  • 1 Post By IMASA
 Old 12-05-2017, 09:24 PM   #1
IMASA's Avatar
Posts: 209   (View Stats)
IMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the world
Default Intermittent shifting issues
Hey all,
I have a 2008 speed3 with 120k kms (~74k miles) and I have an intermittent shifting issue.
I have an ACT street clutch that's ~18months old. New slave (replaced last week). Clutch master cylinder was replaced 2.5 yrs ago. I also have a TWM full replacement shifter kit.
Under most circumstances, the car shifts and and drives fine. However, I have this intermittent problem with shifting that occurs mostly engaging reverse, like backing up when parking the car. Some times when I'm going into reverse, the transmission starts acting up, becoming very difficult to shift into gears reverse, 1, 2, 3, 4. (5th and 6th seem to be ok, but more difficult than normal). I can't even put the shifter into gears R, 1, 2, 3, 4. There's no grinds, no clutch noises. I just can't put the shifter into gear. The pedal feels fine.
If I shut off the car, then the shifter moves through the gears fine. I've tried double clutching but that doesn't help. If I turn the car back on right away, it has the same problem.
If I let the car sit for a few mins/hours, then it's fine again.
This is my 2nd ACT clutch. The first one died due to pressure plate failure due to a broken finger. As far as the clutch pedal is concerned, it feels fine. With the broken ACT PP, I would definitely feel something was wrong with the pedal, as I felt some resistance through the pedal due to the broken pressure plate.
I don't have any fluid leaks. I've tried bleeding the clutch several times.
From researching online, it sounds like I either have a problem with the shifter cables or the clutch pressure plate. Since this problem happens intermittently, is it safe to rule out hardware failure with the pressure plate and/or other clutch parts? There's no clutch noises so I think my throw out bearings and pilot bearings should be fine.
Thanks for any advice/suggestions.
2008 Mazdaspeed3 | Cobb AP | Cobb DP | Cobb FMIC | Cobb RSB | Cobb RSB | SURE 3" MAF full intake | CP-E Stage 2 RMM | CP-E HPFP | H&R Springs | Koni Yellows | TWM FR | MD OCC | Dashhawk | DO Methanol Injection | JBR PMM & TMM | JBR EGR Plate |
IMASA is offline   Reply With Quote
 Old 12-06-2017, 07:33 PM   #2
2012FailWheelDrive's Avatar
Posts: 325   (View Stats)
2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world
Originally Posted by IMASA View Post
Hey all,
Hmm so I have a gen 2 with a Southend stage 3 and a twm replacement as well and seem to have the same problem as you. Drives fine 98% of the time but then suddenly all gears are impossible to get into. I have found that a constant factor is that it is usually after a long drive and the car as well as ambient temps are on the hotter side (usually experience it in summer).
I haven't replaced the slave yet but was going to be my next move along with a tranny fluid change from fomoco to redline.
Sent from my SM-G955U using Tapatalk
"under construction"
2012FailWheelDrive is offline   Reply With Quote
 Old 12-06-2017, 08:44 PM   #3
IMASA's Avatar
My problem occurs mostly when I'm driving to work or from work. I arrive at the destination, attempt to throw it into reverse and can't shift into any gears.
The only way I can get the car to shift is keep trying R or 1st and eventually I can force it in. Or, let the car sit for like 30mins to 1hr and then it shifts fine again.
I replaced the slave, using original Mazda part, put in Motul Gear 300, but that didn't help at all. I tried playing with the shifter adjustment, and the adjustable reverse lock out on the TWM, but didn't help either.
Let me know if you figure your issue out.
 Old 12-07-2017, 11:07 AM   #4
thrisnospork's Avatar
Posts: 254   (View Stats)
thrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond repute
The speed3 shifter cables are adjustable left to right, not sure if that still works with the twm full replacement though but it would be worth looking into.
Sent from my LG-H918 using Tapatalk
thrisnospork is offline   Reply With Quote
 Old 12-07-2017, 04:56 PM   #5
IMASA's Avatar
Yeah, I've already adjusted the side to side movement of the shifter, doesn't seem to have helped me.
 Old 12-07-2017, 07:34 PM   #6
aackthpt's Avatar
Posts: 1,444   (View Stats)
aackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the world
Have you removed the boot and left it that way so you can observe the parts inside the cabin when you have the problem? If not I'd do that first.
Next, get someone to help. Looks like you have an intake so hopefully this is visible with a flashlight... have them watch the transmission arms where the cables attach as you run through all the gears before you leave, including reverse so they can memorize all the movements of the levers, etc. Then drive somewhere that makes it do it and get them watching the trans end again before you try to shift into reverse. Do the shift into reverse and get it to do the lock out, try to go into all the gears - all the while telling the shop hand what you're doing. Hopefully they'll be able to notice something different and if not you'll know there's nothing wrong between the mechanisms inside and the stuff inside the trans. Make sure they also watch the shift weight etc.
Nothing great but the start of basic troubleshooting is about all I've got at the moment.
2013 'speed3, silver
Stage Bro
aackthpt is offline   Reply With Quote
 Old 12-11-2017, 07:44 AM   #7
IMASA's Avatar
Ok, my problem seems to be related to the TWM full replacement. I re-read the TWM install manual and followed their adjustment steps. I had installed the TWM like 4 years ago and forgot it had its own adjustment instructions. I don't think you can just adjust the shifter as per the instruments on youtube as that was what I did and it didn't help at all.
Put it in reverse, adjust the shifter until there's a 1 mm space between the shift linkage and the shifter. This pretty much meant my shifter was adjusted all the way to the left.
My reverse lock out was fine because I had been adjusting that previously.
Now when I shift into reverse, if it doesn't go into gear, I can force it in easier than before, or if I double clutch, it usually can go in. The transmission no longer locks up gears R, 1, 2, 3, 4 when I can't get into R.
 Old 04-21-2018, 04:26 PM   #8
IMASA's Avatar
Update for anyone interested.
The problem started to get a lot worse. When the car won't get into reverse easily, it's because the clutch is dragging. If I hold the clutch in and force it into reverse and rev the engine, the car moves back. When I mention in the OP about the gears becoming difficult to shift, it's because the clutch isn't full disengaged.
Since this seems to happen only after the car is warmed up or hot, I did a lot of googling and someone mentioned they had a similar issue and it was due to a master cylinder with an internal leak. Mine was replaced 2 years ago and I have no visible leaks. My pedal feels fine and there's no air if I bleed the clutch lines. I went ahead and replaced the MC anyways and after 2 weeks of driving, I can confirm that my issue has been solved. I can throw it into reverse a lot easier now, pretty much all the time. There is the occasional time where it won't go in, but just double clutch and it's fine.
Hoyoman likes this.
Issues Shifting - Troubleshooting Help wifudude MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 03-23-2016 04:43 PM
shifting issues bdm665 MazdaSpeed 3 - Engine, Transmission & Driveline 34 02-25-2015 06:03 AM
Slave/Master cylinder Intermittent Issues Jadcock 2010 MS3 - Engine, Transmission & Driveline 3 09-10-2014 12:22 PM
Need Help: Intermittent fuel pressure issues. speed31982 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 06-30-2012 03:18 PM
shifting issues Eric_Williams 2010 MS3 - Engine, Transmission & Driveline 9 06-22-2012 08:13 PM
Page generated in 0.30129 seconds with 23 queries
