Like Tree5Likes
 Old 08-21-2012, 11:59 AM   #81
MS3inDC's Avatar
Posts: 3,070   (View Stats)
Groans: 29
Originally Posted by Standsideways View Post
2X the price for a reason.
Built for racing, not as an oem replacement that may be slightly thicker.
The ron davis rads are thick, very well built, and come with nice big fans and shroud.
The koyo comes with no fans or shroud.
Koyo makes racing radiators as well as oem replacements. I can also say that the koyo racing radiators are very well built (had one on my 240, as stated earlier). It'd be nice if they offered a fan and shroud, but because those aren't included don't disregard koyo.
Either would be better than stock, I'm sure.
MS3inDC is offline   Reply With Quote
 Old 08-21-2012, 12:06 PM   #82
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Yes, koyo makes 2 different radiators for the speed 3 - direct fit oem replacement (16mm thickness like oem - aluminum and plastic end caps) and an all aluminum race radiator (25mm thickness) still direct fit... Great quality! The stock fan and shroud is reused.
Sent from my iPhone using lame ass Tapatalk
The Following 4 Users Say Thank You to hnda etr For This Useful Post:
Boosted Beluga (08-21-2012), impossible (01-07-2016), MS3inDC (08-21-2012), Nliiitend1 (08-23-2012)
 Old 08-21-2012, 12:13 PM   #83
MS3inDC's Avatar
Groans: 29
Plug and play gets my vote... but I'm lazy
The Following 2 Users Say Thank You to MS3inDC For This Useful Post:
Angr-E1 (08-21-2012), Boosted Beluga (08-21-2012)
 Old 09-20-2012, 04:09 PM   #84
MattJackson86's Avatar
Posts: 1,407   (View Stats)
Are there any aftermarket fan and shroud assemblies (without radiator)? Has anyone had an issue with their OEM fan slowing down or dying?
 Old 09-28-2012, 12:34 AM   #85
world famous z's Avatar
Posts: 55   (View Stats)
world famous z will become famous soon enoughworld famous z will become famous soon enough
Groaned at 42 Times in 8 Posts
I've read in other threads that water wetter hasn't been well received by many users on this engine, anyone in this thread had any good or bad experiences on their speed 3 / 6 motor?
I had ran it for a while and noticed that my reservoir was getting very dark / dirty even with coolant flush and services. Replaced the reservoir and new coolant and left the water wetter out this time around and no issues.
world famous z is offline   Reply With Quote
 Old 10-02-2012, 09:53 PM   #86
Tabasco69's Avatar
Posts: 554   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
I run the Ron Davis radiator w/fans and shrouds, be forewarned they sound like giant shop vacuums when they come on (twin 1250cfm Spal fans), I ran an independent relay system, 2 x 40 amp triggered by a 195/on 180/off painless temp switch mount as a splice (1 1/8th" aluminum) in the coolant inlet hose, and another relay that is triggered by the a/c fan clutch to cool the condenser, and a manual switch mounted to the dashboard console.
I also run a cosworth coolant/oil cooler, and a air/oil deraile stack plate cooler (3"depth x 7" height x 12" width) with a thermostatic plate (bypass valve begins to open at 165*) using -8an braided lines.
The radiator does not accomodate the oe condenser, there are no provisions the mount it to the front of the rad like the stock one, I ended up having the mount the condenser to the rad frame by drilling holes on all 4 flat aluminum tabs of the condenser, the stock core is a single pass .5" thick at the most, and does a fairly good job considering, the RD core is 1", dual pass....other then the condenser mounting I had no issues with the install.
425whp/395ftlbs - GTX3071R .82a/r- 20psi- 92 octane pump fuel
Tabasco69 is offline   Reply With Quote
The Following User Says Thank You to Tabasco69 For This Useful Post:
rfinkle2 (02-04-2014)
 Old 10-02-2012, 10:34 PM   #87
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
My friend modified a oem thermostat housing for a 170° thermostat. I'll be installing it tomorrow and get some tests.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 10-04-2012, 09:05 PM   #88
Groans: 50
Here is the modified thermostat.
08 Mazdaspeed 3
 Old 11-19-2013, 09:40 AM   #89
ABolewski's Avatar
Posts: 1,279   (View Stats)
ABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the world
Groans: 52
Bump this shit yo.
