![]() | | #1 | ![]() |
(Thread Starter) | Not Ranked : 0 score The purpose of the DMF is to dampen vibrations from the engine going into the transmission and chassis. It also lessens loads on the transmission itself and reduces synchro wear. All good things so far. The downside is that the springs get soft over time and sometimes fail altogether. I've had a noisy (what I thought was) throwout bearing since new and recently it's becomes worse. When disengaging a gear quickly under load such as pushing in the clutch when backing out of the driveway or after doing a slight burnout at the track, there is a distinct rattling from either the throwout or the DMF that dies out after a second or 2. We keep on blaming the throwout bearings in these cars for rattles but the DMF might also be to blame for the rattles and noises in the transmission area. As they age, we will see more failures and it would be a good idea to list some of the symptoms of failure and failure modes so that people know what to look for. Our flywheels are made by LuK. For those of you that have swapped clutches, was the DMF failed? Was it seized? Was it loose? LuK —|—Products —|—Dual Mass Flywheel (DMF)
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following 9 Users Say Thank You to Lex For This Useful Post: | 86AmishMs3 (03-01-2014), Code Monkey (02-18-2014), CosmicArkie (02-19-2014), cshunter (10-11-2013), helmetface (10-10-2013), Mauro_Penguin (10-10-2013), nycMS3 (10-11-2013), Pointless (10-10-2013), snailD (10-10-2013) |
| Not Ranked : 0 score My dual-mass flywheel was fine when I pulled it out at ~70K miles. Loose, maybe, but every one I've pulled has felt loose, so I don't know if that's due to wear or that's how they are new.
__________________ |
| The Following 5 Users Say Thank You to silvapain For This Useful Post: | El_Diablo (10-10-2013), Lex (10-10-2013), Mauro_Penguin (10-10-2013), Pointless (10-10-2013), snailD (10-10-2013) |
(Thread Starter) | Not Ranked : 0 score Was your transmission noisy when engaging and disengaging the clutch? How was the throwout?
![]() | | #4 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
| Not Ranked : 0 score My neighbor works for LUK (he's an engineer). Any data that you might need that I may be able to get?
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
| The Following User Says Thank You to El_Diablo For This Useful Post: | captain slow (10-10-2013) |
![]() | | #5 | ![]() |
I still have my OE clutch, so if there are any pictures or videos you like me to take of it let me know.
__________________ | |
| The Following 3 Users Say Thank You to silvapain For This Useful Post: |
![]() | | #6 | ![]() |
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 8624 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,845
| Not Ranked : 0 score So along this line of thinking a single mass fw might be accountable accelerated synchro wear. Sent from fastest Ko4 Pu.
__________________ Nator is what it does. |
| The Following User Says Thank You to kritz For This Useful Post: | El_Diablo (10-10-2013) |
![]() | | #7 | ![]() |
| Not Ranked : 0 score I'm not sure how a DM or SM flywheel would impact synchro wear, because when the synchros are doing their job (shifting gears) the clutch is disengaged and the flywheel is not acting on the transmission. @Lex; what are your thoughts?
| The Following User Says Thank You to silvapain For This Useful Post: | El_Diablo (10-10-2013) |
![]() | | #8 | ![]() |
(Thread Starter) | Not Ranked : 0 score I would be interested if they rate the flywheels for torque load and longevity. Since it has a spring and moving parts there is a wear as well as a load factor. Ask him if this is the case. They probably have an internals part number for our FW, let me know if you need the Mazda specific one.
![]() | | #9 | ![]() |
| Not Ranked : 0 score @Smelson; I had no issues with the stock clutch, besides it's ability to hold torque once things got hot. But I can confirm the regular act lightweight flywheel makes plenty of noise with the clutch out in neutral. Sounds almost like a ducati Zigatapatalka
| The Following 6 Users Say Thank You to Ziggo For This Useful Post: | Goodrich27 (12-17-2013), Justin@Freektune (06-04-2014), Nliiitend1 (10-10-2013), redneck4Christ (11-15-2015), silvapain (10-10-2013), Sterling (11-30-2013) |
![]() | | #10 | ![]() |
Has anyone used an aftermarket clutch with the OEM DMF?
