Like Tree32Likes
 Old 09-20-2012, 02:10 PM   #241
S3BAZ1091's Avatar
Posts: 310   (View Stats)
S3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond reputeS3BAZ1091 has a reputation beyond repute
Groaned at 69 Times in 30 Posts
Originally Posted by dereeek View Post
You're probably on a spring pressure map right now. When I started 3 port mode, I started on spring pressure and gradually worked my way up.
Originally Posted by adlpb View Post
Yeah Bucker will gradually increase boost as you tune.
well this morning omw to work the coupler decided it just wanted to come off. so i was fucked. i was able to put it back in drive slow af home. retighthen it. go buy a new coupler because i believe i made the tap way to close to the entrace of the turbo. made new hole on new coupler. mofo didnt want to go in again.. after 2hrs of stuggling nothing. so i used electrical tape. wraped it around the 1st hole i made. made a new hole. coupler seems to be tight in place. still on 10-15psi. bucker replied said i should be OVERBOOSTING not underboosting. went back to my car checked everything. disconnected EBSC pluged it back in. reflashed last revision bucker gave me. idk what i did wrong. checked all hoses were correct in each port and they are. so now idk wtf todo...
S3BAZ1091 is offline   Reply With Quote
 Old 09-20-2012, 02:13 PM   #242
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
You put electrical tape on a hole which is going to be under 20-25psi? You know that's not gonna work, right?
The Following User Says Thank You to adlpb For This Useful Post:
Easter Bunny (09-20-2012)
 Old 09-20-2012, 02:18 PM   #243
S3BAZ1091's Avatar
i know. just for the time being. while one of you guys are able to help me.. i purchased the exact same coupler it had on before. but that bitch would not wanna go in. the 1st hole i made is at the mout of the turbo entrance and there the clamp is holding it down. so im guessing its not exposed to the aire traveling..
 Old 09-20-2012, 02:24 PM   #244
adlpb's Avatar
Groans: 669
You sure bought the same diameter? I had to use WD-40 on my cp-e couple when I did my FMIC. Grease also works. You probably shouldn't be boosting with electrical tape on that hose
 Old 09-20-2012, 02:28 PM   #245
S3BAZ1091's Avatar
exactly what i did. i used oil put a little around it fit it but when i would try and fit it down to the turbo it would bend and be all sucked in..i checked them and the one i have is shorter than the new one. and im not boosting. cause if im suppose to be over boost instead of under means i did something wrong. what im gonna have todo is buy a new coupler. again. and just wait until when ever you are free ? :/
 Old 09-20-2012, 02:38 PM   #246
adlpb's Avatar
Groans: 669
Yeah like I said, I'm going to be busy this week/weekend. But if you want post in the ADD thread and see if someone down south can help you.
 Old 09-20-2012, 02:45 PM   #247
S3BAZ1091's Avatar
i dont mind waiting till next weekend if thats ok? you already know my car and the deal etc. should i go back to stock controller and just clse of the hose to the 3 port?
 Old 09-20-2012, 02:54 PM   #248
Constantin's Avatar
Posts: 3,907   (View Stats)
Constantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the world
Groaned at 18 Times in 16 Posts
There is an even on Sunday, you can come there.... BTW where do you leave? I might have to go to Boca, so can stop by...
OR you can come to Towers tomorrow...
2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq
Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arms | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors
Constantin is offline   Reply With Quote
The Following User Says Thank You to Constantin For This Useful Post:
Ms3_Miami (09-20-2012)
 Old 09-20-2012, 02:54 PM   #249
adlpb's Avatar
Groans: 669
No just stay on 3-port.
Thing about next weekend is that that Sunday is the Autox, so that leaves me Saturday to study for a Midterm on October 1st. So I am not 100% sure if I will have time.
 Old 09-20-2012, 03:00 PM   #250
S3BAZ1091's Avatar
i live in coralsprings off exit on sample on 75. my house to alvaros is like 20min? and in towers how would we be able to look at it? no light too crowded? what event?
oh damn.. guess just drive madly slow...
 Old 09-20-2012, 03:23 PM   #251
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Why are u making holes in couplers?
 Old 09-20-2012, 03:54 PM   #252
Constantin's Avatar
You do you still have MS3 as your avatar???
adlpb likes this.
adlpb (09-20-2012)
 Old 09-20-2012, 04:06 PM   #253
S3BAZ1091's Avatar
Had to make a tap for the 3rd port for the ebcs
Hey what's your number?
Last edited by S3BAZ1091; 09-20-2012 at 04:06 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-20-2012, 04:08 PM   #254
Constantin's Avatar
PMed....b/c don't want bunch of cock pics on my phone
 Old 09-20-2012, 04:25 PM   #255
adlpb's Avatar
Groans: 669
Why do you still have MS3 as your avatar???
