![]() | | #641 | ![]() |
![]() Join Date: Nov 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
Groaned at 9 Times in 3 Posts
| Not Ranked : 0 score "Throttle never closes unless the engine is shutoff. If engine shutoff, throttle closes momentarily so no fuel can go into engine and cause diesling, then opens and stays open. In the case of coasting downhill in gear, throttle stays open, but injectors turn off. acts like an air pump." Edit: "Throttle never closes unless the engine is shutoff. If engine shutoff, throttle closes momentarily so no air can go into engine and cause diesling, then opens and stays open."
__________________ 2007 Cosmic Blue Mazdaspeed 3 GT Mods: Mazdaspeed Cold Air Intake, Mazdaspeed Cat-Back Exhaust, Defi BF Amber Boost Gauge in Driver's Vent Last edited by ASIC_BSEE; 01-15-2010 at 11:53 AM. |
![]() | | #642 | ![]() |
If the throttle stayed open during coasting you would not see high vacuum readings in the manifold so ummm ... who is this person that replied to you? I'd love to ask them more "engineering" questions. | |
![]() | | #643 | ![]() |
The first statement was just in response to my question about when does the throttle plate close. They were just saying that the only time the throttle plate (air flow control) closes is when you turn off the engine. It closes to make sure the engine stops, then re-opens. I believe that is that noise you hear a few seconds after you turn off the car. It's the throttle plate re-openning. The second description applies directly to my case. I was trying to rule out detonation or preignition and this confirms that it couldn't have been detonation or preignition that broke my rod since the injectors were shut off while I was coasting. I called the customer service number for MAZDAUSA, 1-800-222-5500. They really can't guarrantee they will be able to get answers for you, but they try. They are just customer service reps and they pass your question to the Engineers. If they feel the information isn't proprietary, they will respond.
__________________ 2007 Cosmic Blue Mazdaspeed 3 GT Mods: Mazdaspeed Cold Air Intake, Mazdaspeed Cat-Back Exhaust, Defi BF Amber Boost Gauge in Driver's Vent Last edited by ASIC_BSEE; 01-15-2010 at 11:54 AM. | |
| The Following User Says Thank You to ASIC_BSEE For This Useful Post: | djuosnteisn (01-15-2010) |
![]() | | #644 | ![]() |
| Not Ranked : 0 score Yes, the injectors do close during coasting conditions. It is called and over-run fueling state. The throttle plate does not completely close during coasting - correct - but it is close to being closed. Detonation is never a concern during coasting but damage done due to detonation can fatigue and deform a rod that will let go under high engine vacuum. Under vacuum the rod experiences the strongest "pulling" forces on its beam. Think of the beam as a very high strength spring. After enough cycling, if not designed for the load it is handling, it will fatigue and fail. |
| The Following User Says Thank You to Lex For This Useful Post: | ASIC_BSEE (01-30-2010) |
![]() | | #645 | ![]() |
![]() Join Date: Aug 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 160
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score It seems to me that detonation is not a factor at all... of all the posts I've read from guys who had a rod break, and tore down the engine afterwards, there was never evidence of detonation, i.e.: pitting on the piston crowns. I cant say I've seen even one engine with a broken rod where anyone saw any evidence that detonation had anything to do with it.
__________________ '07 Speed 3 GT, Red, MSCAI with flow straightener, 2nd cat delete, JBR TMM, AWR RMM, and Cobb AccessPORT running custom 20% e85 tune. |
![]() | | #646 | ![]() |
![]() Join Date: Aug 2008 Location: jersey
Rep Power: 609 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 388
__________________ | |
![]() | | #647 | ![]() |
| The Kamikaze King! ![]() Join Date: Jun 2008
Rep Power: 1829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,794
Groans: 754
Is that the problem is more likely to be a pre ignition event rather than detonation event. Where the mixture is ignited too early in the stroke by something other than the spark plug, by lets say "glowing carbon deposits". This type of event may not be picked up by the knock sensor and would produce massive extra force on the rod. Enough to throw it through the block. I am not saying this is the cause, I am saying it is much more likely than knock/detonation, because of the lack of evidence of such knock/detonation.
