I'm not sure of this lift issue you speak of. I've had her up to 240km/hr (150mph) and it felt planted. |
I suspect the larger rear spoiler of the MS3 reduces aero life a little bit. But not much. Basically, it comes down to the "wagon" body style, they're conducive to lift and their isn't an easy way to stop it. I know of a race team who was commissioned by Mazda to make the gen1 MS3 competitive. They tried a number of different wing shapes and locations, but wound up with a large wing in essentially the stock location, but it still didn't work very well...and wasn't legal under the rules. They decided instead to use the sedan body. Which virtually ever team uses in touring car classes when given a choice. They can put a big wing on the trunk and stay within most race rules that don't allow a rear wing to extend further than the body. Quote:
So much for the hatch STI ... and even others such as the caddy CTS-V wagon - a serious speed machine. Quote:
You can mitigate the lift or even create downforce with a really big wing on the roof, but that would cause so much drag that I doubt a stock MS3 would even hit 150. Or 140. They're already drag limited to about 152-153. |
Sorry if I challenged your internet ego. |
LOL, you didn't challenge my ego, it was a genuine question. I've gone about 130 in a 15 degree banked corner (a NASCAR oval) and it wasn't too bad, but I could feel the car getting pretty light in back. I've also hit about 145 at an undisclosed location, straight line, reasonably smooth surface, and while the rear end didn't take to flight it did feel light though. Not too bad though, just got my attention. Is your car lowered? Mine isn't but it would probably help if it was. |
I am currently on stock suspension. Soon to be on the Mazdaspeed springs since they have been sitting in my garage for two years. Too busy driving to have them installed I guess :) |
No worries, I know how it is. 150mph with the stock suspension is quite fast. You much have great roads up there in Calgary. If I tried that on a Cali highway I'd probably be dead already! |
Lol. I'm actually 3 hours north of Calgary but I hear ya. We have some pretty nasty roads. The speed run was done on the track of course. |
Geez, 3 hours NORTH of Calgary? How bad does the sledding in Summer need to get before you can drive your car that fast? On a track, of course. Hey wait, isn't this thread about blown motors? |
I think I like this thread better when it's not all doom and gloom! Anyways, back on track.... Who blew up today? |
Well, I can't really call it a blow up, and looking for suggestions/help here. 2008 MS3 GT 17,150 miles. All the standard mods, AP, DP, FMIC, CC, MSCAI 4 weeks ago I had just installed and aftermarket fuel pump due to fact I had all the other standard mods and wanted to be sure and protect my engine. Well after 3 miles on the test drive I downshifted into 2nd and got a steady misfire, at about 5 MPH. I was monitoring fuel pressure the whole time and everything seemed to be within normal psi ranges. The dreaded "blow up at low rpm engine load " went through my mind, but I have always been careful not to load the engine at low rpm, and was not doing so when this happened. Turns out I did not blow, but something inside the cylinder and banged up the plug all to heck. No rod through the block or anything as it turns out. I returned the car to stock and took it to the dealer, after 3 weeks of waiting I was notified yesterday by Mazda that they are denying warranty, that they see no evidence that their parts failed, and something foreign was introduced through the intake system. I don't see how that could be as I had not had the CAI off in months and had driven 500 to 1000 miles. I am going to pay the dealer to pull the head off and see if something broke that caused the issue. That is correct, all Mazda had the dealer do was pull off the valve cover and stop, didn't go any further once they pulled the foreign piece of metal from the cylinder. So not fully blown up, but I am reaching out for any websites or resources that sell or talk about engine blocks, rebuilds, etc. so I can start getting a plan together to either pull the engine and attempt a rebuild myself, or have the dealer do it. The car had always driven excellent up to this point, and I had no issues after putting any of the mods on. Thanks in advance for any help or suggestions. |
Were all the parts you installed new? I am thinking that perhaps something was inside your FMIC or intake piping that needed time to work its way into the manifold and chamber. A really unfortunate event indeed. |
