Like Tree32Likes
 Old 09-04-2012, 12:04 PM   #1
S3BAZ1091's Avatar
Posts: 310   (View Stats)
S3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond repute
Groaned at 69 Times in 30 Posts
Exclamation Mazdaspeed 3 2009 - need help fixing issues - fully built engine
hello fellow msf members. would like to introduce my self. my name is sebastian. i bought a mazdaspeed3 2009 back in december, from a manager at a mazda dealer, this was his personal car. this is a fully built speed3. i live in florida. and this is my first turbo car. yes big mistake buying a fully built car. i learned my lesson. so il get to the point. this car has been through two engines. the stock oem engine and the engine it currently has. the 1st engine blew on the previous owner before the manager. manager bought the car and kept it for him self to build. the car has as far as i know this is the mod list:
- new engine block (dont know what stage or w.e)
-upgraded turbo GT3076R
-FMIC (fusion motorsports)
-Port and polish head
-upgraded pistons
-cobb downpipe
-greedy catback
-CPE FP
-cobb short ram intake
-oil catch can
-denso ivtt22 sparkplugs
-tuned with AP
-aem AF gauge
-defi boost gauge
-act street clutch
and thats as far as i know. the engine was built in a shop called velocity factor ( Import, European, Car, Performance, Parts, Tuner, Tuning, Shop | Velocity Factor ) which we alot of SFLA Mazda Crew dont really like or rely on. i took my car over there as soon as i bought to have them take a look at it. they told me that the project was not complete because Adam (manager at dealer) did not want to add a meth kit and that my car needed a meth kit. they were charging me $1600 for a meth kit and tunning. that same day they charged me $261 to change my oil and replace a oil catch can hose. well now moving foward. i joined the slfa mazdacrew met alot of people who knew about my car etc. met a member by the name of cory who was willing to help me tune my car. he found out by some logs we took that " wgdc is maxed at only 22psi, ur wot afr was all over the place, u had knock over 3* during wot" which he stated wasnt normal and something was wrong with my car. he wasnt able to tune it because didnt really wanna mess with it. velocity factor. told me that when they dynoed and tune the car the car was pushing 414hp 390whp which is amaizing. but cory calculated i was only making around 300hp which is what he was running on stock engine and stock turbo and just a minor mods. so with this car having everything done to it thats not normal. like i said the car runs fine etc. i still have the logs avaible i will attacth them to this post. if anyone here with experiece on tunning or etc is willing to help me find the issues or tune the car i would highly apreciate it.
File Type: csv dyno_run1.csv (861 Bytes, 7 views)
S3BAZ1091 is offline   Reply With Quote
 Old 09-04-2012, 12:09 PM   #2
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
Welcome. Velocity Factor is known all over for being dumblefucks.
Check links 2 on in my sig.
The Following 2 Users Say Thank You to Raider For This Useful Post:
Alejo_NIN (09-04-2012), Ms3_Miami (09-05-2012)
 Old 09-04-2012, 12:10 PM   #3
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
I don't know if there's something wrong with your AP, but your logs are useless. Post some 3rd gear logs if you have them.
Edit: Datalog51 seems to be fine.
You definitely have a problem. First of all, as you know, either your tune is completely off, or your car is trying to compensate for some kind of leak. Which is why your AFR is inconsistent.
You have gigantic amounts of knock at the end of your run.
A 3076r should not run at 90%+ WGDC at 22psi.
Is this your daily driver? I ask because you will definitely need days without driving the car to diagnose why is wrong with it. Especially with that knock at low levels of boost (for a 3076)
The Following 7 Users Say Thank You to adlpb For This Useful Post:
Alejo_NIN (09-04-2012), Constantin (09-04-2012), Easter Bunny (09-08-2014), G26 (09-04-2012), Juyoung (09-06-2012), Ms3_Miami (09-05-2012), Pintozoz (09-04-2012)
 Old 09-04-2012, 12:14 PM   #4
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
This kid needs help, bad. Let's not be huge dicks.