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 ![]() http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. | |
| The Following User Says Thank You to FreeFlyFreak For This Useful Post: | SilverDemon (01-15-2010) |
![]() | | #648 | ![]() |
![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 4726 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. | |
| The Following 2 Users Say Thank You to SilverDemon For This Useful Post: | ASIC_BSEE (01-16-2010), FreeFlyFreak (01-15-2010) |
![]() | | #649 | ![]() |
Groans: 754
That is why the first thing I did when I got ATR was to lean out the AFR. Leaner = less carbon. A catch can would help in this regard too. But I dindt go that route, as I want quick and easy back to stock just in case. Having said that it may not necessarily be carbon deposits that are causing the preignition, but at least that would help minimize one possible cause.
![]() | | #650 | ![]() |
| Eth/Meth Junkie ![]() Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 2957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,846
| Not Ranked : 0 score I also tend to think the heavy carbon build up is a major concern since it could easily provide a pre-ignition initiating condition. Which is why I am using lots of Meth and have a OCC that I am going to install...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
| The Following User Says Thank You to cld12pk2go For This Useful Post: | SilverDemon (01-15-2010) |
![]() | | #651 | ![]() |
![]() Join Date: Sep 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 51
| Not Ranked : 0 score Noobie with a question: Can pre-ignition occur while off-throttle and the injectors turned off? If it does occur, will it cause the rod to break right away or would it weaken the rod over time like detonation would? |
| The Following User Says Thank You to YammerR1 For This Useful Post: | SilverDemon (01-15-2010) |
![]() | | #652 | ![]() |
| Not Ranked : 0 score A pre-ignition event will kill the rod almost instantly. The only way I believe a pre-ignition to occur while off throttle would be a leaky injector, or another fuel source i.e. oil being ingested. There is no engine that can live through a pre-ignition event, but most modern engines can live a while with detonation, but, and this is a big one, once the engine starts making more than 1.5 - 2 horse power per cubic inch it becomes very critical to keep the detonation at bay. Even with very short detonation event there will still be the signs, tops of the pistons will have some sandblasting effect, and metal flakes embedded in the porcelain of the spark plug.
![]() | | #653 | ![]() |
| Not Ranked : 0 score From what I understand, pre-ignition is far more damaging to the pistons than detonation. A single pre-ignition event usually destroys the piston and/or rod on the first event. It is said thet it blows holes in the pistons, but I guess a snapped rod is just as good. I wondered if I had a leaking injector, but they can't test them at the dealership, so who knows. I also wondered if it was oil detonation, but there was no sign of oil ingestion according to the tech.
__________________ 2007 Cosmic Blue Mazdaspeed 3 GT Mods: Mazdaspeed Cold Air Intake, Mazdaspeed Cat-Back Exhaust, Defi BF Amber Boost Gauge in Driver's Vent |
| The Following User Says Thank You to ASIC_BSEE For This Useful Post: | SilverDemon (01-15-2010) |
![]() | | #654 | ![]() |
| Not Ranked : 0 score yeah I agree that preignition could definitely be causing this. We all have seen how the pistons usually have a ton of crud on top of them in a lot of the pics that have been posted. I havent done meth or an OCC, I want to stay warranty friendly, but I do run a can of Seafoam/Deep Creep through the intake before every oil change. I had GREAT success with this stuff on a project car I had a while back. Reminds me, I want to start replacing the PCV valve every 10k or something like that... One thing though... wouldnt the overly rich condition that contributes to the extra carbon buildup, also do a great deal to cool things down and keep the carbon from getting hot enough to preignite the charge? Sorry if thats a dumb question. Also, Havent we had people throw rods that HAD meth and catch cans?
| The Following User Says Thank You to bast525 For This Useful Post: | SilverDemon (01-15-2010) |
![]() | | #655 | ![]() |
What did you plugs look like? Was the car runner a little hotter than usual? Do the cylinder walls look scuffed?
