Like Tree20Likes
 Old 11-08-2009, 04:54 PM   #481
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
damn blink, you blew after i sold you the AP?
2015 Mazda 6
 Old 11-10-2009, 09:35 AM   #482
kroze's Avatar
Posts: 29   (View Stats)
kroze will become famous soon enoughkroze will become famous soon enough
This thread is making me depressed. I just bought a 2010 Speed3
kroze is offline   Reply With Quote
 Old 11-10-2009, 10:02 AM   #483
tmtbiker's Avatar
Posts: 287   (View Stats)
tmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the world
should have done your homework.
Originally Posted by huffentuff09 View Post
Some Dude with bike in his name from FLA don't like my pointless posts..
tmtbiker is offline   Reply With Quote
The Following 2 Users Say Thank You to tmtbiker For This Useful Post:
Driver72 (11-24-2009), ms3077 (12-07-2009)
 Old 11-10-2009, 11:21 AM   #484
s-retire's Avatar
Posts: 58   (View Stats)
s-retire has a spectacular aura abouts-retire has a spectacular aura about
Keep an open perspective. The number of motors that have popped are a small percentage. The car is actually pretty impressive. The support from North American Operations is at best incompetent. Just be aware that Mazda NAO will be looking for any reason available to void a large warranty claim.
Keep it stock, drive it safely and sensibly and good luck. If it fails be prepared to stick by your rights. Stock motors have failed too.
and keep looking here for new updates!
s-retire is offline   Reply With Quote
 Old 11-16-2009, 10:36 PM   #485
akbrazil's Avatar
akbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond repute
Like the many members have said, this post makes a lot of members worried. I just picked up a 2010 ms3 and I would hate to have to deal with a blown motor (the hassel going to the dealer and hoping the claim doesn't get voided for whatever reason)
I haven't seen any 2010 blown motors (probably too soon to tell) but do you guys think Mazda would have fix the problem with the 2010 models????
akbrazil is offline   Reply With Quote
 Old 11-16-2009, 10:53 PM   #486
Smoke_31's Avatar
Posts: 98   (View Stats)
Smoke_31 is a splendid one to beholdSmoke_31 is a splendid one to beholdSmoke_31 is a splendid one to beholdSmoke_31 is a splendid one to beholdSmoke_31 is a splendid one to beholdSmoke_31 is a splendid one to beholdSmoke_31 is a splendid one to behold
Mazda accepts no official responsibility of a design or manufacturing defect for the MS3/MS6/CX7 motors.
Mazda did replace my motor under warranty though.
Smoke_31 is offline   Reply With Quote
 Old 11-17-2009, 06:01 AM   #487
tmtbiker's Avatar
No.
 Old 11-30-2009, 06:25 AM   #488
Speed3D3MonDK's Avatar
Posts: 96   (View Stats)
Speed3D3MonDK has a brilliant futureSpeed3D3MonDK has a brilliant futureSpeed3D3MonDK has a brilliant futureSpeed3D3MonDK has a brilliant futureSpeed3D3MonDK has a brilliant futureSpeed3D3MonDK has a brilliant futureSpeed3D3MonDK has a brilliant futureSpeed3D3MonDK has a brilliant futureSpeed3D3MonDK has a brilliant futureSpeed3D3MonDK has a brilliant futureSpeed3D3MonDK has a brilliant future
Groaned at 19 Times in 3 Posts
Default Blown Engines MS3
So mazda isnt covering most of these blown engines under the 5 year 50,000 mile warranty? or is it because people arent returning the cars back to stock before taking them to the dealership???
Speed3D3MonDK is offline   Reply With Quote
 Old 11-30-2009, 10:51 AM   #489
Smoke_31's Avatar
Usually the dealership makes claim that modification cause the damage. Even vehicles that have been returned to stock have been denied as Mazda claimed they could tell it had been modified.
I showed up to the dealership with Sri, tbe and bpv still installed and they warrantied my engine. It really depends where you take your vehicle.
 Old 11-30-2009, 04:44 PM   #490
imthatchop's Avatar
Posts: 9   (View Stats)
imthatchop will become famous soon enough
what do u guys think this is i got oil coming up bad threw dipstick i think the crankcase is cloged what can be the couse
imthatchop is offline   Reply With Quote
 Old 12-01-2009, 12:58 AM   #491
Smoke_31's Avatar
Obviously pressure is building up. Either your rings or head gasket are passing badly or like you said above, your PVC (system) is plugged. I would start by removing the PVC setup and running a straight through hose to see if it stops. If it doesn't, get a compression/leakdown test done.