@Lex @rfinkle2 @atvfreek @Bucker
The Following 11 Users Say Thank You to G26 For This Useful Post:
Alejo_NIN (09-04-2012), cbspd3flip (09-04-2012), Chriscote (09-06-2012), Constantin (09-04-2012), Easter Bunny (09-08-2014), Juyoung (09-06-2012), Ms3_Miami (09-05-2012), Pintozoz (09-04-2012), Raider (09-04-2012), tbot (09-04-2012), xhymer (09-05-2012)
 Old 09-04-2012, 12:15 PM   #5
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
First, you need to tear that motor down and figure out exactly what's in it, pistons, rods, headgasket, headbolts or arp studs. Then you need to see if it's got an upgraded MAP sensor, and if it's running a larger MAF.
A whole lot of missing info. Never buy a modded car unless you get the full, comprehensive list of EVERY mod on it. Every single detail is important.
Then we need to see the tune, and some 3rd or 4th gear WOT logs (assuming your afr's aren't dangerously lean, of course)
07 MS3
The original Genpoo Hater
The Following 5 Users Say Thank You to Chimmike For This Useful Post:
Alejo_NIN (09-04-2012), Easter Bunny (09-08-2014), helmetface (09-04-2012), Ms3_Miami (09-05-2012), Pintozoz (09-04-2012)
 Old 09-04-2012, 12:25 PM   #6
Alejo_NIN's Avatar
Posts: 1,700   (View Stats)
Alejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the world
Groans: 88
Groaned at 186 Times in 83 Posts
i heard there is a way of telling what pistons it has by removing the oil pan (?)
i dunno if you can trust what VF did tot his car so perhaps reaching to the last owner about receipts for parts and labor done might give you a clue as to what exactly did the car have installed at VF
is this Adam from lou bachrodt mazda?
radonelement.com
Alejo_NIN is offline   Reply With Quote
 Old 09-04-2012, 12:25 PM   #7
Pintozoz's Avatar
Posts: 1,391   (View Stats)
Pintozoz is the leader of the worldPintozoz is the leader of the worldPintozoz is the leader of the worldPintozoz is the leader of the worldPintozoz is the leader of the worldPintozoz is the leader of the worldPintozoz is the leader of the worldPintozoz is the leader of the worldPintozoz is the leader of the worldPintozoz is the leader of the worldPintozoz is the leader of the world
Groans: 124
Groaned at 92 Times in 53 Posts
Good luck with all this buddy, I truly hope nothing wrong happens. Try not to go to aggressive unless the guys at MSF ask you to, don't wanna blow something up.
i have a mazdaspeed3. not doing anything more to it, no interest in dumping money on it. building a miata for the track.
Pintozoz is offline   Reply With Quote
 Old 09-04-2012, 12:28 PM   #8
adlpb's Avatar
Groans: 669
Yeah that's him.
When I bought my Mazda I saw him driving it a couple times. He would tell me about all the shit he did to his car, like street race it on a constant basis. Judging from this and other factors (such as seeing him destroy his speakers), the "built" engine has definitely been abused.
Being the manager, he also drove 2011 MS3 given from the dealer. They offered to sell me this car with 2000miles on it. I sat on it, it looked like a 3 year old car. Turn the key and the radio was on max volume on a station along the lines of Power96. I walked out of the car. Adam is not the type of guy who would have taken care of his car.
Blackedout1978 likes this.
The Following User Says Thank You to adlpb For This Useful Post:
 Old 09-04-2012, 12:29 PM   #9
S3BAZ1091's Avatar
@adlpb it is my daily driver, and alejo yeah adam. il try and contact him to see if he has a full list of the mods. or try contacting VF. as for a shop that can help me tear down the engine i dont know where..
 Old 09-04-2012, 12:36 PM   #10
Will fuck up ur day
Chimmike's Avatar
Groans: 433
If you can't do any of this work yourself bro, honestly, you need to sell it. Dealing with a shop is going to give you headaches and cost a LOT of money.
07 MS3
adlpb (09-04-2012), Easter Bunny (09-04-2012), Juyoung (09-06-2012), rfinkle2 (09-05-2012), smoogs12 (09-04-2012)
 Old 09-04-2012, 12:36 PM   #11
S3BAZ1091's Avatar
oh man.. maybe i should just go back and trade it in ? for a stock?
