Notices
Like Tree9Likes
 Old 03-02-2012, 11:45 PM   #1121
Atx6's Avatar
Posts: 17   (View Stats)
Atx6 is a name known to allAtx6 is a name known to allAtx6 is a name known to allAtx6 is a name known to allAtx6 is a name known to allAtx6 is a name known to all
Originally Posted by cplensdorf View Post
Here are some pics of the new Mazda long block. Cost was $3500 no core. No shipping. As you can see it was packaged nicely on a sturdy cardboard palet. It included valve cover (new style), timing cover and crank pully, fuel pump housing, exhaust studs, oil pump, water pump and oil pan. Needed to purchase a few gaskets, about $80 worth. Then engine was tightly sealed as you can see with tape over ever opening even some that were not openings. Very happy with it so far...got almost 1000 miles on it and the first oil change revealed no problems. The engine was delivered at top dead center with no crank sensor but the tooth was marked in case the engine was turned prior to mounting the crank sensor....I will post more pics if anyone is interested. It took about 15 hours to remove and install including a new clutch. It took about 20 hours to clean parts and all the oil and coolant on everything from the grenading rod. Probably could do the swap in a long day if I had to do it again....not hoping I will have to though.
Hi
Have the same issue as you,just want to know if you can give the Mazda dealer info that you the block from. I live in TX and they cot me $5000 for the block . I will be great if I can get for $3500. Thank again
Atx6 is offline   Reply With Quote
 Old 03-08-2012, 01:59 AM   #1122
Lordchristopher's Avatar
Posts: 4   (View Stats)
Lordchristopher has a little shameless behaviour in the past
Default Help!!!! My motor blew. And they want $9300 to fix it!!!!
I heard a small pop a few days ago. Engine light came on car seemed fine, turned it off and on light want off thought it was just a backfire. So today going down 95 @77 mph, by Philli accelerated heard the pop again this time louder and lots of smoke. Lost power but the car kept moving, drove to the local dealer where it was pronounced DOA. Blown motor.
CP-E MZR DISI 2.3 HPFpump™
CP-E MazdaSPEED3 3" SS Downpipe
CP-E flashed computer with CP-E Standback
Cold air intake
Lowered a bit
sway bars
Passport 9500ix & Laser SHIFTER ZR4™
Lordchristopher is offline   Reply With Quote
 Old 03-08-2012, 02:38 AM   #1123
mituc's Avatar
Posts: 903   (View Stats)
After that event and prior to going to your dealer did you feel any vibrations or anything?
I'm not sure if you can drive the car with a blown motor (meaning a hole in the block, or a severely bent rod/crankshaft, blown valves and so on).
What you're saying here sounds more like oil starvation, meaning that you ran out of oil and your engine internals are cooked up (most probably the piston rings, but not limited to that).
2008 Cosmic Blue Mazda 3MPS
Bilstein B14 PSS, SSR Type-F, Michelin PSS 225/40/R18 US Spec, CS RMM Inserts, AutoExe Street Pads
Cobb SRI, SU TMIC, Cobb XLE, NGK LTR7IX, Corksport CAI Box, UR catted DP and res TP, GS EBCS, Autotech internals, GTX3071, Bosch 3BAR MAP Sensor
StratiVersaTuned
 Old 03-09-2012, 01:54 AM   #1124
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,148   (View Stats)
Groans: 754
Or melted a piston like me.....
I blew mine and limped it 45-50 miles on 3 cylinders.
Suspension:
The Following 2 Users Say Thank You to FreeFlyFreak For This Useful Post:
Neverlift (05-10-2012), Tokay444 (03-09-2012)
 Old 03-09-2012, 09:06 AM   #1125
Default Should we get a big time Lawyer and start a class action law suit.
