![]() | | #361 | ![]() |
![]() Join Date: Dec 2012 Location: Venice,FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 438
| Not Ranked : 0 score You can still run up to 50/50 with Water Wetter but it's most effective running it with pure water. Pure water with Water Wetter, 180 degree T-stat, and the fan controller mod would be a nice way to beef up the cooling system for track guys.
__________________ 2013 MS3 VRM w/Tech -unSure Track RMM//Cobb AP//AT HPFP Internals//HTP 3" Intake//UR Resonated TP//UR CBE//JBR Weighted Shift Knob//JBR Shifter Cage Bushings FlowTuned 2 Gallon E85 blend 307whp/336wtq |
![]() | | #362 | ![]() |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
| Not Ranked : 0 score I've been using purple ice for 4 years now with a 30/70 coolant/water mix during every flush and also see very cool temps. I usually see 183-187 while cruising on the highway all day long fan off. No higher than 196 while driving around town. Only above 200 if sitting in traffic unless the fan comes on or I use A/C. I should mention..I haz failz with an upgraded TMIC.
__________________ www.tunedbynishan.com |
| The Following User Says Thank You to ms3blackmica For This Useful Post: | Micha (07-29-2013) |
![]() | | #363 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson | |
![]() | | #364 | ![]() |
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
| Not Ranked : 0 score I realize i could google this but i figure since we're on the subject i'll pick yalls brains. I recently relocated a coolant hose (that annoying one touching the cold pipe), and refilled with water and coolant. I noticed my temps were getting pretty hot, so i went and saw my level was low... ok, go to open the cap to put more in and hear a hissing, AHH, i forgot to burp the system. Drive around, twist cap until "hiss" 2-3 more times to try to get all the air out, but then i got to thinking ... when water absorbs heat it turns to steam, am i just purging all my water out thinking its air? i know the boiling point of water is ~212*, and my temps arent hitting that, but maybe theres some partial evaporation going on? I'd like to keep water in the system because of its superior heat rejection, but i'm having trouble burping the system at this point. Thanks.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
![]() | | #365 | ![]() |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
Groans: 112
| Not Ranked : 0 score I don't know, I keep burping my system and it always seems to either lose coolant somewhere or more air is coming to the surface in the reservoir. I idled for 3 hors and there were still bubbles coming to the surface, and after a quick drive and parking again I continued to see bubbles.
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress |
![]() | | #366 | ![]() |
| Not Ranked : 0 score Its under pressure, which raises the boiling point of water. IIRC with a 15psi cap it's ~250*F It basically acts like a safety for the car. If it gets too much heat, it will boil and blow off steam. So the coolant will just start to boil off, but won't actually get any hotter till there is no coolant in the block. Zigatapatalka
![]() | | #367 | ![]() |
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
![]() | | #368 | ![]() |
Groans: 112
| Not Ranked : 0 score Hopefully.....if not there might be a leak, that's what I'm worried about.
![]() | | #369 | ![]() |
![]() Join Date: Nov 2010 Location: Benbrook, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,325
Groaned at 18 Times in 14 Posts
Plagiarized from internet. "The pressure cap on a cooling system is the key to raising the boiling point of the 50/50 mix of antifreeze and distilled water. For every pound of pressure cap rating the boiling of point of the above mixture raises 3 degrees. If you had plain water in your cooling system with a 15 pound pressure cap the water would boil @ 257 degrees. If you had a 50/50 mix of antifreeze and water the coolant would boil @ 265 degrees with a 15 pound cap. The boiling point would raise to 270 degrees if you had a 60% antifreeze mixture with a 15 pound cap. If you had a 70% mixture the boiling point would raise to 276 degrees." To burp the system, just take the cap off and let the car run for a while until it heats up the thermostat opens. Once you stop seeing bubbles in the reservoir you're good. There might be some micro areas that are able to boil but they should condense pretty quickly within the pressurized system.
