 Old 12-01-2009, 02:50 PM   #1
bbonkboy's Avatar
Posts: 40   (View Stats)
bbonkboy will become famous soon enough
Groaned at 10 Times in 3 Posts
Default MS3 synthetic oil and filter
a) how often to change the oil on synthetic oil? (ex 7.5k miles)
b) what kind/brand/type of filter to use?
so I'm using Mobil 1 full synthetic 5w-30. But which filter should i match with it? i was told to stay away from "fram". recommend any good ones?
bbonkboy is offline   Reply With Quote
 Old 12-01-2009, 02:51 PM   #2
samsel450r's Avatar
Posts: 350   (View Stats)
samsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the world
i use mobile 1 full synthetic and change it every 3k miles an for the filter i just use a fram..
1999 Formula WS6 1 of 175 Made
Built 347 - Built 347, ARP everything, milled AFR 205's, PatG cam, ls6 Intake, MTI TB, Jethot LT's, True duals, 9inch rear 3.73's, built t56, NX kit W/NANO and more!
samsel450r is offline   Reply With Quote
 Old 12-01-2009, 02:52 PM   #3
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
i like the stock filter
The Following User Says Thank You to For This Useful Post:
DaleNixon (12-04-2009)
 Old 12-01-2009, 02:52 PM   #4
glocK23's Avatar
Posts: 1,753   (View Stats)
glocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the world
Groans: 701
I never liked Mobile 1 synthetic, I think it's garbage.
Anyways, I use Pennzoil Platinum 5w30 and a motorcraft cartridge filter.
Every 4K miles.
glocK23 is offline   Reply With Quote
 Old 12-01-2009, 03:01 PM   #5
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
pp 5w30 & mobil 1 big spin on filter - 8 qts ftmfw.
switching to rotella 5w40 based on haltech's advice.
 Old 12-01-2009, 04:37 PM   #6
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
k&n makes nice filters. Ive been using mobil 1 since first oil change. Ive got 2 uoa's posted with my 3rd on its way. I did change to 5w-40 this change though.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline   Reply With Quote
 Old 12-01-2009, 06:17 PM   #7
Bonafide_Spd3's Avatar
Posts: 344   (View Stats)
Bonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond repute
PP 10w 30, just changed from mobil 1. Heard it was better so had to change
2007 Cosmic Blue Speed3
[ MS CAI w/Straightener] [Cobb AP] [ RPMC TI ] [ FORGE BPV ] [ SU RP ] [ PG FMIC ] [Denso Plugs] [Trz MM] [ TWM SS&Bushings ] [ Greddy TT ] [ Defi Boost Gauge ]
Not going to install-Weapon R catch can. Piss on doing that install
Bonafide_Spd3 is offline   Reply With Quote
 Old 12-01-2009, 06:30 PM   #8
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
Shell Rotella T Syn 5W-40 and I've been using Purolator Pure One filters changed every 5,000 miles. I'm pretty sure I could go 6,000 easily, but I stick with 5k. I've had 3 oil analysis come back with strong numbers and high TBN after 5,000 miles.
 Old 12-01-2009, 06:32 PM   #9
dizwhoadayjohn's Avatar
Posts: 261   (View Stats)
dizwhoadayjohn has a reputation beyond reputedizwhoadayjohn has a reputation beyond reputedizwhoadayjohn has a reputation beyond reputedizwhoadayjohn has a reputation beyond reputedizwhoadayjohn has a reputation beyond reputedizwhoadayjohn has a reputation beyond reputedizwhoadayjohn has a reputation beyond reputedizwhoadayjohn has a reputation beyond reputedizwhoadayjohn has a reputation beyond reputedizwhoadayjohn has a reputation beyond reputedizwhoadayjohn has a reputation beyond repute
mobil1 synthetic 5w-30. And factory oil filter. I can't complain about free mobil1 oil so that's what i'll keep using until whenever
dizwhoadayjohn is offline   Reply With Quote
 Old 12-01-2009, 10:31 PM   #10
ms3077's Avatar
Posts: 4,024   (View Stats)
ms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the world
Groans: 974
Groaned at 738 Times in 373 Posts
AMsoil Full Synthetic 5W30 - 3 to 5k intervals - Factory Filter
It's expensive but worth it in my opinion. The car runs great with it.
ms3077 is offline   Reply With Quote
 Old 12-01-2009, 10:48 PM   #11
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
PP 10w30. fram filter. change every 3k miles
used Mobile 1 and amsoil but my car likes PP the best
2015 Mazda 6
 Old 12-02-2009, 08:30 AM   #12
TegRacer324's Avatar
Posts: 145   (View Stats)
TegRacer324 is just really niceTegRacer324 is just really niceTegRacer324 is just really niceTegRacer324 is just really niceTegRacer324 is just really nice
Castrol Synthetic because it's always on sale at autozone. Change it every 5k. Really don't understand why people buy synthetic and change it every 3k.