Mazda has protected themselves with legal verbiage. After reading most of these post it looks like the are hundreds of us with the same problem, modded or not. As a group we can make a difference and have them replace the motors with better components or refund us every penny we have put into our speed3s. I will look into finding a lawyer who specializes in this area we may need to find every person who own one. And get them on board. I'll let ya all know ASAP. I just want my car fixed. No money.
The Following 2 Users Say NO Thank You to Lordchristopher For This Un-useful Post:
FreeFlyFreak (03-10-2012), Neverlift (05-10-2012)
 Old 03-09-2012, 09:34 AM   #1126
Posts: 9,619   (View Stats)
In the last years the community has made great headway in tuning these cars so that they run a lot safer and last at higher power levels. Mazda remedied some things in the 2010+ cars as well and the zoom zoom boom is a lot more rare these days because of it.
Unfortunately you were running an old tuning system that did not address the tuning issues that made these cars pop .... and the car was modified so you can't really claim it did this stock. It's the unfortunate nature of the beast - if you modify the car you take some risk and you have to keep on top of the trends and changes as the platform matures. It's too bad you didn't come here before it blew.
Lex is online now   Reply With Quote
802MS3 (03-09-2012), CWP_MS3 (04-24-2012), rfinkle2 (03-09-2012)
 Old 03-09-2012, 01:00 PM   #1127
Jrenjoi's Avatar
Posts: 2   (View Stats)
Jrenjoi is an unknown quantity at this point
Unfortunately it is my turn to post on here. 2008 Metro Grey speed3 35,XXX miles. Mods were intake+inlet, COBB AP stage 1 BT OTS map. No warning signs leading up to failure, No CEL before or after. Normal cruising in 2nd gear, shifted into 3rd heard a slight knocking noise, got progressively worse in the next 100 feet or so. Towed to dealer, they said bent rod, even though engine was never disassembled. No warranty coverage due to mods. Looking to replace either the short or long block anyone have good connections? Looking for the cheapest/used replacement not a built block or something brand new. Fun while it lasted.
Jrenjoi is offline   Reply With Quote
 Old 03-09-2012, 02:59 PM   #1128
wankular's Avatar
Posts: 4,336   (View Stats)
Damn. You should have towed it home or to a nearby parking lot to stock out (SRI/TIP are easy), reflash the stock map and then towed it to the dealer.
2009 MS3 sport MGM
The Following 4 Users Say Thank You to wankular For This Useful Post:
DingoDave (09-16-2012), FreeFlyFreak (03-10-2012), manelscout4life (03-09-2012), Tokay444 (03-09-2012)
 Old 03-09-2012, 03:04 PM   #1129
timjs's Avatar
Posts: 439   (View Stats)
timjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the world
Lex, could you please elaborate on this? "Unfortunately you were running an old tuning system that did not address the tuning issues that made these cars pop"
timjs is online now   Reply With Quote
 Old 03-09-2012, 03:24 PM   #1130
Enki's Avatar
Posts: 2,990   (View Stats)
Enki has disabled reputation
Groans: 103
Groaned at 21 Times in 19 Posts
Basically stock cars are more likely to pop than properly tuned modded ones.
speed3Texas (04-04-2012)
 Old 03-09-2012, 03:38 PM   #1131
Meder's Avatar
Posts: 1,054   (View Stats)
Meder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the world
Lex can you explain more about the highway blow ups and why/what caused it?
Meder is offline   Reply With Quote
 Old 03-09-2012, 03:53 PM   #1132
Yes, the gen 1 cars seemed to suffer from some severe detonation when first spooling up after prolonged highway cruising. Mine did the same thing when stock. Meth or no meth, it still did it on the stock tune.
I then played with VVT and it has never done it since in 3 years. The dynamic compression ratio was too high for my local gas and was causing this condition.
mituc (04-24-2012), speed3Texas (04-04-2012)
 Old 03-09-2012, 03:57 PM   #1133
timjs's Avatar
Lex, Stage 1 OTS map...has it addressed this concern?
