Like Tree3Likes
  • 1 Post By Fstrnyou
  • 1 Post By MSMS3
 Old 08-01-2018, 08:27 PM   #1
Fitbkeco's Avatar
Posts: 24   (View Stats)
Fitbkeco is an unknown quantity at this point
Default Misfire. Hard start. Jumpy idle. P0300
Well here it goes.
I recently bought my 08 speed3 the day after I bought it I got a check engine light. Read the code (p0300). I’ve done plugs and coils compression test and still got it. I recently reset the code and it took around 100 miles for the light to come back on. Also with this misfire I get a horrible jumpy idle after being in gear and shift long to neutral and coasting or when I come to a stop. The idle bounces around from 500-750 usually then calms down and falls into the 600-750 range. Other times it’s horrible and falls way below 500 to almost stall (only happened once). Now as for the hard start...it doesn’t happen all the time but every once in awhile it will take a little longer to crank max 8-10 secs. Once it starts it blows smoke (only time it ever smokes) and smell of unburnt fuel. What the hell could it be I’m at a loss. I was thinking maybe crank position sensor? Any input is helpful.
Fitbkeco is offline   Reply With Quote
 Old 08-02-2018, 09:54 AM   #2
Bingo's Avatar
Posts: 737   (View Stats)
Groaned at 9 Times in 7 Posts
A log would help the most, but my initial impressions are that your engine has no idea what's going on in terms of airflow. Now I could be wrong as I don't have much diagnostic experience, but it sounds like a MAF or 02 problem. Again, a log would make this a lot easier.
Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks.
Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A.
 Old 08-02-2018, 09:58 AM   #3
Fitbkeco's Avatar
I wish I had an access port I will be getting one soon but I need to put the money into fixing it first before I can get nice things lol
 Old 08-02-2018, 10:17 AM   #4
Bingo's Avatar
Make no mistake the AP does both. I use my AP as a diagnostic tool that has saved me tons of money since I've had it. Ya it can tune your car and that's very useful but that's half the story. Don't look at it as a performance mod, it's a doctor for your car.
 Old 08-02-2018, 01:21 PM   #5
Fstrnyou's Avatar
Posts: 2,383   (View Stats)
I bought Versatuner to diagnose an issue before I bought any performance mods. Probably the best money spent on this car.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 08-02-2018, 05:34 PM   #6
Fitbkeco's Avatar
I just read on that versatuner sight that an aftermarket intake will mess with the maf. And mine has a cold air intake on it. So it’s probably my maf sensor and buying a new maf probably will do the same thing right
 Old 08-02-2018, 05:35 PM   #7
Fstrnyou's Avatar
If the intake is stock size, it shouldn't be terribly bad.
Other rides:
History:
 Old 08-02-2018, 05:44 PM   #8
Fitbkeco's Avatar
Idk I might buy a maf from rockauto it’s 16 bucks so what’s the worst that could happen. I just unplugged mine and took it to see if it was gummed up. Plugged it back and started the car. It started fine then almost stalled it self out which it’s never done before on start up. Which makes me think it might be the maf.
 Old 08-02-2018, 07:17 PM   #9
Bingo's Avatar
Ya don't buy a rock auto maf. Rock Auto stuff is great for most things but not the maf, get an OEM.
 Old 08-02-2018, 07:28 PM   #10
Fitbkeco's Avatar
Damn lol I just gonna get the cheap on to see if that was the problem lol
 Old 08-02-2018, 11:41 PM   #11
Fstrnyou's Avatar
You would end up with more problems.
Other rides:
History:
 Old 08-03-2018, 08:54 AM   #12
Thor Hammer's Avatar
Posts: 1,846   (View Stats)
Groans: 211
Don't do it. Only OEM MAF sensors will work correctly. Sad, but true. Instead, clean it with MAF cleaner.
MSMS3 (08-05-2018)
 Old 08-03-2018, 11:46 AM   #13
Fitbkeco's Avatar
I’m gonna try and clean it. I’m gonna try and have some one tune it for the intake if it doesn’t work.
 Old 08-03-2018, 12:45 PM   #14
Fstrnyou's Avatar
If it's a stock sized MAF housing, tuning is the last resort after all offer possible issues have been ruled out.