Just a couple ideas.
 Old 12-01-2009, 09:38 AM   #492
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
I wouldn't try that. You will blow your dipstick out.
The PCV valve should prevent boost from getting to the crank case, if it is damaged it may not. If you remove it you are filling your CC with boost.
Try:
1) replace PCV valve with new one
if that doesnt fix it
2) compression/leakdown test
Suspension:
 Old 12-01-2009, 04:15 PM   #493
So All these blown engines are freaking me out a bit, is it happening on the modded out speed's, and whats and EDUCATED response to why these are so "common"
 Old 12-01-2009, 04:25 PM   #494
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
it happens to modded and stock speed3's. Its a design flaw inside the engine. supposably mazda fixed it or made it better in 08.5 and up
The Following User Says Thank You to For This Useful Post:
Speed3D3MonDK (12-02-2009)
 Old 12-01-2009, 04:46 PM   #495
Smoke_31's Avatar
Try:
I ran without a Pcv for months. My dipstick never blew out. If it was failing to open however, it would prevent pressure from leaving the crank case. Your air intake is always at atmospheric pressure or vacuum. It may see something slighty above atmospheric (guessing less than 1psi) when the bpv opens.
It is more likely blow by from rings not sealing properly causing his dipstick to blow out.
 Old 12-01-2009, 05:25 PM   #496
The Kamikaze King!
Groans: 754
With the Mazdaspeed3??
Suspension:
 Old 12-01-2009, 09:32 PM   #497
Smoke_31's Avatar
Yes, with the mazdaspeed3.
 Old 12-02-2009, 08:20 AM   #498
badams118's Avatar
Posts: 821   (View Stats)
badams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the world
Groaned at 126 Times in 71 Posts
What specifically changed on the 8.5?
2011 WRX | Cobb AP | Cobb DP | SPT CBE | AEM CAI
Whiteline F/R Sways | SPT SSK | TWM M1 Abrams
badams118 is offline   Reply With Quote
 Old 12-02-2009, 09:32 AM   #499
18psiWhiteMS3
Lurkers
Posts: n/a
they tightened up some clearances to prevent crank walk or some shit.
 Old 12-02-2009, 01:03 PM   #500
badams118's Avatar
Hmm, I still lean towards Lex's theory of the injectors spraying fuel on the far cylinder wall. It made sense considering the problems I had.
 Old 12-02-2009, 01:04 PM   #501
so by 8.5 and up, do u mean cars birth date or by car year, i have an 08, but it was made in 07.. how do i know is mines an 8.5
 Old 12-02-2009, 06:17 PM   #502
akbrazil's Avatar
if it was purchased in 07 then its an early 08. The 08.5 probably started to come out by early to mid year of 2008. I'm sure there's a way to check either by vin or on a tag off the car. I'm not familiar with mazda (this is my first) but my previous bmw you were able to check by the vin - there was this site I would go on "realoem" made just for bmw and if you type in your vin you get all the basic info of your model plus when it was built (month and year).
 Old 12-02-2009, 07:57 PM   #503
bf360's Avatar
Posts: 2,069   (View Stats)
no theres no need to check your vin, if its an 08.5 you have piano black interior and different seats, also white was only made starting in 08.5
The Following User Says Thank You to bf360 For This Useful Post:
ms3077 (12-07-2009)
 Old 12-02-2009, 07:59 PM   #504
cool, thanks, And Whos had there engine rebuilt, and how much did it cost.... What exactly was done
mines got the metalic gray interior around the radio and on the doors. So its the shity 08?
Last edited by Speed3D3MonDK; 12-02-2009 at 08:01 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-02-2009, 08:04 PM   #505
bf360's Avatar
i wouldnt say its shitty theres plenty of pre 08.5 that made power, the newer ones are just less prone to crank walk
 Old 12-02-2009, 08:28 PM   #506
whats the best way to beat that? new injectors. fuel pump, and good tune?