 Old 09-04-2012, 12:38 PM   #12
adlpb's Avatar
Groans: 669
You're going to take a huge loss trading it in - granted you paid more than a brand new MS3 for this 4 year old car. But as stated previously you probably will spend a lot more fixing it at a shop if you are not willing to do it yourself.
 Old 09-04-2012, 12:42 PM   #13
S3BAZ1091's Avatar
im willing to do it myself. but i dont know how. like i said im just learning alot my self. but taking an engine part thats way out of my league..
 Old 09-04-2012, 12:45 PM   #14
adlpb's Avatar
Groans: 669
That's what I'm saying.
We have a bunch of guys at FL willing to help, but mostly on weekends. Taking an engine apart is not something we can do on a day. Especially since none of us do it on a regular basis.
Taking it to a shop like VF is going to cost you $100/hr labor, plus overnight fees, etc.
The Following 3 Users Say Thank You to adlpb For This Useful Post:
Easter Bunny (09-08-2014), Ms3_Miami (09-05-2012), rfinkle2 (09-04-2012)
 Old 09-04-2012, 12:47 PM   #15
Raider's Avatar
Groans: 856
Hell, even getting and posting pics will hep us confirm the outside.
I would also confirm the fuel pump, as if that is not CPE you will be getting a new motor.
 Old 09-04-2012, 12:52 PM   #16
adlpb's Avatar
Groans: 669
Easter Bunny (09-04-2012), Raider (09-04-2012), rfinkle2 (09-04-2012)
 Old 09-04-2012, 01:03 PM   #17
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Agreed on almost all points above.
1) Get rid of all the logs except # 51 ... that will allow people who can help you to get right to the point.
2) the car is lean @ wot, so I would take it easy until you get that sorted (could be a cause for your kr)
The best thing to do at this point is take it easy on the car until you can be sure it is mechanically sound and then you will want to be sure it has a decent tune.
From what I can see, the only immediate issue in the tune is that your trims are off substantially, but not to the point that you cannot drive the car (will be fine @ anything less than wot).
As far as the KR, built motors may have a tendency to throw more kr due to piston slap, tolerances that aren't as tight as oem, different harmonic resonance etc... so the KR that you are experiencing is definitely concerning, but not necessarily KR.
In summary,
-find out what pistons, rods are in the car
-who the engine builder was
-who tuned the car
AND in the meantime, ask Cory to add some fuel for you.
The Following 7 Users Say Thank You to rfinkle2 For This Useful Post:
adlpb (09-04-2012), atvfreek (09-04-2012), Constantin (09-04-2012), Easter Bunny (09-04-2012), Ms3_Miami (09-05-2012), smoogs12 (09-04-2012), SPEED6 KILLAH (09-04-2012)
 Old 09-04-2012, 01:09 PM   #18
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Those OEM pistons?
Do this: drain the oil, take off the oil pan. See if the balance shaft is in there. If it is, remove it, try to shine a flashlight into the cylinders to see the rods and bottom of the pistons. You should be able to tell if they are aftermarket or stock just looking at them. That's first.
07 MS3
The Following 2 Users Say Thank You to Chimmike For This Useful Post:
Easter Bunny (09-08-2014), rfinkle2 (09-04-2012)
 Old 09-04-2012, 01:12 PM   #19
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
But I haz racecar?
The Following User Says Thank You to helmetface For This Useful Post:
Neverlift (09-05-2012)
 Old 09-04-2012, 01:13 PM   #20
atvfreek's Avatar
Posts: 7,787   (View Stats)
Originally Posted by adlpb View Post
Yeah that's him.
Another thing we need to know is what is being used for boost control? Is it a 2 port solenoid, or 3 port and how is it hooked up.
The maf cal is way off, which is making calc load very low, and in turn running way too much timing for the boost you are at. Dial in the maf cal, lower the ign timing and figure out your boost control set up. That will get you going safely until you can get the rest of the internal engine details from the previous owner
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
 Old 09-04-2012, 01:22 PM   #21
adlpb's Avatar
Groans: 669
If he brings the car to any of us we can identify the BCS and fuel pump.
