![]() | | #41 | ![]() |
Groans: 79
| Not Ranked : 0 score
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
![]() | | #42 | ![]() |
![]() Join Date: May 2010 Location: Baltimore, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 848
__________________ 2007 MS3 GT -- > World's first flying Mazdaspeed3. 2006 MS6 GT -- > World's first n2o Mazdaspeed6. 1990 LS1 RX7-- > Probably broke somewhere #DIX, for all the single ladies | |
| The Following User Says Thank You to WhoIsJeremy For This Useful Post: | djuosnteisn (02-03-2012) |
![]() | | #43 | ![]() |
Groans: 79
| Not Ranked : 0 score Yup. They're like $6 a piece, or something like that. I always just call my local parts department, and usually they can get them in within a day or two.
| The Following User Says Thank You to djuosnteisn For This Useful Post: | WhoIsJeremy (02-03-2012) |
![]() | | #44 | ![]() |
(Thread Starter) | Not Ranked : 0 score But I need them meow! Hopefully they can have em tomorrow
![]() | | #45 | ![]() |
![]() Join Date: Jan 2010 Location: charles co, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,295
| Not Ranked : 0 score I read the FIRST POST about dustin and his flywheel bolts being HAND TIGHT... But DJ do you feel like the flywheel bolts being loose caused the NOISE? I thought you were saying that due to the clutch being made wrong and out of spec that the pressure plate bolts were hitting the bell housing that was causing the noise.. Now with the flywheel being loose that MIGHT have contributed to the noise but if that flywheel was that loose that it will cause that loud of noise with that much torque from driving it alone would possible rip the threads out the crank.. Jeremy about the fork...what i am saying is when you pulled the fork outward to put the TOB on there is a wire that is attached to a ball that is welded to the tranny housing and it is not that hard to pull that wire off that ball or have the wire come off the fork itself during installation. This is the reason i ask you to check the forks tension. Because there is nothing to bring the fork away from the pressure plate other than that wire attached to the fork... Sorry i dont know the name of that part....
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" ![]() 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport |
| The Following User Says Thank You to qtrmile beast For This Useful Post: | djuosnteisn (02-03-2012) |
![]() | | #46 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm praying it's either a) the flywheel is loose and just needs to be tightened and isn't damaged or b) throw out bearing is fucked and maybeeee act will cover costs of a new one considering it's been in my car for 510 babied miles? She's going in the air tomorrow and hopefully I will have her running by tomorrow night.
![]() | | #47 | ![]() |
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" ![]() 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport | |
![]() | | #48 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks, I need it. lol depending on how fucked up it is, I might just let it sit, take off what i can, wait for it to snow and total it lol I'd get a check for 5k over what i payed plus mods! haha
![]() | | #49 | ![]() |
| Not Ranked : 0 score if you need help let me know and i will see what can do to down there to help you..
![]() | | #50 | ![]() |
Groans: 79
There were 2 noises essentially. The initial noise, from contact with the bell housing, and 4500 miles later... of the loose FW.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following 2 Users Say Thank You to djuosnteisn For This Useful Post: | qtrmile beast (02-03-2012), WhoIsJeremy (02-03-2012) |
![]() | | #51 | ![]() |
(Thread Starter) | Not Ranked : 0 score Buying lots of red loctite tonight Sent from my ADR6300 using Tapatalk
| The Following User Says Thank You to WhoIsJeremy For This Useful Post: | djuosnteisn (02-05-2012) |
![]() | | #52 | ![]() |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score i don't buy fw loose, the cromeolley makes a hell of a high pitch tinging sound, my money is on botched tob install or did you pull the bell housing together with bolts, as this would bend the clutch disk and make hella noise just installed one of these this weekend worked flawless also used red locktight cause the bolts go trough the crank, and oil could come down the threads, so i also added locktight to seal it up good
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan Last edited by rigor; 02-05-2012 at 07:25 PM. |
| The Following User Says Thank You to rigor For This Useful Post: | djuosnteisn (02-05-2012) |
![]() | | #53 | ![]() |
(Thread Starter) | Not Ranked : 0 score Flywheel was loose. Every bolt I took out with my hand. Put em back in with red loctite and its perfect. I do here some chatter but only when my hood is popped. I'm going to assume that's just the 6 puck chatter. Flywheel looks like I broke it in perfect though ![]() ![]() Sent from my ADR6300 using Tapatalk
| The Following 7 Users Say Thank You to WhoIsJeremy For This Useful Post: | Captain KR (02-05-2012), crazyp (02-05-2012), djuosnteisn (02-06-2012), qtrmile beast (02-06-2012), rigor (02-05-2012), tddvrrn (02-05-2012), Vader (02-06-2012) |
![]() | | #54 | ![]() |
![]() Join Date: Nov 2010 Location: northwest arkansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,067
Groans: 103
| Not Ranked : 0 score i love happy endings...
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows [SIGPIC][/SIGPIC] ![]() |
| The Following User Says Thank You to tddvrrn For This Useful Post: | WhoIsJeremy (02-05-2012) |
![]() | | #55 | ![]() |
Groans: 40
| Not Ranked : 0 score well ill be go to hell ! my speakers suck, so must not come trough good on my end glad you got it handled, the noise you're hearing is gear lash / chatter, that is what that 2 piece fw is for, to cover that up i hope you breakcleaned the crap out of the holes, to clean the oil out to get a good cure on the red locktight and i also think they have you replace them every time, is for the sealant to actually reseal the crank properly not that the bolts are bad
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
| The Following User Says Thank You to rigor For This Useful Post: | djuosnteisn (02-06-2012) |
![]() | | #56 | ![]() |
| Not Ranked : 0 score wow congrats glad you got it fixed!!!
| The Following User Says Thank You to qtrmile beast For This Useful Post: | WhoIsJeremy (02-06-2012) |
| Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon | Haltech | Automotive News | 3 | 04-17-2010 08:40 PM |
| Major Beer Run | Doc-1 | MazdaSpeed 3 - Engine, Transmission & Driveline | 23 | 12-21-2009 09:25 PM |
| major fail | b-ron | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 47 | 07-01-2009 10:32 PM |
