Yes I was lucky and it didn't vent the block. I felt the vibes in the clutch pedal and babied it home where I pulled the oil pan and found the bent rod. |
I'm running PTP/HPFPUpgrade/DamnFastDD internals, they've been in my car for over 120k miles without issue. Most people here have a problem with him, but again, they've worked for me. Autotech makes good internals, and Corksport as well. If you want a complete pump CP-E has them. |
2010 Gen II here. My Engine hasn't "Blown" but has excessive blow by that is causing it to spew oil out the crank case breather and into the air intake. At first this smoke was diagnosed as a smokey turbo, until the turbo was replaced and things got worse. Leakdown test identified that all cylinders are leaking into the crank case. Compression/Leakdown Results were: Cyl 1: 165PSI/5% leakdown Cyl 2: 150PSI/35% leakdown Cyl 3: 140PSI/50% leakdown Cyl 4: 150PSI/40% leakdown Car still drives ok but power is way down and it occasionally burps, blowing a lot of smoke. This car has done 65000km (40500 Miles) and has done dozens and dozens of track days, so it's had an extremely hard life. Rebuild strategy at the moment is to buy a new long block from Mazda and drop a set of forged internals + injector seals in before doing an engine swap. I was running a DP and Intake and ECUTEK tune at 17PSI, so quite modest power levels (had that done before AP was available). Did NOT have a HPFP for much of this time so am wondering if this might have contributed to the engine wear or if this was purely thanks to all the track miles that the car has done. It might not have exploded but if the fuelling was anything less than perfect then it could have conceivably caused some detonation, especially at the racetrack. It didn't explode, but she sure didn't last long! |
1 Attachment(s) My engine blown 2 days ago car was on cold start up when a loud pop them like a ticking sound hole infront of 4 and spark plug 4 is smashed in, my mods ares only hpfp intake custom catback 77k miles |
As for mod plans (with respect to this post and your previous post), keep the balance shaft, if it's a DD, you'll want it. The OCC is a nice addition, but it's not necessary (I've run without one since I bought my car, and haven't really seen the need myself.) I would definitely post a WTB thread and ask if anyone is selling an AP V2, and get a proper e-tune as well. As the others have said, you'd do well to pick up a set of Autotechs too. |
As to which part? |
The oil recommendation. Dino oil for break in. Sent from my SAMSUNG-SGH-I337 using Tapatalk |
Oh, yeah. Sorry for the confusion. |
I need to pick your brain on fuel economy; I've been following the hypermiling threads and using the information to the best of my ability and I'm not seeing more than 31mpg on the interstate. |
Oh about 80 I think....when I slow down I do get a little better, obviously. But I commute 120 miles to work, and I'm usually in a little bit of a hurry. |
Well, that's probably the answer. If you're averaging 80mph and still getting around 30mpg, you're doing exceedingly well. I have to drive closer to 70mph in order to get anything above 30mpg. You know, wind resistance increasing as a square of the speed tends to have that impact. |
Yeah, I just thought we were driving at similar speeds. Thanks. I also forgot that I'm using 33% e85.... |
Well, I did a 160 mile trip at 75mph and it came out to 20mpg..... |
No one buys a mazdaspeed for hypermiling. Smarten up. |
No, but isn't it nice to be able to have both? |
You can have your cake and eat it too... Last night I got a text from the local full corn test mule of "32 mpg," but I'm still waiting for confirmation that was on the Speed. Edit: NVM, he sent that text to the wrong person; I should have known better since I know he doesn't have the self control to get higher than 20 in the Mazda. |
LOL! Truth! I say I "can" get that good mileage, but I usually see around 26. But it's nice to know that when I'm broke I can make the sacrifice if necessary. |
It can be done though. Just remember that after 60 MPH, you're losing to aero. This was my car on 50/50 (~e45): |
I'm almost never not trying to beat my best time, anytime I go somewhere. That's having my cake and eating it too. Mileage has never entered into the equation. |
But it isn't respectable. It's mildly terrifying. And that actually makes it quite appealing. - Mazda 3 MPS review, Matthew Jones, Top Gear. |
I am doing well to get 20mpg on e40... It is alright, as I get about 5 smiles per mile while boosting... |
Even road, 93/94 pump gas, highway speed (139kmph GPS speed), average fuel consumption is around 26-27mpg. If the speed is lower, around 110-120kmph and held constant (no crazy overtakes, and so on) I get 8-8.5l/100 (33-35mpg). On a 6MPS the fuel economy should be worse with 0.5-0.7l/100 in average (3-5 less mpg) than on a 3MPS because it is heavier and the transfer case takes away some of that moving energy. So there's definitely something off there. Maybe you should try to advance more in the closed loop sections, the factory timing should be fine. I'm not sure how that works with the 10.6:1 compression ratio but theoretically in closed loop a 2.3 liter engine with a 10.6:1 ratio should be significantly more efficient than another 2.3 liter engine with 9.5:1. |
I believe this came up in one of the high-compression build threads a while back. It migh'tve been @phate;, because I think I might've even asked about fuel economy. |
Hm, now to think about it - I do get a lot of random KR coming up at cruise. So the ECU could be reducing advance to try and fix that (even though I doubt its real KR as my engine is reaaaaally producing a lot of KR) and in turn gets bad mileage? The question is: if I increase the load limit for KR - how will that impact ECU's efforts to increase timing till it detects knock? What will happen if it keeps increasing it and it starts knocking but it will not be registered because load is below my set limit? |
If you're getting real KR, then the car should be doing at least 2 things: 1. Pulling a bunch of ignition timing 2. Dumping a bunch of fuel into the mixture to try and cool the combustion chamber The result: Bad fuel economy. Under normal low-load, closed-loop, operating conditions, the DISI motor does tend to generate a fair amount of KR. It's possible to tune around this, and many people have (including me). I used to see knock counts of 5-8 just driving around town, and on the highway. The fact that you're running a higher-than-stock compression engine could be leading to more hotter combustion temperatures, and more knock, more easily. Do you still have your EGR plugged in? |
No, no EGR. |
Good idea, I should try to reconnect it. edit: update: http://www.mazdaspeedforums.org/foru...ml#post2726614 |
120mi commute = beater 99-03 TDI or some other old econobox and save the wear and tear on your mazda. Especially if you're running hi-po tires. Yeesh. Plus, after driving that slow shitbox, your MS3 will feel like a goddamn rocket. Every time. |
Hey first time posting, read on hear and fix a ton on this car due to this site but never posted. Found this thread after I threw a rod and blew a hole through the back of the block last night doing about 35-40mph. Only mod is an intake with 120k miles. Whats the next step? Any suggestions. I'm honestly growing tired of fixing this car every month, but yet I love it to death. Do I buy a used block somewhere? Any suggestions? |
| All times are GMT -7. The time now is 06:32 AM. |
