-   -   Matt D's OCC Kit Check valve (http://www.mazdaspeedforums.org/forum/f10/matt-ds-occ-kit-check-valve-112671/)
vbt101 05-03-2012 11:49 AM
I want to switch out my existing Matt Damond check valve to the McMaster 7775K54 check valve.
Does anyone know what part number his check valve is? I want to verify the pipe diameter of his valve to see whether I can just re-use the fittings that come with his valve on the McMaster.
silvapain 05-03-2012 12:02 PM
Why would you replace the MD check valve? I tested the one on my setup and it works like a BOSS.
vbt101 05-03-2012 12:28 PM
At the Nator East Coast meet, I kept blowing my dipstick out on the dyno. The prevailing opinion among the experts was to replace that check valve.
world famous z 09-04-2012 02:10 PM
who were the "experts" ?
do you run any CEL's relating to the issue?
NJSPEED3 09-04-2012 02:20 PM
I don't think replacing the check valve is goin to help you dude. As a matter of fact the valve is probably 100%. The valve seals under boost, not allowing oil past it and into your intake manifold. At the same time that valve keeps positive cranking pressure from being able to release hense you dip stick issue.
What you need is find a way to vent the crank pressure. There are a couple of options here. You can run silverdemon's venturi set up, or u can tap the baffle in the valve cover and hook it up to a vented catch can. Hit up Anthony, he can walk you threw the install as he did me.
The hose diameter for the Matt's check valve is 5/8" btw.
@SilverDemon @superskaterxes
Raider 09-04-2012 02:23 PM
Old thread is old.
bcmurphy87 09-04-2012 02:24 PM
yea i have the matt d kit and i just added the exhaust venturi and its all better
Page generated in 0.17675 seconds with 11 queries