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. Last edited by Lex; 10-10-2013 at 06:41 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #11 | ![]() |
![]() Join Date: May 2009 Location: Little Neck, NY
Rep Power: 3771 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,108
Groans: 326
| Not Ranked : 0 score the springs in mine were shot a local shop rebuilt it with better springs, it requires special tooling but it can be done |
| The Following 4 Users Say Thank You to 8.5MS3 For This Useful Post: | Easter Bunny (02-27-2014), El_Diablo (10-10-2013), Mauro_Penguin (10-10-2013), silvapain (10-10-2013) |
![]() | | #12 | ![]() |
Groans: 769
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson | |
![]() | | #13 | ![]() |
![]() Join Date: Sep 2011 Location: Birmingham AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 251
| Not Ranked : 0 score When I did mine in my ms6 @ 92k miles it was shot to hell, If I can find it I have a video of it just clunking around when we moved it by hand. A black disk fell out of it in tiny piece and there was a lot of black dust, not just from the clutch. And it felt like there was no springs in it. When it went bad the signs where, grinding of gears, it was really hard on 2nd gear. And in about one week you could not drive it, to save your life. |
| The Following User Says Thank You to Tenchix For This Useful Post: | silvapain (10-10-2013) |
![]() | | #14 | ![]() |
| Not Ranked : 0 score And I remember every time I put the clutch in you could hear it chattering away. |
![]() | | #15 | ![]() |
![]() Join Date: Nov 2010 Location: Manchester, England
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,709
Groans: 49
Groaned at 34 Times in 25 Posts
| Not Ranked : 0 score Using an organic compound clutch I bought from eagle motorsports before they got banned from here. I'm on 75k now, about 20k with the em clutch. All feels well at the minute.
__________________ Tuned with by ![]() K1 Rods//Wiseco Pistons//CX Racing FMIC//JBR Widepath Intake//Custom 3" TBE//Grimmspeed EBCS//Forge BPV//JBR SSP//JBR RSB//JBR Side Mounts//ISC-N! coilovers//JBR BSD and Baffle//Sure TIG Set//Sure R3 RMM//KMD Internals//XS Power Exhaust Manifold//P&P Intake Manifold//Fidanza Flywheel//EM Organic Compound Clutch//GTX3071//DVC30 Meth Kit//3 Gauge Pod.....415WHP....so far!! |
![]() | | #16 | ![]() |
| Not Ranked : 0 score When the clutch pedal is pressed, the flywheel and pressure plate rotate with the engine and only the friction disc rotates with the transmission.
| The Following User Says Thank You to silvapain For This Useful Post: | Lex (10-10-2013) |
![]() | | #17 | ![]() |
The lighter assembly is the clutch itself. Ideally by moving the dampening springs to the flywheel the clutch disc can be made either without the springs or with much smaller ones since it doesn't have to dampen nearly as much of the torque shock. Our clutch does have springs - not sure if it would be lighter should the flywheel be solid.
| The Following 4 Users Say Thank You to Lex For This Useful Post: |
![]() | | #18 | ![]() |
![]() Join Date: Sep 2012 Location: Farmington, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
Groaned at 4 Times in 2 Posts
| Not Ranked : 0 score I actually have my old clutch, pp, and DMF from the recent swap. I'll get the Canon out tomorrow to take pics. The disk and flywheel are actually in pretty good shape. Still noticeable grooves on the disc, no heat spots. My rear main however was toast and there was oil all over the inside of the bell housing. and @Lex; good call on the recommendation. Loving it so far, but still in break in mode.
__________________ Cobb AP // JBR 88d Trilogy // JBR 3.5" WP // JBR RSB // MS Coils // SPC Camber Arms // Autotech Internals // eBay Catless DP // ACT-ZX5-HDSS // TRM C3 17x9 +48 // 255/40/17 NT05 [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to Bobforapples For This Useful Post: | Lex (02-18-2014) |
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
| Not Ranked : 0 score I've always wondered if my clutch feel/shifting issues are related to my dual mass flywheel, but obviously that involves taking it out to diagnose. Lol. A service advisor at Mazda told me that there are rubber parts in the dual mass flywheel that actually melt/fail. Is there any truth to that? I've never seen pictures of our OEM flywheel.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
![]() | | #21 | ![]() |
| Not Ranked : 0 score Yep that actually died before we could even test drive. Ended up having to wait another 4 days to get the red boot one, and then almost had to wait again because of the seal on the hard line.
![]() | | #22 | ![]() |
![]() Join Date: May 2009 Location: Orange County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 806
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score So what's the consensus of this board when it comes to the DMF? Are we finding it's generally worn to the point it needs springs or a full replacement? Or are some of you just swapping the PP/disc with decent results? I think we all agree it's going to vary by user/environment. Just trying to get an idea of what the typical results have been to date. |
| The Following User Says Thank You to Design For This Useful Post: | Nliiitend1 (02-27-2014) |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score I think I would go by mileage and how worn the friction surface is. That and how willing are you to do the job twice.
| The Following 2 Users Say Thank You to Lex For This Useful Post: | Design (02-27-2014), Nliiitend1 (02-27-2014) |
![]() | | #24 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
Groans: 67
| Not Ranked : 0 score I do sort of wonder how good of an indicator the condition of the friction surface is for the purpose of assessing DM flywheel wear (when it comes to the springs and internal mechanism at play)... I'm not quite sure what I'm going to do when the time comes to replace my clutch... Like most folks, I don't really want to spend ~$1200 on a new OEM flywheel, but I'm also not sure I'd like a Fidanza and I don't know that I'd reuse the original once it's approaching 100K miles of hard use...