As far as identifying the internals...that's another issue
The Following 2 Users Say Thank You to adlpb For This Useful Post:
 Old 09-04-2012, 01:25 PM   #22
rfinkle2's Avatar
Groans: 298
If the car is hitting 21 psi by 4,000 rpm's, but is also @ 99% wgdc @ redline and 21-22 psi, he is on a 2 port with a restrictor (especially with head work).
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
adlpb (09-04-2012), Easter Bunny (09-08-2014), tbot (09-04-2012)
 Old 09-04-2012, 01:29 PM   #23
adlpb's Avatar
Groans: 669
Figures.
Velocity factor demanded he get meth, but left him on a 2-port setup. lol
Also, $1600 for meth and a tune. Yeah.
 Old 09-04-2012, 01:36 PM   #24
rfinkle2's Avatar
Groans: 298
another note: unkink the valve cover to tip vent hose. LOL
@chimmike and @atvfreek... $10.00 says that oem valve is leaking the remaining boost that should be hitting the motor.
adlpb (09-04-2012), atvfreek (09-04-2012), Easter Bunny (09-04-2012)
 Old 09-04-2012, 01:39 PM   #25
G26
G26's Avatar
Groans: 39
One of you guys can tune it I'm not touching it.
The Following 2 Users Say Thank You to G26 For This Useful Post:
Pintozoz (09-04-2012), rfinkle2 (09-04-2012)
 Old 09-04-2012, 01:41 PM   #26
rfinkle2's Avatar
Groans: 298
Just add 15% fuel to the whole curve.
I'm sure he'll relieve you of all responsibility. HAHA!
TBH, it looks as if someone who knows what they are doing tuned it, and somehow, the trims came out of whack.
 Old 09-04-2012, 01:53 PM   #27
S3BAZ1091's Avatar
Hell I hace ny weekends off. Uf you guyd are willing yo help me take a look at all this I highly appreciate it , il buy beer for everyone.
 Old 09-04-2012, 02:14 PM   #28
adlpb's Avatar
Groans: 669
Where do you live? Do you have a place to do it?
 Old 09-04-2012, 02:16 PM   #29
S3BAZ1091's Avatar
I live in coralsprings fl. I live in apartments so i dont hace a place and all friends live in apt also :/
 Old 09-04-2012, 02:27 PM   #30
dereeek's Avatar
Posts: 2,053   (View Stats)
dereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the world
Groans: 386
He lives near my neck of the woods in Coral Springs.
BNR3-FREEK-PU-398HP
I lost track of the mods in my car.
dereeek is offline   Reply With Quote
 Old 09-04-2012, 02:33 PM   #31
adlpb's Avatar
Groans: 669
Right...but the issue is finding a place to do it, since it might require overnight work.
 Old 09-04-2012, 02:38 PM   #32
S3BAZ1091's Avatar
Pj from the sfla crew has his own shop. The owner of cartek in davie, his going to install my rmm so i will speak to him about using his shop
 Old 09-04-2012, 02:41 PM   #33
dereeek's Avatar
Groans: 386
Let the NATOR FL guys in South Florida put the RMM on for you, that way they can also look at your car. Any family friends, storage units, someone who knows someone with a place?
BNR3-FREEK-PU-398HP
The Following 2 Users Say Thank You to dereeek For This Useful Post:
adlpb (09-04-2012), Constantin (09-04-2012)
 Old 09-04-2012, 02:44 PM   #34
adlpb's Avatar
Groans: 669
I don't know what's up with you SFLA guys handing out cash to this PJ guy for simple fucking jobs like a RMM installation. We can do that shit in 10 minutes.
And you're telling me that you're on a full BT turbo setup on a built engine and you don't have a RMM? Holy fuck. Your car was built backwards.
Constantin (09-04-2012), rfinkle2 (09-04-2012)
 Old 09-04-2012, 02:46 PM   #35
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Damn it must be something about florida and shitty vendors. Raider has his work cut out over there.
dereeek likes this.