TegRacer324 is offline   Reply With Quote
The Following User Says Thank You to TegRacer324 For This Useful Post:
speed3 (12-02-2009)
 Old 12-02-2009, 08:33 AM   #13
eddelgado's Avatar
Posts: 84   (View Stats)
eddelgado will become famous soon enougheddelgado will become famous soon enough
Penzoil Platinum 5w-30 and Wix filter every 5000 miles.
Ed
eddelgado is offline   Reply With Quote
 Old 12-02-2009, 08:40 AM   #14
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Groans: 166
PP 5W30 mazda filter 4000 miles
Where do you guys go to get UOA's? Ive been curious to get one, but dont know where to go.
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
Originally Posted by Say Chi Sin Lo View Post
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
 Old 12-02-2009, 10:10 AM   #15
dan7225's Avatar
Posts: 511   (View Stats)
dan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the world
$22.50 @ blackstone labs.
i used mobil1 10w-30 and napa gold/wix (5)1516 spin on filter. it's HUUUUGE!
dan7225 is offline   Reply With Quote
 Old 12-02-2009, 11:13 AM   #16
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Penzoil Platinum 5W-30 changed every 3-4K religiously. I have the spin-on filter conversion and just use Mazda filters. I also always replace the crush washer on the plug. I don't leave things like that to chance.
There is nothing wrong with Fram filters. They've been making filters for a looooong time. I've ran my fair share of Frams in the past and never once had an issue.
this forum serves 2 purposes
 Old 12-02-2009, 11:38 AM   #17
terrylharris's Avatar
Posts: 1   (View Stats)
terrylharris is an unknown quantity at this point
Groaned at 3 Times in 1 Post
Since Mazda does not recommend, actually prohibits, synthetic oil.....what do you guys do about your warranty? I have called big Mazda and they claim to void warranty if you use synthetics.
terrylharris is offline   Reply With Quote
The Following 3 Users Say NO Thank You to terrylharris For This Un-useful Post:
 Old 12-02-2009, 11:50 AM   #18
I <3 your mom
Dash08's Avatar
Groans: 293
That's rubbish. Synthetic oil offers greater protection and prolongs engine life. Especially on forced induction engines. This is just common knowledge. It also helps with controlling fuel dilution which is the reason most change their oil so frequently in the 2.3 MZR. This engine sees heavy fuel dilution even after only 3000 miles. Go check the UOA threads. It's all there.
As for warranty, when I had my engine replaced under warranty, I sent them all my receipts from my synthetic oil purchases and they didn't even raise an eyebrow. I even had the spin-on filter conversion, but because it's a FOMOCO part, they didn't say anything.
Just do your research so you have the upper hand if anything goes down. I did and it got my engine replaced for free with warranty still intact.
 Old 12-02-2009, 01:40 PM   #19
eddelgado's Avatar
You can also get your oil analysis kits from NAPA. They run about $15 each or so but do not include shipping. The analysis is pretty much the same as what you get from Blackstones. I think Blackstone may provide more detailed comments from someone reviewing the results.
Ed
 Old 12-02-2009, 04:20 PM   #20
nyghtryder's Avatar
If that was the case they wouldnt use the oil I provide them when they changed my oil.
Do we know what the factory fill is? Alot of cars now come with synthetic as the factory fill.
NATOR PA
 Old 12-02-2009, 04:24 PM   #21
phantom3's Avatar
Posts: 1,223   (View Stats)
phantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the world
Groans: 190
Groaned at 53 Times in 32 Posts
Factory fill is synthetic. My dealership only stocks synthetic oil... Not that I let them change my oil...
My mission is to go fast.