| The Following User Says Thank You to SilverDemon For This Useful Post: | ASIC_BSEE (01-15-2010) |
![]() | | #656 | ![]() |
![]() Join Date: Jan 2009 Location: Venice, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 135
Groaned at 41 Times in 9 Posts
| Not Ranked : 0 score I would think that a well-designed OCC wouldn't void your warranty, since everybody knows they are better for an engine than a PCV system is. But Mazda's job is to cut their losses, so... Besides, in California at least, you have use an OEM PCV system to get through a smog check. The CARB insists that all those stray fluids and gasses get burnt in the engine, instead of shed into the environment. Nevermind if you put the grizzle from an OCC in to your used motor oil tank and dispose of it responsibly, they mandate PCV's. Period. It's been said before, but this motor wasn't designed from scratch for direct injection, it was an add-on. I don't know if they got it quite right yet, but I do know that revisions to the PCV system have been made since the DISI motor was introduced. Still, I'm amazed about how much mystery junk fills up an OCC that would otherwise be dumped back into the intake manifold - without the benefit of fuel detergents to clean it up. As for engines with methanol systems and OCC's installed to combat the problem blowing up too, well, apparently it's not enough. One product I've had good luck with in the past was Mopar Combustion Chamber cleaner. It's specifically made to clean carbon from the combustion chambers. Works a bit differently than Seafoam, which I'm not fond of, but if properly used it does dissolve carbon buildup very well. You don't put it in the fuel or oil, you spray it into a vacuum port with the motor just runnning a bit above idle, and let it sit for 3 hours, then drive the car hard to blow out the result. Lot's of cat-clogging smoke will be produced, but it really did wonders on my previous cars. I'm hesitant to recommend it on these motors though since it was formulated to be sprayed into a throttle body that the DISI motor lacks, but I payed a shop to visually "scope" the cylinders and they as were clean as an OR. Much different motors though. And I spent a lot money replacing the cat's on my last car because the CEL was throwing a failure code, so it would't pass smog. Ran great though, passed the sniiffer test with ease, and the engine had zero carbon buildup in the cylinders after 85K. Point being, if pre-ignition is actually happening from carbon buildup, this stuff WILL remove it. But I take zero responsibility if it does more harm than good on your car though. What I wouldn't do is use a piggyback ECU that leans the AFR out in any condition. I know from my shitty mpg that the stock ECU just dumps fuel to stop detonation. But how they got a motor certified to dump so much un-burned fuel into the air is a mystery. And "Italian tune-ups" just make it worse. I haven't even pulled a spark plug on my car yet, it only has 10K, but I'm concerned. I'd like to solve the problems without voiding the engine warranty, and if running too rich too often is the real culprit, shame on Mazda. Personally though, carbon buildup is an especially bad thing on pressurized motors, so a plug check and maybe a dose of Mopar CC is in order. And I like the idea of replacing the PCV every year, even on a stock car, since that seems to be a constant issue. At least on the pre-2010 versions, which have a different ECU and yet another revision of the PCV system. It's probably a better combo, but I can't legally change them in my state. Besides, the ECU is integrated into what used to be called the "body computer," so it might do more harm than good. Plus, it would obviously void the warranty, and make it impossible to pass a smog check, since the ECU is essentially married to the VIN number, which their machines look for right away. |
![]() | | #657 | ![]() |
I could see carbon deposits being of concern if he were ripping around in high boost and cylinder temps got hot enough to cause the carbon to glow, which could ignite injected fuel before the spark does. | |
![]() | | #658 | ![]() |
Groans: 754
Could there have been some damage due to pre ignition and then the rod gave way under the tension of engine braking..... maybe. All I did was post my theory on why I think "most" MZR motors blow, it was not related to anyone's particular case. Personally, in ASIC_BSEE's case I would suspect some kind of flaw in the rod metal. Just because it broke in a different place than the other rods I have seen pics of, further down toward the crank in a thicker part of the rod. It may be too mangled to tell, but I would be interested to see if there is evidence of bending on that rod. Or evidence of a flaw in the metal structure. Again, just speculation from looking at the pics.