Did you see what they removed? Was it identifiable? Pics of said foreign object? Seems an awful coincidence that this happened immediately after fuel pump install. Did you loosen or remove any part of the intake/intercooler system to make the fuel pump install easier? To where something could have dropped in there? |
My guess is a spark plug tip. If they could pull it out through the spark plug hole, it can't be any bigger! |
Oh, and FWIW, I've been getting driveabilty stumbles during light loads between 2800 and 3200rpm lately. Smooth idle, no probs at WOT in that range, but there's definitely something going on there during little or no boost. Stock engine though, and I just drive it like any other car. If the ECU has problems in that transition period, and the motor pops, I'm good as far as warranty. Don't have a Dashhwak or anything so I don't know what's happening, I just feel it driving around town n city traffic. It's not my job as a customer to work around a stumble with a completely stock drivetrain, but I will take it in for it's 30K service and mention it, just to cover my ass. I'm at 13K now so that might take a while. But I really don't care. The best possible outcome is that it will grenade in the next year or so and Mazda will put a brand new engine in the car so I can feel better about keeping it longer if choose to. |
The piece they pulled out of the cylinder was about the size of a nickel and mangled, unable to tell what it was originally. I just found out Mazda denied warrnaty saying something foreign was introduced into the air intake. BS on that I think. I did take off my cobb intake when I did the fuel pump, but was ever so careful. And I would think it would have taken out my turbo first. The plug was bashed up, but still intact. I just cannot believe Mazda did not at least have the dealer shop take the head off to examine. I have asked how much it would cost me to do this. So far the local dealer is at least acting like the care, we shall see. There is always a chance I dropped something in the intake, but doubtful, especially since it would have been pre-turbo. I let the car idle for 25 minutes as stated when installing the new fuel pump, then was on about the 3rd mile of the 1,000 rpm to 4,000 rpm break in drive, watching my boost gauge to be sure I did not go into boost. I did actually start the car a few times after it was towed to my house, kept at idle, and only for a few seconds when I was on the phone with the company that sold me the aftermarket fuel pump. They tried to be helpful. When at idle most of the time I heard no noise, a couple of times I heard some clinking around in the engine, but not always. I know I am hoping for a miracle that no damage was done to the cylinder, but I know it is doubtful. |
The size of a nickle, that is pretty big, I doubt something that big would have made it through the turbo with out destroying it, and I cant even imaging it making it through the intercooler. You sure its not the head off a valve, sounds about the right size..... Isnt that what mazdaspeedgirl or (whatever she is called) have happen....... twice?? Head came off number two cylinder valve. |
Well I believe it is cylinder #2, 2nd in from drivers side? Might not have been quite the size of a nickel, part isn't around the car any more, probably sent off to Mazda, but it was at least the size of a dime or more. I just don't see how I could have dropped anything in when I worked on the fuel pump. And I had 500 miles on the car since the last mod, which was a FMIC, but I blew air threw all the tubes etc before installing. I am hoping the Dealer won't want an arm and a leg to take off the head so I can know for sure, and have piece of mind it was not a problem caused by the engine and move on to what I will do next. Which will be either rebuild, replace, or trade for a CX7. I already primed the new car guys yesterday by test driving one. If the numbers worked out on what they would give me for my car, I might consider it. But I would sure miss driving the MS3. |
I think you have enough evidence if the turbo isn't damaged. no way a piece of metal could go through the compressor without mangling that too. just sounds like another lame attempt by Mazda to get out of a warranty claim. |
