 Old 10-03-2009, 12:40 AM   #201
Thanks for the photos.
I have completed the analysis of the chicken and the egg with your motor - in other words what went first. The answers is the rod was bent for some time. The motor ran this way and eventually the piston ring got snatched on the bore, locked the piston in, rod twisted, broke, and hammered its way out of the block. I will have a more descriptive doc on how this was arrived at within the next few days.
The next questions are - why was the rod bent and are any of the other bent? Was there an issue with the rotating assembly as a whole?
The picture above shows me that there is uneven wear on the wrist pin bearing. I saw uneven wear on all your rod bearings. This means that rod #4 is either bent as well, or the combustion is happening off centre, or that the entire rotating assembly is offset.
Can you please look at the rod for any bends (along any axis) and take a picture?
Can you please grab pictures of the rod lying flat on a table from both sides (I want to see if it contacts the counterweights on one side more than another?
Can you please grab a picture of the wristpin showing where the wear marks are (from rod bushing and piston)? The wear marks are likely offset from centre on the wristpin.
Can you please grab a picture showing the underside of the piston? Looking for possible rod/piston contact.
If possible, I would like to take a look at all the rods/pistons/bearings first hand, and will gladly pay shipping for them both ways (and of course return them) if you can get them to a post office.
Thanks!
The Following 6 Users Say Thank You to Lex For This Useful Post:
802MS3 (10-05-2009), bani (11-28-2009), FreeFlyFreak (10-05-2009), kgb (10-03-2009), s-retire (10-04-2009), spnkr21 (10-03-2009)
 Old 10-03-2009, 12:17 PM   #202
Here is a diagram showing how the injector spray pattern was on your piston (in red). The blue shows how the injector spray pattern SHOULD have been.
This means the piston was rotated in the bore for at least a little while or that the injector had an issue.
802MS3 (10-05-2009), bani (11-28-2009), dirtyspeed3 (10-03-2009), kgb (10-03-2009), s-retire (10-04-2009), spnkr21 (10-03-2009)
 Old 10-04-2009, 10:50 PM   #203
A small update on this. From the information and pictures posted, it appears the entire rotating assembly was misaligned in this motor. From the rod bearing wear spots (Bearing reading experts needed), to the wrist pin and small end bearing wear.
There is likely a manufacturing/assembly error on Mazda's part in this one and that this motor would have failed one way or another. If you have the ability I would take this up with Mazda.
I know I have promised a full report and it is coming, just been too busy to compile it. I am going to make sure the report is thorough and is posted in as many forums as possible. I would not be surprised if a lot of these "strange" failures are indeed manufacturing flaws.
802MS3 (10-05-2009), bani (11-28-2009), djuosnteisn (10-05-2009), Frequentflyer (10-17-2009), kgb (10-06-2009), xSP33Dx3x (11-26-2009)
 Old 10-04-2009, 11:02 PM   #204
Dino V's Avatar
Posts: 134   (View Stats)
Dino V is a splendid one to beholdDino V is a splendid one to beholdDino V is a splendid one to beholdDino V is a splendid one to beholdDino V is a splendid one to beholdDino V is a splendid one to beholdDino V is a splendid one to beholdDino V is a splendid one to behold
Sorry to hear!
Dino V is offline   Reply With Quote
 Old 10-05-2009, 12:09 PM   #205
Thestaplegunkid's Avatar
Posts: 150   (View Stats)
Thestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the world
Shots of the main bearings, from the girdle side.
Thestaplegunkid is offline   Reply With Quote
The Following User Says Thank You to Thestaplegunkid For This Useful Post:
Lex (10-05-2009)
 Old 10-05-2009, 12:12 PM   #206
papajohn026's Avatar
Posts: 111   (View Stats)
papajohn026 is a name known to allpapajohn026 is a name known to allpapajohn026 is a name known to allpapajohn026 is a name known to allpapajohn026 is a name known to allpapajohn026 is a name known to all
Originally Posted by Thestaplegunkid View Post
So... in the Quest for knowledge... we forge onward. This is a piece of rod I found in the oil pan.... and i've placed it where it seems to best fit.
oh my goodness. this is ugly
papajohn026 is offline   Reply With Quote
 Old 10-05-2009, 12:14 PM   #207
Thanks Ryan! Do you still have the parts listed below and can grabs shots of these while you're with the motor?