Best. Comeback. Ever.
The Following 3 Users Say Thank You to adlpb For This Useful Post:
Constantin (09-20-2012), dereeek (09-20-2012), Ms3_Miami (09-20-2012)
 Old 09-20-2012, 04:57 PM   #256
G26
G26's Avatar
Groans: 39
Doesn't the turbo have a port on the compressor housing for a boost source?
 Old 09-20-2012, 04:59 PM   #257
adlpb's Avatar
Groans: 669
He has a 3076 IWG
Now go change that avatar
jman46 (09-20-2012)
 Old 09-20-2012, 05:14 PM   #258
G26
G26's Avatar
Groans: 39
Dam woulda been nice for vf to tap the housing before installing it.
 Old 09-20-2012, 06:07 PM   #259
S3BAZ1091's Avatar
Its vf -.- bunch of faggots
 Old 09-20-2012, 07:01 PM   #260
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
If your hose popped off thats more then likely where your leak is at. If your tryn it out now, you have a hole in the coupling that is taped up :/ obviously you will have a leak. When you get everything fixed correctly then we can see if you have any real leaks. Did you reuse the old lines that were on the wastegate and intake or did you run new ones? Also did you check the bottom coupling of the hot pipe? To move the coupling you had to move the pipe.
Esit: hahaha I just realized Corey heard "leak" and came running into this thread hahahahhahahaha
TEAM LUXURY
Sid3wayS is offline   Reply With Quote
The Following 3 Users Say Thank You to Sid3wayS For This Useful Post:
adlpb (09-20-2012), Ms3_Miami (09-20-2012), S3BAZ1091 (09-20-2012)
 Old 09-20-2012, 07:12 PM   #261
G26
G26's Avatar
Groans: 39
Lol nigga sheeeeet.
The Following 2 Users Say Thank You to G26 For This Useful Post:
Ms3_Miami (09-20-2012), Sid3wayS (09-20-2012)
 Old 09-20-2012, 07:27 PM   #262
S3BAZ1091's Avatar
i reused the lines. they had extenders to i used the lines that came with the bc to reach the BC and the one that runs on top of the engine right? im going to meet up with @Constantin tomorrow after work. see if he sees anything.
i also tired used the same coupling it had before , i bought it new from usp motrosports down my street. bu the bitch would not wanna go in and when it did and tried to connect it to the turbo it would just bend and be all sucked in. constantin said i should be fine now. since like i said i taped up the hole. but the hole is sitting where the mouth is so its no were the air flows. and on top is the clamp so i hope and doubt theres no leaks from there. i tighthen that mofo as hard as i could. havent been boosting. only sometimes goes to 5psi but i dont let it go past that.
forgot to mention who ever did this piping tried doing ridges on the ends of the piping with the same soldering.. smh. worst piece of piping ive seen in my life. saving up for some real piping kit.
Last edited by S3BAZ1091; 09-20-2012 at 07:31 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-20-2012, 07:34 PM   #263
Sid3wayS's Avatar
Groans: 97
As tight as you can is not the right way, that will cause an even bigger leak quicker. What hose running onto of the motor do you speak of. Reason I asked if you reused it is because given how your engine bay hes not been taking care of in a long time, its possible that those hoses are dry rotted and when you moved them around to connect to the new ebcs its possible that they cracked, I would check them out and replace them.
TEAM LUXURY
The Following 2 Users Say Thank You to Sid3wayS For This Useful Post:
 Old 09-20-2012, 07:37 PM   #264
S3BAZ1091's Avatar
so then what would be the right way? and thats true. il buy some new lines this weekend. and try to replace them what i have left from the one that came in the package isnt enough.the hoses had tips in them to be able to add more instead of replacing the whole thing. so i just removed the 1st half and replaced it with the new ones. get me?
 Old 09-20-2012, 07:44 PM   #265
Sid3wayS's Avatar
Groans: 97
Yeah I get what your saying, the barbed coupling is because on the k04 the line coming out of the housing is 6mm and the hose supplied is 4mm. I would change them out just to be safe and not use any fittings.
As for how tight, you want it snug,and even, over tightning just ends up squishing the coupling and not making a good even seal.
TEAM LUXURY
The Following User Says Thank You to Sid3wayS For This Useful Post:
 Old 09-20-2012, 07:47 PM   #266
S3BAZ1091's Avatar
oh.. yeah il some new lines this weekend. hope its a breeze to change the one to the wastegate cause looks like bitch to get under. and yeah i know what you mean il check it out. but im pretty sure its all good. but thanks for the help. il post what @Constantin and me see tomorrow and il update when i replace the lines. thanks for the help again.
