Like Tree6Likes
 Old 03-01-2011, 07:17 AM   #81
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Exploding, broken window, open trunk, mismatched wheels neon brings lulz.
OneBAMFpog likes this.
 Old 03-01-2011, 07:45 AM   #82
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
Addikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the world
Groans: 157
Groaned at 29 Times in 16 Posts
damn man that sucks, your car sounds just like mine. At least the camera takes some good video.
09 MGM MS3
BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s
Addikted To Boost is offline   Reply With Quote
 Old 03-01-2011, 07:54 AM   #83
SIXual Panda's Avatar
Posts: 2,363   (View Stats)
SIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the world
Groans: 56
damn!!!! epicly rare video! i would be so proud to have that on video if that were me. good luck with whatever you decide to do. either rebuild or stock it out and go MK4.. either way.. you will have yourself a nice car.
I envy your ass raping.
The Money Pit: 2006 Mazdaspeed6 GT (BCM)
Fully built, Ported everything, GTX3582r, Port Injection, Twin disk clutch, 2-piece Driveshaft.... still slow.
The Daily Bitch: 2003 Mazda Protege5 with infinity miles on it
SIXual Panda is offline   Reply With Quote
The Following User Says Thank You to SIXual Panda For This Useful Post:
Docnox (03-01-2011)
 Old 03-01-2011, 10:57 AM   #84
bwspeed's Avatar
Posts: 286   (View Stats)
bwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the world
stock intercooler?
bwspeed is offline   Reply With Quote
The Following User Says NO Thank You to bwspeed For This Un-useful Post:
turd burglar (03-01-2011)
 Old 03-01-2011, 11:11 AM   #85
MrBojangles's Avatar
Posts: 93   (View Stats)
MrBojangles is the leader of the worldMrBojangles is the leader of the worldMrBojangles is the leader of the worldMrBojangles is the leader of the worldMrBojangles is the leader of the worldMrBojangles is the leader of the worldMrBojangles is the leader of the worldMrBojangles is the leader of the worldMrBojangles is the leader of the worldMrBojangles is the leader of the worldMrBojangles is the leader of the world
Groaned at 4 Times in 1 Post
Yup. This car blew because it was running lean. I suspect pump failure since my last log had WOT afrs in the mid 10s and would dump carbon. In that video there is almost no smoke and then poof. Who knows though.
MrBojangles is offline   Reply With Quote
The Following 2 Users Say Thank You to MrBojangles For This Useful Post:
djuosnteisn (03-02-2011), Docnox (03-01-2011)
 Old 03-01-2011, 11:41 AM   #86
708
Erich's Avatar
Posts: 4,274   (View Stats)
Why not pull the pump, see how smoothly (or not) it compresses and then disassemble it and check the condition of the internals. Did you hear a lot of new noise coming from the pump? When they start to fail you get more and louder tapping sounds from the cam follower not maintaining constant contact with the pump internals.
How long ago was your last log (or when you were last monitoring)?
Erich is offline   Reply With Quote
 Old 03-01-2011, 01:08 PM   #87
zx2man's Avatar
Posts: 1,356   (View Stats)
zx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the world
Ummmm, afr's in mid 10's is actrully alittle rich. Higher# =leaner
Perfect WOT in this car should be around 11.3-11.9,..somewhere around there...now if you were running say 13s..that would be lean....but 10s is on the rich side.
Also when fp is failing....usually you will get some cut...meaning some hesitation in the higher rpms. did you experience any of this before you blew??
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO*
zx2man is offline   Reply With Quote
 Old 03-01-2011, 01:23 PM   #88
708
Erich's Avatar
That was his point. He was in the 10s and dumping carbon. In this video he was getting no carbon at all so likely lean. There was other evidence like what sounded like knock in some of his earlier pulls in the video.
 Old 03-01-2011, 01:28 PM   #89
right
 Old 03-01-2011, 01:33 PM   #90
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Originally Posted by KiddMnKy View Post
Just had to post this because of how epic it is and I figured this would be a good place to start.
YouTube - Dodge Neon Burnout gone wrong with Clutch Blowing Up
lawl..what a fucking retard!
 Old 03-01-2011, 01:47 PM   #91
zx2man's Avatar
Sorry, misread your information. Just checkin, some people dont know how afr's work, so my bad
Anyways back to the pump, did you experience any fuel cut at all before the WOT?? my ptp pump started cutting is this colder weather colder weather out, so no wot for me right now.
