 Old 11-02-2009, 04:18 PM   #81
JBR
JBR's Avatar
Posts: 6,629   (View Stats)
Groans: 28
Originally Posted by mo4130 View Post
When I installed mine the other day, even after fine tuning the shifter it sometimes feels as if its popping out of second and then when going into 3rd, it grinds. To me it feels as if even though the clutch pedal is depressed that the clutch actually hasnt released the pressure on the plates.
That's odd. Is it, or is it not popping out of 2nd?
As far as the clutch releasing, this would have no effect on that.
Help with more details and we'll get to the bottom of it. No one has reported anything similiar to what you describe.
Thanks,
Jamie
JBR is offline   Reply With Quote
 Old 11-02-2009, 08:22 PM   #82
thedude's Avatar
Posts: 42   (View Stats)
thedude is a name known to allthedude is a name known to allthedude is a name known to allthedude is a name known to allthedude is a name known to allthedude is a name known to all
Mine felt like grinding a bit in 2nd (as if the clutch wasnt fully depressed as well), but once I fiddled with the adjustment and it went away. I would trying doing a little further adjustment...but in really small increments.
2007 Speed 3, Silver GT...stereo goodies, tint, MS CAI, JBarone shift plate...hopefully more to come.
thedude is offline   Reply With Quote
The Following User Says Thank You to thedude For This Useful Post:
JBR (11-02-2009)
 Old 11-02-2009, 08:40 PM   #83
mo4130's Avatar
Posts: 118   (View Stats)
mo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant future
Groaned at 13 Times in 4 Posts
It feels as if it literally popping out of second sometimes, im gonna fine tune it tomorrow. but other then that, a fine piece and makes my shifter feel soo much better.
mo4130 is offline   Reply With Quote
 Old 11-02-2009, 08:43 PM   #84
N|njutsu55's Avatar
Posts: 174   (View Stats)
N|njutsu55 is the leader of the worldN|njutsu55 is the leader of the worldN|njutsu55 is the leader of the worldN|njutsu55 is the leader of the worldN|njutsu55 is the leader of the worldN|njutsu55 is the leader of the worldN|njutsu55 is the leader of the worldN|njutsu55 is the leader of the worldN|njutsu55 is the leader of the worldN|njutsu55 is the leader of the worldN|njutsu55 is the leader of the world
Just installed mine this afternoon. It feels like my old STI short shifter. Good stuff. I took the car out for a grocery run and everything felt solid. I'm thinking in time I'll need to make adjustments as others are doing but for now all shifts are smooth.
Excellent product
Thanks again Jamie.
N|njutsu55 is offline   Reply With Quote
The Following User Says Thank You to N|njutsu55 For This Useful Post:
JBR (11-02-2009)
 Old 11-02-2009, 08:50 PM   #85
JBR
JBR's Avatar
Groans: 28
When you tune your shifter take the extra time to get it right. If this does not resolve you problem we'll need to get more in depth. We can talk by phone if need be.
Thanks,
Jamie
 Old 11-03-2009, 03:47 PM   #86
Tim25's Avatar
Posts: 7   (View Stats)
Tim25 has a spectacular aura aboutTim25 has a spectacular aura aboutTim25 has a spectacular aura about
I can't PM either, too much of a noob here! I really want one of these, all the STS's on the market drop the knob height - it's supposed to be a "short SHIFT kit" not a "short KNOB kit"!
TIM
Tim25 is offline   Reply With Quote
 Old 11-03-2009, 04:25 PM   #87
BudUMfan's Avatar
Posts: 1,204   (View Stats)
BudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the world
Groaned at 9 Times in 7 Posts
How do you tweak it?
BudUMfan is offline   Reply With Quote
 Old 11-03-2009, 07:36 PM   #88
JBR
JBR's Avatar
Groans: 28
Here is a video and it explains how to tune the shifter. I have done this, I know others who have done this with my plate and with short throw shifters, and believe me my car is sweet to shift now.
Here's how to get in there. It's so easy.
1 - Remove your shift knob by rotating it counter clockwise
2 - Open the ashtray door and remove the ashtray
3 - Push the boot down and reach under the the silver ring surrounding the boot and gently pull up. The cover will pop right off.
4 - Slip the trim with the boot off the shifter and set aside
5 - Reassemble in the reverse order
When making the adjustment to the shifter take your time. Make small adjustments. The end result is well worth the extra time you take to make it shift really nice.
The video can be found here:
www.jamiesplanet.com/support
Thanks,
Jamie
 Old 11-03-2009, 09:33 PM   #89
thajones's Avatar
Posts: 6   (View Stats)
thajones will become famous soon enough
If it's not too late, I may have to bite on this, had something similar for my old 02 Sentra SE-R and loved it (especially ease of install)
thajones is offline   Reply With Quote
 Old 11-04-2009, 05:14 AM   #90
JBR
JBR's Avatar
Groans: 28
Never too late.