 Old 12-02-2009, 08:40 PM   #507
Doc-1's Avatar
Posts: 407   (View Stats)
Doc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the world
Groaned at 30 Times in 15 Posts
I waited 15 minutes before I started putting the Mods to this car. This car and engine were made to mod. Best base I have ever worked from. Yea I have blown engines before and a few transmissions (other platforms) but WTH this car is crazy fun to drive and have yet to hurt it. Wasted my tires in 10,000 miles. I have had more smiles per mile than any other car. If you are concerned about it leave it stock still fun, but if you have 5K you can turn this car into the terror of the neighborhood. The platform has issues...so what.... so does everthing else.
Doc-1 is offline   Reply With Quote
The Following 3 Users Say Thank You to Doc-1 For This Useful Post:
802MS3 (12-05-2009), ms3077 (12-07-2009), MS3Zoom24 (12-03-2009)
 Old 12-05-2009, 05:52 PM   #508
Some explain what crank walk is?
 Old 12-05-2009, 06:02 PM   #509
18psiWhiteMS3
Lurkers
Posts: n/a
its when ur rods pack there bags and leave, here is a pic of what it looks like
Last edited by 18psiWhiteMS3; 12-05-2009 at 06:03 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to For This Useful Post:
DaleNixon (12-05-2009), ms3077 (12-07-2009)
 Old 12-05-2009, 06:37 PM   #510
LoL i know the side effect, im talking about what it really is. I dont understand that. And is it just caused from upgrading the breathing mods on the car? And another quick question, i installed the SRI, and im curious as to if this will cause the car to run lean without a re-tune, or if by unplugging the battery, it will reread the intake amd adapt
 Old 12-06-2009, 01:02 AM   #511
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
After you install any component that will alter engine dynamics, you're going to want to:
1. Disconnect negative battery cable.
2. Pump brake pedal to completely drain power.
3. Let sit for 30-60 minutes.
4. Reconnect battery cable and drive car modestly for 100 miles.
Your ECU should be fully adjusted to the new parameters after this. Keep in mind that these steps are for simple bolt-ons. Anything more demanding than breather or exhaust mods will most likely require a tune of some sort.
this forum serves 2 purposes
ms3077 (12-07-2009)
 Old 12-06-2009, 02:36 AM   #512
kwsmithphoto's Avatar
Posts: 1,035   (View Stats)
kwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the world
Groaned at 41 Times in 9 Posts
Crank walk is when the crank tends to move across it's bearing surfaces, adding a bending load to the connecting rods.
The "walk" part only applies to when it's running. Engine off, some people call it "end play," or "runout," and few other terms floating around, but basically:
Crankshafts aren't supposed to move very much along their axis of rotation. If they do, man, all sortsa shit can go wrong.
This car has never been raced, modified, or abused in any way. Maintained as required, only wear items have been replaced with OEM or better parts, in compliance with all warranty terms, and federal and state laws.
kwsmithphoto is offline   Reply With Quote
 Old 12-06-2009, 06:49 AM   #513
So by purchasing forged rods and such, problem solved?
 Old 12-06-2009, 09:51 AM   #514
18psiWhiteMS3
Lurkers
Posts: n/a
yes pretty much
 Old 12-06-2009, 01:21 PM   #515
the main thing crank walk is caused by is putting a beefy ass clutch in right?
 Old 12-07-2009, 07:22 AM   #516
DaleNixon's Avatar
Posts: 2,079   (View Stats)
Groans: 91
There's also something about thrust washer tolerances and planet alignment.
 Old 12-07-2009, 03:48 PM   #517
ILSpeed308's Avatar
Posts: 26   (View Stats)
ILSpeed308 is just really niceILSpeed308 is just really niceILSpeed308 is just really niceILSpeed308 is just really nice
Default Blown Motor - Still at the Dealer
i hoped to never have to post here, but it looks like i've been hit with the rod problem everyone else seems to be having...
i was day driving to work on the highway - 6th gear at about 70mph when the car felt like it stuttered. check engine light then oil light. i cut the motor off and pulled to the side of the road - oil everywhere. towed it to my buddy's shop and yup - #4 rod snapped sending something straight down through the oil pan. motor is shot.
so - 5 hours later and a ton of work, the car is back to stock and being towed to the dealer. since it was a weekend, of course Mazda's not open for the dealer to start the warranty claim. i spoke to them today and they're in the process of sending pictures / e-mails to Mazda.
the only thing that remains on the car is my gauge cluster - boost gauge and wideband O2 which i removed the bung from. haven't heard back yet but from what the service guys were telling me, i should be getting a remanned longblock from Mazda. Car was remapped back to stock with my AP as well.