 Old 03-09-2012, 03:58 PM   #1134
How old is the map and what have you been running before it? You also have to remember that this kind of damage happens over time.
 Old 03-09-2012, 04:01 PM   #1135
timjs's Avatar
Thank you for the reply.
Well I got my AP like a month ago...downloaded the latest stage 1 calibration from Cobb's site for stock air intake/ upgraded fuel pump.
I have full bolt-ons sitting here waiting to be installed but all these mystery engine failures have me nervous to move forward.
 Old 03-22-2012, 08:25 AM   #1136
jracer's Avatar
Posts: 1,671   (View Stats)
Groans: 85
just some info..
i emailed onlinemazdaparts.com and i can get a long block shipped to me in florida for $3750.00 aprox.
2006 speed6~Cobb AP~COBB custom E-tune~CobbTIP-CobbSRI~CPeHPFP~ATPdp~Magnaflow exhaust~Denzo plugs~Forge bov~Matt Damon's Occ Kit~Treadstone FMIC~PG V1 Ex.Manifold~CPE safe seals~SU EGR block off plate~SURE TIG intake mani gasket~SU lower motor mount~AWR trans. mount/passenger mount~SU shifter bushings~CPE diff mount~H&R springs~Tenzo type M ~235/40/18 Firestone Indy 500 Wide Oval~ipod adapter~HD lip~Prosport boost gauge~ TWM Desert Eagle Shift Knob~JBR shift plate~spin on oil filter~Block8head Vent Pod~ported intake manifold w/ VTCS delete~EBC red pads w/ slotted rotors~4500k HID fogs 2 gal. E85 mix !!!
jracer is online now   Reply With Quote
The Following 2 Users Say Thank You to jracer For This Useful Post:
shadesofgray19 (03-22-2012), Tokay444 (03-26-2012)
 Old 04-21-2012, 01:33 PM   #1137
aviator79's Avatar
Posts: 1,413   (View Stats)
Anybody that has blown that is looking to just sell as is and cut there losses?
aviator79 is online now   Reply With Quote
 Old 04-21-2012, 05:18 PM   #1138
cplensdorf's Avatar
Posts: 100   (View Stats)
cplensdorf is a splendid one to beholdcplensdorf is a splendid one to beholdcplensdorf is a splendid one to beholdcplensdorf is a splendid one to beholdcplensdorf is a splendid one to beholdcplensdorf is a splendid one to beholdcplensdorf is a splendid one to behold
Where were you a few months ago? I love this car when it is working property, but after rebuilding the entire front suspension at 60k, new VVT at 80k, new engine at 92k and now a rebuild of the rear suspension and replacement of a new tire because of the suspension at 102k, I would gladly have offed this car if I knew this.
cplensdorf is offline   Reply With Quote
 Old 04-21-2012, 08:29 PM   #1139
jack_hammer's Avatar
Posts: 4,199   (View Stats)
Groans: 413
Groaned at 105 Times in 61 Posts
There's one in the fs section.
Sent from my LG-MS690 using Tapatalk 2
it's fun to do bad things
 Old 04-25-2012, 03:57 PM   #1140
steven10's Avatar
Posts: 22   (View Stats)
steven10 has a reputation beyond reputesteven10 has a reputation beyond reputesteven10 has a reputation beyond reputesteven10 has a reputation beyond reputesteven10 has a reputation beyond reputesteven10 has a reputation beyond reputesteven10 has a reputation beyond reputesteven10 has a reputation beyond reputesteven10 has a reputation beyond reputesteven10 has a reputation beyond reputesteven10 has a reputation beyond repute
more sad story, Mazda crossover
Mazda CX-7 Engine Problems - Car Forums - Edmunds
steven10 is offline   Reply With Quote
 Old 05-06-2012, 04:21 AM   #1141
DiGi Faggot's Avatar
Posts: 1,082   (View Stats)
DiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the world
Groaned at 86 Times in 49 Posts
Zoom Zoom Boom?