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
![]() | | #25 | ![]() |
| Not Ranked : 0 score My experience with BMW tells me it's hit or miss. As a general rule, anything with 100K or more should get replaced. But at nearly 1K, risking another 6 hrs/$500 in labor makes it "almost" worth it. And to the above point, there really is no suitable heavyweight replacement for our cars. |
![]() | | #26 | ![]() |
Groans: 47
| Not Ranked : 0 score There should be some specs in the shop manual for the the amount of play in the springs, to indicate reuse/replace. However, if I end up doing my clutch, I will not even consider reusing mine or purchasing a new OEM DMF. ACT Streetlite is steel and only a few pounds lighter than stock, so you won't end up with as much chatter as going with a lighter/aluminum flywheel. There will be some chatter and possibly more vibration, but it's kind of a moot point when a lot of us are fully mounted anyways. DMFs really only matter if you're going for as little NVH as possible, which is why OEMs use them. With all of the people running aftermarket flywheels on here, I'd think we would see more transmission issues if it was really significantly reducing drivetrain stress. In fact, a bad DMF will probably be even worse than an aftermarket SMF.
| The Following User Says Thank You to sidekick For This Useful Post: | redneck4Christ (11-15-2015) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score The lack of damping on the SMF is enough to steer me away. The clutch face on these cars is non-linear enough without introducing further rigidity. And the extra 10% in weight makes a world of difference when calculating inertia at 1K RPMs or more. I imagine slightly higher RPMs would get around many of the issues. But for a typical DD they are often more headache than they're worth. |
![]() | | #28 | ![]() |
Groans: 47
I used a SMF to replace the OEM DMF in my old GTI, it was about half the weight and aluminum. It was noticeable when leaving a dead stop, but other than that, it wasn't noticeable. It just meant feathering/slipping the clutch a little more. I can't imagine a 5lb drop is going to make a significant difference. Especially considering these engines make about 3x as much torque as my GTI did.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() | |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score On older Porsches replacing the DMF with a SMF caused some crank failures due to the lack of dampening but I haven't seen that here.
| The Following User Says Thank You to Lex For This Useful Post: | sidekick (02-28-2014) |
![]() | | #30 | ![]() |
Groans: 47
| Not Ranked : 0 score It's definitely possible, I just think we would have seen some failures by now with all of the people running super light flywheels and beating the shit out of their cars. Lol.
![]() | | #31 | ![]() |
The writeup in this thread mimics my own conversations with fellow 3 series owners (though a bit more technical). Most agree if you can afford it, get the DMF for a DD: OEM Dual Mass Flywheel Or Exedy Single Mass Flywheel - MINI Cooper Forum To your point, I completely agree that a steel SMF is a MUCH better option over aluminum. | |
![]() | | #32 | ![]() |
Groans: 47
Streetlite: 21.4lbs The prolite is over 10lbs lighter than stock, IIRC the stock DMF is somewhere between 26-30lbs. "Forgiveness" in a clutch setup is generally related to how aggressive the clutch material is and the clamping force of the pressure plate.
![]() | | #33 | ![]() |
| Not Ranked : 0 score Yeah I'm aware of the weight difference but wasn't aware it was a whole 10 lbs lol. OEM Flywheel is just over 26 lbs (opposed to 30). And for some reason I thought streetlight was more like 23-24. Guess not? ![]() I still think any difference - however small - is going to impact driveability in stop & go. On the Civic EM1, many of my peers went with the Exedy HF01 flywheel while I stuck with Exedy OEM (Daikin). It was only a 15-20% delta. But matched with low end torque from the B16, it was tough to engage from a stop without chatter. Our cars aren't much better outside boost. We need the inertia, IMHO. |
![]() | | #34 | ![]() |
| Not Ranked : 0 score FWIW, with @Lex; recommendation for the ACT Street kit and street lite flywheel, I've been very impressed. It was noticeably stiffer the first 100miles, but now @ 500mi the pressure, release point, and engagement feel near to stock. Now my leg could be used to it, but it engages and slips exactly like OEM to me. There is chatter, but it's only noticeable when engine braking. I don't hear it cruising w/o music. Only a 88a RMM atm.
| The Following User Says Thank You to Bobforapples For This Useful Post: | Design (03-03-2014) |
![]() | | #35 | ![]() |
![]() Join Date: Jun 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score I had mine fail at 70k. The symptoms were huge vibration (imagine vibration bad enough that you couldn't see clearly in any of the mirrors/dash moving up and down ~1") It was startling. I had the clutch replaced at the same time but it was in relatively good condition. I Autox'd the car very frequently and wonder if the extended high rpm/bouncing redline activities led to the failure.
