![]() | | #41 | ![]() |
| highest hp speed6 in cali ![]() Join Date: Nov 2010 Location: Nator San Diego, CA
Rep Power: 3193 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 191
Groaned at 326 Times in 194 Posts
| Not Ranked : 0 score |
| The Following 3 Users Say Thank You to Joe Isuzu For This Useful Post: |
![]() | | #42 | ![]() |
| (Toe-kay) ![]() Join Date: Jan 2011 Location: Oakville Ontario Canada
Rep Power: 8685 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,684
Groans: 501
Wait...
__________________ ![]() ![]() Tokay Racing BeCuse Seals. BeCuse you need these. Demodded. Mwho? | |
![]() | | #43 | ![]() |
| Must Have Teh 10's! ![]() ![]() ![]() Join Date: Mar 2008 Location: Rockville, md
Rep Power: 9975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
Groans: 98
Groaned at 122 Times in 91 Posts
i wouldent run less then an 80/20mix of water/AF and only if you live somewhere where temps never break freezing
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust 510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs WWW.SONICTUNING.COM Certified RichTune e-Tuner KILLAH BUILT by SPEED PERF6RMANC3 | |
![]() | | #44 | ![]() |
| psn boostenya ![]() Join Date: Jun 2009 Location: Riverside, CA
Rep Power: 1285 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,769
Groans: 38
Groaned at 15 Times in 13 Posts
Isn't mazda's brand coolant a 70/30 w/af mix?
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
![]() | | #45 | ![]() |
| Veblen Goods ![]() Join Date: Jan 2009 Location: Dania Beach, FL
Rep Power: 2113 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,365
I haven't had any problems with overheating but that's because I had so many overheating and blown head gasket problems with my previous MR2 that I do everything I can to prevent it on the MS3. I am running a ETS TMIC and a D04 70/30 MW mix for track work. I took the Mazda emblem off in the front and inserted some wire mesh. Might not make a huge difference but I tell myself it all adds up in keeping temps low. For oil cooling I just run a heat sink that slides over a huge K&N filter. The thing is huge and touches the tub but big oil filters also help dissipate the heat. For boost it's 22 psi boost to red line and I mostly shift at 6.2 to 6.5K with the occasional third gear pull out of a corner going to 7.2K. One thing I haven't seen anyone mention here is timing. I am not a fan of high timing so I keep it at red line at 12* even with meth and race gas AND about 2 1/2 gs of Ethanol. I know I can probably run way more than that but as long as the clutch isnt holding up to the task I won't push it higher. During 30 min session coolant temps stay at 192 to 196*. Once into the cool down laps they increase to about 212 to 220. In the pits they can climb to 232 after shut off unless I ran about 5-10 mins of cruising at low load. What I do then is just turn the car on for about 30 seconds to let the coolant flow a little. For glycol / water mix you can run up to 80% water before scaling occurs I read. I run 70% distilled water. One more thing I just read on Speedkillah's build is that his oil temps decreased 10-15 deg by switching to Rotella T6 oil. Not sure how that temp drop is possible just by switching oil. I am also running T6 though so may be there is something to it. These are older pics but you get the idea. ![]()
__________________ ![]() GHEY THUNDER Last edited by Tomas; 07-02-2012 at 09:26 PM. | ||
| The Following 4 Users Say Thank You to Tomas For This Useful Post: | 802MS3 (07-02-2012), Boosten Ya(josh) (07-02-2012), charlesfist (07-03-2012), Nliiitend1 (07-03-2012) |
![]() | | #46 | ![]() |
Groans: 38
In the cool down laps turn your AC on but with the temp at 90° so it's blowing hot air out and the fan is on cooling the radiator. Also if you turn the car off, turn it to the on position (without the engine running) have the heater on to help get some more heat out. I know you might know this Tomas but if anyone else doesn't, now they do.
| The Following User Says Thank You to Boosten Ya(josh) For This Useful Post: | Tomas (07-02-2012) |
![]() | | #47 | ![]() |
![]() Join Date: Apr 2009
Rep Power: 319 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 347
Groans: 195
Groaned at 34 Times in 24 Posts
| Not Ranked : 0 score Daddy Chinkus, what kind of external oil cooler were you running?