111k, Piston Ring Failure. MS6. Stock Never Modded.
Could be due to excessive oil usage/faulty turbo; or could have been piston ring failure over time. Disassembly in months to come.
DiGi Faggot is offline   Reply With Quote
 Old 05-10-2012, 09:14 PM   #1142
Neverlift's Avatar
Posts: 3,118   (View Stats)
Groans: 542
Groaned at 181 Times in 120 Posts
Originally Posted by avento View Post
just adding too it, it seems no body knows what our engines blow, iam pretty knowledgeable about cars, i had a built subie. but any way, my ms6 has 84xxx miles on it, had it for 3 weeks and today pulling it out of my long driveway. heard knock knock, boom. oil and coolant were everywhere, and oil was shooting out my exhaust, idk what that means. but i found a hole in the back under the turbo looks like cylinder 3's rod or the crank shot off and did the damage. theres oil in the air box, everywhere. no warning sign, its garage kept, and its all stock one owner. had fresh oil change. and its been running fine, no problems no noises. and today was just a regular day until i hit 25mph in second gear getting read to shift into 3rd. i was probably at 3500 rpms or so. but it sucks cause the dealership won't fix it cause aim 200 miles over my warranty. which is bs.
It took me 2 weeks to blow mine after buying it @ 85k. Knowing what I know now, I should have picked up an AP immediately rather than waiting a couple weeks lol.
Oh well... it was incredibly fun while it lasted.
'04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//OEM Hardtop//Bride Gias II//Autokonexion CF Trunk v2
'06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line//Spin On Oil Filter Conversion
'91 MR2: Planned 1MZ V6 or 3SGTE swap
Driver Mod Level: Focus ST Academy So Cal Champion '12
The Following User Says Thank You to Neverlift For This Useful Post:
radioflyer (08-12-2012)
 Old 05-11-2012, 09:02 AM   #1143
dajuice27's Avatar
Posts: 15   (View Stats)
dajuice27 is an unknown quantity at this point
Can I get in on this even if I have a CX-7?
Same Engine, Same DAMN PROBLEMS!!
Sad thing is my car was stock but now it sports a hole through the block. I got pictures of oil causing an environmental hazard from the blown engine and pieces of metal caught at the bottom of the engine cover inside the engine bay.
I am waiting for the "official" report fromo my mechanic before deciding what to do next but it seems this is a typical issue with that engine.
Hey, you in the Toyota - you SUCK ASS!
dajuice27 is offline   Reply With Quote
 Old 05-11-2012, 02:02 PM   #1144
(Toe-kay)
Tokay444's Avatar
Posts: 9,556   (View Stats)
Groans: 503
Bet that guy in the Toyota is laughing his fucking bag off now.
Demodded.
Mwho?
Tokay444 is online now   Reply With Quote
mituc (07-31-2012), SLOWHATCH (05-04-2013)
 Old 07-30-2012, 08:19 PM   #1145
gabegarcia956's Avatar
Posts: 13   (View Stats)
gabegarcia956 has disabled reputation
2007 mazdaspeed3
76,XXX miles
mods- cold air intake
got to drive it for 4 weeks then this....
just pulled away from paying my toll and about 200feet later it was zoom zoom bang oil went all over and metal went flying. so its and the dealership now and they have not called me back yet but i hope my extended 100,000 bank warranty covers it.
gabegarcia956 is offline   Reply With Quote
 Old 08-12-2012, 09:40 PM   #1146
kinetiq's Avatar
Posts: 9   (View Stats)
kinetiq is an unknown quantity at this point
This thread kinda freaked me out. I am running the stock tune but was thinking about getting the Cobb AP. Am I technically at risk by running the stock tune? Does the dealer offer an upgraded tune that will resolve some of these issues so I am less likely to blow something? Or do I just need to get the AP sooner than later if I want to keep my car for a while? I have a 2008 with 30K miles on it, I am the original owner so I know it hasn't been driven hard. I get on it from time to time but nothing too much. My plan was to start doing some upgrades after the 5 year warranty runs out in a few months.