 Old 11-10-2009, 07:44 AM   #91
kroze's Avatar
Posts: 29   (View Stats)
kroze will become famous soon enoughkroze will become famous soon enough
I just installed mine and I don't like it. 2nd gear just barely goes in and could easily popped out of gear. Also during the install I notice the shifter boot is rubbing against another cable, overtime this is going to ruin the shifter cable boot.
kroze is offline   Reply With Quote
 Old 11-10-2009, 07:59 AM   #92
JBR
JBR's Avatar
Groans: 28
Only a couple of people have reported issues with 2nd gear. It was easily corrected.
I would recommend adjusting your shifter as described in the video found here:
As for the boot, I doubt it will ever wear out and I provide the lube for added protection.
Let me know if I can be of any help.
Thanks,
Jamie
 Old 11-12-2009, 05:14 AM   #93
JBR
JBR's Avatar
Groans: 28
The change over from paint to powder coat is complete. The new parts look very impressive.
Jamie
 Old 11-12-2009, 06:01 AM   #94
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
my 2 cents... i've had mine on for awhile now and it's really grown on me. initially i liked the short shifts but felt uncomfortable with the engagement. the ssp has a stickier/thicker enagagement if that makes any sense. i would delay letting out the clutch thinking i wasn't in gear. eventually i overcame my engagement fears.
- i've never popped out of gear w/ the ssp
- the shifter cable boot looks fine despite the rubbing
The Following User Says Thank You to karl-hungus For This Useful Post:
JBR (11-12-2009)
 Old 11-12-2009, 06:14 AM   #95
JBR
JBR's Avatar
Groans: 28
Have you ever adjusted the shifter? It makes it very nice.
Jamie
 Old 11-12-2009, 07:46 AM   #96
patrick failman
Groans: 74
Jamie
haven't adjusted it yet. think i'm already content.
 Old 11-12-2009, 07:59 AM   #97
JBR
JBR's Avatar
Groans: 28
Yeah, I like how it feels too.
 Old 11-13-2009, 11:45 PM   #98
wankular's Avatar
Posts: 4,343   (View Stats)
I've had it about a month and had no problems. The other day I had to use a little effort to get into reverse but it went in. It's weird because I checked and in reverse the plate isn't near anything. But once it's in gear I've never had it pop out. I'm not looking forward to going back to stock if I ever have to go to the dealership.
2009 MS3 sport MGM
 Old 11-14-2009, 04:47 AM   #99
JBR
JBR's Avatar
Groans: 28
I wouldn't bother taking it off to go to the dealer unless your having some kind of drivetrain issue. I don't
Thanks,
Jamie
 Old 11-15-2009, 08:49 PM   #100
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Groaned at 9 Times in 6 Posts
Just ordered mine in black.
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
Hectik1 is offline   Reply With Quote
 Old 11-17-2009, 11:39 AM   #101
akatz3's Avatar
akatz3 has a spectacular aura aboutakatz3 has a spectacular aura aboutakatz3 has a spectacular aura about
Groaned at 27 Times in 2 Posts
akatz3 is offline   Reply With Quote
 Old 11-17-2009, 12:03 PM   #102
JBR
JBR's Avatar
Groans: 28
I'm sorry to hear you're not happy with it. So far you are 1 of 2, that I know of, out of well over a 100 that has serous issues with it. This is actually odd because, most of what you're saying is contrary to what everyone has said with the exception of a couple. I'd be happy to refund your money if you'd like to return it.
A heavier weight would not make it any better. It's already 5oz over the COBB weight.
Sorry,
Jamie
 Old 11-19-2009, 04:10 PM   #103
The Angry Goose
Hectik1's Avatar
Got mine yesterday, installed it just right now. Took 15 minutes. Very, VERY simple install.
Took it around and wow what a difference. It does exactly what a STS does. I drove a TWM equipped car a couple months back and has the same feel and shift throw. It feels like it never really goes into gear but if you look it still has a decent amount of travel. It feels like my old Evo's shifter throws. I do have the SU bushings in addition to this mod.
I think a lot of the issues people are coming from the fact that there is such a difference in travel and feel from stock.
Hector
2014 Mazda 3
1979 Mazda Rx7
The Following User Says Thank You to Hectik1 For This Useful Post:
JBR (11-20-2009)
 Old 11-19-2009, 04:59 PM   #104
JBR
JBR's Avatar
Groans: 28
Fantastic! I'm glad you like it. Your so right about the feel. It is the same as the STS. For some reason there is a misconception that it's not the same feel.
What do you think of the finish? You have one of the first batch I PC'd. I think the black looks so great. Still looks wet.
Thanks,
Jamie
The Following User Says Thank You to JBR For This Useful Post:
Hectik1 (11-19-2009)
 Old 11-19-2009, 07:53 PM   #105
The Angry Goose
Hectik1's Avatar
Thanks,
Jamie
The finish is amazing. Very glossy and no blemishes,etc. Top notch. Makes me ashamed that I have a stock airbox covering it up.
Did a couple quick shifts earlier....once I get the timing; look out! It works!