The Following User Says Thank You to NJSPEED3 For This Useful Post:
dereeek (09-04-2012)
 Old 09-04-2012, 02:46 PM   #36
S3BAZ1091's Avatar
Cause I honestly dont have the tools or place. Like I said uf we can gather up and help me im more willing to help and learn and no I dont. :/
 Old 09-04-2012, 02:48 PM   #37
Constantin's Avatar
Posts: 3,907   (View Stats)
Constantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the world
Groaned at 18 Times in 16 Posts
@S3BAZ1091 first of all welcome! As probably you already found out, you came to the right place!
Hey guys, lets set up another install day and help him out to find out what is under the hood! However, it is best if you can get all the info from previous owner!
@speeed may be your warehouse and will get your coilovers in the same day!
I have EBCS brand new laying around. So, if it turns out you need one quick, I can give you mine.
And DON'T go to VF.... Charging around $300 for oil and OCC house change, besides other things is ridiculous!! It is max an 1 hour job!
EDIT: Pay for installing RMM!!! I remember my first NATOR install day when guys through in JBR trilogy in like two hours Anyhow, come by Fort Lauderdale after work, we'll install it in like 10 min, like @adlpb said!
2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq
Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arms | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors
Constantin is offline   Reply With Quote
The Following 3 Users Say Thank You to Constantin For This Useful Post:
adlpb (09-04-2012), dereeek (09-04-2012), rfinkle2 (09-04-2012)
 Old 09-04-2012, 02:49 PM   #38
ericrapp0507@gmail.com's Avatar
Posts: 281   (View Stats)
ericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the world
you sir are in a pickle for now. drive easy till one of these MSF elves can at least look a the tune.
reduce boost and add fuel and or reduce timing till the mechnicals can be sorted. certainly drop boost target at wot. I hope you get the help, it may not be that bad if you can source someone who is worth a fuck with laptop. Hang in there and no rash decisions.
it seems some of those knowledgable guys are here already.
2/07 build date. 5/07 arrival date
88750. tracked before broken in.
Broken and broken again. been hit 4 times
235/40 fr 225/40 rear. Direzza / NT 555 /Tenzo dc-5 br 18x8.5 / DBA 4000xs/ EBC Reds /Goodridge SS lines /motul rbf/Moog control arms / axles upgraded/ Hotchkis sway fr / Whiteline adj links and tower brace/ REAR -mazdaspeed camber arms/ Tripoint anti sway/ Laura's GTspec trunk cage brace./ KSport RR. w/front camber plate w/ nasty spring rate/TopSpeed PMM Solid RMM/ sure TMM/Corksport parts =TBE w/RP or hf cat depending-Turbo- Injector seals -Fuel pump internals-Pulleys / PG v2 exh mani /HTP 3.5/ bosch 3 bar map/ new injectors/ Grimmspeed ebcs/ JMF intake /Perm Tuned vent plate/Damond Motorsports full EGR delete/DM dual CC/ Forge BPV/CP-e FMIC/Cobb v3
Samco preformed rad hose/ + Mishimoto and goodyear hoses/lines/ Braille 17/ custom tray/
Koyo Rad filled w/ Mishimoto Chill/ RPurple motor blood
ericrapp0507@gmail.com is offline   Reply With Quote
 Old 09-04-2012, 03:00 PM   #39
S3BAZ1091's Avatar
@constatin thanks and that sounds great yes all of you guysi really appreciate the quick response the support and effort in willing to help me. Loor I said in willing todo w.e beer ir me and foodw.e it is. And thanks @erricapp0507 there is alot of great help here !
Btw it has cpe rmm bit as we all know they suck so i Bree it replaced
Last edited by S3BAZ1091; 09-04-2012 at 03:00 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-04-2012, 03:01 PM   #40
Constantin's Avatar
Shit...your cell phone typing sucks!
Try looking for a place where we can all meet (besides the RMM install). You can even try to negotiate a rend of a warehouse somewhere for a weekend...
The place for the next install/research day is crucial aspect at this time...
@dereeek you back home yet?
New Fully Forged engine installed. Which oil? greg08 MazdaSpeed 6 - Engine, Transmission & Driveline 10 04-15-2011 09:51 AM
Cost of going fully built vbt101 MazdaSpeed 3 - Engine, Transmission & Driveline 11 10-07-2009 03:40 AM
Page generated in 0.61108 seconds with 34 queries