Also, there are times when I dont always dump smoke when I go wot either..like my first couple wots I will...then couple wot pulls right after wont...my car is Tim Bailey tuned with 11.7 afr's....anyways yeah your trying to figure things out, and I hope you do. Keep us posted.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
COBB RSB
 Old 03-01-2011, 02:09 PM   #92
708
Erich's Avatar
Were you logging fuel pressures? If you are getting a cut with no drop in fp prior to the cut, then maybe it is load related (not sure when you had it tuned or how long the protuners have had access to the load cap.) If your fuel pressure is dropping, then you may have a pump from PTP's bad batch. Contact PTP and get it warrantied.
 Old 03-01-2011, 02:10 PM   #93
fjames's Avatar
Posts: 1,058   (View Stats)
From the water vapor I'm guessing that was a cold start? You're into boost at less than a minute after a cold start in freezing weather then it looks like. Since nobody's saying anything, does that mean people think this is a normal way to drive? I wish people would figure out this is a 25K shitbox with a higher specific output from the factory than almost any other car ever legally for sale in the U.S. in the history of the universe.
The Following 6 Users Say Thank You to fjames For This Useful Post:
banditscout (03-01-2011), Danish (03-01-2011), Dano (03-08-2011), Docnox (03-01-2011), OneBAMFpog (03-01-2011), wankular (03-01-2011)
 Old 03-01-2011, 02:12 PM   #94
708
Erich's Avatar
I actually wondered about that the first time I watched the video as well. Would be doubly bad if there was knock in his tune as the knock sensor doesn't even come on until the coolant temp is like 140 degrees.
The Following User Says Thank You to Erich For This Useful Post:
Dano (03-08-2011)
 Old 03-01-2011, 02:37 PM   #95
fjames's Avatar
Yeah, according to ATR it's 158 - I set a low temp warning on my DH for "less than or equal to" 160 to remind me
 Old 03-01-2011, 02:37 PM   #96
Ziggo's Avatar
Posts: 3,843   (View Stats)
My shit knocks like crazy on a cold start between the time the coolant reaches ~170f and the time when the oil gets hot.
Seems like all the clichés rolled into one:
Cold temperature
5th gear
Shortly after a shift
Partial throttle
PTP fuel pump
Ask Me About My:
Docnox (03-01-2011)
 Old 03-01-2011, 02:44 PM   #97
dizzydtrain's Avatar
Posts: 2,476   (View Stats)
dizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the world
Groans: 64
Cold temperature
5th gear
Partial throttle
PTP fuel pump
It does appear to be the case. Not sure what it is about winter driving but I rarely have the urge to floor it or get on the car. Once it's nicer out, I have no issue with wot.
Cp-e HPFP : JBR 80duro RMM : JBR Special Edition Heavy Shift Knob : JBR EGR Delete : Matt Damond OCC kit : Cobb AP : Cobb DP : Cobb BPV XLE : ETS TMIC : CP-e SRI : Cp-e TIP : Magnaflow CBE : Aeroforce Interceptor Dual Gauge : Blockhead vent pod :PERM Tuned : H&R Springs : TSW Nurburgring 18x8.5 w/ 235/45 Hankook Ventus V12 Evo : DDM 6000k Lows : DDM 3000k Fogs : Corksport LED light kit : 3M 35% color stable tint
dizzydtrain is offline   Reply With Quote
 Old 03-01-2011, 03:48 PM   #98
Lets rule out a couple things. I had just driven the car almost an hour home from work. I got out, went in the house, changed clothes and grabbed the camera. The car was off for MAYBE 10 minutes at most. It was fully up to operating temperature.
Everything else I think you're all right on the money with.
The car was tuned by Jorge at P&L in Chicago. I know for sure it wasn't the tune. The car leaned out at some point in the last couple weeks and finally went. I drove it like an asshole at all times so I assume something changed recently. I didn't notice any fuel cut since I upgraded my pump. I have a log around here somewhere but its a few weeks old and I assume not very helpful.
That being said, I am no tuner. That's why I got a protune, i dont trust my knowledge in that area enough.
Docnox (03-01-2011), Ferdball (03-01-2011)
 Old 03-01-2011, 04:04 PM   #99
Sniper2606's Avatar
Posts: 569   (View Stats)
Sniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the world
Groans: 33
Groaned at 32 Times in 15 Posts
any pics or videos on the engine?! and btw im sorry for the lost
Silly Lebron, rings are for Kobe
2011 WRX STI pro tune Invidia Downpipe and Exhaust,Cobb Intake Cobb AP 91
The nigga bought aluminum tubes! Do I need to tell you what the fuck you can do with an aluminum tube!?! ALUMINUM!!
Dave Chappelle
Sniper2606 is offline   Reply With Quote
 Old 03-01-2011, 04:12 PM   #100
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Tune has nothing to do with the current weather in which it blew. It doesnt matter what your timing and fuel targeting was, 98% of fuel injected cars out there will ADD additional timing during cold weather to lean the car out. Most run extremely fat in cold weather.
