Yeah 430 is a bit expensive for CX. Just be patient, you might find something here. |
Again COBB is expensive but has the BEST piping kit out there in terms of 1. Number of pipes in set 3 only, compared to 5+ pieces in other sets. 2. routing of the pipes is best design ive seen. 3. Stainless steel t-bolt clamps 4. 2.5 inch piping for your BT 5. powder coat "+15hp" |
Don't shoot me for this question, but you guys have no idea how many times I hear confliction opinions: In South Florida, what is best to use? An upgraded TMIC or a FMIC? I hear many saying here it really doesn't matter, that obviously FMIC is cooler overall, but the TMIC gets colder at higher speeds. It's all conflicting as fuck. |
I had a TMIC and it would heat soak a lot. |
Also, if you want a decent sized FMIC core you will have to remove/modify your front crash bar. Vendors like UR and cp-e sell replacement crash bars. |
Edit: My bad again the price was 295 shipped |
lol Quote:
btw I just checked fb and u didnt add me |
so what shall be my next upgrade? got the EBSC what shall i get next? |
You have a cracked PMM...so that |
EBCS + tune, should fix your WG issues. If not, Bucker will tell you what to get next performance wise. |
All I'm saying is if you tune your car, you will have to do several data logs. In those logs, you will be placing 450+ lb-ft of torque in your mounts/axles. Even more now that the car will be tuned properly. I would not do it, especially knowing your PMM/RMM have been broken for a long period of time, putting more stress on your TMM. If that goes, well that's it for your built engine. |
OP needs to PM @jbarone and get some motor/trans mounts before his engine falls out. |
@S3BAZ1091, plus not just your engine, but your GF too will appreciate the JBR mounts :) |
so i was able to install the boost controller have a look! http://img171.imageshack.us/img171/9...9170826.th.jpg http://img18.imageshack.us/img18/443...9170835.th.jpg http://img35.imageshack.us/img35/931...9181124.th.jpg http://img140.imageshack.us/img140/4...9181133.th.jpg http://img829.imageshack.us/img829/2...9190445.th.jpg http://img195.imageshack.us/img195/4...9190456.th.jpg |
Nice! Sorry I couldn't help, week schedule is busy. But you're learning the ways of NATOR and seeing how much more satisfying it is to work on your own car than paying people like Felipe/PJ to do it. |
You're probably on a spring pressure map right now. When I started 3 port mode, I started on spring pressure and gradually worked my way up. |
Yeah Bucker will gradually increase boost as you tune. |
| All times are GMT -7. The time now is 06:59 AM. |