Total MPS just posted this picture saying their new radiator will go on sell in February next year. I'm pretty interested, I really want to keep my coolant temps down as much as I can in the summers in SoCal. With my TR1035 intercooler I fear stock just isn't going to cut it.
2010 Alternative Lifestyle Blue Mazdaspeed3
(sold)
2008 Chevy Colorado. The only truck that comes with a lifetime guarantee...
ABolewski is offline   Reply With Quote
The Following User Says Thank You to ABolewski For This Useful Post:
 Old 11-19-2013, 11:17 AM   #90
magicka's Avatar
Posts: 520   (View Stats)
magicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the world
I'm not discounting the benefits of an upgraded rad, but, from what I've read, there are some cheaper and easier ways to keep things cool. Ducting the FMIC and rad to direct max airflow through rather than around helps. @Dano; had good luck on the stock rad and (I think) fans with a fan controller designed by @BlueStreak;. SP63 is working on developing a production version.
EDIT:
The thread is "MZR DISI Heat Management"
2009 CWP MS3 GT
Rally Armor Flaps | Gen Pu Wheels | JBR 80d v1 RMM/RSB/TIGs/Boost & Bypass Tubes
TWM Full Replacement Shifter | CS SRI/TIP/Skid Plate | Koni FSD 4045 | Matt Damon OCC | Cobb DP/AP | CP-e TMIC/HPFP
PTP VVT Actuator/Injector Seals & Studs | Samco Rad Hoses | Redline Leather Shift & E-Brake Boot
BNR S3 | Stratified Boost Dial
magicka is offline   Reply With Quote
The Following 3 Users Say Thank You to magicka For This Useful Post:
BlueStreak (01-24-2014), Dano (01-14-2014), rfinkle2 (02-04-2014)
 Old 11-19-2013, 12:15 PM   #91
hnda etr's Avatar
Groans: 90
What has been modified?
Originally Posted by ABolewski View Post
Bump this shit yo.
Link to this info?
The Following User Says Thank You to hnda etr For This Useful Post:
magicka (11-19-2013)
 Old 11-19-2013, 12:51 PM   #92
Andjo's Avatar
Posts: 937   (View Stats)
Andjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the world
Bump this shit yo.
Link to this awesomeness?
GT3076 and supporting mods with Kozmic Motorsports Built motor and tune
FUTURE MODS: 6266 with V-Band everything
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
2013 TROLL CHAMPION "DYLANFYHN"
Andjo is offline   Reply With Quote
 Old 11-19-2013, 01:50 PM   #93
Groans: 50
@honda etr; the metal part has been changed. So the actual thermostat is different.
08 Mazdaspeed 3
The Following User Says Thank You to Boosted Beluga For This Useful Post:
hnda etr (11-19-2013)
 Old 11-19-2013, 03:28 PM   #94
ABolewski's Avatar
Groans: 52
@hnda etr; @Andjo; it's on their Facebook. Just search Total MPS.
And thanks @magicka; I was trying to remember the name of that thread.
(sold)
The Following 2 Users Say Thank You to ABolewski For This Useful Post:
hnda etr (11-19-2013), magicka (11-19-2013)
 Old 02-04-2014, 10:03 AM   #95
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Worth a read:
Cooling System Additives - Turbo and High-Tech Performance Magazine
Mauro_Penguin likes this.
The Following 4 Users Say Thank You to rfinkle2 For This Useful Post:
Mauro_Penguin (02-04-2014), RedBull22 (02-07-2014), Tokay444 (02-04-2014), Tomas (02-04-2014)
Aluminum Racing Radiator for MS3 AlpineFD MazdaSpeed 3 - Engine, Transmission & Driveline 10 06-27-2012 04:16 PM
Radiator cleanup mituc MazdaSpeed 3 - Engine, Transmission & Driveline 5 09-29-2009 02:25 PM
Cp-e radiator hose speed01 Custom Performance Engineering (cp-e.com) 1 06-22-2009 01:02 PM
Radiator Leak? lvmazdaspeed3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 06-06-2009 02:34 PM
Radiator Fan badams118 MazdaSpeed 3 - Engine, Transmission & Driveline 3 06-03-2009 09:06 PM
Page generated in 0.36845 seconds with 30 queries