Lex it seems like you have some knowledge about this, any input would be greatly appreciated.
kinetiq is offline   Reply With Quote
 Old 08-12-2012, 09:49 PM   #1147
Err - all I can say on the topic is that a custom tune is not only more powerful but also more reliable - esp for the Gen1 cars.
The condition under which a lot of the early cars have blown is highway heatsoak and then spooling up to pass and this has a lot to do with the stock tune and its very aggressive dynamic compression ratio. Depending on your local fuel quality this may or may not be an issue. If you experience the car hesitating when accelerating on the highway after cruising for over 20 minutes then it is best to tune this condition out.
Bone stock cars have blown as have modified ones - but if you have performance modifications installed on the car, an AP with at least an OTS tune will be better than stock. Custom tuning takes you a step above this.
Also remember that the fuel pump is a weak point in the system so unless it is upgraded I would be watching it very closely if you're seeing over 16-17psi of boost.
fooqr (08-12-2012), kinetiq (08-16-2012), mituc (08-16-2012), wolly6973 (08-13-2012)
 Old 08-12-2012, 10:36 PM   #1148
radioflyer's Avatar
Posts: 434   (View Stats)
radioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the world
Lex is one of the most knowledgeable guys on this platform when it comes to tuning. I would drive my car off of a bridge if he told me to.
That being said, get an AP before you do ANYTHING to that new engine.
To do list while waiting to get your car back. (besides getting an AP)
1.) Read Abilor's tuning guide and truly understand it. Most importantly, how to calibrate your MAF, check HPFP pressure, monitor KR how to take and read logs ect.
2.) Read ALL of the stickies in the tuning section.
This will give you a basic understanding of what to keep an eye out for. I know how it is, I drove mine for 10k and popped a motor with just an intake and stage 1 AP map. I came out of it with a thirst for knowledge and while I'm not an expert, I have a pretty good idea of how to keep myself out of trouble.
PM me if you have any questions about warranties. This is the one thing I did become an expert at after going through this.
Power: // K&N SRI // Cobb TIH // ETS TMIC // CNT Catted Turbo-Back // AT Internals // ITV-22's
Tuning & Fuel: Cobb AP // 25% e85/91oct // Cobb EBCS // Stratified Tuned
Suspension: Koni Yellows // Swift Spec R Springs // Hotchkis FSB // JBR RSB
Mounts: CPE Stage 2 RMM // CPE PMM // CPE TMM
Shifting: Corksport SSP // Corksport Shifter Assembly Bushings
Wheels & Rubber: XXR 527 // Some crappy free tires at the moment
How to make your car BSOD:
http://www.mazdaspeedforums.org/forum/f13/carputer-105207
radioflyer is online now   Reply With Quote
The Following 2 Users Say Thank You to radioflyer For This Useful Post:
kinetiq (08-16-2012), Lex (08-13-2012)
 Old 08-16-2012, 07:25 PM   #1149
kinetiq's Avatar
Lex and radioflyer, thank you for your replies and information. I will definitely check out the links and make sure I get an AP before adding any other mods to the car. Luckily I don't have to get on the highway very often so hopefully I will be fine just driving the car like I have until I can get the AP with an OTS tune.
Thanks again for the help!
 Old 08-23-2012, 07:56 PM   #1150
mcreprog's Avatar
Posts: 5   (View Stats)
mcreprog is an unknown quantity at this point
Default Blown engine - will sell car
I blew the engine in my 2006 MS6 GT last weekend, and I'm willing to part with the car as is. The repair is so costly I don't see how I can justify it.