![]() | | #659 | ![]() |
![]() Join Date: Jan 2010
Rep Power: 0 ![]() Thanks: 0
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score good stuff |
| The Following 3 Users Say NO Thank You to phong3992 For This Un-useful Post: |
![]() | | #660 | ![]() |
Groans: 754
| Not Ranked : 0 score Stop Already: Find more posts by phong3992 Read. Don't post till you have something useful to say/ask
| The Following 3 Users Say Thank You to FreeFlyFreak For This Useful Post: |
![]() | | #661 | ![]() |
| Not Ranked : 0 score I got the word that the short block was ordered and they should have an ETA this week. I owe my dealership a HUGE thanks for all they have done. They really have gone out of their way to diagnose my car and get this whole thing resolved.
| The Following User Says Thank You to ASIC_BSEE For This Useful Post: | FreeFlyFreak (01-19-2010) |
![]() | | #662 | ![]() |
| Not Ranked : 0 score That's really good news, very happy for you. How much did that extended warranty cost you, and what company is it? |
![]() | | #663 | ![]() |
![]() Join Date: Aug 2009
Rep Power: 2585 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,910
Groans: 35
Groaned at 16 Times in 11 Posts
| Not Ranked : 0 score ASIC_BSEE.. did u have a tune? A friend who has a MS3 -07 was called in to Mazda to have his ECU reprogrammed.. some update. One of the update he was told was a torque limiter in gears 1-3, some early -07s doesent have this, all later models should have it. That could be a problem maybe if u dont have it.. just a thought... anyone heard of this?
![]() | | #664 | ![]() |
| Not Ranked : 0 score Looking through these pictures here ... always the same story - the rod get sslightly tweaked so now the beam is not straight - or it was never completely straight stock. After this the car continues to run but the rod is loaded off axis on every stroke works the metal ... kind of like bending a wire back and forth. This can last for a while but eventually the rod fatigues and snaps. Thing is that most of the time no one will notice a slight bend in the rod and the rod will let go at an unexpected time after it's been worked enough. The rods seem to be quite malleable from that point of view. Definitely a forged metal - not that it matters at this point. |
![]() | | #665 | ![]() |
| Not Ranked : 0 score Has anyone noticed this type of a change in ATR's stock style maps?
![]() | | #666 | ![]() |
__________________ 2007 Cosmic Blue Mazdaspeed 3 GT Mods: Mazdaspeed Cold Air Intake, Mazdaspeed Cat-Back Exhaust, Defi BF Amber Boost Gauge in Driver's Vent | ||
![]() | | #667 | ![]() |
| Not Ranked : 0 score Wow that's expensive, but it sounds like they came through with great service. Thanks for the info. |
![]() | | #668 | ![]() |
![]() Join Date: Feb 2010 Location: Killeen TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score I used to drive my MS3 like a rent-a-car ![]() , and I have never had an issue with it. I already spent a lot of money on parts including a gt3076r, and I am waiting for the fuel pump to arrive, so I can start putting stuff on and tuning. I am really worried about blowing my engine up, and I am wandering if the problem that every body that blown his engine had good lubrication. Did they change the oil when they were supposed to? Were they monitoring oil pressure? Was the engine receiving enough fuel? Every body is talking about what happened, but no one have given those details yet. When I say monitoring I am not talking about a dash-hawk. Did anybody have gauges to monitor that? Did they look at them, or they just had them because they look cool on the dash? ![]() To be honest I have a lot of things to install, and all I have is a boost gauge for right now. I am wandering if a good stand-back tune would prevent me from having that issue. |
![]() | | #669 | ![]() |
| Not Ranked : 0 score I just read that entire ptp thread on oil hydrolocking the motor yada yada.. any verification on that? or anything? I just wanted a reliable fun DD with a bit of power but it potentially looks like a big headache coming my way |
![]() | | #670 | ![]() |
![]() Join Date: Apr 2008 Location: Edmonton, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
| Not Ranked : 0 score In all honesty, keep it stock and if anything happens, Mazda can warranty it. If you want to modify it, get the MSCAI2, MS catback, MS spings or coilovers and be happy with it. It is a fun car in stock form. If you feel really brave, add a Cobb AP and get a tune done. It will be reliable and fun to drive. For dealership visits, uninstall the Cobb AP and TAKE THE UNIT OUT OF YOUR CAR. The biggest thing is to get a good tune done when you add a modification. Even with an intake, you should at the very least, calibrate your MAF sensor. That's my opinion. |
