-   -   JBarone Short Shifter Plate (http://www.mazdaspeedforums.org/forum/f10/jbarone-short-shifter-plate-38800/)
JBR 11-02-2009 04:18 PM
Originally Posted by mo4130 (Post 349814)
When I installed mine the other day, even after fine tuning the shifter it sometimes feels as if its popping out of second and then when going into 3rd, it grinds. To me it feels as if even though the clutch pedal is depressed that the clutch actually hasnt released the pressure on the plates.
That's odd. Is it, or is it not popping out of 2nd?
As far as the clutch releasing, this would have no effect on that.
Help with more details and we'll get to the bottom of it. No one has reported anything similiar to what you describe.
Thanks,
Jamie
thedude 11-02-2009 08:22 PM
Mine felt like grinding a bit in 2nd (as if the clutch wasnt fully depressed as well), but once I fiddled with the adjustment and it went away. I would trying doing a little further adjustment...but in really small increments.
mo4130 11-02-2009 08:40 PM
It feels as if it literally popping out of second sometimes, im gonna fine tune it tomorrow. but other then that, a fine piece and makes my shifter feel soo much better.
N|njutsu55 11-02-2009 08:43 PM
Just installed mine this afternoon. It feels like my old STI short shifter. Good stuff. I took the car out for a grocery run and everything felt solid. I'm thinking in time I'll need to make adjustments as others are doing but for now all shifts are smooth.
Excellent product :bigok:
Thanks again Jamie.
JBR 11-02-2009 08:50 PM
When you tune your shifter take the extra time to get it right. If this does not resolve you problem we'll need to get more in depth. We can talk by phone if need be.
Thanks,
Jamie
Tim25 11-03-2009 03:47 PM
I can't PM either, too much of a noob here! I really want one of these, all the STS's on the market drop the knob height - it's supposed to be a "short SHIFT kit" not a "short KNOB kit"!
TIM
BudUMfan 11-03-2009 04:25 PM
How do you tweak it?
JBR 11-03-2009 07:36 PM
Here is a video and it explains how to tune the shifter. I have done this, I know others who have done this with my plate and with short throw shifters, and believe me my car is sweet to shift now.
Here's how to get in there. It's so easy.
1 - Remove your shift knob by rotating it counter clockwise
2 - Open the ashtray door and remove the ashtray
3 - Push the boot down and reach under the the silver ring surrounding the boot and gently pull up. The cover will pop right off.
4 - Slip the trim with the boot off the shifter and set aside
5 - Reassemble in the reverse order
When making the adjustment to the shifter take your time. Make small adjustments. The end result is well worth the extra time you take to make it shift really nice.
The video can be found here:
www.jamiesplanet.com/support
Thanks,
Jamie
thajones 11-03-2009 09:33 PM
If it's not too late, I may have to bite on this, had something similar for my old 02 Sentra SE-R and loved it (especially ease of install)
JBR 11-04-2009 05:14 AM
Never too late.
kroze 11-10-2009 07:44 AM
I just installed mine and I don't like it. 2nd gear just barely goes in and could easily popped out of gear. Also during the install I notice the shifter boot is rubbing against another cable, overtime this is going to ruin the shifter cable boot.
JBR 11-10-2009 07:59 AM
Only a couple of people have reported issues with 2nd gear. It was easily corrected.
I would recommend adjusting your shifter as described in the video found here:
As for the boot, I doubt it will ever wear out and I provide the lube for added protection.
Let me know if I can be of any help.
Thanks,
Jamie
JBR 11-12-2009 05:14 AM
The change over from paint to powder coat is complete. The new parts look very impressive.
Jamie
karl-hungus 11-12-2009 06:01 AM
my 2 cents... i've had mine on for awhile now and it's really grown on me. initially i liked the short shifts but felt uncomfortable with the engagement. the ssp has a stickier/thicker enagagement if that makes any sense. i would delay letting out the clutch thinking i wasn't in gear. eventually i overcame my engagement fears.
- i've never popped out of gear w/ the ssp
- the shifter cable boot looks fine despite the rubbing
JBR 11-12-2009 06:14 AM
Have you ever adjusted the shifter? It makes it very nice.
Jamie
karl-hungus 11-12-2009 07:46 AM
Jamie
haven't adjusted it yet. think i'm already content.
