Like Tree2Likes
  • 2 Post By ziwang55
 Old 04-03-2012, 05:10 PM   #1
ziwang55's Avatar
Posts: 172   (View Stats)
ziwang55 is a splendid one to beholdziwang55 is a splendid one to beholdziwang55 is a splendid one to beholdziwang55 is a splendid one to beholdziwang55 is a splendid one to beholdziwang55 is a splendid one to beholdziwang55 is a splendid one to beholdziwang55 is a splendid one to behold
Default Motor mount thread issue
Installed my jbr rmm 70 duro. Great product. Couple days later got loose to I tried to retorque everything.
As I was retorquing the bolt that goes up into the frame and through the rubber bushing. It kept turning. So I took it out and realize its stripped.
The hole us stripped. Now I'm clueless. Idk what to do.
Sent from my HTC Amaze 4G using Tapatalk
ziwang55 is offline   Reply With Quote
The Following User Says Thank You to ziwang55 For This Useful Post:
gearhead750 (04-04-2012)
 Old 04-03-2012, 05:14 PM   #2
TexasSpeed3's Avatar
Posts: 1,996   (View Stats)
TexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the world
Groans: 273
i forgot what the guy did but i know this has happened b4
2011 Black Mica - Daily
JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp
Last edited by TexasSpeed3; 04-03-2012 at 05:26 PM. Reason: no need to mention anyone anymore
TexasSpeed3 is offline   Reply With Quote
 Old 04-03-2012, 05:15 PM   #3
bigriver's Avatar
Posts: 1,123   (View Stats)
See my "How to" thread. easy to fix so dont sweat it. My repaired nut is holding just fine.
Here the link:
http://www.mazdaspeedforums.org/foru...ir-kit-105601/
The Following 8 Users Say Thank You to bigriver For This Useful Post:
crazyp (04-03-2012), franz (04-03-2012), Raider (04-03-2012), Sid3wayS (04-03-2012), SJP0tato (04-04-2012), SKiZ0TT (04-07-2012), TexasSpeed3 (04-03-2012), ziwang55 (04-03-2012)
 Old 04-03-2012, 05:16 PM   #4
crazyp's Avatar
Posts: 1,093   (View Stats)
crazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the world
Groans: 68
Groaned at 22 Times in 9 Posts
you can probably get away with installing a helicoil on it. I know sears sells helicoil sets not sure where else
2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC
crazyp is offline   Reply With Quote
 Old 04-03-2012, 05:24 PM   #5
bigriver's Avatar
I bought my kit from Grainger since they had it in stock (m12 x 1.25) and there was a store nearby.
The Following 2 Users Say Thank You to bigriver For This Useful Post:
crazyp (04-03-2012), ziwang55 (04-03-2012)
 Old 04-03-2012, 05:28 PM   #6
Meder's Avatar
Posts: 1,065   (View Stats)
Meder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the world
I did this 3 years ago and my heli coil is still going strong with several re installs of the rmm.
Meder is offline   Reply With Quote
 Old 04-03-2012, 05:35 PM   #7
bigriver's Avatar
OP -- also, FYI, the bolt in the second pic of your post is the bolt that connects the rmm and the tranny bracket. The bolt for the rmm in the subframe is the same size and thread pitch but the thread starts immediately from the end of the bolt. I don't think it matters but you may want to switch the bolts.
The Following User Says Thank You to bigriver For This Useful Post:
 Old 04-03-2012, 05:36 PM   #8
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
Helicoil. I have had one in for a year
2015 Mazda 6
 Old 04-03-2012, 05:41 PM   #9
ziwang55's Avatar
lol i had a feeling it was the wrong one. so i put the correct one in. thanks for the heads up.
and thanks for everyones quick reply.
how long can i go before something goes wrong? i cant fix it right away. since i dont have all the nessesary stuff. and i need to use my car.
