-   -   The Motor Mount Thread (http://www.mazdaspeedforums.org/forum/f10/motor-mount-thread-100696/)
Inquisitive 01-29-2015 04:54 AM
@Raider;
Many of the OP’s images are URL links, which are broken as that is the nature of the Internet over time. My images are embedded jpgs and should have more permanency.
If by “missing a lot” you meant images and "available from" URLs in my post, that exercise is now complete. Juggling 25 images was interesting. Please let me know if I inserted any incorrectly or if anything is missing.
If you meant the OP’s words, I have RhoadBlock’s quote and can add his words to my post http://www.mazdaspeedforums.org/foru...ml#post2800159 as appropriate.
Raider 01-29-2015 06:21 AM
Originally Posted by Inquisitive (Post 2800159)
Genpu MMs:
• JBR RMM 88 & unknown durometer
• CP-E RMM Stage 2
• JBR TMM unknown
• CorkSport RMM
• JBR PMM unknown
• JBR RMM 80
• Sure RMM TorqR3 WARNING: read http://www.mazdaspeedforums.org/foru...3/#post1927730
• JBR PMM 80
• JBR RMM 70
• Cobb RMM
• CorkSport TMM
• Damond Motorsports RMM
• JBR PMM 70 & 88
• CP-E TMM
• TRZ RMM
• CorkSport PMM
• Street Unit RMM WARNING: read http://www.mazdaspeedforums.org/foru...3/#post1927730
• Ford Electric Focus RMM (RMM part number CM5Z-6068-A; bolt W500545S900)
• Minerva PMM & TMM (probably best to avoid, see http://www.mazdaspeedforums.org/foru...orwerkz-65851/ )
• Sure PMM & TMM WARNING: read http://www.mazdaspeedforums.org/foru...3/#post1927730
• AWR RMM 88
• Torque Solution RMM
Update using 2015 prices:
JBR RMM Urethane
MS6
http://www.mazdaspeedforums.org/foru...1&d=1422448444
MS3
Available from:
MS6
JBR RMM Urethane MS6
MS3
JBR RMM Urethane MS3
MS6 (Yes: 80a $105), MS3 1st Gen (Yes: 88a $100, 80a $125, 70a $125), MS3 2nd Gen (Yes: 88a $100, 80a $125, 70a $125)
CP-E RMM Stage 2 Rubber
MS6
http://www.mazdaspeedforums.org/foru...1&d=1422506769
MS3
http://www.mazdaspeedforums.org/foru...1&d=1422528447
Available from:
MS6
CP-E RMM Stage 2 Rubber MS6
MS3
CP-E RMM Stage 2 Rubber MS3
MS6 (Yes: 70a xFlex) $139, MS3 1st Gen (Not found), MS3 2nd Gen (Yes) $198
JBR TMM Urethane
http://www.mazdaspeedforums.org/foru...1&d=1422448506
Available from:
MS6
JBR TMM Urethane MS6
MS3
JBR TMM Urethane MS3
MS6 (Yes: 80a, 70a) $175, MS3 1st Gen (Yes: 88a, 80a, 70a) $185, MS3 2nd Gen (Yes: 88a, 80a, 70a) $185
CorkSport RMM Urethane
MS6's Insert
http://www.mazdaspeedforums.org/foru...1&d=1422448647
MS6's Full Replacement
http://www.mazdaspeedforums.org/foru...1&d=1422448738
MS3's Insert
http://www.mazdaspeedforums.org/foru...1&d=1422507038
MS3's Full Replacement
http://www.mazdaspeedforums.org/foru...1&d=1422507092
MS3's Race
http://www.mazdaspeedforums.org/foru...1&d=1422507132
Available from:
MS6
CorkSport RMM Urethane MS6
MS3
CorkSport RMM Urethane MS3 Gen1
CorkSport RMM Urethane MS3 Gen2
MS6 (Yes, Standard 70a) $115.99, MS3 1st Gen (Yes: Insert 70a $39.99, Standard 80a $99.99, Race 80a $125.99), MS3 2nd Gen (Yes: Insert 70a $39.99, Standard 80a $99.99, Race 80a $125.99)
JBR PMM Urethane
