 Old 01-09-2017, 07:32 PM   #1
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Default Let's Talk About Valve Spring Retainers
Okay guys so as of late I've been looking around at valvetrain and head upgrades. There's a decent amount of options out there for us and I plan on running some hotter cams and revving out to 8k. Due to this I've started looking around at valve springs, I think for 8k and the cams I plan on running that Crower's 65lb option is a good match.
This spring kit retails around $280. Not horribly priced but I got to thinking as to where that cost comes from, I mean it's just a set of springs and retainers after all. After spending some time flipping through Crower's catalog I figured it out. The springs themselves are very cheap, the whole set of 16 can be bought for under $100. The rest of that $280 price comes from the retainers. The retainers by themselves are a bit over $200. My guess for that cost is because they're Ti.
So what I'm wondering is, do we NEED upgraded retainers when running upgraded springs? Of course there's the possibility that stock retainers may not work with these springs but presuming they do, I don't think Ti retainers are really necessary unless I'm missing something crucial about them.
If anyone has any input about this I'd love to hear it.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 01-09-2017, 10:18 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
All I can think of is, it's not for strength, but reducing weight thereby reducing inertia that leads to valve float at high revs. The springs won't have to work as hard to keep the valve from getting launched off the cam lobe. High pressure springs often come from thinker wire, which limits how much they can compress before they bind. Lighter components mean you can have lighter gauge spring wire with the same results.
Lighter weight > stronger springs
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
Mazdazilla6 (01-10-2017)
 Old 01-10-2017, 07:50 AM   #3
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
I haven't looked into Crower's catalog for this specifically, but I seem to remember the retainer design being quite a bit different than OEM retainers.
There may be compatibility issues that will force you to use upgraded retainers with upgraded springs, similar to the valve guides required for Supertech valves.
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
 Old 01-10-2017, 08:29 AM   #4
I can't find a picture of the actual retainer from Crower but I'm gonna order up one spring and see if it fits into my spare head with stock hardware. Just need to make sure I've got all the dimensions right for the spring.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 01-10-2017, 08:38 AM   #5
WetzMS3's Avatar
Groans: 430
Crower and OEM retainers (pic found in How to replace valve seals guide)
File Type: jpg Crower_75lb_Valve_Springs__33549.1459164867.1280.1280.jpg (161.6 KB, 21 views)
2013 MS3 Black Mica
 Old 01-10-2017, 08:51 AM   #6
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
I was scrolling past all the threads under new posts, and scrolled past this way too fast. Thought it said "let's talk about vaping". Instantly was like, yeah and brorus too.
Carry on. lol
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
Mazdazilla6 (01-10-2017), WetzMS3 (01-10-2017)
 Old 01-10-2017, 08:53 AM   #7
Well the top sides look pretty similar so I guess that's promising?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 01-10-2017, 06:22 PM   #8
jtday's Avatar
Posts: 650   (View Stats)
jtday is the leader of the worldjtday is the leader of the worldjtday is the leader of the worldjtday is the leader of the worldjtday is the leader of the worldjtday is the leader of the worldjtday is the leader of the worldjtday is the leader of the worldjtday is the leader of the worldjtday is the leader of the worldjtday is the leader of the world
Well I blew the motor in a past car of mine due to a cracked retainer. Take that with a grain of salt I guess.
2009 MS3 GT
- JBR SRI/TIP - CS Racepipe - TurboXS CBE - Cobb AP - Stratified E85 Flash Tune Stg. II (294/342) - Stratified Guardian Angel - Autotechs -
CP-e S2 RMM - KW V2 - SPC RUCAs
jtday is offline   Reply With Quote
 Old 01-10-2017, 06:30 PM   #9
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
Groaned at 7 Times in 6 Posts
What motor, what car?
-feejay
-wetzel
 Old 01-10-2017, 07:47 PM   #10
jtday's Avatar
M20B25 (2.5l SOHC straight 6, solid valvetrain) old bmw
2009 MS3 GT
 Old 01-11-2017, 01:18 PM   #11
Okay, I think I've got it figured out by cross referencing rates and retainer part number on Crower's catalog. The spring that Crower uses for our kits is PN 68195. A set of 16 is $77.33 from Crower. If you don't want to drop $200 on Ti retainers you SHOULD be able to use chromoly retainers PN 87085S, although they're listed as used for a Subaru. Those are only $69.03 for a set of 16.
I'm going to order 1 spring to see if it fits with our stock retainers. I'm also going to order 1 chromoly retainer to see how much lighter it is than stock and if it will work with our valve stem locks. After doing a bit of research, Ti retainers are only used for their weight and seeing as we have small valves and already don't have valve float issues at 7500 on stock springs I think these will work just fine without Ti retainers at 8000.
After going over some data posted in another valve spring thread, it looks like these springs are barely stiffer than our stock springs but have a lot more travel before they bind (which is good for a hotter cam as we hit bind right around .400" lift on stock springs).
Edit: ordered
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
Talk me out of it... TCU34 Mazdaspeed3/6 General Discussion 47 04-09-2011 09:59 PM
DOes ANYONE have OEM high pressure Pump spring retainers!! PAM.srt4 Mazdaspeed3/6 General Discussion 12 12-15-2009 03:07 PM
Let's Talk about... thanox2 Mazdaspeed3/6 General Discussion 7 03-27-2009 12:09 PM
Page generated in 0.31161 seconds with 26 queries
