![]() | | #81 | ![]() |
![]() Join Date: Jun 2008 Location: Atlanta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 98
Groaned at 19 Times in 13 Posts
| Not Ranked : 0 score
I take exception to that remark. | |
| The Following User Says Thank You to SneakyP86 For This Useful Post: | tuners (07-11-2009) |
![]() | | #82 | ![]() |
| Not Ranked : 0 score I have a connecting rod and piston out of a working DISI engine in my hand. They both look stout and piston has carbon buildup but no indication of detonation damage. One thing jumps out about this: On the machined surface of the big end of the rod, there are some scoring marks. They usually stop or start right where the cap and main section of the rod come together. This tells me 2 things: 1. The machined side of the rod makes contact with the crank as it rotates. 2. The machining on the cap and rod is done independently such that there is an "edge" if you will when they are mated. Most blowups have either been in cruise or more commonly when shifting gears. Low load. The rotating assembly is being forced to stop or snagging or binding causing the rod to break or bend under those high pressure conditions. The question is: where is the snag or binding happening. Some say it's the BS. Perhaps. I don't like that the rods make contact with the side of the crank. After a blowup, do the rod bolts stay in place? I want to see more pictures of blown engines and the fracture points on the rods. Anyone have pics or links to these blowup pictures? |
| The Following 2 Users Say Thank You to Lex For This Useful Post: | 802MS3 (07-12-2009), djuosnteisn (07-10-2009) |
![]() | | #83 | ![]() |
| Banned ![]() Join Date: May 2008 Location: DC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 348
| Not Ranked : 0 score Rod bolts sometimes stay in place and sometimes don't ....What cylinder # rod and piston do you have? |
![]() | | #84 | ![]() |
Have you seen these same score marks Scott? Where the BS gear is on the crank, there is a step on the crank surface that meets the rod. This can have a higher chance of snagging. The piston also gets very hot as this engine had oil burn marks from the oil channel exits coming down the piston sides. | |
![]() | | #85 | ![]() |
![]() Join Date: Oct 2008 Location: New Brunswick, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 37
(Thread Starter) | Not Ranked : 0 score When I take my motor apart, I"ll take lots of pictures. |
![]() | | #86 | ![]() |
| Axle Breaker ![]() Join Date: Mar 2008 Location: Rio Rancho, NM
Rep Power: 4000 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,595
Groans: 162
| Not Ranked : 0 score Which rod did you happen to chuck?
__________________ |
![]() | | #87 | ![]() |
![]() Join Date: Aug 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 8 Times in 4 Posts
![]() | | #88 | ![]() |
![]() | | #89 | ![]() |
![]() Join Date: Jun 2008 Location: Raleigh NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
Groaned at 37 Times in 23 Posts
![]() | | #90 | ![]() |
![]() Join Date: Dec 2008 Location: Harrisburg, pa
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score well i for one know that i just ordered a BSD and windage tray. whats the worst that could happen.....you blow? there's a good possibility you will do that anyway. your damned if you do and your damned if you don't so you might as well do what gives you personal piece of mind. As for me i will feel better when the BS is out and i have a windage tray in there. |
![]() | | #91 | ![]() |
![]() Join Date: Oct 2008 Location: WEST PALM BEACH,FL
Rep Power: 0 ![]() ![]() Thanks: 1
| Not Ranked : 0 score I AM HERE TO TELL YOU THAT DOING A BALANCE SHAFT DELETE DOES NOT SAVE A MOTOR I AM LIVING PROOF I JUST BLEW UP YESTERDAY AND HAD BSD&METH NOTHING SAVES THESE PIECE OF S*&T MOTORS I HAD THE BSD FOR ABOUT 9,000MILES NOW AND IT DIDN'T HELP AT ALL I HAVE PIECES OF ALUMINUM ALL OVER!!!!!!!!!!!!!!!!!!!!!!!!! |
![]() | | #92 | ![]() |
| Fux Wit It ![]() ![]() Join Date: Mar 2008 Location: Li
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,795
Groans: 175
1. The damage was done before you got the BSD or 2. You didn't stand a chance cause you were modded.
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous | |
![]() | | #93 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
Your all the sudden proof? What was done to your car? What were you doing when it blew? o and fuck your caps lock... SHUT IT OFF | |
| The Following User Says Thank You to Deadman For This Useful Post: | 802MS3 (07-12-2009) |
![]() | | #94 | ![]() |
Groans: 162
| Not Ranked : 0 score +1 I just need the details of the blow. Don't tell me that BSD and Meth won't save your car while you drive around boosted up in 6th gear at 2000 RPM. Or that you popped off the wastegate line and was running with 30psi. There are always details involved and they do make the difference. I've got 20000 miles on my BSD that I did before I started modding anything. It sways me strongly to my side of course, but with some reasonable data I'm always open to hear that it doesn't help.