MS6
http://www.mazdaspeedforums.org/foru...1&d=1422507608
MS3
http://www.mazdaspeedforums.org/foru...1&d=1422528515
Available from:
MS6
JBR PMM Urethane MS6
MS3
JBR PMM Urethane MS3
MS6 (Yes: 80a, 70a) $175, MS3 1st Gen (Yes: 80a, 70a) $185, MS3 2nd Gen (Yes: 80a, 70a) $185
Cobb RMM
http://www.mazdaspeedforums.org/foru...1&d=1422528569
Available from: Cobb RMM MS3
MS6 (Not found) $, MS3 1st Gen (Yes) $159, MS3 2nd Gen (Yes) $159
CorkSport TMM Insert Polyurethane
MS6
http://www.mazdaspeedforums.org/foru...1&d=1422528621
MS3
http://www.mazdaspeedforums.org/foru...1&d=1422357283
Available from:
MS6
CorkSport TMM Insert Polyurethane MS6
MS3
CorkSport TMM Insert Polyurethane MS3
MS6 (Yes) $54.99, MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $39.99
http://www.mazdaspeedforums.org/foru...1&d=1422357478
Available from: Damond Motorsports RMM
MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $145 in black or gold
CP-E TMM
http://www.mazdaspeedforums.org/foru...1&d=1422528720
Available from: CP-E TMM
MS6 (Not found), MS3 1st Gen (Yes, 75a) $271.30, MS3 2nd Gen (Yes, 75a) $271.30
TRZ RMM
http://www.mazdaspeedforums.org/foru...1&d=1422528773
Available from: TRZ RMM
MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $100
CorkSport PMM
http://www.mazdaspeedforums.org/foru...1&d=1422357543
Available from: CorkSport PMM
MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $229.99
http://www.mazdaspeedforums.org/foru...1&d=1422448355
Available from:
MS6 (Not confirmed), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $43.92 + $1.10
AWR RMM Urethane
MS6
http://www.mazdaspeedforums.org/foru...1&d=1422507900
MS3
http://www.mazdaspeedforums.org/foru...1&d=1422528845
Available from:
MS6
AWR RMM Urethane MS6
MS3
AWR RMM Urethane MS3
MS6 (Yes: 95a, 80a, 70a) $82, MS3 1st Gen (Yes: 95a, 80a, 70a) $95, MS3 2nd Gen (Yes: 95a, 80a, 70a) $95
AWR PMM Urethane
MS6
http://www.mazdaspeedforums.org/foru...1&d=1422529392
MS3
http://www.mazdaspeedforums.org/foru...1&d=1422529447
Available from:
MS6
MS6 (Yes: 95a, 80a, 70a) $172, MS3 1st Gen (Yes: 95a, 80a, 70a) $172, MS3 2nd Gen (Yes: 95a, 80a, 70a) $172
AWR TMM Urethane
MS6
http://www.mazdaspeedforums.org/foru...1&d=1422529506
MS3
http://www.mazdaspeedforums.org/foru...1&d=1422529551
Available from:
MS6
AWR TMM Urethane MS6
MS3
AWR TMM Urethane MS3
MS6 (Yes: 95a, 80a, 70a) $140, MS3 1st Gen (Yes: 95a, 80a, 70a) $225, MS3 2nd Gen (Yes: 95a, 80a, 70a) $225
Torque Solution RMM Polyurethane
http://www.mazdaspeedforums.org/foru...1&d=1422530287
Available from: Torque Solution RMM Polyurethane MS3
MS6 (Not found), MS3 1st Gen (Yes, 75a) $134.99, MS3 2nd Gen (Yes, 75a) $134.99
TRZ TMM
http://www.mazdaspeedforums.org/foru...1&d=1422529912
Available from: TRZ TMM
I like this a lot! Does anyone else have info to add?
08.5MS3 01-29-2015 06:31 AM
There is no TRZ PMM, only the rear motor mount and TMM. May want to update the P to a T in the description and link. Perhaps it was a simple typo after looking at all these damn mounts.
