  • 1 Post By finalems3
 Old 03-07-2013, 11:09 AM   #1
finalems3's Avatar
Posts: 30   (View Stats)
finalems3 is just really nicefinalems3 is just really nicefinalems3 is just really nicefinalems3 is just really nicefinalems3 is just really nice
Groaned at 3 Times in 1 Post
Default Misfire only when 90%to100% throttle
Changed spark plugs to the NGK laser Iridium, pre-gapped at (.32) changed out the coil pack as well...
I can drive the car fine and can still put the pedal down 89% of the way but when i go wot it misfires..
It misfires/bogs/stutters down 3 times and then i have to let off the gas...
there is no check engine light for it because i havent gone wot at all because the car idles/drives fine everywhere as long as i dont...
Took it to the shop and they said my injectors were fine...
Could it be:
-vacuum leak?
-bad ground somewhere?
finalems3 is offline   Reply With Quote
 Old 03-07-2013, 11:11 AM   #2
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
Have you done a compression test for cyl 3 yet...
Also, gap that plug down a bit.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 03-07-2013, 11:13 AM   #3
Oliverms3's Avatar
Posts: 1,632   (View Stats)
Oliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the world
do you have any logs or anything to monitor the car?
my only guess is maybe the car is running super rich and maybe the maf is dirty
2010 BM MS3 - Cobb AP||3gal corn||Autotech Internals||ETS TMIC||Forge BPV||Denso Iridium ITV22||TurboXS DP||ARK exhaust||CP-E Nano SRI||PG TIP||JBR RMM||JBR PMM||TRZ TMM||NRG ETD||DDM 55w 5000k HIDs and DDM 35w 3000k HID fogs||JB Heavy Knob||JB SSP||ST Coilovers w/ Eibach rear Camber Kit(made by SPC)||17x9 +28 Drag DR31 (track) RPF1 18x8 +35 (DD)||HKS TT Type 0||Clarion EQ||MB Quarts speakers||Pioneer amps and 10" Competition Sub.
346hp 392lbs of sexyness
Oliverms3 is offline   Reply With Quote
 Old 03-07-2013, 11:18 AM   #4
smoogs12's Avatar
Groans: 423
He had said in a previous thread (not 100% sure why he made a new one) that he was getting a p0303.
So I can only assume that since his injectors are "fine" and he has changed plugs (unless its a more involve ignition issue) that the missfire is compression related.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 03-07-2013, 11:21 AM   #5
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
BAM!
 Old 03-07-2013, 11:22 AM   #6
Oliverms3's Avatar
oh ok...
then possible causes would be is
Faulty spark plug
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector
Poor compression
The Following User Says Thank You to Oliverms3 For This Useful Post:
rfinkle2 (03-07-2013)
 Old 03-07-2013, 11:24 AM   #7
smoogs12's Avatar
Groans: 423
BAM!
Guessing you think its spark blowout?
That would definitely be nice if it was something simple.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following User Says Thank You to smoogs12 For This Useful Post:
 Old 03-25-2013, 01:10 PM   #8
finalems3's Avatar
finally fixed the problem! Went to a shop that my family takes their cars too...anyway the problem was that the new coil pack that we put on cylinder 3 was bad!!! Problem fixed and now i can actually feel the power of the car....thinking its gonna need a new rear motor mount next
dereeek likes this.
Unsettling hesitation under part throttle and full throttle at first track day dachtler 2010 MS3 - ECU Computer Tuning 0 10-01-2012 02:49 PM
Need help! Misfire... I think ztnedman1 Gen2 MS3 General Discussion 5 05-24-2012 02:15 PM
Misfire Bucker MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 02-23-2012 03:06 PM
misfire rodrigo MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 10-28-2011 10:37 PM
OL/part throttle at what percent throttle? MS3Zoom24
Cobb ATR Support
4 10-31-2009 02:37 PM
Page generated in 0.29646 seconds with 23 queries
