MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
![]() | ![]() | #1 | ![]() |
![]() Join Date: Dec 2013 Location: San Diego, CA
Rep Power: 125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 83
(Thread Starter) | ![]() ![]() ![]() I saw a few people running into problems with arp main studs and I didn't know if people are reusing the stock main bolts or if they are buying new. At the machine shop where my work is being done they found a bulletin on their engine servicing software that had specs with measurements on reusing head bolts but I don't see anything on main bolts, infact I don"t see much at all in the way of info for the mzr disi.. |
![]() | ![]() | #2 | ![]() |
![]() Join Date: May 2010 Location: Benton, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,028
| ![]() ![]() ![]() From my little bit of research plus personal opinion; don't reuse either head/main bolts. I don't care about stretch measurements. Head bolts are a bigger concern in this platform anyways. ARP main bolts do not allow for the Balance Shaft to be reinstalled. If you plan on reinstalling it then you will need to use the OEM main bolts or be prepared to alter the ARP mains.
__________________ 2010 Mazdaspeed 3 Liquid Silver Metallic HTA 3076 | HTP 4" Intake, battery tray, under mount piping | CPE Exhaust Manifold, downpipe, FMIC & Stage 2 RMM | MD TMM and PMM | Tial MV-R ewg w/ Kozmic dump tube | VCTS delete/Ported IM | JBR OCC, EGR delete, BSD w/ oil pan baffle & RSB | SP63 Oil Cap Breather | Synapse SB BPV | UR CBE | Autotech HPFP | H & R Coilovers | Whiteline Endlinks | Manley Pistons & Rods | L19 Head Studs | Kozmic 6th Port w/ DW65c ITFP | Snow Performance Stg 2 Meth | JMF Manifold | SouthBend Stg 3 Endurance Clutch | Tuned with ![]() |
The Following 2 Users Say Thank You to jdmage_mx5 For This Useful Post: | England15j (02-03-2015), wyeto (02-04-2015) |
![]() | ![]() | #3 | ![]() |
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,860
Groans: 126
| ![]() ![]() ![]() I have never seen anyone break an OEM main bolt on this platform that wasn't directly contributed to another failure. If you want to keep the balance shaft, go new OEM if even for just peace of mind. It all depends on what your goals and needs for your build are.
__________________ '09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE |
![]() | ![]() | #4 | ![]() |
As for the mains I agree, wouldnt want to cheap out on 60$ worth of bolts to lose your engine.
Balance shaft will be removed power goals are in the high 300's and hopefully one day 400 hp, I'm going to be going with a gt2871 turbo. | ||
Display Modes | |
Exhaust Manifold Studs vs. Bolts | SLOWHATCH | Gen2 MS3 General Discussion | 12 | 10-14-2016 01:40 PM |
ARP main studs and balance shaft | KCi | 2010 MS3 - Engine, Transmission & Driveline | 1 | 12-23-2014 09:29 PM |
Studs VS. Bolts. | James Geese | MazdaSpeed 3 - Engine, Transmission & Driveline | 12 | 08-25-2013 12:54 AM |
Rods and main studs | ms3boost | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 06-08-2009 10:11 AM |
