iriduim spark plugs if i get irdium spark plugs and istall them since they have a 4 prong on top do i need to gap them and or will the ecu toss a cel?/ do i getta flash ecu or unplug negative |
no.. you have some gimmick split fire type plugs... standard iridiums have a single conductor... and yes get iridium plugs (ITV20, ITV22) unless you want to change melted/foul plugs every few thousand miles |
Yes i will get the the two codes you put up there those are for? like the type i should get or recommened |
i cant understand what you are saying. get the denso ITV20 or ITV22 |
Those are not codes. They are the plug model number. the ITV20 are replacements for the stockers and the ITV22 are one step colder. Here, found this. http://www.mazdaspeedforums.org/foru...s-itv22-53859/ Some people have problems running these plugs in the winter. What mods do you have? |
| All times are GMT -7. The time now is 07:42 AM. |