I am a relative noob in this forum, and I wish I had been educated about what it takes to make the car reliable because I loved driving it. I'm just completely dejected at this point.
mcreprog is offline   Reply With Quote
 Old 08-23-2012, 09:16 PM   #1151
Groans: 413
It sucks feeling that way about a car
Probably sent from a toilet
 Old 08-23-2012, 10:28 PM   #1152
Unfortunately by the looks of it most stock MS6s will meet this fate sooner or later.
 Old 08-28-2012, 11:04 AM   #1153
fastest 3-cyl MS3
btstarcher's Avatar
Posts: 1,686   (View Stats)
How do you tune this condition out?
JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, HKS BPV, SSP OCC, JBR TIG's, JBR EGR delete, Cobb AP, Kenne Bell BAS, PTP HPFP internals, Steedspeed turbo manifold, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Cobb RSB, Whiteline Anti Lift Kit, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, PTP BSD
Dizzy Tuned by Boost_creep in progress
hopefully soon: GTX2867R or GTX3076R
 Old 08-31-2012, 06:12 PM   #1154
Needforspeed 6's Avatar
Needforspeed 6 is an unknown quantity at this point
From what I just read, you guys are right. Mine just let go too at 45000miles ( 75000km), although I did not go through the block. Seems cylinder one bent its rod from the photos I took. This happened while I was on the highway, about after 15 minutes of driving on a hot day, I accelerated from a ramp, while in 5th 55mph approximately, then the hiccup hesitation again and weird and loud clicking sound. I only have a CAI ( AEM and a BOV. You know the rest same story as the others. I always put synthetic oil in my MS6 2006 since 2006, more frequently then required, never abused the car and babied it. Two months prior to this, after another visit to the dealer for the often reported hesitation/hiccup, they found the injectors to be faulty and were causing the hiccup/hesitation issue. So even without warranty, I may have a case as there is a one year warranty on this 2500$ repair. They did go through the car in details then as they took 5 hours to find what the issue was.
Thanks for this thread, this is fantastic help for me... I ll keep you posted.
Needforspeed 6 is offline   Reply With Quote
 Old 09-01-2012, 07:15 PM   #1155
mcreprog's Avatar
Default Cutting my losses
Yep, my engine blew 3 weeks ago. I'm selling the car as-is. Looking for a buyer. Can't post in the forsale section because I can't get an image with a handwrItten sign. See Craigslist St Louis or message me.
2006 Mazdaspeed6 GT Ti Gray
 Old 09-01-2012, 07:28 PM   #1156
Hope they give you a new engine. A new tune/calibration would resolve this issue once you get the car back together.
Tokay444 (09-02-2012)
 Old 09-02-2012, 09:15 AM   #1157
smakdown61's Avatar
Posts: 1,016   (View Stats)
smakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the world
Groaned at 37 Times in 23 Posts
Looking for an answer to this as well. I've been using a slightly modified 1.05 OTS tune for a long time now. Comparing the VVT values with the newest 2.10 map, looks like its changed a bit. Should I copy the 2.10 VVT values to my current map?
smakdown61 is offline   Reply With Quote
 Old 09-02-2012, 09:35 AM   #1158
fastest 3-cyl MS3
btstarcher's Avatar
That's what my tuner was using, and I think they're generally safe, but I'm waiting for Lex to chime in. I still went ZZB, but I may have had some underlying issues.
 Old 09-16-2012, 12:31 PM   #1159
brandon3212's Avatar
Posts: 7   (View Stats)
brandon3212 is an unknown quantity at this point
I am in the market for a used car and one of the local used car lots has a mint 2007 speed 3 with just over 100,000 K on it. After reading this forum my question is, "is it safe!?". I REALLY like the looks of it and would like to buy it, but I don't want to buy a car thats going to explode....