Mods - CPE Downpipe, Cobb FMIC, CPE CAI, Denso IVT22 gapped @ .026, Turbosmart 50/50 BPV - Recirc, custom AP tune by P&L Tuning (Chicago, IL).
Guess I have a few questions :
1. I was holding about 20psi with the custom tune putting down about 280hp / 293 lb/ft tourque at the wheels. Need new rods to be safe?
2. I was hopefully going to be modding the car with CDFP internals, turbo manifold and have my turbo reworked. Will it be safer with the new rods?
I'll post again once I hear from the dealer.
Currently Driving - 2010 Mazda 6 v6 - LOADED which is impressive.
ILSpeed308 is offline   Reply With Quote
The Following User Says Thank You to ILSpeed308 For This Useful Post:
FreeFlyFreak (12-07-2009)
 Old 12-07-2009, 05:12 PM   #518
I <3 your mom
Dash08's Avatar
Groans: 293
^^^^Don't worry man. Mazda doesn't do remanufactured engines for mazdaspeeds. They use brand new longblocks.
 Old 12-07-2009, 05:33 PM   #519
... Didn't u here a ticking noise somewhat prior to this? Something slightly outta the ordinary, because usually u will here the crank walk prior to it throwing a rod...
 Old 12-07-2009, 05:35 PM   #520
Unfortunately 20 psi with flow mods on the stock pump caused some prior damage to the rods that finally let go.
802MS3 (12-09-2009), Decepticon (12-07-2009), mr_mazda329 (12-27-2009)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/mazdaspeed-2-3l-disi-turbo-blown-engine-6113/
Blown engine theory This thread Refback 12-21-2015 05:13 AM
Mazda 8 Owners - Page 145 - Mazda Mall - Autoworld Forum This thread Refback 10-25-2015 08:17 PM
What are your guys thoughts on the Mazdaspeed 3 or 6? : cars This thread Refback 07-20-2015 07:18 AM
The Garage - Car Enthusiast Club [Now Motorcycle friendly&#33;] - Page 890 - Off Topic - Linus Tech Tips This thread Refback 07-19-2015 12:49 PM
Si to Mazdaspeed 3? - 8th Generation Honda Civic Forum This thread Refback 05-13-2015 03:22 PM
2016 Mazdaspeed 3 - Page 3 - RedFlagDeals.com Forums This thread Refback 04-27-2015 05:10 PM
MazdaSpeed 2.3L DISI Turbo Blown Engine Resource Thread - Mazdaspeed Forums This thread Refback 03-19-2015 05:29 AM
2.3 duratec engine upgrades? This thread Refback 03-17-2015 05:34 PM
Problem/Noise/Rattle *Video* This thread Refback 10-06-2014 05:45 AM
2015 WRX 2.0 FA20DIT Cobb AccessPort Available Now! - Page 7 - NASIOC This thread Refback 07-31-2014 01:48 PM
BOSS and a Mazdaspeed 3 that would not leave me alone... - Page 2 This thread Refback 04-10-2014 06:29 PM
Drove my first 350z (revised) - Page 13 - MY350Z.COM Forums This thread Refback 03-31-2014 06:30 PM
Problem/Noise/Rattle *Video* This thread Refback 03-02-2014 11:40 AM
Mazda 6 MPS blow engine ? This thread Refback 02-14-2014 01:16 AM
Cheerio after brief ownership This thread Refback 01-27-2014 10:31 AM
Mazda esitleb - Mazda 3 MPS : Mazda mudelid - Page 13 This thread Refback 01-09-2014 04:18 PM
Mazda 8 Owners - Autoworld Forum This thread Refback 12-22-2013 08:02 AM
Mazdaspeed 3 Why it's a PITA! This thread Refback 11-05-2013 09:55 PM
VWVortex.com - New (to me) Car - Or, let's see if buying a second hand, modded DD is a good idea... This thread Refback 10-30-2013 06:01 PM
High mileage club for ss 9-3? - Page 3 - SaabCentral Forums This thread Refback 09-12-2013 07:39 PM
Czy jeste? zadowolony ze swojego MPS'a? (2/6) This thread Refback 04-19-2013 12:21 PM