Currently Designing:
The golden girdle of the gods
The CF "fuck your face" IM
phantom3 is offline   Reply With Quote
The Following User Says Thank You to phantom3 For This Useful Post:
nyghtryder (12-02-2009)
 Old 12-02-2009, 04:26 PM   #22
nyghtryder's Avatar
Dash08:
Where you get the fomoco spin on conversion from?
NATOR PA
 Old 12-02-2009, 04:31 PM   #23
ANGRYEAGLE's Avatar
Posts: 133   (View Stats)
ANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant future
I was also told by my dealer that they do not recommend synthetic. i thought that they would jump at the chance to make more money off of me, but no. so I just let them do my oil changes while it is under warranty.
ANGRYEAGLE is offline   Reply With Quote
 Old 12-02-2009, 04:47 PM   #24
I <3 your mom
Dash08's Avatar
Groans: 293
Dash08:
Street Unit. Talk to Mark. I paid like $60 bucks shipped and it came with a Mazda filter and a new crush washer. It's a good deal, my oil changes are even faster now.
 Old 12-02-2009, 04:48 PM   #25
nyghtryder's Avatar
If the factory fill is synthetic then the techs at your dealers a moron. It never ceases to amaze me how little they know about these cars.
NATOR PA
The Following User Says Thank You to nyghtryder For This Useful Post:
Juyoung (04-20-2013)
 Old 12-02-2009, 06:19 PM   #26
There should be no reason a synthetic oil should not be recommended in modern turbo-charged engine.
 Old 12-02-2009, 07:01 PM   #27
214mazdaspeeder's Avatar
Posts: 39   (View Stats)
214mazdaspeeder is a splendid one to behold214mazdaspeeder is a splendid one to behold214mazdaspeeder is a splendid one to behold214mazdaspeeder is a splendid one to behold214mazdaspeeder is a splendid one to behold214mazdaspeeder is a splendid one to behold
just recently royal purple 5w-40 evry 4k k&n filter (B4 turbo smoke 5W-30 evry 4k) my dealer does my oil changes and they never said anything about my synthetic he said its better. i wish mazda would get on the same page
214mazdaspeeder is offline   Reply With Quote
 Old 12-02-2009, 07:04 PM   #28
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
PENZOIL PLATINUM 5W-30 with external filter K&N HP-1002 every 3000 miles. Tranny Change every 5th motor oil change with AMSOIL SYNTHETIC TRANNY OIL MTGQT-EA.
 Old 12-02-2009, 07:05 PM   #29
IshiKage's Avatar
Groans: 278
Lightbulb
not sure where you've been, but they changed that.
thats why they have synthetic amsoil at the dealership
2015 Mazda 6
The Following User Says Thank You to IshiKage For This Useful Post:
ms3077 (01-15-2010)
 Old 12-02-2009, 07:18 PM   #30
lidokrantz's Avatar
Posts: 663   (View Stats)
lidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the world
LOL....at my Mazda dealership it is recommended to switch to fully synthetic asap by the service mgr...i did at 600 miles and never an issue with Mobil1(what the dealer uses)...although i do change it every 3,000 miles..I also bring in my own oil and Mazda uses there filter... I never heard that from the factory they use synthetic....i doubt it actually, but maybe they changed from 07..IMO change it frequently and all the good oils will work fine, but feel the synthetic is better for a turbo car. May try PP...if it's on sale, but so far Mobili1has treated me just fine..
Current.. 2009 BMW 135i Twin Turbo, Sedonna Red Metallic, M Sport Pkg, Premium Pkg, Cold Weather Pkg with heated seats, Xenons,M Sport steering wheel, BMW Factory Sport Exhaust..300hp, 300 Tq.. in reality..320 hp 320 tq stock
SOON: BMS JB3....tune, ICarbon rear diffuser, ....all under warranty...
Past/Sold...2007 MazdaSpeed3,CP-E TBE, CAI, Advan Rs Gunmetal, TWM STS with bushings TWM Desert Eagle shift knob,, Defi Amber boost gauge, HKS BOV with CP-E flange..also tried CP-E Nano SRI (MazdaSpeed CAI, Rota TQ Hyperblack, are FOR SALE 4 months old)
lidokrantz is offline   Reply With Quote
 Old 12-02-2009, 07:28 PM   #31
starscream's Avatar
Posts: 630   (View Stats)
starscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the world
Groans: 44
I thought the factory oil was a Synthetic Blend rather then a true Synthetic?
starscream is offline   Reply With Quote
 Old 12-02-2009, 08:11 PM   #32
bbonkboy's Avatar
Never did a oil change on this MS3. Where is the oil filter on this car? Is it easily accessible?
what is this spin on conversion everyone seems to be talking about?