An inexperienced tuner will try to "tune-out" your "issue" and maybe even get it close.
An experienced tuner can recognize the inconsistencies in the MAFcal and will tell you there's an issue that needs to be fixed.
Other rides:
History:
 Old 08-04-2018, 07:23 AM   #15
Fitbkeco's Avatar
If I knew how to upload pics from my phone I would show you guys what I take is on it
 Old 08-04-2018, 08:08 AM   #16
Fitbkeco's Avatar
Trying to upload
File Type: jpeg C52B4BC6-8A41-4588-B384-03E4B3F18032.jpeg (3.07 MB, 28 views)
 Old 08-04-2018, 09:02 AM   #17
Fstrnyou's Avatar
What the heck kinda hose is that connecting your valve cover vent to intake?
And WTF kind of bypass hose setup is that?
Db09ms3 likes this.
Other rides:
History:
 Old 08-04-2018, 09:48 AM   #18
Fitbkeco's Avatar
Man the kid before me treated this car like shit. I’m trying get this right lmao
 Old 08-05-2018, 10:58 AM   #19
Fitbkeco's Avatar
So I went through it all and I think it’s in need of a tune for the stupid intake. Some guy has a hypertech tuner I said hell sell me for 60. He had it on his speed3. Any one ever heard of that tuner. And is it any good
 Old 08-05-2018, 11:11 AM   #20
Fstrnyou's Avatar
There's at least 1 member on here that uses a hypertech and loves it. Suits his needs, but it's not for everyone.
Other rides:
History:
 Old 08-05-2018, 11:18 AM   #21
Fitbkeco's Avatar
I can get it for 60 bucks
 Old 08-05-2018, 11:23 AM   #22
Fstrnyou's Avatar
@MSMS3;
Other rides:
History:
MSMS3 (08-05-2018)
 Old 08-05-2018, 11:37 AM   #23
Fitbkeco's Avatar
I literally went through the whole car this morning so the only thing I can think is that it needs a tune for the bov and intake. I can’t think of anything else it could be.
 Old 08-05-2018, 12:43 PM   #24
MSMS3's Avatar
Posts: 2,511   (View Stats)
Groans: 140
Originally Posted by Fstrnyou View Post
HT can max out the K04 with compatible mods on pump gas. But, you must have the stock K04 or identical flow (BNR Stage 1, for example), must have stock intake MAF tube size, and, if using an aftermarket intake that requires an air straightener just before the MAF, that straightener must be in place.
It is picky on the intake choices because it sets its MAF cal on the known flow of specific intakes it has tested. Those intakes are listed in its configuration setup menu. Get that wrong and it does not perform properly and may throw a code for lean at idle condition. That's classic for improper MAF cal.
It is very compatible with most exhaust side mods, including 3" catless dp/rp, provided you upgrade the hpfp internals.
So, if you are on the stock K04, pump gas, and have a compatible intake, its a good choice. That POS cobbled together home brew intake on OP's car will not work.
BTW, bypass valve or blow off valve has nothing to do with this discussion. As long a the stock valve is functioning properly, it is altogether suitable, as are most common aftermsrket valves with just about any tune for the K04. If OP's valve is not leaking and is running in recirc mode, it should be left alone.
I've posted many logs and VD charts here in multiple threads about my results with Hypertech. With my mods I am seeing a safe and reliable 300 whp and 300 ft. lbs. torque on pump 93 octane. I don't think you can do much better with any other safe tune for the stock K04 and pump gas.
You cannot use it on other turbos, larger MAF housings, or with ethanol or blends. If you run 3" downpipe with it you must upgrade pump internals.
Db09ms3 likes this.
2017 Audi Q5 3.0 T (supercharged) Stage 2, EPL tune, JHM overdrive crank pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 430 hp.
 Old 08-05-2018, 12:53 PM   #25
MSMS3's Avatar
Groans: 140
Not for that intake. I'm not sure any tune would be safe with it. Sorry
 Old 08-05-2018, 02:27 PM   #26
Fitbkeco's Avatar
Yeah I’m gonna get an intake before obviously lol
 Old 08-05-2018, 05:31 PM   #27
MSMS3's Avatar
Groans: 140
Any reputable intake from a major company (many threads here on choices) either SRI or CAI style, as long as your maf housing is OEM diameter, will do.