Quality Control/Production Issue Checklist Upon Delivery This thread Refback 04-12-2013 11:21 AM
Mazdaspeed 3 Why it's a PITA! - Page 2 This thread Refback 03-19-2013 04:18 AM
Mazda 6 MPS blow engine ? ? Mazda MPS Owners Club This thread Refback 03-04-2013 05:42 AM
coup en wot - Mazda 3 Quebec This thread Refback 01-27-2013 01:24 PM
Problem/Noise/Rattle *Video* ? Mazda MPS Owners Club This thread Refback 01-17-2013 12:52 PM
Cheerio after brief ownership ? Mazda MPS Owners Club This thread Refback 01-14-2013 04:04 PM
Mazda 6 MPS blow engine ? ? Mazda MPS Owners Club This thread Refback 01-14-2013 01:57 AM
Quality Control/Production Issue Checklist Upon Delivery - Page 6 This thread Pingback 12-05-2012 11:48 PM
Random Thread - Page 8734 - StanceWorks This thread Refback 11-08-2012 10:46 PM
mazdaspeed3 engine kablooie - Miata Turbo Forum - It's the Cat's Meow This thread Refback 10-17-2012 09:13 AM
A noob's guide to issues with the 6 &bull; Mazda MPS Owners Club This thread Refback 10-12-2012 01:26 PM
Mazda 6 MPS blow engine ? &bull; Mazda MPS Owners Club This thread Refback 10-12-2012 12:20 PM
Mazda Speed3 - Miata Turbo Forum - Home of the Boostin' Bangers. This thread Refback 09-25-2012 07:59 PM
BOSS and a Mazdaspeed 3 that would not leave me alone... - Page 2 - SVTPerformance This thread Refback 09-11-2012 06:37 AM
mazdaspeed3 engine kablooie - Miata Turbo Forum - Home to the Turbo Miata This thread Refback 08-28-2012 10:52 AM
I love my SI but test drove a mazdaspeed 3 whiile with my wife! - Page 2 - 8th Generation Honda Civic Forum This thread Pingback 08-24-2012 09:30 AM
Mazdaspeed 3 Why it's a PITA! - Page 3 This thread Refback 08-12-2012 01:34 AM
Adios amigos'.... - Page 3 - Ford Mustang Forums This thread Refback 08-03-2012 10:09 AM
Adios amigos'.... - Page 2 - Ford Mustang Forums This thread Refback 08-03-2012 09:01 AM
The Forum Wars: Season 2 - Page 111 - 8th Generation Honda Civic Forum This thread Refback 07-31-2012 09:33 AM
RX-8 with Mazdaspeed3/6 Motor Swap plan - Page 2 - TriStateTuners.com :: Home of Tristate Auto Enthusiast This thread Refback 07-03-2012 04:15 AM
Why doesn't the MazdaSpeed3 get more love? This thread Refback 06-27-2012 06:56 AM
VWVortex.com - Why doesn't the MazdaSpeed3 get more love? This thread Refback 06-27-2012 06:39 AM
Mazda MPS Owners Club &bull; View topic - Mazda 6 MPS blow engine ? This thread Refback 06-06-2012 07:55 PM
Subaru's confirms new FA20 turbo motor - Page 12 - Subaru Impreza WRX STI Forums: IWSTI.com This thread Refback 05-22-2012 10:56 PM
Blown engine theory - Page 15 This thread Refback 04-12-2012 03:08 PM
VersaTuner: ????????, ??????????, ????? ?????? This thread Refback 03-30-2012 06:26 AM
Mazda MPS Owners Club &bull; View topic - Cheerio after brief ownership This thread Refback 03-28-2012 01:47 PM
6Y MAZDA's 2006 MazdaSpeed 6 This thread Refback 03-25-2012 07:43 PM
Big turbo chicken thread phailerider MazdaSpeed 3/6 - Turbo Induction 111 07-01-2010 06:18 AM
Green Genesis Coupe shows up, 286 hp turbo DI engine nearby? Haltech Automotive News 1 05-07-2008 08:24 AM
Blown Seal? Rican219 MazdaSpeed 6 - Engine, Transmission & Driveline 8 04-19-2008 09:52 AM
GReddy Turbo Ti-C 3" Catback Exhaust - Mazdaspeed 3 Performance Racing Mazdaspeed3/6 General Discussion 5 04-12-2008 09:57 AM
FREE Microsoft Mobile Business Resource Kit Haltech Hot Deals Section 0 03-26-2008 08:30 AM
Page generated in 0.58235 seconds with 37 queries
