 Old 02-07-2011, 06:26 PM   #41
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Originally Posted by neotide87 View Post
That is good to know about the aluminum TIP will be louder than the silicone one from Cobb and others... Def dont need the cabin to be louder but the performance gains do outweigh that tho. Hmm more saving now for the Cobb one over the CS one I had planned.
Any pics of the install?
The CS is a great piece. You can get the entire intake for cheap.
 Old 02-07-2011, 08:31 PM   #42
Mistersix's Avatar
Posts: 2,585   (View Stats)
I personally dont have any pics of it installed. Honestly though, its pretty buried in there and not much to see.
 Old 02-08-2011, 07:02 AM   #43
Fermion's Avatar
Posts: 300   (View Stats)
Fermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the world
I should have taken some, but then again there already is a good write up in the how to section that has great pictures. Not much to see with the shroud on.
2007 MS3 Red
HKS BPV, AEM CAI, COBB TIP, Eibach Pro Springs, Black RPF1's 17x9 +45, CNT Catless DP, Racing Beat TBE, JBR SSP & Bushings
Fermion is offline   Reply With Quote
 Old 02-08-2011, 07:18 AM   #44
boostftw1's Avatar
Posts: 56   (View Stats)
boostftw1 is a splendid one to beholdboostftw1 is a splendid one to beholdboostftw1 is a splendid one to beholdboostftw1 is a splendid one to beholdboostftw1 is a splendid one to beholdboostftw1 is a splendid one to beholdboostftw1 is a splendid one to behold
another reason to run recirc is that most valves are cracked open under part throttle vacuum letting in unfiltered air , I had a small filter on my greddy for this reason. It was on a speed density car that's why it was vta.
2009 MS3 Cpe nano, dashhawk, turboxs fmic, cpe rmm, AP stage 1+ fmic, Cobb tip
boostftw1 is offline   Reply With Quote
K&N installed asherstan 2010 MS3 - Engine, Transmission & Driveline 8 06-01-2010 08:20 PM
Installed CS SRI & Tip achoman01 2010 MS3 - Engine, Transmission & Driveline 11 03-07-2010 03:13 PM
AEM CAI Installed Creatve 2010 MS3 - Engine, Transmission & Driveline 20 10-15-2009 07:05 PM
ETS 3.5 installed shucky MazdaSpeed 3/6 - Turbo Induction 7 09-09-2009 06:33 PM
CEL with CPE PnP Installed btkrausen MazdaSpeed 3/6 - ECU Computer Tuning 22 11-05-2008 11:01 AM
Page generated in 0.24576 seconds with 23 queries