Its sad to see that she blew, but there are several factors that may have played a roll here. If you didnt feel any cut and i dont recall hearing any cut, then i would rule out the whole pump. It would of should signs of fail before it blew and were talking days before hand.
Since nothing was logged, were not even going to know. Its all speculation. I would put my money on higher timing and a higher AFR which cause it to detonate and lose the rod.
 Old 03-01-2011, 04:37 PM   #101
I had to take the video down. Someone put it on NASIOC and I dont want that much exposure because those guys are douchebags
The Following User Says Thank You to MrBojangles For This Useful Post:
Sport6 (03-01-2011)
 Old 03-01-2011, 04:48 PM   #102
Sniper2606's Avatar
Groans: 33
oh wow dicks.... anyways idk if this was ask before but where did you get that camera mount?! i have a Flip HD and i wanna do the same
Dave Chappelle
 Old 03-01-2011, 05:29 PM   #103
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
what happened to the link of the video? its removed?
The Following User Says NO Thank You to SpeedSixxx For This Un-useful Post:
Tokay444 (03-01-2011)
 Old 03-01-2011, 05:29 PM   #104
zx2man's Avatar
First thing I did when I experience some hesitation from the fuel pump was grab my AP and log a WOT pull. From 5000-5800 rpm, my fuel psi dropped from 1700+ to 900 lol...yeah..shitty fp. This pt pump is one of the newer ones, I will not get it replaced by them, Im just gonna go for cp-e pump and call it a day.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
COBB RSB
 Old 03-01-2011, 05:33 PM   #105
Docnox's Avatar
Posts: 1,435   (View Stats)
Docnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the world
Groans: 35
Aww, I never even got to see the video.
Sorry for the explosion though. I vote keep the mk3 and build the speed. Then you'll have rwd and fwd monsters. Can't beat that.
'06 Speed 6
Black Mica
Mazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe,
3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp
Altered Customs fmic, Autotech fp internals
Cobb AP, Stage 2+ 93 tweaked
Centric blanks, EBC red pads
Lotek center gauge pod: AEM wideband, Autometer boost and volts
Tints, blacked emblems, spec-v front lip, Shark fin
Redline MT-90, ITV-22s, Matt Damond OCC
13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap)
DO Meth kit waiting on install
Docnox is offline   Reply With Quote
 Old 03-01-2011, 05:38 PM   #106
zx2man's Avatar
Yeah because they have soo much room to talk with "cast" pistons whose ringlands crack all the time due mostly due Subaru's stock shitty tune, or wrx's weak 5speed tranny, so they either try hardend gear sets or buy a 6 speed sti tranny, which umm isnt cheap...Love Subarus.....awesome cars, but like everyone else they got thier share of mishaps as well.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
COBB RSB
 Old 03-01-2011, 05:39 PM   #107
stefan's Avatar
Posts: 2,216   (View Stats)
stefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the world
Groans: 140
Groaned at 116 Times in 64 Posts
BOOOO for taking down the video.
set it to private and post the link in VIP. done.
Originally Posted by NJSPEED3:
you see here in NJ when you meet the nj nator crew ...its a wrap for your warranty son
stefan is offline   Reply With Quote
 Old 03-01-2011, 05:44 PM   #108
cucamelsmd15's Avatar
Posts: 5   (View Stats)
cucamelsmd15 will become famous soon enough
Or, you boys could just catch the video in its entirety here:
http://dl.dropbox.com/u/2057062/OT/mazda_douche.mp4
cucamelsmd15 is offline   Reply With Quote
The Following User Says Thank You to cucamelsmd15 For This Useful Post:
SpeedSixxx (03-01-2011)
The Following 2 Users Say NO Thank You to cucamelsmd15 For This Un-useful Post:
gigs2000 (03-02-2011), Sport6 (03-01-2011)
 Old 03-01-2011, 05:51 PM   #109
Ferdball's Avatar
Posts: 1,340   (View Stats)
Ferdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the world
Why the reference to douche?
Ferdball is offline   Reply With Quote
 Old 03-01-2011, 05:54 PM   #110
stefan's Avatar
Groans: 140
google says he's a subaru dude (who apparently just registered here to post the link).
 Old 03-01-2011, 05:54 PM   #111
Sport6's Avatar
Posts: 427   (View Stats)
Sport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the worldSport6 is the leader of the world
Nice video name
2007 GT - traded
2009 WRX
Sport6 is offline   Reply With Quote
 Old 03-01-2011, 05:56 PM   #112
mdl3v8's Avatar
Posts: 410   (View Stats)
mdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the world
Groaned at 14 Times in 5 Posts
His join date is May 2009, but 1 post? Hmmm...