Raider 01-29-2015 06:37 AM
TMM, not PMM. Fixed.
ibcrusn 01-30-2015 08:59 PM
Was in scoping out the refresh and found Damond's PMM missing and figured I'd post up the info to add.
Available from: Damond Motorsports PMM
MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $225 in black or gold
Inquisitive 01-31-2015 07:15 PM
Updated
• Added JBR RMM MS3 image
• JBR TMM: the unnamed image was the MS6, now named and added MS3’s image
• Fixed broken JBR PMM MS6 image
• Removed orphaned “$” in Cobb RMM MS6
• Added DM RMM MS6 image and price (Thanks @ibcrusn; )
• Fixed broken AWR RMM MS6 image
We are now up to 30 images.
genpu007 02-01-2015 12:49 PM
thanks for this, very useful! I am going to have to look further into this!
TiGraySpeed6 02-01-2015 12:52 PM
Please, in the future limit or trim quotes- there was no need to completely repeat the original post in order to express your appreciation!
Thanks, and glad you found it helpful.
There @Raider; I'm being nice....
genpu007 02-01-2015 01:39 PM
Oh god I'm sorry! I don't know how that happened
Raider 02-02-2015 01:26 PM
OP updated! Thanks, @Inquisitive;!
Raider 02-02-2015 01:55 PM
Uh, i just saw the Damond Motorsports RMM pic is the PMM, and no PMM in your post, @Inquisitive;. Can you update it and I can copy it up to the OP and Knowledgebase?
Douggievee 06-16-2015 12:30 PM
Ok, so for the MS6 I wanna do the 80 JBR Trilogy, the Turbine Tech FMM, Turbine Tech Front dif mount and CP-e rear dif mount. Would this be the best complete mount solution I could do for my 10 year old car to get eall the mounts up to spec?
Raider 06-16-2015 12:33 PM
That sounds like a plan to me. Will keep it all in check!
mituc 07-02-2015 04:35 PM
Did anyone have the chance to ride either the same car or similarly modified cars with the CS Race mount with the 80DURO bushings and the Cobb RMM? I guess both do a similar job at holding the motor in place but I'm interested in the added NVH comparison.
CS doesn't have the 70DURO bushings any more for their race mount and so far this was the perfect mount for me (I don't mind changing the bushings every 15-20k miles, but I mind the added NVH), so now because I'm at the last set of 70DURO I'm searching for the quietest replacement which is still on the market.
Or is there a quieter option than these two (of course, also suitable for holding nearly 450 pounds of torque away from the firewall)?
JBR 07-02-2015 04:44 PM
We still offer our 70 duro rear mount.
mituc 07-02-2015 10:56 PM
Thank you! Everybody talks about your 80 and 88 DURO mounts so I wasn't even aware you offer a mount with better comfort even if I'm pretty familiar with your product line.
Can you tell what is the diameter of the center bushings of the 70DURO mount? It looks like I really need to add the JBR 70DURO to my comparison list.
JBR 07-03-2015 07:59 AM
The bushing diameter is 3". It's very big and provides a lot of deflection.
mituc 07-28-2015 06:24 AM
Ok, I decided to give the JBR 70DURO RMM a try and also purchased a set of 80DURO bushings plus another spare 70DURO. Since I had all the soft mounts in history this was the only one that was missing from my drawer.
The CS race mount I have is on its last set of 70DURO bushings which are almost fresh, they have like 2k miles on them, so in case things will not go well with the JBR (which I doubt, but always possible since all comes down to a matter of taste and personal preference) I will still have a backup for a while (20k kms/12k miles or so).
mudawg 07-29-2015 09:22 PM
Got a cs race mount and it's awesome. Can't beat it since it was free! Vibs are not bad at all. Actually was pretty surprised as I thought they would be more. No more missing third hopefully. The stock one had 60k and was wasted.
mituc 08-05-2015 07:19 AM
I received the JBR RMM today. It looks good. However, the 70DURO bushings are significantly stiffer than the 70DURO bushings from the CS race mount. I also got a spare set of 80DURO just in case I needed more, but judging by the stiffness of the 70DURO I'm now thinking those may already be too stiff.
