Maisonvi Makes my Shifter Bigger 27 Attachment(s) I've had all the JBR Shifting goodies, shifts felt way more solid over stock, every bit helped, with bushings probably what the oem setup needed the most IMO. Erections were good. http://www.mazdaspeedforums.org/foru...1&d=1416544659 Broke the shifter just going through gears at a light, sounds like I'm not alone, but still, an uncommon occurrence of erectile dysfunction, and not while under particular sexual forces at the time. http://www.mazdaspeedforums.org/foru...1&d=1416540134 http://www.mazdaspeedforums.org/foru...1&d=1416540134 Luckily I found a used Cobb STS, installed with shortest throw and stock height. Erections were good again, with humorously short throw combined with the JBR shift plate. Which was fun to try and feel, much like anal. But shifting somehow felt like there was more resistance and effort involved, fine-tuning the orange-tit thing in the shift assembly helped prevent 99% of gear lock out, but going solidly into gear still did not always feel confident anymore. At a recommendation of a fellow nator, I removed the short shift plate, and left it without a shift weight completely. Shifting my erection improved noticeably , with the downside that going into gear felt a bit more loosey-gooesy like oem. But it was clear that throttle blips needed to be adjusted, which is my personal queue that my stick work is getting faster relative to my foot work. However I seeked to regain the more virgin-tight feel that the short shift plate gave me, and I refused to be abstinent. I yearned for a larger erection, to satisfy my hand by means of mechanical leverage. Here are the options I saw readily available: TWM $49-$69 (A little expensive, don't they shame vets publicly and cover it up?) SURE $99 (LOL) Ebay brands, like sickspeed $15-$30 (Not bad price, but not very solid looking though) Circuit Hero $35-$55 (Probably my next bet, good reviews, good price) Stratified $65 (A little fat, sure it works well, a little expensive, looks great with their knob) Really I just needed a cock that won't break, is reasonably priced, and if possible, have a nice oem-ish fit, and doesn't look too ghetto. In particular, I wanted something that fit well with the shift boot. And not like your extension is trying to bang a chick a few sizes too big: http://www.mazdaspeedforums.org/foru...1&d=1416542369 http://www.mazdaspeedforums.org/foru...1&d=1416542369 http://www.mazdaspeedforums.org/foru...1&d=1416542369 http://www.mazdaspeedforums.org/foru...1&d=1416545489 (Does this make my vagina look big?) Which led me to contact @maisonvi for some personalized pleasure. He does great stuff https://www.facebook.com/maisonviknobs if you wanna see the rest of his gallery and candids. We talked about what I wanted, and how what's available wasn't what I wanted and he made it happen, much like they do for me in Bangkok, which is really just what I call just a Thai restaurant downtown. TL;DR Here is a pic of what he came up with before he sent me mine. http://www.mazdaspeedforums.org/foru...1&d=1416542820 My screen was dripping with my own semen, it was everything I asked for, nice girth, and flush with the shift boot. Probably looks best with his knob, but I am too attached to mine, we have a healthy relationship. http://www.mazdaspeedforums.org/foru...1&d=1416543113 And here is my install to show how you how nice and tight everything was after screwing it on. Cock ring and insertion tool http://www.mazdaspeedforums.org/foru...1&d=1416544659 fit together like the best of friends http://www.mazdaspeedforums.org/foru...1&d=1416544659 Remove wrinkly black phallus, instead of looking up the adapter nut size, grab every ratcheting wrench and trial and error to see which one fits your application instead. Much like I do with tabs in 4chan before beginning my fap journey. http://www.mazdaspeedforums.org/foru...1&d=1416544659 Also grab a vice grip, because you have a cobb STS, and your shaft spins like tyrion lannister in bed. http://www.mazdaspeedforums.org/foru...1&d=1416544659 Admire the love scars your cobb sts shaft now has from the rough play. http://www.mazdaspeedforums.org/foru...1&d=1416544659 Remove vagina. Because it is incredibly frustrating trying to get black plastic shift boot piece to go back into the out hole. Remove sand from vagina gained during frustration while you're at it. http://www.mazdaspeedforums.org/foru...1&d=1416544814 place black plastic piece back on shifter, and shift boot atop of that, and sandwich it with maisonvi supplied cockring until its nice and neat. Because you were too lazy to get fabric glue to properly glue redline shift boot to black plastic