3" JBR TIP + 3.5" Treadstone MAF Housing | GTX2867R | CP-E catted DP | COBB CBE | Autotech Internals | CXRacing Piping + TR8 | DevilsOwn Meth Kit | Forge BPV | JBR Shifter Bushings | DM RMM | JBR PMM | JBR RSB | Moog Front/Rear Endlinks | Koni Yellows
mdl3v8 is offline   Reply With Quote
 Old 03-01-2011, 05:57 PM   #113
Ferdball's Avatar
Spy.
 Old 03-01-2011, 05:58 PM   #114
Tokay444's Avatar
Groans: 793
Sounds like a stalker faget.
mdl3v8 (03-01-2011)
The Following 2 Users Say NO Thank You to Tokay444 For This Un-useful Post:
dizzydtrain (03-01-2011), SpeedSixxx (03-01-2011)
 Old 03-01-2011, 06:00 PM   #115
Yes, I clearly registered in 2009 to post the link you fucking dolt.
 Old 03-01-2011, 06:03 PM   #116
mdl3v8's Avatar
So why did you join?
Edit: Anyway... OP still sucks you blew.
 Old 03-01-2011, 06:08 PM   #117
Sport6's Avatar
Youtube shows his chubby face in his helmet in a miata.
2007 GT - traded
2009 WRX
 Old 03-01-2011, 06:13 PM   #118
03scgt's Avatar
Posts: 400   (View Stats)
03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world
it was posted on svtperformance too lol
03scgt is offline   Reply With Quote
 Old 03-01-2011, 06:14 PM   #119
Because I bought some things from the classifieds on here when I had a MS3.
And your point? I keep my douchebaggery on the track, where it belongs, unlike the OP.
The Following User Says NO Thank You to cucamelsmd15 For This Un-useful Post:
 Old 03-01-2011, 06:19 PM   #120
The mature NASOIC crowd stepped in folks. The internet police is everywhere. I guess STIs are driven at posted speed limits at all times while not on the track.
I am a fan of safety - but where is the proof that OP was breaking the law? Why don't you leave the law up to the people meant to make those decisions and enforce it.
Out of all the douchebaggery you see on youtube this was mild - at least the OP wasn't racing anyone.
Dano (03-08-2011), Docnox (03-02-2011), kgb (03-01-2011)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/my-speed3-engine-explodes-hd-video-73612/
Friends MazdaSpeed3 blows up - PM Whitford for video. - Page 14 - NASIOC This thread Refback 03-08-2011 09:11 PM
Friends MazdaSpeed3 blows up - PM Whitford for video. - Page 8 - NASIOC This thread Refback 03-04-2011 05:42 AM
Friends MazdaSpeed3 blows up - PM Whitford for video. - Page 9 - NASIOC This thread Refback 03-03-2011 07:10 PM
Friends MazdaSpeed3 blows up - NOW with VIDEO - Page 8 - NASIOC This thread Refback 03-02-2011 07:56 PM
Friends MazdaSpeed3 blows up - NOW with VIDEO - Page 9 - NASIOC This thread Refback 03-02-2011 07:18 PM
Friends MazdaSpeed3 blows up - NOW with VIDEO - Page 14 - NASIOC This thread Refback 03-02-2011 06:12 PM
My roomates MazdaSpeed3 Blowing up on video - Page 2 - LS1TECH This thread Refback 03-02-2011 02:38 PM
Friends MazdaSpeed3 blows up caught on video - Page 14 - NASIOC This thread Refback 03-02-2011 12:50 AM
My roomates MazdaSpeed3 Blowing up on video - Page 2 - LS1TECH This thread Pingback 03-01-2011 11:02 PM
Friends MazdaSpeed3 blows up caught on video - Page 9 - NASIOC This thread Refback 03-01-2011 06:05 PM
Friends MazdaSpeed3 blows up caught on video - Page 8 - NASIOC This thread Refback 03-01-2011 05:38 PM
Aetherfury 2010 Speed3 Resonator Delete. Epic video and questions answered ;) Aetherfury 2010 MS3 - Engine, Transmission & Driveline 49 07-07-2010 02:23 PM
2010 Speed3 Stock Exhaust Video Aetherfury 2010 MS3 - Engine, Transmission & Driveline 5 10-27-2009 11:14 AM
OK i need some help here. before my motor explodes Wenis Prinkle
Cobb ATR Support
28 09-04-2009 12:49 AM
Page generated in 0.56374 seconds with 40 queries