![]() | | #95 | ![]() |
![]() Join Date: Jan 2009 Location: Greenacres, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 179
| Not Ranked : 0 score agreed. details please.
__________________ Formerly: TG 06 MS6- CAI, TMIC, TBE Currently: RR 08 Evo X- SRI, UICP, TP, CBE, Tune |
![]() | | #96 | ![]() |
![]() Join Date: Jun 2008 Location: New Port Richey, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,984
Groans: 88
Having said that, I am sorry for your loss....can you list the basics...mods, rpm...you probably know the drill...
__________________ FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute JAM SESSION........US Amps (in Series w/ Stock Amp) using OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back) RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors - Acne Rear Bumper LED Reflectors | |
![]() | | #97 | ![]() |
![]() Join Date: Aug 2008 Location: jersey
Rep Power: 609 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 388
| Not Ranked : 0 score Says he was fully bolted with an sst |
![]() | | #98 | ![]() |
| Not Ranked : 0 score *patiently waiting for latest blow thread* |
![]() | | #99 | ![]() |
![]() Join Date: Jan 2009 Location: New Brunswick, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,314
Groaned at 43 Times in 28 Posts
| Not Ranked : 0 score i got blown last night
__________________ 06 MS6, Cobb AP, -TUNED on corn mix, KMD v2 fp internals, NGK Iridium IX sp, Cp-e Xcel NANO, PG tip, SU bpv, AWR rear MM, Jbarone shifter plate and bushings, ATP catted dp, Corksport catback, Altered Custom fmic, H&R springs...R.I.P. 08.5 MS3, Cobb Ap, KMD v2 fp internals, Denso ITV22 sp, Cobb Sri, TurboXS bpv, SU rear mm, SU shifter bushings, ETS TMIC, SU boost tubes, Cp-e catted dp, Enkei EKM3. |
![]() | | #100 | ![]() |
![]() Join Date: Aug 2008 Location: Kahaluu, HI
__________________ 07 Black Mica with Sunroof" 11/17/11 ZZ-SB (Spun #4 Rod Bearing @97,643 miles) "I'm back Baby" says the almighty Bender CURRENT MODS: Cobb ATR self tune+JBR WP+FMIC+BNR S3+MI+IM+CP-e EXMAN: VDyno 351hp and 331tq BEST 1320: COBB AP S2+MSCAI2+FMIC-v1.03i Best ET on 2Nov08 13.6@98mph (yeah I missed 5th gear) | |
![]() | | #101 | ![]() |
| Not Ranked : 0 score I thought I read a thread about MS3Boostin running the SST and testing some other stuff. Yes start a new thread with details, cause I am mulling over the reworked turbo route.
![]() | | #102 | ![]() |
| Not Ranked : 0 score i had cold air intake,turbo inlet,turbo back exhaust,fuel pump internals,cpe fmic,dnp manifold,ptp sst,bsd,meth,pnp standback,hks twin ignition, i had pretty much every bolt on part you can think of. I left work and as i'm driving i had some out of the ordinary knock like 2.2,then i saw 5.3 but then it all cooled off and the car was running fine i pulled into the bank shut the car off came back started the car and took of, as i was pulling out of the bank around 4k rpm in 1st gear kaboom smoke every where and right there i knew what had just happened (ZOOM ZOOM BOOM)ftl!!!!!!!!!!!!!! |
| The Following User Says Thank You to MS3BOOSTIN For This Useful Post: | djuosnteisn (07-13-2009) |
![]() | | #103 | ![]() |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3168 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score plz send Lex your busted engine
__________________ '08 CWP MS3 w/ T3 3071r |
![]() | | #104 | ![]() |
![]() Join Date: Apr 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 247
| Not Ranked : 0 score So SORRY to here Ryan...your Speed was coming along so nice.....I should of warned you the Advans increase hp/tq by 30 whp.....but anyway man, you are taking this much better than i would of and i wish you the best at putting it back together better than stock.....
