 Old 09-08-2009, 07:47 PM   #161
davesxx01's Avatar
Posts: 93   (View Stats)
davesxx01 is a name known to alldavesxx01 is a name known to alldavesxx01 is a name known to alldavesxx01 is a name known to alldavesxx01 is a name known to alldavesxx01 is a name known to all
Groaned at 27 Times in 4 Posts
Balance shaft pics? Does it still rotate?
Cars: 07 MS6, '10 3 GT, '05 G35 coupe.
davesxx01 is offline   Reply With Quote
 Old 09-08-2009, 07:55 PM   #162
Thestaplegunkid's Avatar
Posts: 150   (View Stats)
Thestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the world
The BS assembly was fine, untouched, and rotates. No chipped teeth on either gears.
Thestaplegunkid is offline   Reply With Quote
 Old 09-08-2009, 08:23 PM   #163
So... in the Quest for knowledge... we forge onward. This is a piece of rod I found in the oil pan.... and i've placed it where it seems to best fit.
The Following 8 Users Say Thank You to Thestaplegunkid For This Useful Post:
06Speed6 (09-11-2009), 802MS3 (09-09-2009), dirtyspeed3 (09-09-2009), djuosnteisn (09-08-2009), FreeFlyFreak (10-05-2009), Lex (09-08-2009), MicaBlackMS6 (09-13-2009), s-retire (09-12-2009)
 Old 09-09-2009, 10:35 AM   #164
davesxx01's Avatar
Wow! Hmmmm, Thats one theory that may be laid to rest.
Been studying you pics with a local engine builder who specializes in race engines only, not regular rebuilds (albeit he has never touched a DI motor, and dosen't care to) he thinks all the oil "may" have entered the IM when the piston went sideways.
He also said that without looking at all your parts in person it's just speculation!
He has lots of broken rods laying around and the twisting, shear, and snaping of yours is leading him to think off center force against piston/rotating assembly. He suggests checking all the other rods for any signs of twist/bend with the proper measuring equipment. (not eying)
 Old 09-09-2009, 10:57 AM   #165
I will say this. Any metal fatigues over time. If the extra power run on an engine is above the failure threshold at some time in its life, it will fail - it is essentially a ticking time bomb. This failure threshold follows an S-N curve similar to the one below
As you can see, the part will fail at a much lower stress as it is cycled more and more. The rod should be designed such that stock load should be below the lower point of the curve as it ages (or at least for the warranty period). This failure is due to microcracks forming and expanding over time weakening the beam.
However, the odd car that is never driven hard (or is stock) that bends rods is just a mystery because that is compressive overload (or twisting force) that shouldn't happen at a few psi. The BS is probably not locking but excessive crank endplay and clutch being pushed in under load, stuck injector, oil in combustion chamber, preignition are all possible culprits.
To learn more, read this: http://www.forging.org/FIERF/pdf/FatigueBehavior.pdf
flyrevs2 (09-09-2009)
 Old 09-09-2009, 06:05 PM   #166
Well, I remembered tonight... that way back on the "fateful" day, I picked up some pieces that were on the back of the flat bed... after we got my car off. One of those pieces was the missing chunk of connecting rod.... yes it managed to get out of the block... and the engine bay, and rattled it's way onto the tow truck's bed.
The Following 5 Users Say Thank You to Thestaplegunkid For This Useful Post:
dirtyspeed3 (09-09-2009), djuosnteisn (09-09-2009), FreeFlyFreak (10-05-2009), Lex (09-09-2009), s-retire (09-12-2009)
 Old 09-09-2009, 06:17 PM   #167
dirtyspeed3's Avatar
Posts: 78   (View Stats)
dirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond repute
Groans: 35
Great documentation!
dirtyspeed3 is offline   Reply With Quote
 Old 09-09-2009, 06:34 PM   #168
davesxx01's Avatar
Lex, excessive endplay is exactly what my local builder ask about!
Seems like a lot of people are popping while shifting!?
Again, just spectulation though!
Wouldn't that explain the twist of the rod causing abnormal stress and early failure, as you posted above?
