| y2kc0wb0y | 10-09-2008 08:30 AM | Lightened Flywheels: Things to know I just read that the MS3 and MS6 now have a lightened dual mass flywheel option. Outstanding work and a big thanks to SSInstaller. Since a group buy is already in the works I thought it would be important to share some knowlege I have on them.
1. With out a doubt; there is nothing better to make an engine rev quickly than adding a lightened flywheel. (ok arguably Titanium or Aluminum connecting rods); but hands down LF's are one of the single most important mods for reducing rototational mass on the crank assembly. Freeing this load on the engine will increase power output for sure on even a stock MZR engine.
2. All things have a cost however. Lightened flywheels, while they allow a engine to rev really fast, they also allow the engine to drop revs really fast. Example: when you get out of the throttle quickly. IE, you push the clutch (for long enough time to return to idle) from a high RPM you might find yourself restarting your car. This is because the engine revs will drop so fast the ECU might not be quick enough to recover the environment change. (this has yet to be proven on the MS platforms, but this has been my experience with other applications). Quick or normal shifts betwen gears will not be a problem. see # 4.
3. Lightened Aluminum flywheels typically transmit noise. IE throwout bearing noise. It's sounds like a rattle but only at idle. (Again this has yet to be proven on the MS platforms, but this has been my experience with other applications). However, loud/open exhaust or slightly increasing radio noise can typically muffle the noise.
4. Loss of torque for clutch engagement. Less rotating mass means clutch engagement will probably need to be made at slightly high revs to get the car rolling. It will certainly take a little getting use to, but basically it only means relearning the sweet spot(s).
I hope this helps in your decision. Look out EVO's and STI's the Mazda game is getting pretty serious |
