intake // Speedies TIP // Turbosmart BOV // RPM Street Spring // Bilstein Struts/Shocks // TWM Stage 2 Short Shifter // CPE Dogbone rear mount // CPE JuggerNaught Diff mount // COBB Shifter weight // HPFP Internals // Magnaflow FULL 3IN Back// Denso ITV 22s // Full TIGS // EGR Delete // Shorty Antenna // PA Engineering OCC // LED swap
Cheeto is offline   Reply With Quote
 Old 07-25-2012, 05:20 PM   #43
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
What? Obviously you didn't read the OP... I was NOT asking about HOW TO clean the intake valves... You're an idiot. I forgot that the point of public forums was to post once and leave...
 Old 07-25-2012, 05:29 PM   #44
theurgy's Avatar
Posts: 2,580   (View Stats)
One service I had looked at before and was offered to me as a dealer was TerraClean.
They have an option where they spray their solution into a running engine from the intake tube (or in this case the boost tube between the coldpipe and the throttlebody).
Specifically the machine they refer to is this:
TerraClean
Now some of the science behind TerraClean is a little wonky and some chemical engineers laugh at some of their material.
That said I had contacted a sales rep from TerraClean to try and locate a dealer that would offer this service.
I'll quote his response:
On Mon, Apr 16, 2012 at 3:45 PM> wrote:
> I would suggest taking it to *Omitted Dealership Name* Mazda. Talk to Frank the Service
> Manager. They have all the adapters and S-Tool for the intake. Make sure
> you specify that you are having intake valve issues.
> Also, you have to be realistic as to what the valves look like after. You
> can't expect a solution injected into the intake to have the same result as
> removing the manifold and scrubbing the valves. It's like surgery vs
> vitamins.
> Regards,
> *Name Omitted
BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob.
To be installed: SS Brake Lines.
theurgy is offline   Reply With Quote
 Old 07-25-2012, 08:33 PM   #45
sidekick's Avatar
Groans: 47
TerraClean
Well that pretty much puts an end to the argument. Thanks for that info
2006 Mazdaspeed6
 Old 07-25-2012, 08:50 PM   #46
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Hmm, sound like seafoam to me.
Pickles Tune in progress
 Old 07-25-2012, 09:43 PM   #47
Constantin's Avatar
Posts: 3,907   (View Stats)
Constantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the world
Groaned at 18 Times in 16 Posts
TerraClean
I wonder if somebody actually used that thing and toot pics ...
2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq
Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arms | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors
Constantin is offline   Reply With Quote
 Old 07-25-2012, 10:47 PM   #48
theurgy's Avatar
I asked the dealership how much the service was and it was somewhere in the neighborhood of $400 CDN.
Not worth being a guinea pig for that kinda bullshit money.
 Old 07-25-2012, 10:58 PM   #49
shadesofgray19's Avatar
Posts: 794   (View Stats)
BMW does the media blasting, nuff said. If you could inject something I'm pretty sure they would be doing that instead.
2006 Black Mica MS6 - Sold 10/15
shadesofgray19 is offline   Reply With Quote
 Old 07-26-2012, 06:26 AM   #50
mzr0818's Avatar
Groans: 221
I agree...
I'm going to be the guinea pig because for me its free. It also gives me a chance to fit somethingg to make it work as well as possible. I think I can have it done at retail for much less than that. Our cars are a lot easier to take off the intake then the 335's are. Especially if you have a front mount.
Here are some pics.
The machine. It has the media inside the canister and is hooked up to shop air
The connection from a shop vac, machine, and the intake port on the head. This is the part I will have to make. I have a spare head at the house to mate it to and ensure a tight fit to the cyl head ports.
How the connections go together.
EMWNM 2013
Tuned by Nishan
The Following User Says Thank You to mzr0818 For This Useful Post:
Constantin (07-28-2012)
 Old 07-26-2012, 11:31 AM   #51
aviator79's Avatar
Posts: 3,934   (View Stats)
Groans: 67
Thermal Insulator Gaskets.
Oh. I got one of those for my MS6. Not going to use one in the CX-7 which I am preparing to clean the valves on. I just did my MS6 with B12 and rifle cleaners, but going to get the walnut gun for the Cx-7 as it is approaching 60k. Need to do a full service on it.
 Old 07-26-2012, 11:52 AM   #52
Posts: 9,484   (View Stats)
With higher concentrations of E85 BAT heat makes little difference in performance but I didn't want to reuse a gasket. I always try to put things back together better than they were before. Lol.
Maybe a waste of money, but then again so is everything we all do to our cars. Hahaha
Tappin
MSMS3 (07-27-2012)
 Old 07-26-2012, 12:07 PM   #53
Cheeto's Avatar
Agreed, I have 50k right now and only want to do this about every 50k.
I am going to do both though, B12 soap and scrub then vacuum out. Media blast second while vacuuming to keep dust/dirt down. TIG cause I live in Texas.
Chad Erwin -ATX
MODS:
Intake Valve Cleaning Solution? theurgy MazdaSpeed 6 - Engine, Transmission & Driveline 53 03-10-2013 11:12 PM
Valve Cleaning beachshoer Gen2 MS3 General Discussion 16 07-08-2012 07:43 PM
Will be cleaning my EGR valve meciboy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 20 04-16-2012 02:15 PM
EGR valve cleaning desertrat MazdaSpeed 3 - Engine, Transmission & Driveline 5 03-06-2010 09:17 AM
Page generated in 0.34223 seconds with 28 queries