Compared to the 70DURO CS bushings the JBRs are slightly smaller in diameter (probably 0.1inch) and slightly taller (also probably 0.1inch). But they are a lot stiffer, while I can squeeze the 70DURO CS in my hand, for the 70DURO JBR I needed two hands to induce any deformation. Indeed the CS bushings were used but the fresh ones are not a lot stiffer. We will see.
http://s4.postimg.org/qrsmuj789/IMAG2510.jpghttp://s4.postimg.org/4iepnzbrt/IMAG2511.jpghttp://s4.postimg.org/qt2kny921/IMAG2512.jpg
https://www.youtube.com/watch?v=wvtfFUICFgA
Gitcherex 10-09-2015 07:35 PM
Im looking at the JBR trilogy kit, and I seen that its recommended for the 80 rmm and tmm but only a 70 pmm. Would this not cause excessive wear on the mounts because two of them are vibrating more (or something)? Also I seen that JBR posted a 10% off code a while back, is there another sale coming up for Columbus day or an actual holiday lol.
Raider 10-09-2015 07:41 PM
I loaded up on the 3 running the highest duro. I love it.
Gitcherex 10-10-2015 08:53 AM
how is the nvh? It is my DD and the wife wouldnt like it if it vibrated more than her BoB's.
Raider 10-10-2015 09:02 AM
They settle over time.
Do some reading on msf so many threads about this were discussed. This is not the tread for it.
mituc 10-10-2015 09:34 AM
Leaving the TMM and PMM stock, a 80duro RMM will shred your brains out. A 70duro PMM will ensure that the windows will pop off to vent the brain remains out. A 80duro TMM will make sure that whatever is still left into your skull will be drilled out. Ask me how I know.
Back in 2010 I fell into the same trap of other users here, "I have this and that mount and I love it, NVH increase is minimal". Probably minimal if you drive with the windows down, stereo at one third of the total volume, or if you're half deaf. I didn't fit in any of these categories. Since then I had about 75% of all aftermarket RMMs and tried them out. Of course the factory PMM went back in, and since about 2 years now I'm using the gen2 TMM with the CS insert (which in this configuration makes the engine stay a bit twisted as I can see where the transmission bracket and the RMM hotizontal bolt meet, but I'm ok with this and it's a good setup).
If you DD your car, take it to medium/long trips with your familiy and so on, then leave the PMM and TMM stock. If you have a gen2 MS3 or if you can get a gen2 TMM on a gen1 you can install the CS TMM insert, and that's about it.
As for the RMM you can get the JBR 70duro. I don't know how the CS 80duro is, I only have the 70duro which for some absolutely idiotic reason they don't make any more, but the CS 80duro may be an option as well (the 70duro is as quiet as the stock one, so I imagine the 80duro may be something like the CP-e 60duro
Raider 10-10-2015 10:00 AM
I had the 88 solo with more vibes from trz TMM. Went JBR sides a sit went down.
mituc 10-10-2015 12:34 PM
Unfortunately stiffer side mounts (PMM+TMM) that we currently have available are still too much for a DD. Of course it depends on how you daily drive that car, if it's just for commuting, how long the commute is, if you also track the car often enough to become unfeasible to swap the motor mounts and the time, how much you hoon the car because being deep into the throttle all the time may make the extra NVH from the mounts unnoticeable, and so on.
In my case I managed to get the car where it is with minimal almost no NVH increase (it's only the DP that makes the car a bit louder at low speeds, but at cruising speeds the NVH increase is 0). However, if I'd drag race the car then the motor mounts I have probably will last 20-30 passes before I either blow them (the PMM) or wear them out (TMM/RMM). And that's not even that much. Or tracking the car on circuit racing often enough will also result in MM premature wear, because all those braking/hard acceleration reprises will take their toll on the mounts and the chassis itself.