- Can you please look at the other rods for any bends (along any axis) and take a picture?
- Can you please grab pictures of rod #4 lying flat on a table from both sides (I want to see if it contacts the counterweights on one side more than another?
- Can you please grab a picture of the wristpin for rod #4 showing where the wear marks are (from rod bushing and piston)? The wear marks are likely offset from centre on the wristpin.
- Can you please grab a picture showing the underside of the piston #4? Looking for possible rod/piston contact. Do any other pistons have marks of the rod rubbing on their underside?
 Old 10-05-2009, 02:47 PM   #208
Here's the results of laying rod number 4 on a straight edge. Rods 2 and 3 checked out fine.
Also, see attached rod #4 wrist pin
The Following 3 Users Say Thank You to Thestaplegunkid For This Useful Post:
djuosnteisn (10-05-2009), Lex (10-05-2009), s-retire (10-06-2009)
 Old 10-05-2009, 02:58 PM   #209
I can't tell from the rod pics - is #4 bent?
 Old 10-05-2009, 03:07 PM   #210
Yeah, on the flat of the wrist pin end... on one side, light comes through from the right, on the other side, light can be seen shining through on the left. Indicating a bend in the rod, the other rods 2 and 3 lay perfectly flat on both sides.
The Following 2 Users Say Thank You to Thestaplegunkid For This Useful Post:
djuosnteisn (10-05-2009), s-retire (10-06-2009)
 Old 10-05-2009, 04:53 PM   #211
Was the #4 rod touching the underside of the piston on the small end?
How do the other wrist pins look from rods 2 and 3? #4 shows uneven wear. Do the other wrist pins also show uneven wear?
 Old 10-05-2009, 09:33 PM   #212
3 wrist pins, from left to right, we have 4-3-2
And the underside of piston 4, with highlighted rod to piston contact marks.
Pistons 2 and 3 were clean.
 Old 10-05-2009, 09:46 PM   #213
Thanks for all the pictures; they've been a great help and I hope an eye opener for the community
So after all, the random blowup was some time coming. I wonder how long it ran with 2 bent rods until a simple shift did it in. The mystery of blowing up coming out of a parking lot is solved. All these cars that blow have prior damage and the pistons finally lock.
I know you mentioned you had some knock - how much knock did you have? Any during WOT? Part throttle knock?
How long was the AP tune on the car for and for how long was the car modified?
The clean oil in the intake manifold is still a little strange to me.
 Old 10-05-2009, 10:04 PM   #214
-Last few runs I had the car on.... I got up to 4 knock under WOT, It would also give me Part throttle knock up to 4KR
-noticed my fuel pressure falling to 1200 (was just gonna order internals)
-The tune had been on for 500 kms
-First mods were Cobb SRI, installed around 10K kms, then gradual addition of other mods, the last two being, the AP at around 30K kms, and the FMIC around 35K kms, and KaBoom around 39K kms.
-Oh, the clean oil in the intake, wasn't so clean when I drained it out. It appeared to have some antifreeze mixed in, so I believe it came out after the accident.
 Old 10-05-2009, 10:06 PM   #215
Great info, thanks Ryan. The oil in the intake did most likely come out during the incident.
 Old 10-05-2009, 10:38 PM   #216
Piston 4
 Old 10-06-2009, 08:48 AM   #217
^ Piston #4 also has an uneven spray pattern indicating it was likely rotated in the bore.
 Old 10-17-2009, 02:29 AM   #218
Ryan, if you could get the last few pics of #2 and #3 small end rod bearings that would be great!
 Old 10-17-2009, 05:51 AM   #219
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
csi msf. find the killer, lex!
 Old 10-17-2009, 11:58 AM   #220
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
Wow. It would be something if this is a manufacturing/assembly flaw and it wouldn't be the first time Mazda has done this. Miata's had this problem in 99-00 with many of the most reliable motors Mazda had ever built grenading for no reason, mainly during shifting because of excessive endplay.
 Old 10-17-2009, 12:05 PM   #221
Lex I'll have these for you by tonight, putting a roof on the house atm.
 Old 10-17-2009, 12:18 PM   #222
Thanks Ryan, good luck with the roof!
