 Old 08-19-2014, 11:14 AM   #1
Mofford12's Avatar
Posts: 8   (View Stats)
Mofford12 is an unknown quantity at this point
Default Ms6 Cylinder 1 & 4 wet
i have a 2007 speed6 with 83k miles .. she is as stock as it gets, purchased thru my dealer as a trade in and was owned by a lady in her 50's i have all service records. nothing major was ever done to the car..
my issue is one day i wanted to put some oem plugs in it and as i pulled them out 1 by 1 i obvisoulsy looked at what i could thru the spark plug hole i noticed 1 and 4 was wet.. strange? checked my oil and for sure was low.. 3 days prior i did 5.5 qts of rotella 5w40.. so i topped oil back off and put the new plugs in, car ran fine an i continued to check my oil. i would say im going thru .5-1 qt a week..
compression test 1,2,3,4
185,180,180,185
leak down test 90psi all 4 held very well
car was hot when test were performed..
turbo has minimal to no play
no records that pcv valve was ever replaced..
before i start throwing money at this or that i would like some tips or idea as to the issue
Mofford12 is offline   Reply With Quote
 Old 08-19-2014, 11:30 AM   #2
speed23's Avatar
Posts: 1,476   (View Stats)
My money's on the turbo burining the oil, but you cant see smoke cause hidden by the cats. I guess that doesnt explain the wet in 1 and 4, but if you have good compression all should be ok, no?
 Old 08-19-2014, 11:35 AM   #3
[R]usty's Avatar
Posts: 2,198   (View Stats)
[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world
Groans: 79
Any oil in the cold side of the turbo?
2010 Mazdaspeed3 w/tech
Cobb AP V3JBR Tru 3" Wide PathJBR Boost Tubes & BPV HoseCobb XLE BPVCP-E TMIC ║ UR Racepipe ║ Magnaflow CBEAutoTech InternalsGrimmSpeed EBCS ║ JBR RSBSPC Camber ArmsKW V3 CoiloversJBR IM+TB TIGs & TB BypassJBR SSPE - Focus RMMStopTech Slotted Rotors and EBC Yellow Stuff PadsTechna-Fit SS Brake Lines
[R]usty is offline   Reply With Quote
 Old 08-19-2014, 12:22 PM   #4
Mofford12's Avatar
no oil on the cold side.. very small amount of oil inside the tube that goes from tmic to throttle body.. but no oil inside the intercooler either
would i have to pull the air/fuel ratio sensor to check the hot side of the turbo
Supplier testing 3-cylinder engines with cylinder deactivation Haltech Automotive News 0 07-14-2014 02:50 PM
Cylinder#1 Turbo4banger MazdaSpeed 3 - Engine, Transmission & Driveline 1 01-26-2014 06:01 PM
Cylinder 3 missfire 08 Red Rocket MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 09-13-2012 10:35 AM
Page generated in 0.24534 seconds with 22 queries
