 Old 03-16-2014, 02:53 PM   #1
Roofis119's Avatar
Posts: 22   (View Stats)
Roofis119 will become famous soon enoughRoofis119 will become famous soon enough
Groaned at 9 Times in 2 Posts
Default leaking break fluid from clutch line need help
My clutch line is leaking from the coupling that connects the metal clutch line from the rubber clutch Line. I took it apart and there is a small orange rubber o ring that is ripped. Mazda dose not sell it separately and was wondering where I can buy it please help
07 MS3 true Red
Injen cai
Dual port bov
3" Corksport cbe
Greddy tt
Roofis119 is offline   Reply With Quote
 Old 03-16-2014, 04:16 PM   #2
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
*brake
I hugged rfinkle2
 Old 03-16-2014, 04:19 PM   #3
Roofis119's Avatar
Thanks for the help*
07 MS3 true Red
Injen cai
Dual port bov
3" Corksport cbe
Greddy tt
 Old 03-17-2014, 10:35 AM   #4
mach69's Avatar
Posts: 79   (View Stats)
mach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond repute
First things first, Donate Brownie.
Don't you love it when the dealer makes you buy unnecessary parts for the one you want?
The problem with Brake fluid on O-rings is some are incompatible. You need an O-ring made of a certain material. Your traditional O-ring is made of Nitrile Rubber. The brake fluid would cause this type of material to swell up. This causes a terrible seal and would continue to leak.
What you need is an EPDM (Ethylene Propylene) O-ring. You didn't specify the size of the O-ring and I have no idea what it is, but amazon has a nice chart for EPDM o-rings (Link below). If you have a caliper, measure the dimensions you need and plug it into this chart. Good luck.
EPDM O-Ring, 70A Durometer, Black: Amazon.com: Industrial & ScientificEPDM O-Ring, 70A Durometer, Black: Amazon.com: Industrial & Scientific
2008 Mazdaspeed 3 - True Red
Engine: CPE Nano, CPE TIP, CPE TMIC, CPE HPFP, CS BeCuse Injector Seals, SU Boost Tubes, Forge BPV V1, ITV-22, AQ Motorsports DP, Dashhawk, Spin-on Oil filter conversion, Saikou Michi OCC, Cobb AP Self-tuned, VTCS Delete, EGR Delete, TB Coolant Bypass, DFDD VVT, 3 bar map
Drivetrain: Southbend Clutch Stage 3 DD, JBR Short Shift Plate, SU Shifter Bushings, CPE Stage 2 RMM, CPE TMM
Suspension: Koni Yellows, Eibach Springs, Cobb RSB, MOOG Swaybar Endlinks, Energy Suspension FSB Bushings
mach69 is offline   Reply With Quote
 Old 03-17-2014, 10:37 AM   #5
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Dizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the world
Is the o ring in the metal line or rubber? You can buy a ss line to replace the rubber one if its in that
Sent from my HTC One using Tapatalk
Dizzy Turbo is offline   Reply With Quote
 Old 03-20-2014, 11:37 PM   #6
Absolut1l's Avatar
Posts: 170   (View Stats)
Absolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond repute
I agree with Dizzy. Just buy a steel braided clutch line. The rubber line is prone to failure.
Mods: Can't mod a car that's always broken!
Absolut1l is offline   Reply With Quote
Clutch stuck to floor, hydraulic fluid leaking Nate010 MazdaSpeed 3 - Engine, Transmission & Driveline 1 12-10-2013 06:45 PM
Leaking transaxle fluid? kyle53 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 08-18-2013 04:40 PM
rear shock leaking fluid.. SharkDiver MazdaSpeed 3/6 - Suspension & Brakes 19 02-09-2012 06:08 AM
Leaking clutch line bova MazdaSpeed 6 - Engine, Transmission & Driveline 3 12-23-2011 10:09 PM
Brake fluid reservoir leaking? Hank3 MazdaSpeed 3/6 - Suspension & Brakes 4 08-11-2009 06:37 AM
Page generated in 0.28927 seconds with 24 queries