The point is that we need to find the right balance when using, or even recommending a part to someone. It's like, "I want to go big turbo, what turbo should I get?", next answer "go 3580!". Wait, no! There are some questions that need to be answered first: what are the power goals, is the motor forged, is it a MS3 or MS6, what do you intend to use the car for (use that power or just have a dyno queen that puts power down properly only in 6th in street tires?), so on and so on.
This current MM thread is only about what we have available, not also what and when to chose. Not making the right choice results into frustration, in not being able to enjoy the car as much, or even hate it.
We have all these vendors with awesome looking parts and all of them fully and properly functional. But it's not only this, what's the point of giving the duro rating of the urethane/rubber bushes if the end user is not aware of the actual noise increase in the cabin? We have motor mounts with 60duro bushes as loud as other 80duro mounts, so it's all very confusing for someone new to this.
So for those who DD the car, go in long trips with it eventually with kids, and still want to enjoy the extra madness they added under the hood leave the side mounts stock and pick the RMM wisely.
Nevershallifall 10-11-2015 09:26 AM
Forgive me if I missed the information but I didn't see link and picture for the Damond TMM.
MS3Shadow 10-11-2015 10:10 AM
Probs needs to be updated.
sent from my Nexus 6P
mituc 08-13-2016 10:21 AM
The initial post needs a little update: the CS TMM insert for MS3 works on gen1 only if you import the TMM, the tripod it bolts on and the long bolt from a gen2.
Also, did anyone have the Cobb RMM, the CorkSport racemount with 80DURO bushings and the DamondMotorsport RMM and can compare them in therms of NVH? I'll run out of 70DURO bushings for the CS RMM soon, the 80DURO don't seem to last, so I'm looking for alternatives for a RMM good for both daily commutes and spirited driving on a relatively high torque car (450+ lb*ft). I've had the JBR 70DURO and it's a bit louder than I'd like, the CS 80DURO is fine, so can anyone tell how are the three mentioned above relatively to each other?
Nevershallifall 08-13-2016 11:15 AM
So far I have found the cpe stage 2 to be my favorite rmm but the dmm one that my friend got is pretty amazing also. I debated switching so I was running the dmm 3 sum
mituc 08-13-2016 12:25 PM
Pretty "amazing" in therms of what and compared to which other mounts?
I had the CP-e 60DURO and it was quite crappy. Clunks and squeaks everywhere. Most probably the Stage2 one is better but it's also stiffer because it eliminates the big round bush and that's not what I'm after.
mituc 08-20-2016 12:40 AM
Ok, to answer my own question above it looks like the Cobb RMM is quieter than the JBR 70A (and probably not as stiff, but stiff enough).
MS3Shadow 08-20-2016 01:16 AM
Well anything is quieter than JBR
Gigawatz 04-26-2017 12:05 PM
The warning thread that is linked to from this thread is dead.
I just replaced my RMM with a Damond and found out that it was a Street Unit. I was curious to read what was reported with the warning thread - unfortunately it must have been "the shit" for the conversation because everywhere has linked to it. However, it is now no where to be found and I tried using a google site based search and the internal search routines to relocate it and I have failed.
Was it deleted or was it moved? Do you guys have any idea?
El Diablo's Master 06-30-2018 10:23 AM
Any feedback about the CS PMM?
kTaLgsTo 06-30-2018 10:32 AM
Yeah it holds the engine in place, are you talking version one or two?
El Diablo's Master 06-30-2018 10:39 AM
I'm gonna be honest, didn't know there were two versions haha. I'm referring to the MM that CS is currently selling on their website.
kTaLgsTo 06-30-2018 11:16 AM
They sell two... A one piece mount (first rev) and a two piece.
El Diablo's Master 06-30-2018 01:46 PM
This is the one I'm referring to https://corksport.com/corksport-mazd...tor-mount.html
kTaLgsTo 06-30-2018 01:49 PM
Well I do appologize, I could have swore you wrote rmm, not pmm....
That pmm is well and good, but I've heard damond motor mounts are the best...
Most people's comments are damond or nothing
El Diablo's Master 06-30-2018 02:45 PM
No worries, my friend. Thanks for the help I'll check it out now!
Page generated in 0.25145 seconds with 11 queries