 Old 09-16-2012, 12:54 PM   #1160
fastest 3-cyl MS3
btstarcher's Avatar
It's probably fine. As long as it's not been beat to shit.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/mazdaspeed-2-3l-disi-turbo-blown-engine-6113/
Mazdaspeed 3 for a daily? - S2KI Honda S2000 Forums - Page 2 This thread Refback 03-01-2011 10:13 PM
GARRETT This thread Refback 02-01-2011 01:30 AM
APR S1 GTI vs MazdaSpeed6 - Page 2 - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com This thread Refback 01-26-2011 09:44 AM
The Forum Wars: Season 2 - Page 114 - 8th Generation Honda Civic Forum This thread Refback 01-06-2011 10:23 AM
The Forum Wars: Season 2 - Page 113 - 8th Generation Honda Civic Forum This thread Pingback 01-05-2011 03:13 PM
Who here went from MKV ---> MKVI? - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com This thread Refback 12-30-2010 03:12 PM
Moteur de recherche : Web, Photos, Videos, Voyages, Encyclopédie This thread Refback 12-20-2010 08:15 AM
Si to Mazdaspeed 3? - Page 4 - 8th Generation Honda Civic Forum This thread Refback 12-16-2010 02:32 PM
S2000 Forums -> Mazdaspeed 3 for a daily? : S2KI This thread Refback 12-08-2010 12:58 PM
Trading in the Si for.. - Page 2 - 8th Generation Honda Civic Forum This thread Refback 11-13-2010 11:48 AM
Mazda Speed3 - Miata Turbo Forum - Home of the turbo Mazda Miata. This thread Refback 08-01-2010 06:55 PM
Klub MazdaSpeed: Forum • Zobacz w?tek - Czy jeste? zadowolony ze swojego MPS'a? This thread Refback 07-16-2010 04:11 AM
any evo x owners come from a mazdaspeed 3? - Page 8 - evolutionm.net This thread Refback 07-09-2010 06:49 AM
Mazdaspeed 3 Why it's a PITA! - B15U.com - Nissan Sentra Forum This thread Refback 07-05-2010 08:18 AM
Klub MazdaSpeed: Forum • Zobacz w?tek - Czy jeste? zadowolony ze swojego MPS'a? This thread Refback 06-28-2010 05:26 AM
Mazda MPS3 vs. Porsche 996 Turbo - Seite 3 - Hondapower.de e.V. Forum This thread Refback 06-03-2010 03:06 PM
Civic si vs 2010 mazdaspeed3 - Page 3 - 8th Generation Honda Civic Forum This thread Pingback 06-03-2010 09:36 AM
Mazda CX-7 (2007 - ) - Engine emission at low revs | Motoring discussion | Back Room Forum | Honest John This thread Refback 05-08-2010 12:19 AM
2.3 duratec engine upgrades? - The Ford Focus Forum | Powered by Focaljet This thread Refback 04-16-2010 02:01 PM
Bearing de crank ?? - Mazda 3 Quebec This thread Refback 04-14-2010 07:43 AM
mazdaspeed 3 engine noise - Zuula Search This thread Refback 04-12-2010 07:58 PM
Stage 2 + GTI MKV DSG vs 2009 MS3 - Page 2 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 04-11-2010 08:59 PM
Stage 2 + GTI MKV DSG vs 2009 MS3 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 03-26-2010 04:10 PM
OMG!! 12s Si (All Motor) - Page 23 - 8th Generation Honda Civic Forum This thread Refback 03-25-2010 08:03 PM
OMG!! 12s Si (All Motor) - Page 21 - 8th Generation Honda Civic Forum This thread Refback 03-25-2010 02:18 PM
OMG!! 12s Si (All Motor) - Page 20 - 8th Generation Honda Civic Forum This thread Pingback 03-25-2010 02:04 PM
Got my new car! CHEATING ON DODGE!!! - Page 2 - Dodge Caliber Forums This thread Refback 03-18-2010 11:31 PM