I know exactly when the con rod in my engine got bent; it was at 10 psi of boost in 3rd gear at 2800-2900 rpm after a 20 minute drive at 40 mph in 4th gear on my way home. It knocked like crazy and I got out of the throttle right away. The engine was making a tapping noise right after this happened. I limped it home (this was a Friday night) I took it to work and removed a couple of mods (test pipe, PTP HPFP, PTP balance shaft delete kit and oil pan baffle) I could not see any damage to the con rods at that time. I took it to the dealer and they decided it was a "Top End" noise and pulled the head off, did a full valve job, replaced the timing chain and tensioner (this took almost a month in the shop) When they called and said it was ready I went down and picked it up but it was making the same noise (maybe at slightly less volume but the same noise). I called them Monday morning and told them it was not "fixed" and they told me the factory rep told them that Mazda was all done and were not going to do anything else for me. Keep in mind I had owned the car for 3 years 3 months and 39,950 miles. I was holding their feet to the fire on the Driveline warranty. I was driving the car back and forth to work but not doing anything crazy with it. I finally got tired of talking to the service writer and the lead mechanic and asked to see the Service Manager. I spent an hour in the SM's office with the Service writer. I took a lot of information that I had found online (this site and others) about some of the problems that have been going on with the DISI engines. I had pulled the valve cover off and checked the valve clearance and then did a leak down test, #3 cylinder had over 55% leak past the rings!! The other 3 cylinders were all below 8%. I asked if they had done a leak down and they said they had, I asked them to look in the records and see what the test numbers were. GUESS WHAT, they had the same numbers BEFORE they pulled the head off and did the valve job, they did not check it again after they did the work. The SM told me that the District Service Rep from Mazda was going to be there the next day and if I would bring the car back he would discuss it with him and show that the noise was still there. I told him I would be back and thanked him for is time. As I was getting into my car the SM and the Sw were walking down the sidewalk right in front of my car when I started it, the noise was there and they both heard it, the SM asked me to open the hood and he listened very carefully and said "We Are Not Done With This Yet". On the way back to my shop (less than 2 miles from the dealership) I was pulling away from a stop light with a cop car in the lane next to me and at 25 mph at about 3 psi of boost in 3rd gear it kicked the #3 con rod out of the engine. I had the car delivered back to the dealership (less than 40 minutes after I had left the SM office). The next day they called and said they had "ordered" a new engine and I should come and get a loaner car. This car had done the "big knock" twice before both times after more than 20 miles at freeway speeds at a steady cruise and it happened either at the end of the off ramp as I pulled away or at the very next stop. I am sure the crankcase breather system was causing oil to puddle in the intake manifold. When they had the head off the first time it was in for work there was oil in the intake manifold and signs of some oil in the combustion chamber. I have done 3 open track driver's schools with this car (I'm an instructor) and put between 125-150 miles each day with no problems at all so it is interesting that the problem happened after driving the car at 40 mph for 20-25 minutes at low engine speeds and less than 10 psi of boost. I have oil pressure, oil temp, water temp, boost pressure (with a tattle tale) and Intake air temp measured at the throttle body gauges that have been on the car for about 34,000 miles so I have been keeping track of the engine for most of its life. I now have an oil catch can on the line between the intake manifold and crankcase with an extra check valve between the manifold and OCC. I also have Oil catch can on the line from the VC to the intake pipe with a one way check valve on the line. When the engine is on boost the valve between the Intake Manifold and the OCC closes and if there is any crankcase pressure it is allowed out through the valve cover and through the check valve into the occ. When there is vacuum in the intake manifold it tries to pull a vacuum in the crankcase because the valve at the VC is closed so no air can get pulled through the engine and into the Intake manifold, the only air available is just blow by. In 3000 miles I have taken less than 3 tablespoons of liquid out of the Intake manifold catch can and none out of the one on the valve cover. I used a bore scope to look into my intake manifold after a 60 mile cruise on the freeway and found no sign of oil or moisture at all. I'm still keeping track of it but I have hope. I don't think this engine has "WEAK RODS" at all, I put almost 300 miles on a connecting rod that was so badly bent the rings were not seating any more, one that was making so much noise that the service manager was shocked to hear it at idle. My engine "Hydro