![]() | | #48 | ![]() |
Groans: 191
cxracing core, im selling my old one if interested. got one on the fs thread
![]() | | #49 | ![]() |
![]() Join Date: Jun 2011 Location: Decatur, IL
Rep Power: 230 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 328
On Sunday I took my car out and I was hitting 235 and it would not go down at all. I let it sit for about 10 min with the AC on no hotter no colder then I took it out and tried just driving regular. No change then took it up to 100 MPH still no change. What do you guys think the problem is. I have a synapse fmic its.about.3 to 3.5 thick
![]() | | #50 | ![]() |
Groans: 191
might want to check your radiator fan. turning the AC on will make it worse, heater core will help but also idle wont help cool temps either.
![]() | | #51 | ![]() |
We tried going fast to force air in but nothing happened.I will check my fan though thanks.
![]() | | #52 | ![]() |
Try going moar fast.
__________________ ![]() GHEY THUNDER |
| The Following 3 Users Say Thank You to Tomas For This Useful Post: |
![]() | | #53 | ![]() |
Groans: 38
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit | |
![]() | | #54 | ![]() |
Groans: 38
| The Following User Says Thank You to Boosten Ya(josh) For This Useful Post: | superskaterxes (07-03-2012) |
![]() | | #55 | ![]() |
![]() Join Date: Jun 2009 Location: Lost Angels, Cali
Rep Power: 5068 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,681
Groans: 78
Groaned at 274 Times in 243 Posts
A2696 is the plastic/aluminum aftermarket replacement with similar performance to the stock OEM radiator with a 16mm thick core. The Koyorad KH061816 is an all-aluminum performance radiator with a thicker 25mm core. Sent from my iPhone using lame ass Tapatalk
__________________ ![]() | |
| The Following 2 Users Say Thank You to hnda etr For This Useful Post: | laxplayermjd (07-03-2012), Tomas (07-03-2012) |
![]() | | #56 | ![]() |
| I RATCHET then I MOLLY... ![]() Join Date: Jul 2010 Location: Sterling, VA
Rep Power: 1356 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,386
Had a koyo radiator on my 240... Shit worked well, maybe too well. Lol. I had virtually no heat in the winter time. Lol sent using ninjatroll
__________________ ![]() cobb ap // RICHTUNE // msd dh // autotech fpi // cp-e nano // htp tip // nator dc fmic // hks ssqv *vta* // cs dp // su tp cp-e rmm(65duro) // jbr pmm(80duro) // jbr tm(88duro) // sure ssb // nator dc sts // jbr hw shift knob hawk hps // sonic tuning st8 18x8.5 +42 www.sonictuning.com 311 whp - 345 lb/ft : Dynojet @ Moore Automotive *93 pump [4/13/13 MNM] 13.85 @ 106.68 @ Mason-Dixon Dragway *550' ASL [4/14/13 MNM] | |
![]() | | #57 | ![]() |
| Monk Tuning ![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 872 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,032
Any idea of fitment issues between the years? They list this as an 07-09 part, but I would lover to have this on my 11.
__________________ 2011 Speed3-CP-E Stage 2 RMM, JBR TMM, JBR SSP, JBR SSB, 3.5" JBR WP, DDM 55w 6000k, Hoen Fog Lights, Autotech Internals, Enkei 17x8.5 RPF1, TIGs, EGR Delete, OCC, Treadstone TR8, FoMoCo Trans Fluid, Swift Springs, BSD and Baffle Kit, Ported Intake Manifold ala Driver311, CPE Injector Seals,PTP injector stud kit, RB Fabrication Ex Manifold, PTP 1950 Rail valve, ITV22s, Cordova Throttle Body, E85 blend Tuned by ME!!! Waiting to install- JTMS3 SUB BOX!!! TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
![]() | | #58 | ![]() |
Groans: 191
aluminium is the way to go. itll heat soak a lil bit at idle since its so conductive however as soon as fresh air starts hitting it itll cool down fast. with pure distilled and water wetter my temps range from 180-140. if i start coasting for awhile ive seen my temps go below 130 on a cold night. p.s dont burn yourself. ALL of the radiator will get hot |
![]() | | #59 | ![]() |
| Track Fiend ![]() Join Date: Jan 2012 Location: Canada
Rep Power: 161 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 586
| The Following 3 Users Say Thank You to Standsideways For This Useful Post: |
![]() | | #60 | ![]() |
Im surprised corksport hasnt released something aswell. I know they sell/sold one for the protege at one time. |
![]() | | #61 | ![]() |
Rep Power: 4090 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26,497
$380 and claims 100% fitment? Not bad, not bad at all. KOYO RACING RADIATOR: MAZDASPEED-3 07-09-Options Auto Salon - Sport Compact Car Performance Parts
![]() | | #62 | ![]() |
![]() | | #63 | ![]() |
Groans: 78
I contacted koyo racing about fitment, and they said the only thing you may need to do is trim the hoses 1/4" because larger core means the piping sticks out a bit further.