 Old 04-03-2012, 05:43 PM   #10
Groans: 273
i wouldnt drive it without the mount installed
 Old 04-03-2012, 05:47 PM   #11
bigriver's Avatar
THIS
There are only three mounts (RMM, PMM TMM). The other two will not be able to hold the engine. The TMM will fail and your tranny will be dragging on the ground while your dp bangs the firewall.
 Old 04-03-2012, 05:52 PM   #12
ziwang55's Avatar
oh what i meant was not fixing the thread. i have the mount and the car still pulls strong since the bolt doesnt just come out.
i saw your how to. im gonna get to it right away. its awsome. thanks alot.
Last edited by ziwang55; 04-03-2012 at 05:52 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-03-2012, 05:56 PM   #13
bigriver's Avatar
Oh. Too risky imo. Cheaper to just rent a car or take a cab. The issue is with all that vibration, the bolt may back itself out. Its probably being held by a small piece of thread in the nut that didnt come out.
 Old 04-03-2012, 05:58 PM   #14
ziwang55's Avatar
ur right it actually is. the bolt just spins tight then loose. tight and loose again. so im gonna go to grainger tomorrow and get it done.
 Old 04-03-2012, 06:05 PM   #15
bigriver's Avatar
Where are you? If you are near me you can borrow my kit. I have extra coils.
 Old 04-03-2012, 06:09 PM   #16
ziwang55's Avatar
im in mn no where near. i wish i was close. cuz grainger is closed now. so ill have to wait.
unless theres other stores that sells?
 Old 04-03-2012, 06:14 PM   #17
bigriver's Avatar
Problem is the bolt size. M12 is hard to find. Autozone sells helicoil kits but not in m12. Maybe check other auto parts stores. Mcmaster and Fastenal also have them but they would be closed tonight.
 Old 04-03-2012, 06:15 PM   #18
gearhead750's Avatar
Posts: 383   (View Stats)
gearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the world
Groans: 30
subbed and a little scared. Just installed JBR RMM a few days ago. Just re-checked torque on bolts today everything seems to be fine. Is the recommended 90 ft lbs on this bolt too much?? Good luck OP.
Thanks 4G63 for the avatar!!!
Originally Posted by DarkHeartMS6 View Post
I didnt think there was a person on this planet as stupid as you... Congratulations, you proved me wrong. WTF is a Mazda RX-7 if not one of the best "tuner" cars as you put it.. out there. Jump off the honda dick, pull the Golf R cock out of your mouth... replace it with a gun and end this world of your stupidity! Please, before you cause a retard apocolyptic end to our world
gearhead750 is offline   Reply With Quote
 Old 04-03-2012, 06:20 PM   #19
bigriver's Avatar
I believe torque is 70. At least for jbr dogbone and corksport inserts.
Edit - oh jamie says 90 for the billet mounts. Idk maybe check with him.
 Old 04-03-2012, 06:27 PM   #20
Crarrs's Avatar
Posts: 1,662   (View Stats)
Groans: 98
Probably. The factory service manual says 54-66 ft-lbs. Most of the other aftermarket mounts say 70-75 ft-lbs. That's probably why people keep stripping them at 90. Page 01-10B-44 in the Gen2 manual for those who want to check.
2004 MSM TiGrey
 Old 04-03-2012, 06:33 PM   #21
Groans: 30
90 is what the JBR installation guide says for the billet RMM
 Old 04-03-2012, 06:38 PM   #22
Crarrs's Avatar
Groans: 98
The part that's stripping is a Mazda part. It's been established that some of these welded nuts are weaker than others due to heat effects during manufacturing.
2004 MSM TiGrey
 Old 04-03-2012, 06:38 PM   #23
Groans: 30
@jbarone
Any input?
 Old 04-03-2012, 06:41 PM   #24
Crarrs's Avatar
Groans: 98
@jbarone
Any input?
Perhaps somebody based their torque spec off the N-m one in the manual....