locked" it's self on its own oil. BTW I don't LUG the engine but I have never been shy about getting on the gas in all the gears 1-5 in the 2500 rpm range; it pulls like a freight train. This was a specific event that caused the damage and as far as I am concerned it had nothing to do with "WEAK" parts or lugging, it was a bad design of the crankcase breathing system and intake manifold design that allowed the oil to puddle and then at the first time I tried to accelerate and opened the throttle enough to move a lot of air that puddle got "sucked" into one cylinder in a quantity big enough to cause HYDROLOCK. Just so you know I restore Vintage Racing cars for a living. I have been building race engines for road racing for the last 20+ years. I have done BMW, Porsche, Ford, Chevrolet, Ferrari, Alfa, VW, Cosworth, BRM, and Coventry Climax engines and have seen my fair share of engines blown up. This is my street car, my daily transportation not my race car, I'm not looking for 600 hp I enjoy the 256 HP I'm getting right now (I have my own dyno). I have driven over 175 different race cars over the years, everything from a 1926 Stutz to mid 80's ground effect F1 cars, 700 hp Can Am cars to 120 hp 900 lb Lola sports racers, that is me in a 917K Porsche in the pictures. 250 hp in a 3200 lb station wagon is a lot of fun but I am not trying to kid myself into thinking it is anything other than a fun street car. Sorry about the long rant just needed to finally get this off my chest. |
Boosties Car; 2007 MazdaSpeed 3 91,000 MILES Cylinder; unknown Damage; unknown RPM; see speed Mods; Cobb SRI, Corksport TP Exhaust Manifold; Stock Situation; 30 MPH, going up a hill i'm guessing it's about a 50 degree incline Other: Same situation as member s-retire. "There was no indication of low oil condition prior to engine failure. The low oil pressure indicator light did not illuminate until after the motor quit. There was no increase in operating temp." Warranty; no warranty, car is over 60,000 miles |
Well more on my saga of the piece of material that bounced around in the cylinder, and just to recap, 2008 MS3 GT 27,135 miles so should be under warranty. Since Mazda denied warranty saying something was introduced into the intake, I asked the Service manager to quote me labor to just pull the head. $600 is what he told me today, more than I had thought it would be. So the dilemma is do I just throw $600 out there hoping that a valve is broke and maybe I can go back at Mazda for warranty, or tow it home and try it myself. I am mechanically inclined, but last engine I rebuilt was on a 1966 Corvette 327 engine LOL. I have a 2nd vehicle good ole reliable 98 Jimmy to drive so the MS3 could be in the garage as a summer project. But I just don't know how involved this would be, past the obvious. Also, if I was to tow it home, take the head off myself, find a broke valve, do you think not having the work and discovery done by an authorized Mazda dealer with give Mazda North American ammunition to deny warranty again? The Service Manager did say the $600 would of course apply towards labor if I got lucky enough to just need work done on the head, if the cylinder is not scored. But no way to know what I am looking at as far as repairs until that head comes off. I am going to try and get a picture of the piece of material that was pulled from the cylinder and post it. Cannot really tell what it was originally. But I did see a pic on another site of the under side of the head, saw the color of the valves, and the piece of material did look dark like two of the valves in pic I saw. Probably wishful thinking at this point. Anyway, I appreciate the listening and the input. |
Byron, hope you got my PM and can answer. I appreciate your insight. The scenario you described is quite common - high KR after highway cruise ... but I am not convinced it it hydrolock for several reasons: - I used to be able to induce this knock/KR spike with a boost spike after hwy run at will. - The "resonance" picked up by the knock sensor is not the same for a detonation event and hydrolock so you shouldn't see KR on the dash hawk in the case of hydrolock unless the event damaged the rotating assembly. - I had an oil CC with a secondary PCV for a year and could induce this condition. I only alleviated this problem when I reduced dynamic compression ratio and boost spikes. - The PCV system is designed in such a way that "large" amount of oil are very difficult to find themselves in the intake manifold at once. Oil vapor sure. - If this condition is present on the hwy, I presume the same condition would be present when cruising at say 30mph in the city. Or even under high vacuum at idle for example. - If oil was hydrolocking the engine that accumulated under vacuum conditions, we would see a lot of Duratec motors blow like this as they have the same PCV system setup. Duratecs have been sold for the last decade in many vehicles. Looking forward to your thoughts. Quote:
There is also the design of the intake manifold, the throttle body and majority of the manifold it's self are below the intake ports in the head, it may be that this intake manifold design is prone to allowing the oil vapor to condense and puddle in one spot. It would then take a sudden flow of air or cornering to move it so it would go down one runner into a single cylinder in one intake cycle to do the hydrolock damage. If the amount of oil is not large enough to fill the chamber and cause the hydrolock condition it would sure cause a knock, smoke , running issue like many have had ( including me on other occations) but it just takes that one time to do the damage. |
I am certainly inclined to think prolonged highway cruise is an operating condition that lends itself to knocking and that many of our motors go out in similar ways to what Byron experienced. Here's something interesting - we are not alone. The Cobalt DI LNF motors suffer from a similar issue. A GM engineer describes what he believes highway knock has at the source. This is similar to my findings/feelings and both our motors and the LNF operate in similar ways. I have highlighted point of interest in red. I hope this clears up some confusion on knock and how many of the motors go to heaven. Remember that our engine is 9.5:1 static CR compared to the LNF 9.2:1 making it more knock happy. Also, they have a smaller motor meaning less ability to spool the turbo and boost spike and shorter stroke meaning they are less prone to bending rods. http://www.solsticeforum.com/forum/f...visited-61506/ Quote:
Moar from wikipedia: Quote:
10 Attachment(s) Well do I ever have egg on my face. Not Mazda's fault at all. Not sure how I dropped something in the BOV intake but I did. Very small washer or something, See pics. Not sure how it kept out of the engine for the 100 miles it did. Thing is, engine looks almost like I could put a plug back in and drive it. Obvious pitting on the piston head. The valves look good, #3 cylinder was the cullprint, head is pretty pitted up. Mechanic said the valves moved freely with the cam. The cylinder walls did not look or feel scored. You can see a vertical line, but cannot feel it with fingernail or finger. Mechanic didn't really say, "oh yeah" that cylinder is screwed, but did worry about small material between cylinder walls and rings. He did also say compression was at 90, other 3 where at 160 or so. I am going to buy a new or rebuilt engine, but I just think that pulliing the rod and piston and replacing the piston and rings, it might run. The mechanic said the pitting on the head could cause problem with combustion due to the way the fuel is "atomized" at high pressure. Anyway, take a look, thanks for the comments. Lesson learned, double double double check everything. |
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Doh! |
Anyone know of someone or a place thats selling a 2.3l disi turbo motor...mine just blew after 82k miles... -.- |
mine just blew after 91k miles, can someone tell me why there was oil in my intake tubing as well as around my filter? |
I have seen a few used engines out there, 1 on Ebay motors for $2,995 or offer and $450shipping, others for around $3,200 to $3,400 with or without shipping. You can also use the CX7 engine. I am going with a new engine from the Dealer for the warranty. They quoted $3,950 for the engine. Plus I think I can get them to knock about $1,000 or so off of the $2,500 labor they quoted to drop the old engine and put the new one in. I don't think they would negotiate on labor if I source my own engine. Rebuilts sometimes are costing more than new. I am wondering what I will be able to sell my old engine for. No low end damage, just some ever so slight scoring on the one cylinder, and head will probably need to be reworked. I could put a spark plug in it today and it would run, just lower compression on one cylinder. How long it would run for might be another question LOL. I have a couple of emails from places that have given me a quote if you want to pm me I can forward their info to you. |
waranty info I just blew my friggin motor. 19,000 miles.. not on the gas, just coasting in 4th coming up to a red light.....BOOM! im reading all these posts and getting scared.... Has ANYBODY had luck with the waranty? If so what kind of shit can i expect and look out for. Any help would be great. Thanks |
| All times are GMT -7. The time now is 06:32 AM. |