 Old 09-09-2009, 06:57 PM   #169
What are the black dots on the fracture surface here? Are those impurities embedded into the rod?
802MS3 (09-09-2009), djuosnteisn (09-09-2009), kgb (09-09-2009)
 Old 09-09-2009, 07:59 PM   #170
bf360's Avatar
Posts: 2,069   (View Stats)
thats funny we just went over testing metal in my engineering class tonight
 Old 09-09-2009, 09:14 PM   #171
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Hahaha, lex i was just gonna ask you if you saw any manufacturing flaws in the rod, but you managed to beat me to it. We'll see if that is indeed some sort of flawed inclusion.
Staple gun kid, your kicking ass, i just want to thank you a ton for documenting this so damn well. Your helping us all out man, and imo we owe you. When you are done with your diagnostic stuff, you should at least send the rod with possible flaw to lex, and maybe more pieces. But til then, keep snapping away!
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 09-10-2009, 10:28 PM   #172
jahman's Avatar
Posts: 903   (View Stats)
jahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the world
Groaned at 9 Times in 7 Posts
Man, in a strange way I almost HOPE the rods are flawed. And we have proof. What a huge victory that would be over those fuckers. No wonder they are so tight lipped about these engine failures.
07 Mazdaspeed3
jahman is offline   Reply With Quote
 Old 09-11-2009, 04:37 AM   #173
_Toxic_'s Avatar
Posts: 643   (View Stats)
_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world
Groans: 35
Groaned at 16 Times in 11 Posts
It would be interesting to know how high the temperature gets in the engine/combustion champer in these cars? I mean to high temperatures eventually weakeness the rod and such.. just speculating..
2010 Mazda 3 MPS White Pearl Mica
K&N Typhoon SRI // Ray Catback Exhaust // Eibach Pro Kit // Tenzo R Type M 18x8 Titanium // 20% Tint all wind
_Toxic_ is offline   Reply With Quote
 Old 09-11-2009, 06:34 PM   #174
Sorry, I think it's the angle of the photo. Those are just smoothed areas, due to an impact on the surface. Not black impurities.
The Following User Says Thank You to Thestaplegunkid For This Useful Post:
 Old 09-11-2009, 08:02 PM   #175
easy's Avatar
Posts: 539   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
are the stock pistons and rods cast?
i thought i read somewhere that they are forged, but i dunno.
easy is offline   Reply With Quote
 Old 09-12-2009, 01:39 AM   #176
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
jmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the world
Groans: 162
rods are forged, pistons aren't.
jmhinkle is offline   Reply With Quote
The Following User Says Thank You to jmhinkle For This Useful Post:
06Speed6 (09-12-2009)
 Old 09-12-2009, 07:14 AM   #177
Laloosh's Avatar
Posts: 5,166   (View Stats)
Groans: 57
heres a theory posted by many from day1. The rods are weak, mystery over. Why is everyone still digging for a reason why these things blow? Name any mazda engine with strong rods.....
 Old 09-12-2009, 07:40 AM   #178
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
Well now that you solved that mystery can you please start working on the no big power one please lol.
Carry on citizens....
10.7 @ 133 auto 1G DSM
The Following User Says Thank You to Darksun280 For This Useful Post:
 Old 09-12-2009, 01:39 PM   #179
 Old 09-12-2009, 02:39 PM   #180
Laloosh's Avatar
Groans: 57
i dont even know what engine you posted.
 Old 09-12-2009, 03:55 PM   #181
easy's Avatar
Groans: 27
well isn't just only that, theories ...
im glad their is someone out there trying to confirm what causes these engine to blow.
 Old 09-12-2009, 04:10 PM   #182
BPC8
 Old 09-12-2009, 04:20 PM   #183
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Well ive waited to post to this tread, it seems to me that the piston seems to have cracked before the rod failed as evidensed by 3 of the 4 cylinders being dry and only one being wet with oil.
I am also going to bet that the pin boss area failed first and the piston stayed together until the other side slowly cracked, this is evidenced by the cracks in the crown around the boss that did not fail, the engine noise and imbalance in the weeks before, and the burning oil in the days prior to total failure.