__________________ Current.. 2009 BMW 135i Twin Turbo, Sedonna Red Metallic, M Sport Pkg, Premium Pkg, Cold Weather Pkg with heated seats, Xenons,M Sport steering wheel, BMW Factory Sport Exhaust..300hp, 300 Tq.. in reality..320 hp 320 tq stock SOON: BMS JB3....tune, ICarbon rear diffuser, ....all under warranty... . Past/Sold...2007 MazdaSpeed3,CP-E TBE, CAI, Advan Rs Gunmetal, TWM STS with bushings TWM Desert Eagle shift knob,, Defi Amber boost gauge, HKS BOV with CP-E flange..also tried CP-E Nano SRI (MazdaSpeed CAI, Rota TQ Hyperblack, are FOR SALE 4 months old) Last edited by lidokrantz; 07-15-2009 at 08:12 AM. |
![]() | | #105 | ![]() |
| Not Ranked : 0 score The markings here are what I am talking about. This particular rod has been bent. A non bent rod has less severe markings but these show what I am talking about. |
![]() | | #106 | ![]() |
Sorry about your situation, the more info we have the better for the community. | |
| The Following User Says Thank You to Lex For This Useful Post: | djuosnteisn (07-13-2009) |
![]() | | #107 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well I'm tearing my car apart as I type, finally located the hole, it's in the back of the block, #1 rod is currently sticking through the side of my block.... and the fuckin thing managed to take a chunk out of my oil pan ![]() My question is, has anyone tried removing the engine only (ie, leave the tranny in the car) from a mazdaspeed 3. I only have like inch and a half of movement on the accesory side.... to clear my flywheel and clutch. Wondering if anyone did this. |
![]() | | #108 | ![]() |
Please note if the rod bolts are intact. I may be interested in the rod and associated pieces from the wreckage unless you want to keep them. I can pay postage. | |
| The Following User Says Thank You to Lex For This Useful Post: | 802MS3 (07-13-2009) |
![]() | | #109 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well here's what I found when I took the undertray off... It's a big pic, for your viewing pleasure... this is looking up from beneath the car, back side of the oil pan, that's #1 wedged through the block. |
| The Following 5 Users Say Thank You to Thestaplegunkid For This Useful Post: | 06Speed6 (07-14-2009), djuosnteisn (07-13-2009), kgb (07-14-2009), Lex (07-13-2009), Meder (07-15-2009) |
![]() | | #110 | ![]() |
| Not Ranked : 0 score Thanks for the pic. Can you move the rod at all or is it fairly stuck in there? Is it possible to get a "head-on" pic of the fracture on the rod? |
![]() | | #111 | ![]() |
![]() | | #112 | ![]() |
| Not Ranked : 0 score Bump for pics |
![]() | | #113 | ![]() |
Groans: 79
| Not Ranked : 0 score Bigger bump for staplegunkid to just send the rod(s) to lex.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
![]() | | #114 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
| Not Ranked : 0 score Im not sure how much you can really learn without the entire engine, that would probably be the better route.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG |
![]() | | #115 | ![]() |
| Not Ranked : 0 score I want to start by seeing the fracture point ... it's a starting point - see if I can make anything out from it having beat the block up. I'd like to also see piston shots (or what is left) and the other rods. |
![]() | | #116 | ![]() |
![]() | | #117 | ![]() |
Groans: 175
| Not Ranked : 0 score Sounds like another closed casket funeral....
![]() | | #118 | ![]() |
(Thread Starter) | Not Ranked : 0 score So, while I was continuing the tear down last night, I took a look at my Turbo compressor. There appears to be quite a bit of shaft end play. Enough so, that I think it's been making contact with the housing, see the pic below, what do ya think? |
![]() | | #119 | ![]() |
Groans: 175
| Not Ranked : 0 score well your gonna bebleeding money id scoop up a used stocker for like 250 or theres a couple upgraded stockers floating around for like 650.
![]() | | #120 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well, I just got home from the family vacation (2 weeks in Oregon). The motor is ready to drop out of the car, but i'm back to work for the next week and a half, so there will be little updates for a while. The new motor is currently at P3 getting built. I guess I need a new turbo too.... so many new things. |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/kaboom-options-new-block-rotating-assembly-31984/ | ||||
| OMG!! 12s Si (All Motor) - Page 23 - 8th Generation Honda Civic Forum | This thread | Refback | 03-25-2010 09:05 PM | |
| OMG!! 12s Si (All Motor) - Page 21 - 8th Generation Honda Civic Forum | This thread | Refback | 03-25-2010 03:17 PM | |
| OMG!! 12s Si (All Motor) - Page 20 - 8th Generation Honda Civic Forum | This thread | Refback | 03-25-2010 03:04 PM | |
| Partial Throttle Knock Retard - Page 3 - COBB Forums | This thread | Refback | 07-13-2009 02:01 PM | |
| GM to idle 13 assembly plants for up to 9 weeks | Haltech | Automotive News | 0 | 04-23-2009 03:10 PM |
| GM to idle 13 assembly plants for up to 8 weeks | Haltech | Automotive News | 0 | 04-23-2009 02:00 PM |
| BS assembly thoughts | 06Speed6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 2 | 03-08-2009 04:24 PM |