| The Following User Says Thank You to Smoke_31 For This Useful Post: | _Toxic_ (02-12-2010) |
![]() | | #671 | ![]() |
| Not Ranked : 0 score I hope I can have a solid warranty on a used version, not get owned if they find out the car's been previously modded or some shit |
![]() | | #672 | ![]() |
![]() Join Date: May 2009 Location: Honolulu, Hawaii
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
| Not Ranked : 0 score Check this picture out that my friend took of my blown MZR engine ![]() This really sucked but my cars back up and running now. running better than ever! Last edited by 808mazdaspeed3; 02-14-2010 at 02:28 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #673 | ![]() |
| Not Ranked : 0 score ^ Details on how it blew, etc etc? |
![]() | | #674 | ![]() |
| Not Ranked : 0 score I was previously running and AccessPort. Cruising at 60MPH on the highway just started seeing smoke and then a pop. Pulled over to find a large puddle of oil on the ground and me stuck on the side of the road. After inspection of the engine by friends we found the engine running to lean. The turbos exhaust housing was all white and powdery. Spark plugs completely fowled. My engine met all the requirements for stage 1 and 2. from speaking with my friends i realized that not all OTS (off the shelf) maps are created equally and that due to the altitudinal conditions my car is under it will directly affect my A/F ratios. We have a tuner that will be coming to Hawaii to tune my new engine and goodies when they arrive! |
| The Following 2 Users Say Thank You to 808mazdaspeed3 For This Useful Post: | Lex (02-14-2010), madvillain (02-15-2010) |
![]() | | #675 | ![]() |
Did you have a fuel pump installed and noticed any weird issues with the car prior to the blow? Thanks for the info, just doing a bit of a survey of blow-ups - it's a bit of a hobby | |
![]() | | #676 | ![]() |
| Not Ranked : 0 score to further elaborate on what i mentioned... for the past two days I've been noticing bellowing white smoke coming from my tail pipe. This happens mostly at idle. I'm due for a PCV valve change and definitely a oil catch can. I also looked into the PTP stop smoke fix and I'm still smoking. It went away late yesterday but I'm still concerned because my new engine has less than 4k on it now. Unfortunately I didn't buy this car new and at 32k it blew. Who knows what the previous owner had done to it. I suspect it had an AP on it previously because there was a cobb sticker in the engine on the radiator support when I got it. car was bone stock though. I'm still not running my AP though.
unfortunately no fuel pump internals or pump installed due to it being unavailable. I'm ordering the PTP internals though. no worries. Glad someones taking the initiative to get to the bottom of these issues. Last edited by 808mazdaspeed3; 02-14-2010 at 03:03 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #677 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
| Not Ranked : 0 score Not sure if this is important or not...but according to Mazda (dont ask how I know) this issues is directly linked to Hydrolocking due to Too much fuel. How many people had upgraded Fuel Punp/Internals? I would still think is a hole in the ECU) but supposedly the cause is that the system gets more fuel than it expects (during a certain situation) and it hydrolocks because there is too much fuel in the cylinder. ALSO, there is a section in the ECU that monitors and records when and If the ECU is changed. so SUPPOSEDLY they know when you change it...even if you set it back. Dont flame me...just sharing what I heard from mazda (while they were working on 2 engines that were blown) |
![]() | | #678 | ![]() |
![]() | | #679 | ![]() |
![]() | | #680 | ![]() |
| Big turbo chicken thread | phailerider | MazdaSpeed 3/6 - Turbo Induction | 111 | 07-01-2010 06:18 AM |
| Green Genesis Coupe shows up, 286 hp turbo DI engine nearby? | Haltech | Automotive News | 1 | 05-07-2008 08:24 AM |
| Blown Seal? | Rican219 | MazdaSpeed 6 - Engine, Transmission & Driveline | 8 | 04-19-2008 09:52 AM |
| GReddy Turbo Ti-C 3" Catback Exhaust - Mazdaspeed 3 | Performance Racing | Mazdaspeed3/6 General Discussion | 5 | 04-12-2008 09:57 AM |
| FREE Microsoft Mobile Business Resource Kit | Haltech | Hot Deals Section | 0 | 03-26-2008 08:30 AM |