I dont see anything that indicates that it was a heat related failure since nothing is blue, melted, or scored and the piston has no coking on the underside. I also dont see anything that indicates that the pin siezed in the boss or that it contacted the cylinder wall due to a lock type failure.
I see no obvious signs of major detonation on the piston crown since the top ring area seems to be intact.
I think it was a straight up material failure, here is a paragraph about the hypereutectic pistons that we have that I ripped from a piston mfg web site:
Modern pistons are made from a variety of aluminum alloys and are produced using two basic processes. Most OEM pistons are made from alloys which contain a large percentage of silicon and are produced by a casting process. These high silicon alloys are known as "hypereutectic" alloys due to the silicon levels above 12%. A properly designed and manufactured cast hypereutectic piston offers excellent durability, light weight, and relatively low cost. However, these alloys are brittle and thus not very tolerant of detonation. High quality forged pistons are made from alloys such as 2618. These have a much lower silicon content (<1%)and this makes them less prone to cracking under extreme conditions. In addition, the forging process itself tends to produce a tougher piston.
Nice work with all the pics.
2006 Mazdaspeed 6
802MS3 (09-13-2009), Lex (09-12-2009)
 Old 09-12-2009, 04:34 PM   #184
Realgib3's Avatar
Posts: 2,443   (View Stats)
Groans: 52
It's crazy looking at these pics because it seems to be an exact clone of my rod and piston from my motor blowing up... only I had a LOT of the pieces exit the block and sit on the splash gaurd under the engine. Also... the cylindar where the rod snapped was dry but the other 3 were filled with oil on top of the pistons...And I blew while shifting...with FFS... On a good note though I got the warranty to go through and should have my car back Monday or Tuesday!!!
The Following User Says Thank You to Realgib3 For This Useful Post:
flyrevs2 (09-13-2009)
 Old 09-12-2009, 04:40 PM   #185
Piston cracking first was my first thought as well. The remaining skirt is so beat up that I also saw the rod breaking first and free spinning and breaking/cracking the piston at the bottom of the bore, finally pushing it up, as another possibility. Especially since there are no real signs of detonation on the piston surface.
 Old 09-12-2009, 09:56 PM   #186
Speeeeeed
06Speed6's Avatar
It could be that the piston cracked which caused the rod to eventually fail due to the uneven loading, once the rod failed it smacked the piston a few times and pushed it up the bore.
I really dont think that crack in the piston crown was cause by anything other than the piston itself failing.
2006 Mazdaspeed 6
 Old 09-13-2009, 10:33 AM   #187
I took some shots of each cylinder, for comparison reasons.
 Old 09-13-2009, 06:07 PM   #188
Speeeeeed
06Speed6's Avatar
Looks pretty normal to me.
2006 Mazdaspeed 6
 Old 09-13-2009, 08:43 PM   #189
Captain
Groans: 79
...However, these alloys are brittle and thus not very tolerant of detonation...
LOL if this is the case.
"hi i'm mazda, spec ^these^ pistons and now lets develop a tune that constantly pushes our cars into detonation for minimum emissions. good bye"
I just wanted to ask a quick noob what could cause an engine to blow up question.
We brought up the topic before about how un-even flow in the IM or ports could cause un-even cylinder filling, and potential for lean cylinders and heating etc, but that hasn't been confirmed or denied.
Another question in my mind though, arising from the same scenario but not heat or afr related, is could the uneven cylinder filling cause an un-even loading on the crank from some cylinders exerting more power than others?
www.permtuning.com
Last edited by djuosnteisn; 09-14-2009 at 10:04 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-15-2009, 10:50 AM   #190
Realgib3's Avatar
Groans: 52
Interesting that I read this right after a post about MA Performance pnp intake mani.... They reduced the flow variance in the cylinders from around 26% to 5%... Not saying it's gonna be a magic cure for motors blowing but I can't help but wonder if the uneven air flow is part of the problem...
 Old 09-18-2009, 10:00 AM   #191
All located pieces of rod and piston have been packaged up and sent West to Lex. So that he can analyze them in his secret lab.