Hector
2014 Mazda 3
1979 Mazda Rx7
JBR (11-20-2009)
 Old 11-20-2009, 05:12 AM   #106
JBR
JBR's Avatar
Groans: 28
LOL...In a couple of weeks you will have relearned how to drive the car. Look out is right!
 Old 11-20-2009, 08:32 AM   #107
dimaxxxl's Avatar
Posts: 397   (View Stats)
dimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the world
Ordered mine today!!! Can't wait
2010 Mazdaspeed3 with Tech package
Mazdaspeed Intake in SRI
DDM 6000K HID's
Turbosmart Dual Port BOV
dimaxxxl is offline   Reply With Quote
The Following User Says Thank You to dimaxxxl For This Useful Post:
JBR (11-20-2009)
 Old 11-20-2009, 09:20 PM   #108
The Angry Goose
Hectik1's Avatar
Pretty much relearned already. Knocked off some 2-3 and 3-4 shifts lightning quick. I seriously can't wait until next year to see what I can do at the strip.
Hector
2014 Mazda 3
1979 Mazda Rx7
 Old 11-21-2009, 04:59 PM   #109
JBR
JBR's Avatar
Groans: 28
Who can guess what this is? Never say never.
Thanks,
Jamie
 Old 11-21-2009, 05:53 PM   #110
MKTMS3's Avatar
Posts: 321   (View Stats)
MKTMS3 is the leader of the worldMKTMS3 is the leader of the worldMKTMS3 is the leader of the worldMKTMS3 is the leader of the worldMKTMS3 is the leader of the worldMKTMS3 is the leader of the worldMKTMS3 is the leader of the worldMKTMS3 is the leader of the worldMKTMS3 is the leader of the worldMKTMS3 is the leader of the worldMKTMS3 is the leader of the world
I guess a MS6 shift plate? wernt you having trouble designing it? looks like you found your fix!?
MKTMS3 is offline   Reply With Quote
 Old 11-21-2009, 06:23 PM   #111
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
jamie, has anyone tried this yet in conjunction with a TWM shifter? my curiosity is still here.. if no one does by mid december i'd be happy to try one out for you, perhaps open up a bit more of a market for you.
 Old 11-21-2009, 10:12 PM   #112
JBR
JBR's Avatar
Groans: 28
You are correct. I've had this cooking for a while, actually since a few days after my initial failed attempt. It is gonna be a really nice piece when it's done.
Thanks,
Jamie
If your refering to the combination for the MS3 it has been tested and does not work. Well it works but the car is hardly drivable.
Last edited by JBR; 11-21-2009 at 10:14 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-22-2009, 12:24 AM   #113
madvillain's Avatar
Groans: 78
Yeah I'm talking about the MS3, it's a no go huh? haha too short throw?
 Old 11-22-2009, 01:13 AM   #114
MKTMS3's Avatar
WHAT DID I WIN?!?
 Old 11-22-2009, 05:41 AM   #115
JBR
JBR's Avatar
Groans: 28
Yeah, reduced like 80% and stiff as all get out.
 Old 11-24-2009, 11:57 AM   #116
akatz3's Avatar
Last edited by akatz3; 03-08-2010 at 03:48 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-25-2009, 08:03 AM   #117
JBR
JBR's Avatar
Groans: 28
Originally Posted by akatz3 View Post
If I can return it for a refund that would be excellent.. Id really appreciate it. When will the money be refunded? and can you resend an address for me to ship it to? Thanks.. Andrew
PM Sent with shipping address. The money will be refunded as soon as I receive it.
Thanks,
Jamie
 Old 11-25-2009, 04:44 PM   #118
akatz3's Avatar
 Old 11-25-2009, 09:42 PM   #119
HLR Element's Avatar
Posts: 2,477   (View Stats)
HLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the world
Groans: 109
Thinking of having a Christmas sale? hahah... i'll have to keep this in mind for a mod after a few other things
HLR Element is offline   Reply With Quote
 Old 07-28-2010, 11:30 AM   #120
rfleck's Avatar
Posts: 2   (View Stats)
rfleck is an unknown quantity at this point
I have the short shift plate as well installed on my 2010 and it grinds sometimes when going into 3rd. Is there any adjustments needed to eliminate this issue?
rfleck is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/jbarone-short-shifter-plate-38800/
Schaltwegverkürzung - Short Shifter Alternativen This thread Refback 04-06-2013 03:40 AM
Short shifter plate??? This thread Refback 06-15-2011 08:54 AM
Schaltwegverkrzung - Short Shifter Alternativen This thread Refback 12-15-2010 10:54 AM
Short Shift Plate - DFW Mazdas This thread Refback 12-12-2009 06:44 AM
FS: Mazdaspeed 3 Short shift plate - Beyond.ca - Car Forums This thread Refback 10-16-2009 10:47 PM
Snazzy short throw shift plate darth vader MazdaSpeed 3 - Engine, Transmission & Driveline 26 09-25-2009 03:19 PM
Page generated in 0.58729 seconds with 36 queries