| The Following User Says Thank You to hnda etr For This Useful Post: | Tomas (07-03-2012) |
![]() | | #64 | ![]() |
![]() Join Date: Sep 2009 Location: Rosemead, CA
Rep Power: 149 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 670
Groans: 27
glad i came across this thread ... was also experiencing higher temps while on a road course, probably not as high as the fmic guys .. but pretty much up until right now, i thought it was just my car's cooling system not being 100% temps will start out ok the first 1 or 2 laps .. but then after it hovers around 214ish give or take a few degrees so i guess a new rad is in my near future ...
__________________ 08 MS3 () Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, Autolite XP5263 () Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Enkei GF1/Ferderal RS-R, Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms, ATE Super Blue Brake Fluid () Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90 |
![]() | | #65 | ![]() |
| The Following User Says Thank You to MS3inDC For This Useful Post: | Tommyspeed3 (07-21-2012) |
![]() | | #66 | ![]() |
| Not Ranked : 0 score today i was watching my temp coming home from work and it was at 241, i have my bottom plate on to scoop air and my fan is all good. i was talking to a guy who said something about it being the timing. i dont really know what to do. i was just going to throw a stock map on for a bit and see if the tune is causing it. idk why it would thats all i could think of doing next along with buying this water wetter shit
![]() | | #67 | ![]() |
Groans: 501
When was your last flush and fill?
![]() | | #68 | ![]() |
![]() | | #69 | ![]() |
Groans: 27
__________________ 08 MS3 () Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, Autolite XP5263 () Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Enkei GF1/Ferderal RS-R, Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms, ATE Super Blue Brake Fluid () Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90 | |
| The Following User Says Thank You to easy For This Useful Post: | Carl (07-11-2012) |
![]() | | #70 | ![]() |
![]() | | #71 | ![]() |
Groans: 78
| Not Ranked : 0 score You haz caught teh ghey...
![]() | | #72 | ![]() |
![]() | | #73 | ![]() |
Groans: 38
Is your coolant brown?
![]() | | #74 | ![]() |
| Not Ranked : 0 score its green and i have to watch my hot cold gauge climb 2 notches away from hot bc i dont have my other car. i am getting so fucking mad at this car its one thing after another. everyone keeps saying its my thermometer but i cant get a cheap one anywhere. the cheapest one around butt fuck decatur is 180. ahhhhhhhhhhhh i am drunk and pissed. i want to ghost ride this bitch in a river and just go buy my raptor right now!!!!!!
![]() | | #75 | ![]() |
Groans: 501
Change thermostat and coolant. Problem solved.
![]() | | #76 | ![]() |
![]() | | #77 | ![]() |
![]() Join Date: Dec 2011 Location: howard, pa
Rep Power: 657 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,328
Groans: 44
Groaned at 14 Times in 5 Posts
So I just read this whole thread. Right after I did my coolant bypass I sliced a line and lost my coolant. Fixed it and afterwards I noticed my temps reaching 210 on idle and between 180-190 cruising. It used to sit at 187 constant. But its starting to be more stable now. I think I had some air in the line but it seems to be evening out. But if I'm hitting 190 cruising on a hot day (85-90*) I'm perfectly fine? I was freaking out seeing 210 on a stand still. Thought when my gf's dad cleaned out my coolant he shorted the fan or something.
__________________ |
![]() | | #78 | ![]() |
![]() | | #79 | ![]() |
Groans: 78
They make racing rads for the speed 6 I think you need to call them to order though...
![]() | | #80 | ![]() |
Built for racing, not as an oem replacement that may be slightly thicker. The ron davis rads are thick, very well built, and come with nice big fans and shroud. The koyo comes with no fans or shroud. | |
| The Following User Says Thank You to Standsideways For This Useful Post: | Angr-E1 (08-21-2012) |
| Aluminum Racing Radiator for MS3 | AlpineFD | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 06-27-2012 03:16 PM |
| Radiator cleanup | mituc | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 09-29-2009 01:25 PM |
| Cp-e radiator hose | speed01 | Custom Performance Engineering (cp-e.com) | 1 | 06-22-2009 12:02 PM |
| Radiator Leak? | lvmazdaspeed3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 06-06-2009 01:34 PM |
| Radiator Fan | badams118 | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 06-03-2009 08:06 PM |