__________________ www.Hangoverracingteam.com www.spokes.org |
![]() | | #36 | ![]() |
Groans: 47
![]() | | #37 | ![]() |
![]() Join Date: Apr 2012 Location: Charlotte, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 646
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score I have the ACT Street Disk and Prolite Flywheel. My driving style has changed but it isn't like driving a triple disk or anything. You lose revs between shifts much quicker and it doesn't care for reverse with the clutch fully engaged. But otherwise it is perfectly steetable. The car sounds like a mix between a tractor and a dry clutch Ducati at idle with the clutch out, because racecar. I have all my stock setup, Ill take a look at the stock flywheel and see if anything is amiss.
__________________ 1999 Cosmos M3 turning bits and more better suck, squish, bang, and blow FREEK'D 2012 Liquid Silver Genpu-sold We were young, and we were fearless and, after all, nobody had ever told us young engineers that we couldn't successfully land humans on another planet. So we did it. Last edited by smr87; 03-12-2014 at 10:47 PM. |
![]() | | #38 | ![]() |
__________________ www.Hangoverracingteam.com www.spokes.org | |
| The Following User Says Thank You to toadatx For This Useful Post: | sidekick (03-16-2014) |
![]() | | #39 | ![]() |
![]() Join Date: Jan 2013 Location: Corvallis, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
| Not Ranked : 0 score Not sure how much this will help but... The day after I bought my MS6 with 72k miles, the clutch went out. I never got a chance to look at the DMF.. But I saw the PP and it was literally broken/cracked. The dealer replaced it for free, so they got to choose what clutch to put in it. They chose a Clutchmasters FX100 kit that came with a lightweight aluminum flywheel. 10,000 miles later, my car is in the shop getting a new transmission and clutch. Before I took it to the shop, the car was hopping around and making an awful loud racket coming right out of the transmission/bell housing. Maybe it was me constantly shifting like a noob due to the absurdly heavy clutch pedal, or maybe the setup just wasn't ideal. But I've been through hell so far and will soon have a 3rd clutch in my car in barely over a year.. I purchased a South Bend Stage 2 clutch kit that will go in next week. I also didn't want to pay $1200 just for a new stock flywheel. And I didn't want to keep that ridiculously loud flywheel or ridiculously heavy clutch pedal either. The SB kit has a custom Steel flywheel. So in a month or so I'll be able to chime in on all 3 types of flywheels on this car. I'm really hoping the steel SMF is a good compromise between the DMF and light weight SMF. I can say that the stock DMF was far quieter than the SMF I had. Oh, and I am on all stock motor mounts. (for now)
__________________ Mods: Can't mod a car that's always broken! |
![]() | | #40 | ![]() |
![]() Join Date: Sep 2013 Location: Quebec
| Not Ranked : 0 score mine just went out 2 weeks ago...73k miles. The oem clutch wasn't slipping at all even when i spin the tires the TOB noise was there since 1-2 years right after stiffer mount install. I wasn't concerned that much because 88duro bring some noise but 2 weeks ago, after few WOT in 4-5 gears, a heavy vibration and rumbling noise appeared. I drove back slowly to home and was sure something expensive went out!!! i checked axles, tranny oil and decided to remove the tranny and check it believing main bearing inside tranny was shot. Tranny removed, i touchecd the FW and was afraid it fall out without removing the bolts...! The PP + halft the FW was loose on the crank like if the crank bolt was 3-4 turns loose. The PP forks are worn not evenly, the disc is worn but the slipping surface isn't blue or uneven. Jus the FW have so much play in all ways that i believe it was almost going to have the second part to ''fly'' away from the other if i kept driving it!!! I can move it up and down of about 3/8'' but the play in the rotation movement isn't that much, just 5-6 teeths. My pilot bearing is completly destroyed, the tranny input shaft was no longer supported. I just don't know if the pilot bearing broke first and make the FW to go loose or if the FW broke the bearing by vibrating that much... Anyway i need to put something new and i don't know yet is i want 1 piece or DM???
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... |
| The Following User Says Thank You to Jeff23spl For This Useful Post: | jm211 (04-22-2014) |
| Can anyone explain dual mass flywheels and maybe shed some light on my situation | jester1341 | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 10-28-2013 09:30 AM |
| Single mass flywheel | Guthrie | MazdaSpeed 6 - Engine, Transmission & Driveline | 13 | 10-23-2012 01:05 AM |
| transmission failures on teh ms3 | 08_ms3_gt | MazdaSpeed 3 - Engine, Transmission & Driveline | 29 | 04-16-2010 10:49 PM |