 Old 10-17-2009, 05:17 PM   #223
Alright, here they be.
 Old 10-17-2009, 05:58 PM   #224
Thanks Ryan - correct me if I'm wrong but the wear looks even across the width of these bearings.
 Old 10-17-2009, 06:13 PM   #225
That is correct Lex.
 Old 10-17-2009, 08:58 PM   #226
Bonafide_Spd3's Avatar
Posts: 344   (View Stats)
Bonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond repute
Damn this is crazy, sucks its been happening. Hope you find out the cause man, thanks for all the pictures and research
2007 Cosmic Blue Speed3
[ MS CAI w/Straightener] [Cobb AP] [ RPMC TI ] [ FORGE BPV ] [ SU RP ] [ PG FMIC ] [Denso Plugs] [Trz MM] [ TWM SS&Bushings ] [ Greddy TT ] [ Defi Boost Gauge ]
Not going to install-Weapon R catch can. Piss on doing that install
Bonafide_Spd3 is offline   Reply With Quote
 Old 11-25-2009, 04:51 PM   #227
Alright, well just for an update. The new motor fired up today!
No issues or concerns.
Updates later
djuosnteisn (11-25-2009)
 Old 11-25-2009, 05:37 PM   #228
lidokrantz's Avatar
Posts: 663   (View Stats)
lidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the world
Super!!! Man, i wish i had the smarts and the time to do something like this myself...very happy for ya and i hope all works as planned.. keep us updated on how the car runs.
Current.. 2009 BMW 135i Twin Turbo, Sedonna Red Metallic, M Sport Pkg, Premium Pkg, Cold Weather Pkg with heated seats, Xenons,M Sport steering wheel, BMW Factory Sport Exhaust..300hp, 300 Tq.. in reality..320 hp 320 tq stock
SOON: BMS JB3....tune, ICarbon rear diffuser, ....all under warranty...
Past/Sold...2007 MazdaSpeed3,CP-E TBE, CAI, Advan Rs Gunmetal, TWM STS with bushings TWM Desert Eagle shift knob,, Defi Amber boost gauge, HKS BOV with CP-E flange..also tried CP-E Nano SRI (MazdaSpeed CAI, Rota TQ Hyperblack, are FOR SALE 4 months old)
lidokrantz is offline   Reply With Quote
 Old 11-25-2009, 10:31 PM   #229
Yeah, It was the nicest sound I've heard in a long time
One thing, I know people have mentioned their upgraded CDFP's being louder than stock, and this is definetly the case with my KMD V2. there's an audible clacking sound when you hit the gas, and I got my scope out, and it's definetly the pump. Just wondering if others found this.
Here's a pic of her after her first trip out of the garage and down to the ramps (to check for leaks)
Lex (11-25-2009), MazMusic (11-26-2009)
 Old 11-25-2009, 10:36 PM   #230
c2hig's Avatar
Posts: 5   (View Stats)
c2hig is an unknown quantity at this point
hope I never have to be posting a thread like this
c2hig is offline   Reply With Quote
 Old 11-26-2009, 01:02 AM   #231
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
LOL at those ramps! Absolutely genius.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
DaleNixon (11-30-2009)
 Old 11-26-2009, 03:18 PM   #232
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Nice work bro, glad your back on the road.
2006 Mazdaspeed 6
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/kaboom-options-new-block-rotating-assembly-31984/
OMG!! 12s Si (All Motor) - Page 23 - 8th Generation Honda Civic Forum This thread Refback 03-25-2010 09:05 PM
OMG!! 12s Si (All Motor) - Page 21 - 8th Generation Honda Civic Forum This thread Refback 03-25-2010 03:17 PM
OMG!! 12s Si (All Motor) - Page 20 - 8th Generation Honda Civic Forum This thread Refback 03-25-2010 03:04 PM
Partial Throttle Knock Retard - Page 3 - COBB Forums This thread Refback 07-13-2009 02:01 PM
GM to idle 13 assembly plants for up to 9 weeks Haltech Automotive News 0 04-23-2009 03:10 PM
GM to idle 13 assembly plants for up to 8 weeks Haltech Automotive News 0 04-23-2009 02:00 PM
BS assembly thoughts 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 2 03-08-2009 04:24 PM
Page generated in 0.53431 seconds with 31 queries