2004 MSM TiGrey
 Old 04-03-2012, 06:43 PM   #25
ziwang55's Avatar
I think 90 torque is too much. I would've been fine if I did 70 I'm guessing
 Old 04-03-2012, 07:03 PM   #26
Groans: 30
But what doesn't make sense is that if it was torqued down to 90 and it held there, how does it just strip on it's own? Somehow it had to have gotten cross threaded... IDK
 Old 04-03-2012, 07:07 PM   #27
Crarrs's Avatar
Groans: 98
That's not a normal strip. That is the threads actually being pulled out of the nut in one piece. The manufacturing process weakens the nut allowing that. I've seen them at work before, and I've only seen it happen on welded nuts.
2004 MSM TiGrey
The Following User Says Thank You to Crarrs For This Useful Post:
gearhead750 (04-03-2012)
 Old 04-03-2012, 07:18 PM   #28
ziwang55's Avatar
Probably just weak oem welded nut.
 Old 04-03-2012, 08:46 PM   #29
bigriver's Avatar
Mine stripped exactly the same and I pulled out the thread in one piece. I never overtorqued mine and suspect the vibration and forces on that one nut could be enough to shear it clean. Just speculation but I have no other explanation.
 Old 04-04-2012, 04:06 AM   #30
Groans: 30
Should i leave mine at 90??? Or maybe back it out to 65-70. Maybe leave it alone and just mark the bolt and check it periodically to see if it's moving? Fuck I'm thinking of just taking the damn JBR RMM out, but I really don't want to back that bolt out and see threads come out with it...
I also noticed that the JBR billet RMM instructions are the ONLY ones that say to use 90 ft lbs on this bolt and also on the 3 transmission bolts. All the other mounts require only 70 ft lbs. Why would it be so much different?
@bigriver I notice you went with the CS RMM inserts instead. Why?
The Following User Says Thank You to gearhead750 For This Useful Post:
Crarrs (04-04-2012)
 Old 04-04-2012, 04:51 AM   #31
JBR
JBR's Avatar
Posts: 6,616   (View Stats)
Groans: 28
90 ft/lbs is fine for that bolt and the others. As mentioned, it's the nut not the torque.
Jamie
JBR is offline   Reply With Quote
The Following 3 Users Say Thank You to JBR For This Useful Post:
gearhead750 (04-04-2012), SKiZ0TT (04-07-2012), TexasSpeed3 (04-04-2012)
 Old 04-04-2012, 06:00 AM   #32
bigriver's Avatar
@gearhead750 I switched to cs rmm inserts because of the stripped nut. I previously had 88 duro rmm, 88 duro tmm and 80 duro pmm. When you consider that the pmm and tmm have multiple mounting bolts while rmm has just one, there is a lot of stress being placed on the rmm subframe nut and it may be the weak link. I guess the tmm and pmm have a single bushing bolts but those sre much larger than the rmm bushing bolt. However the rmm bushing bolt is the only bolt that directly mounts in the frame.
Again just speculation, but when the entire thread from the nut comes out in one piece, i couldnt find any other cause. Maybe someone else can figure this out for sure, I really dont know.
So recently Lex also said he would either use cs rmm inserts or cpe stage 2 rmm. I place a lot of value on anything he says. This convinced me to switch to cs inserts because both of these mounts place less stress on the rmm subframe nut. While I'm 100% sure the repaired nut is fine, I just wanted more peace of mind. So far I've been impressed with the inserts and they work just fine. The inserts are not as good as the dogbone for torque steer and wheel hop, but I'm okay with that. I also reinstalled stock pmm and tmm as some other folks I've talked to have no issues with stock pmm and tmm. But just as I finish typing this, a thread pops up on a failed oem tmm.
Please do not interpret my reply as bashing of stiff mounts. That is not my intent. I had a problem, fiixed it and made the switch purely for my own peace of mind since my car is my DD and I commute over 80 miles each day. Repairing the nut is easy but when it strips, that is just an awful feeling.
gearhead750 (04-04-2012), JBR (04-04-2012)
 Old 04-04-2012, 06:35 AM   #33
Crarrs's Avatar
Groans: 98
Good point. What's the reason for this @jbarone?