Who here went from MKV ---> MKVI? - VW GTI MKVI Forum / VW Golf MKVI Forum / VW R20 Forum / VW GTI Forum - Golfmk6.com This thread Refback 03-17-2010 02:31 PM
382whp/380wtq - Page 2 - Maxima Forums This thread Refback 02-23-2010 12:39 AM
Klub MazdaSpeed | Forum • Zobacz w?tek - Czy jeste? zadowolony ze swojego MPS'a? This thread Refback 02-15-2010 12:56 AM
Mazda CX-7 - Engine emission at low revs: Motoring Discussion forum This thread Refback 01-28-2010 12:19 AM
Cobalt ss vs ms3 - Page 3 - Cobalt SS Network This thread Refback 01-23-2010 05:25 PM
Tell me about Mazda 3 / Mazdaspeed 3 - MX-5 Miata Forum This thread Refback 01-08-2010 09:35 AM
Bye-bye Lexus! Hello.... - Page 3 - MX-5 Miata Forum This thread Refback 01-05-2010 08:37 PM
Blown engine theory - Page 8 This thread Pingback 01-05-2010 06:45 AM
MySpace.com - External Link Alert This thread Refback 01-04-2010 02:54 PM
Untitled document This thread Refback 12-26-2009 01:13 AM
Wow..Does Everyone's Si Suck? - Page 5 - 8th Generation Honda Civic Forum This thread Pingback 12-15-2009 11:29 AM
From Nissan to Mazda. - Page 2 - Colorado Mazda Club This thread Refback 12-15-2009 08:24 AM
New RX-7... from the Horse's Mouth... - Page 2 - MX-5 Miata Forum This thread Refback 10-22-2009 01:22 AM
civic si or ms3 - Page 4 - 8th Generation Honda Civic Forum This thread Pingback 10-20-2009 03:51 AM
Car Buffs - Dallas Dance Music - Dallas nightlife, music, tickets, and more This thread Refback 10-13-2009 08:26 PM
08 mazdaspeed 3 - Page 4 - 8th Generation Honda Civic Forum This thread Pingback 10-09-2009 03:24 PM
Mazdaspeed 3 Why it's a PITA! - B15U This thread Refback 09-29-2009 11:40 AM
Mazdaspeed3 new wheel color and teeth. - TriStateTuners.com :: Home of Tristate Auto Enthusiast This thread Refback 09-26-2009 03:50 PM
2009 civic si or 2009 mazdaspeed 3 (this thread is old) - Page 28 - 8th Generation Honda Civic Forum This thread Pingback 09-23-2009 05:20 PM
2009 civic si or 2009 mazdaspeed 3 (this thread is old) - Page 18 - 8th Generation Honda Civic Forum Post #453 Pingback 09-22-2009 11:29 AM
2009 civic si or 2009 mazdaspeed 3 (this thread is old) - Page 17 - 8th Generation Honda Civic Forum Post #453 Pingback 09-22-2009 08:17 AM
2009 civic si or 2009 mazdaspeed 3 (this thread is old) - 8th Generation Honda Civic Forum This thread Refback 08-24-2009 11:39 AM
2009 civic si or 2009 mazdaspeed 3 (this thread is old) - Page 5 - 8th Generation Honda Civic Forum This thread Refback 08-23-2009 03:23 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Big turbo chicken thread phailerider MazdaSpeed 3/6 - Turbo Induction 111 07-01-2010 05:18 AM
Green Genesis Coupe shows up, 286 hp turbo DI engine nearby? Haltech Automotive News 1 05-07-2008 07:24 AM
Blown Seal? Rican219 MazdaSpeed 6 - Engine, Transmission & Driveline 8 04-19-2008 08:52 AM
GReddy Turbo Ti-C 3" Catback Exhaust - Mazdaspeed 3 Performance Racing Mazdaspeed3/6 General Discussion 5 04-12-2008 08:57 AM
FREE Microsoft Mobile Business Resource Kit Haltech Hot Deals Section 0 03-26-2008 07:30 AM
Page generated in 0.59328 seconds with 47 queries