piece. http://www.mazdaspeedforums.org/foru...1&d=1416544814 Attach penis extension, admire perfect fit with cock ring. http://www.mazdaspeedforums.org/foru...1&d=1416545049 Attache adapter thing for JBR knob. Switch to ratchet after using your fingers to screw it on only after realizing it's cutting into your skin, which will make fapping very interesting tonight. http://www.mazdaspeedforums.org/foru...1&d=1416545049 New fapping motions for the 3" extension, length of which I specifically asked for, relatively mild compared to other extensions. I wanted to be #becauserallycar , but also for it not to be too high angled on my arm for DD. http://www.mazdaspeedforums.org/foru...1&d=1416545260 http://www.mazdaspeedforums.org/foru...1&d=1416545260 Moar pics http://www.mazdaspeedforums.org/foru...1&d=1416545574 http://www.mazdaspeedforums.org/foru...1&d=1416545574 http://www.mazdaspeedforums.org/foru...1&d=1416545574 http://www.mazdaspeedforums.org/foru...1&d=1416545574 http://www.mazdaspeedforums.org/foru...3&d=1416545575 Feel free to take note how far I sit up and how short I am. And thanks again to @maisonvi for the awesome custom work. |
Oh right, and it shifts awesome. Looks great, and the height is perfect. It also improves the grip on my JBR knob, to be able to grab it utilizing the under-side with my fingers now too. The extra leverage really helps, and shifts are simply effortless, even 6th-5th-4th feels better. Really has more of that sensation of the stick being sucked into gear. And it passes the tests. Throttle blips have happily needed to be adjusted again for the quicker shifting (: |
More on the resistance I was feeling with having all the JBR stuff plus the Cobb STS. Fine tuning the shifting bias always helps no matter what mods you have, and should be adjusted whenever you change the throw. I had to adjust it after the JBR shift plate, after the Cobb STS, and also again when I installed the JBR shield that keeps the reverse lock out knob thing from rubbing. All mods were limiting my possible "sweet spots" I could use while adjusting the shifter bias. After doing all the above, there was basically only one place where I could adjust it to, and not have any gear lock out. To put it in a very not college-word sounding way, maybe there was just too much going on with my shifter, and that caused all the resistance I was feeling before removing the JBR short shift plate. |
this looks exactly like what I am looking for after my Cobb STS install |
Looks good. I feel like I need a shower after reading all of that. |
Hey man. Glad you like it. Its always fun when I can customize something for someone. Plus this did turn out pretty sweet. Sent from my XT907 using Tapatalk |
bwaaahahahahahahahaha made the whole thing worth reading right there... |
@maisonvi;, I've been wondering if you'd be interested in making a sort of hourglass-shaped extension. The design would be such that the bottom portion of the extension roughly approximates the diameter of the plastic ring that supports the shift boot. The top of the "hourglass" shape would flare slightly below the threaded portion, such that any of a wide variety (not all, obviously) of shift knobs would fit flush-ish without looking like there's a large step-transition in diameter. |
Or message me and I can work to get what you want Sent from my XT907 using Tapatalk |
1 Attachment(s) Quote:
Any chance you'd want to make a few more of those @maisonvi; ? |
Interesting narrative for a shifter extension. Looks and sounds good. Sent from my iPad using my stinky fingers |
dammit I forgot something. This is my break-in process whenever I modify my shifter. It's the same method I used when I try to resist fapping and promise myself to be productive the rest of the day. |
Watched video. Tried technique. Instructions unclear; dick stuck in RMM. |
@breakfstincluded; any long term impressions? Has fapping become more efficient? |
Super short shifts with Cobb SS + SSP was fun, but it just didn't feel reliable to me. Adjusting the shift assembly thing helped, but I still felt I was in danger of missing a shift at any moment, like running into the "walls" between gears if I'm not vigilant enough one day. Just having the Cobb SS + Extension + Knob, and no plate or shift weight I like a lot more, I feel like it puts all the leverage on the correct side of things, and so the mods don't work against each other. I also am shifting faster for sure, being dependent on my arm for once, and not just how well I can coax the shifter and all the short shifting mods into gear. And @maisonvi 's stuff is just beautiful and has held up flawlessly. |
| All times are GMT -7. The time now is 07:25 AM. |