How is the torque not the root cause for the nut stripping?
2004 MSM TiGrey
 Old 04-04-2012, 06:36 AM   #34
Groans: 30
Jamie
I think a more in depth answer might help as all of your other mounts except for the billet say to use 70 ft lbs. And why use 90 ft lbs on the 3 transmission bolts as well? 90 seems like an awful lot when the stock specs say up to 66 (Bushing). This would make pulling all of those threads out of the nut make more sense than blaming it on a faulty nut.
Sorry OP didn't mean to jack your thread just trying to get some information for those of us with these mounts that have followed these torque specs.
 Old 04-04-2012, 06:50 AM   #35
JBR
JBR's Avatar
Groans: 28
The torque spec I used is based on the size and grade of bolt 86-93ft-lbs dry. Do I think the 90 vice 70 is the cause, no. Why do the molly instructions say to torque to 70 and the billets 90; don't recall it's been a while since either where written. I'll change them shortly.
In the 3 years I've been doing this I have only heard of stripped nuts 2-3 times so that makes the higher torque spec, IMHO less likely. With that said I'll change it.
Thanks,
Jamie
The Following User Says Thank You to JBR For This Useful Post:
 Old 04-04-2012, 07:47 AM   #36
bigriver's Avatar
@jbarone - I agree with Jamie that the 90 lbs torque is not the issue. Cpe also recommends 90 lbs and guys are using breaker bars to tighten the nuts too so if 90 lbs was the issue we should be seeing a lot more stripped nuts. My issue popped up when I started doing wot logs for my etune and going close to redline. Eveything was fine when I was on ots maps and not really getting close to redline.
JBR (04-04-2012), TexasSpeed3 (04-04-2012)
 Old 04-04-2012, 08:18 AM   #37
Vinnie's Avatar
Posts: 714   (View Stats)
Vinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the world
Groans: 76
subbed
'12 speed 3 CWP w/tech: DIZZY Tuned by Phate!,cobb AP,Autotech internals, cp-e nano, cp-e TIP, JBR 88 dogbone, JBR SSP/bushings, JBR rear sway bar, UR test pipe
RIP '08 speed 3 silver cp-e 75 duro RMM, cp-e intake, cp-e TIP, Jbarone SSP and bushings.
Vinnie is offline   Reply With Quote
 Old 04-04-2012, 11:44 AM   #38
ziwang55's Avatar
got it fixed. a shop did it for 40 bucks. heli coil. watched him do it just like in your how to.
JBR and gearhead750 like this.
The Following 4 Users Say Thank You to ziwang55 For This Useful Post:
bigriver (04-04-2012), gearhead750 (04-04-2012), JBR (04-04-2012), TexasSpeed3 (04-04-2012)
 Old 04-04-2012, 02:26 PM   #39
ziwang55's Avatar
they do sell heli coils in small packs. without the drill bit. which i think it much cheaper.
 Old 04-04-2012, 05:29 PM   #40
bigriver's Avatar
Yup. If you have the matching bit and tap then its no problem to just buy the coils.
ziwang55 (04-04-2012)
The Motor Mount Thread RhoadBlock MazdaSpeed 3 - Engine, Transmission & Driveline 341 06-30-2018 01:45 PM
Motor Mount Inserts vs. Rear Motor Mount Pro's n Con's Dre 2010 MS3 - Engine, Transmission & Driveline 23 05-21-2016 07:47 AM
AWR passenger motor mount issue ? jracer MazdaSpeed 6 - Engine, Transmission & Driveline 3 10-13-2011 10:04 PM
passenger motor mount issue? cageyvet MazdaSpeed 3/6 - Big Turbo Builds 2 07-24-2010 02:23 PM
weakest motor mount..? what mount takes a dump first? Lvis MazdaSpeed 3 - Engine, Transmission & Driveline 29 03-02-2009 10:39 PM
Page generated in 0.56469 seconds with 30 queries