JBR 11-12-2009 07:59 AM
Yeah, I like how it feels too.
wankular 11-13-2009 11:45 PM
I've had it about a month and had no problems. The other day I had to use a little effort to get into reverse but it went in. It's weird because I checked and in reverse the plate isn't near anything. But once it's in gear I've never had it pop out. I'm not looking forward to going back to stock if I ever have to go to the dealership.
JBR 11-14-2009 04:47 AM
I wouldn't bother taking it off to go to the dealer unless your having some kind of drivetrain issue. I don't
Thanks,
Jamie
Hectik1 11-15-2009 08:49 PM
Just ordered mine in black.:hump:
akatz3 11-17-2009 11:39 AM
JBR 11-17-2009 12:03 PM
I'm sorry to hear you're not happy with it. So far you are 1 of 2, that I know of, out of well over a 100 that has serous issues with it. This is actually odd because, most of what you're saying is contrary to what everyone has said with the exception of a couple. I'd be happy to refund your money if you'd like to return it.
A heavier weight would not make it any better. It's already 5oz over the COBB weight.
Sorry,
Jamie
Hectik1 11-19-2009 04:10 PM
Got mine yesterday, installed it just right now. Took 15 minutes. Very, VERY simple install.
Took it around and wow what a difference. It does exactly what a STS does. I drove a TWM equipped car a couple months back and has the same feel and shift throw. It feels like it never really goes into gear but if you look it still has a decent amount of travel. It feels like my old Evo's shifter throws. I do have the SU bushings in addition to this mod.
I think a lot of the issues people are coming from the fact that there is such a difference in travel and feel from stock.
JBR 11-19-2009 04:59 PM
Fantastic! I'm glad you like it. Your so right about the feel. It is the same as the STS. For some reason there is a misconception that it's not the same feel.
What do you think of the finish? You have one of the first batch I PC'd. I think the black looks so great. Still looks wet.
Thanks,
Jamie
Hectik1 11-19-2009 07:53 PM
Thanks,
Jamie
The finish is amazing. Very glossy and no blemishes,etc. Top notch. Makes me ashamed that I have a stock airbox covering it up.
Did a couple quick shifts earlier....once I get the timing; look out! It works!
JBR 11-20-2009 05:12 AM
LOL...In a couple of weeks you will have relearned how to drive the car. Look out is right!:biggthumpup:
dimaxxxl 11-20-2009 08:32 AM
Ordered mine today!!! Can't wait
Hectik1 11-20-2009 09:20 PM
Pretty much relearned already. Knocked off some 2-3 and 3-4 shifts lightning quick. I seriously can't wait until next year to see what I can do at the strip.
JBR 11-21-2009 04:59 PM
Who can guess what this is? Never say never.
Thanks,
Jamie
MKTMS3 11-21-2009 05:53 PM
:scratchchin: I guess a MS6 shift plate? wernt you having trouble designing it? looks like you found your fix!?
madvillain 11-21-2009 06:23 PM
jamie, has anyone tried this yet in conjunction with a TWM shifter? my curiosity is still here.. if no one does by mid december i'd be happy to try one out for you, perhaps open up a bit more of a market for you.
JBR 11-21-2009 10:12 PM
You are correct. I've had this cooking for a while, actually since a few days after my initial failed attempt. It is gonna be a really nice piece when it's done.
Thanks,
Jamie
If your refering to the combination for the MS3 it has been tested and does not work. Well it works but the car is hardly drivable.
madvillain 11-22-2009 12:24 AM
Yeah I'm talking about the MS3, it's a no go huh? haha too short throw?
MKTMS3 11-22-2009 01:13 AM
:arms:WHAT DID I WIN?!?
JBR 11-22-2009 05:41 AM
Yeah, reduced like 80% and stiff as all get out.
akatz3 11-24-2009 11:57 AM
JBR 11-25-2009 08:03 AM
Originally Posted by akatz3 (Post 364032)
If I can return it for a refund that would be excellent.. Id really appreciate it. When will the money be refunded? and can you resend an address for me to ship it to? Thanks.. Andrew
PM Sent with shipping address. The money will be refunded as soon as I receive it.
Thanks,
Jamie
akatz3 11-25-2009 04:44 PM
HLR Element 11-25-2009 09:42 PM
Thinking of having a Christmas sale? hahah... i'll have to keep this in mind for a mod after a few other things
rfleck 07-28-2010 11:30 AM
I have the short shift plate as well installed on my 2010 and it grinds sometimes when going into 3rd. Is there any adjustments needed to eliminate this issue?
Page generated in 0.20668 seconds with 11 queries