 Old 08-05-2018, 11:01 PM   #28
aackthpt's Avatar
Posts: 1,450   (View Stats)
aackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the world
I’ve done plugs
Oh it's you, I saw your ass on FB. Did you gape the plugs correctly? What spec did you use?
2013 'speed3, silver
Stage Bro
aackthpt is offline   Reply With Quote
 Old 08-06-2018, 04:32 AM   #29
Fitbkeco's Avatar
I did get plugs and gapped them to .26 - .27. And yeah that fb group is ass. Every one is dick or just says 7 like that helpful lmao
 Old 08-06-2018, 06:32 AM   #30
Fstrnyou's Avatar
STAGE 7!!!!
Other rides:
History:
 Old 08-06-2018, 06:48 AM   #31
Fitbkeco's Avatar
What’s with that 7 shit makes no sense to me
 Old 08-06-2018, 06:49 AM   #32
Fstrnyou's Avatar
Embrace the 7 and you will be set free.
Db09ms3 likes this.
Other rides:
History:
 Old 08-06-2018, 08:54 AM   #33
Ds_06_Speed6's Avatar
Posts: 38   (View Stats)
Ds_06_Speed6 will become famous soon enough
At minimum Id get an oem bypass valve setup back in there.
Hit me up, think I still have my oem valve in the garage. Youll have to source a proper bypass hose though.
Ds_06_Speed6 is offline   Reply With Quote
 Old 08-06-2018, 12:20 PM   #34
Fitbkeco's Avatar
I do have a stock bypass valve that my buddy just gave to me but I need to get the gasket for it.
 Old 08-06-2018, 02:01 PM   #35
MSMS3's Avatar
Groans: 140
I think it is about $10 at the dealer.
Given that boost is going to be under 20 psi, you could probably just make one from bulk gasket material at any auto parts store. Trace the pattern, the center hole and the two mounting bolt holes, and cut out. It's not like it's 200 psi. Should hold fine.
You could put a very light coat of gasket sealer (Permatex comes to mind) on both sides, just in case, but not really necessary.
Don't over torque the mounting bolts. They strip out easily and some ham-fisted guys have broken them off in the manifold.
 Old 08-07-2018, 04:43 AM   #36
Fitbkeco's Avatar
I got gasket so I’m gonna throw it on and see if it helps at all
 Old 08-09-2018, 03:14 PM   #37
Fitbkeco's Avatar
So I didn’t get an ap and went super cheap till I figure it out. I picked up one of those obd2 readers from amazon. And this is what it told me on my hour drive to work this morning
File Type: jpeg 8B907EF5-5072-450B-973B-6067EB04A989.jpeg (3.43 MB, 5 views)
File Type: jpeg 15302A80-D8FD-4B80-BDA1-7FD01C84B1B9.jpeg (3.73 MB, 12 views)
 Old 08-15-2018, 01:46 PM   #38
Groans: 211
No useful data there bud. Need to see fuel trims.
 Old 08-30-2018, 11:14 AM   #39
Fitbkeco's Avatar
So I think I found the problem and it lies with the hpfp
 Old 08-30-2018, 01:45 PM   #40
Solarsurge's Avatar
Posts: 571   (View Stats)
0.05v is super low for O2 sensor voltage, so it would have to either be a bad fuel pump, gaping hole in your intake manifold, or bad sensor. Sensor shouldn't drop below .1v
MSMS3 (09-01-2018)
Low compression, P0300 misfire, rough idle with AC TheProYodler 2010 MS3 - Engine, Transmission & Driveline 39 11-27-2017 05:06 PM
P0300, Hard start, bouncing idle.. NEED HELP! easaly MazdaSpeed 3/6 - Troubleshoot/Diagnostics 77 03-21-2017 08:28 PM
Hard Start, Long Crank, Rough Idle red ghost MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 10-07-2014 10:24 PM
burning smell, jumpy rpm at idle, hesitant to accelerate, and extremely slow darkilluzion 2010 MS3 - Troubleshoot/Diagnostics 64 12-22-2010 04:09 PM
P0300 misfire CEL Mazdaspeed E MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 07-29-2009 04:20 PM
Page generated in 0.54564 seconds with 28 queries