 Old 09-20-2012, 07:48 PM   #267
Sid3wayS's Avatar
Groans: 97
Any time. When you guys are looking at it hit me up if anything jumps out at you.
TEAM LUXURY
 Old 09-20-2012, 07:51 PM   #268
S3BAZ1091's Avatar
will do thanks!
 Old 09-20-2012, 10:43 PM   #269
Constantin's Avatar
Are you ever coming to Towers? Tomorrow is a good time
 Old 09-20-2012, 10:49 PM   #270
Sid3wayS's Avatar
Groans: 97
Hahaha every time i say yes im going something pops up or it rains.
TEAM LUXURY
 Old 09-20-2012, 10:53 PM   #271
Constantin's Avatar
Well don't say "yes"... but we should expect you there tomorrow
 Old 09-24-2012, 12:14 AM   #272
S3BAZ1091's Avatar
so i was able to get the coupler (new one) fit perfectly with the help of PJ, boosted and coupler is not going anywere. still on 10-15psi. this week his going to help me do a leak test see if i have any leaks. and just sit and wait for Bucker to get back to tunning.
 Old 09-24-2012, 07:45 PM   #273
Sid3wayS's Avatar
Groans: 97
Ok good before you said u wouldnt pass 10 so 10-15 is better. Did you check the lines going to the ebcs?
TEAM LUXURY
 Old 09-24-2012, 11:14 PM   #274
S3BAZ1091's Avatar
i was gonna do that this week when we did the leaks since he has a lift be alot easier to get under but im gonna have to a wait a while since i just lost my job..
 Old 09-25-2012, 07:32 AM   #275
Constantin's Avatar
Did you race your boss and bit him w/o a tune a very low boost? He got upset and fired you?
 Old 09-25-2012, 10:49 AM   #276
S3BAZ1091's Avatar
lol something like that. haha
 Old 10-01-2012, 05:30 PM   #277
S3BAZ1091's Avatar
so i was just browsing edgemotorsports webpage looking around and i found this: Forge Motorsport Piston Turbo Actuator Kit Mazdaspeed 3 6 MS3 MS6
this is what it looks alot like whats under my car under the turbo. (to who ever knows what issues i was having before) that niple went to the stock BC and now is on the new grimmspeed. did i hook it up right? its says actuator and arent i suppose to hook up the BC to the wastegate? @Constantin @Sid3wayS @adlpb digno has the pics i sent him from under my car when i was hooking up the lines. might this be why im underboosting?
 Old 10-01-2012, 05:47 PM   #278
Sid3wayS's Avatar
Groans: 97
The physical wastegate is on the inside of the turbo, because you have an internal wastegate. The actuator is the arm on the outside which hooks up and open/closes the wastegate. That arm is controlled by the ebcs. The round part between the arm and ebcs is the acuator.
The term "wastegate" is used generaly to refer to both the physical valve on the inside and the actuator on the outside.
Did you replace the old lines to and from the bcs? Did you check that all the clamps are on tight including the TiP and bottom of your fmic? Did you perform the leak test?
TEAM LUXURY
adlpb (10-01-2012), S3BAZ1091 (10-01-2012), speeed (10-01-2012)
 Old 10-01-2012, 05:55 PM   #279
S3BAZ1091's Avatar
Did you replace the old lines to and from the bcs? Did you check that all the clamps are on tight? Did you perform a leak test?
ohh ok, sorry for the noob question/post and no not yet. i got laid off from my job a week ago and i dont start work again till this upcoming monday so im running on low fumes till i start working again. last paycheck from other job comes in this week so ima head over and do the leak test and check the lines and anything else so i can start tunning, Bucker isnt going to be able to tune since his computer broke/ rfinkle hasnt answered yet, ive been talking to Lex from Stratified MazdaSpeed Tune (dont know if his good or not? any other recommendations?) and then replace my mounts. hopefully i get some cash for my bday this week and all going towards my car. but thanks again for the quick answer.
 Old 10-01-2012, 06:36 PM   #280
Ms3_Miami's Avatar
Posts: 3,185   (View Stats)
Ms3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the world
Groans: 55
yes Lex is a great tuner.
08 Black Mica Ms3~full bolt ons/Nishan Tuned-Sold
NATOR FL
Ms3_Miami is offline   Reply With Quote
The Following User Says Thank You to Ms3_Miami For This Useful Post:
New Fully Forged engine installed. Which oil? greg08 MazdaSpeed 6 - Engine, Transmission & Driveline 10 04-15-2011 09:51 AM
Cost of going fully built vbt101 MazdaSpeed 3 - Engine, Transmission & Driveline 11 10-07-2009 03:40 AM
Page generated in 0.59225 seconds with 26 queries