The Following User Says NO Thank You to bbonkboy For This Un-useful Post:
 Old 12-02-2009, 11:20 PM   #33
nyghtryder's Avatar
oil change is easy, but you have to remove the plastic tray. People get the spin on because you can get a larger oil filter as well as making the filter change easier. If you dont have the spin on you need to get an oil filter wrench made for the mazda. I could only find the right size at autozone the others were too loose. look in the how to section im sure someone has done a write up.
NATOR PA
bbonkboy (12-04-2009)
 Old 12-03-2009, 08:22 AM   #34
KR....i haz it
Blackspeed's Avatar
Groans: 166
you can get the filter wrench with a puchase of a box of filters here:
Genuine(Cartridge) Mazda Oil Filter New Lower Price Pack of 5 with Free Oil Filter Wrench
The Following 6 Users Say Thank You to Blackspeed For This Useful Post:
06Speed6 (12-12-2009), bbonkboy (12-04-2009), Juyoung (04-20-2013), kwsmithphoto (12-06-2009), ms3077 (12-04-2009), shpankey (01-10-2010)
 Old 12-03-2009, 12:46 PM   #35
bbonkboy's Avatar
Thanks!
 Old 12-03-2009, 12:50 PM   #36
KR....i haz it
Blackspeed's Avatar
Groans: 166
you're welcome.
theres also a little button below everyone's post that says "thanks"
The Following User Says Thank You to Blackspeed For This Useful Post:
bioevolve (12-03-2009)
 Old 12-04-2009, 02:11 AM   #37
bbonkboy's Avatar
you're welcome.
haha. sweet. new here so learning all the bells and whistles..
 Old 12-04-2009, 11:31 AM   #38
patrick failman
Groans: 74
jesus. you use your first post to threaten void warranties? call big mazda back and tell them to fix their oil change coupons.
Oil Change Plus
Get more fluid for your money! We'll change your Mazda's oil and filter, plus we'll top off the vital fluids and perform a thorough Mazda Full Circle Service Inspection.
* Change motor oil per specifications
* Install a Genuine Mazda oil filter
*Top off vital fluids
* Synthetic Oil extra
* Some models slightly higher - see dealer for details
* Complete Full Circle Service Inspection
$29.95
Plus applicable taxes. Valid only at Douchebag's Mazda. Cannot be used with any other applicable offer. Mazda vehicles only. Some vehicles may be slightly higher. Hazardous waste fee if applicable. Expires 2010-01-03. Please present coupon at time of write-up.
The Following User Says Thank You to karl-hungus For This Useful Post:
Speedn3 (12-04-2009)
 Old 12-04-2009, 05:21 PM   #39
Speedn3's Avatar
Posts: 642   (View Stats)
Speedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond repute
Oil Change Plus
$29.95
lmao......
Speedn3 is offline   Reply With Quote
 Old 12-04-2009, 07:51 PM   #40
DR_
DR_'s Avatar
Posts: 37   (View Stats)
DR_ is a glorious beacon of lightDR_ is a glorious beacon of lightDR_ is a glorious beacon of lightDR_ is a glorious beacon of lightDR_ is a glorious beacon of light
I cut a hole in the plastic under tray that is just big enough to change out the oil filter. There is already a hole there but it doesn’t line up with the filter so I just made one that did line up.
DR_ is offline   Reply With Quote
Motul 8100 Fully Synthetic Oil Matrix311 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-12-2010 10:46 AM
should i change to synthetic? johnac08 MazdaSpeed 3/6 - Turbo Induction 12 09-05-2009 08:35 PM
What synthetic oil works best in the ms3 IYO marven MazdaSpeed 3 - Engine, Transmission & Driveline 110 06-20-2009 10:50 AM
From Cow to Crankcase: Synthetic oil from animal fat Haltech Automotive News 0 12-03-2008 03:50 PM
Synthetic oil really needed? gsrtype1 MazdaSpeed 3 - Engine, Transmission & Driveline 61 11-13-2008 07:05 AM
Page generated in 0.53246 seconds with 43 queries