The Following 11 Users Say Thank You to Thestaplegunkid For This Useful Post:
802MS3 (09-18-2009), Chief_Wiggum (09-18-2009), Darksun280 (09-18-2009), dirtyspeed3 (09-19-2009), djuosnteisn (09-18-2009), dphm (09-21-2009), FreeFlyFreak (10-05-2009), kgb (09-18-2009), Lex (09-18-2009), phantom3 (09-22-2009), s-retire (09-18-2009)
 Old 09-25-2009, 01:59 PM   #192
Here's a shot of the spark plug from #1 (the wet one), and some other plug (the normal one)
s-retire (09-29-2009)
 Old 09-25-2009, 02:13 PM   #193
Is it just the pic or is the strap on the blown plug eaten away/smooth near the tip?
 Old 09-26-2009, 12:01 AM   #194
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
looks the same , look at the electrode in a str8 up line in relationship with the ground strap on both. prolly a lighting issue
 Old 09-26-2009, 12:11 AM   #195
I want to come back to scuffing of the bore. The cylinder that failed had the most scuffing on the exhaust side. The intake sideskirt broke off the piston when it failed. This is leading me to believe the ring locked in the bore with the piston going up. That put pressure on the intake sideskirt and on the exhaust side ring which broke along with the rod.
Can you tell me how the bore feels in the highligted area? Do you feel scuffing marks (does your fingernail catch on them?)
Grab a non broken piston ring and place it in the bore and push it down to the scuffing point. See if the ring lies flat touching the bore evenly or if there are any gaps forming between the bore and the piston ring in places indicating a bore that is not true. It may not be visible to the eye but worth a shot.
Also, I know this is a shot in the dark, but feel the bore all the way around from intake to exhaust where it is highlighted. Do you feel the bore being completely even and round?
Thanks again!
djuosnteisn (09-26-2009), s-retire (09-29-2009)
 Old 09-28-2009, 08:14 PM   #196
Pics for Lex.
The Following 4 Users Say Thank You to Thestaplegunkid For This Useful Post:
djuosnteisn (09-29-2009), FreeFlyFreak (10-05-2009), Lex (09-28-2009), s-retire (09-29-2009)
 Old 09-28-2009, 09:16 PM   #197
Sorry to be asking for so much, but is it possible to get the other rod bearings? I am seeing some wear on the edge of these bearings that seems odd.
 Old 09-28-2009, 09:48 PM   #198
Bearings from rods 3 and 4. The large scratch in #3 was sustained during handling.
The Following 2 Users Say Thank You to Thestaplegunkid For This Useful Post:
djuosnteisn (09-29-2009), s-retire (09-29-2009)
 Old 09-29-2009, 01:41 PM   #199
papajohn026's Avatar
Posts: 111   (View Stats)
papajohn026 is a name known to allpapajohn026 is a name known to allpapajohn026 is a name known to allpapajohn026 is a name known to allpapajohn026 is a name known to allpapajohn026 is a name known to all
the pauter rods are insanely beefy
papajohn026 is offline   Reply With Quote
 Old 10-02-2009, 08:50 PM   #200
Here's a couple (not so great) shots of the wrist pin end bearing. Not nearly as photogenic as his bigger brothers.
This is from rod #4
Lex (10-03-2009)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/kaboom-options-new-block-rotating-assembly-31984/
OMG!! 12s Si (All Motor) - Page 23 - 8th Generation Honda Civic Forum This thread Refback 03-25-2010 09:05 PM
OMG!! 12s Si (All Motor) - Page 21 - 8th Generation Honda Civic Forum This thread Refback 03-25-2010 03:17 PM
OMG!! 12s Si (All Motor) - Page 20 - 8th Generation Honda Civic Forum This thread Refback 03-25-2010 03:04 PM
Partial Throttle Knock Retard - Page 3 - COBB Forums This thread Refback 07-13-2009 02:01 PM
GM to idle 13 assembly plants for up to 9 weeks Haltech Automotive News 0 04-23-2009 03:10 PM
GM to idle 13 assembly plants for up to 8 weeks Haltech Automotive News 0 04-23-2009 02:00 PM
BS assembly thoughts 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 2 03-08-2009 04:24 PM
Page generated in 0.60573 seconds with 36 queries