__________________ 2010 MS3 Mica Black Tech Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch ![]() | |
| The Following User Says Thank You to aggierandy For This Useful Post: | Voltwings (07-29-2013) |
![]() | | #370 | ![]() |
Groans: 79
| Not Ranked : 0 score I haven't had a chance to look really, just wondering if anyone in here knows - What's the thread / pitch for an oil sandwich plate on our motors? I'd like to try a themostatic sandwich plate for a remote cooler at some point: http://97.74.32.155/files/thermos$.pdf
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following User Says Thank You to djuosnteisn For This Useful Post: | DSIT995 (08-02-2013) |
![]() | | #371 | ![]() |
| The Following 2 Users Say Thank You to Voltwings For This Useful Post: | djuosnteisn (07-29-2013), Tomas (07-29-2013) |
![]() | | #372 | ![]() |
![]() Join Date: Jan 2010 Location: El Cajon, CA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,323
| Not Ranked : 0 score The regular sandwich plate that fits our engine is Greddy part# 12002801. The thermostatic sandwich plate is part# 12401126. It has the M20xP1.5 threads.
__________________ www.MOTOIQ.com Beater Titan |
| The Following 6 Users Say Thank You to Todd98SE For This Useful Post: | 802MS3 (07-29-2013), bob^3 (07-30-2013), djuosnteisn (07-29-2013), Nliiitend1 (07-29-2013), Voltwings (07-29-2013), wolly6973 (07-30-2013) |
![]() | | #373 | ![]() |
Groans: 79
| Not Ranked : 0 score Muchos Gracias.
![]() | | #374 | ![]() |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
You need the 3/4x16 UNF. Just like the spin ons we use.
__________________ ![]() | |
| The Following 5 Users Say Thank You to Tomas For This Useful Post: | djuosnteisn (07-30-2013), Nliiitend1 (07-31-2013), Todd98SE (08-01-2013), Voltwings (07-29-2013), wolly6973 (07-30-2013) |
![]() | | #375 | ![]() |
![]() Join Date: Feb 2011 Location: Vaughan, Ontario, Canada
Rep Power: 1135 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 977
Groaned at 55 Times in 26 Posts
| Not Ranked : 0 score I used Motul Mocool, it's 500mL for 10L. I think I used about 375mL according to the factory spec on coolant capacity. @Voltwings; If you are having trouble bleeding the coolant system I suggest you run the system and raise the coolant bottle so all 3 hoses are covered by whatever mix you are using, leave it like this for a few minutes until the motor is up to temp. Some people recommend turning the heater on to full blast as well while doing this. If you want to get more particular you can raise the front of the car on jack stands or do it on a driveway with the front of the car at a higher position then the rear to help force the air out. After that you should be good to go. A few nights around freezing I don't think it's enough to worry about, if you leave a water bottle in the car overnight and it freezes tats a good gauge as to whether or not you should be running antifreeze in the winter. I will be switching back to FL22 or whatever the Mazda mix is around October then back to water in May.
__________________ Fueled by the haters. |
![]() | | #376 | ![]() |
Sent from my iPhone using Tapatalk 2
__________________ www.MOTOIQ.com Beater Titan | |
| The Following 2 Users Say Thank You to Todd98SE For This Useful Post: | Nliiitend1 (07-31-2013), Tomas (07-29-2013) |
![]() | | #377 | ![]() |
Groans: 79
I'm thinking of trying this Mocal plate out: http://97.74.32.155/files/thermos$.pdf SP1T has the right threads... but i'm not entirely sure how well it will fit. Most likely, the spin on dimensions are fairly standard in the industry... but who knows. $90 isn't bad for a thermostatic spin on oil cooler. I'll post pics whenever i get it on.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following 2 Users Say Thank You to djuosnteisn For This Useful Post: | Boosted Beluga (07-30-2013), Tomas (07-30-2013) |
![]() | | #378 | ![]() |
| Not Ranked : 0 score My project for the day.
| The Following 4 Users Say Thank You to Voltwings For This Useful Post: |
![]() | | #379 | ![]() |
(Thread Starter) | Not Ranked : 0 score cooling the home depot bucket ?
| The Following 14 Users Say Thank You to Dano For This Useful Post: | BlueStreak (07-30-2013), bob^3 (07-30-2013), Boosted Beluga (07-30-2013), charlesfist (08-01-2013), Code Monkey (07-30-2013), djuosnteisn (08-01-2013), Easter Bunny (07-30-2013), Elvisrosales88 (07-30-2013), El_Diablo (07-30-2013), Fobio (07-30-2013), Mauro_Penguin (07-31-2013), MZRSPEED (07-30-2013), Sid3wayS (08-01-2013), Tomas (07-30-2013) |
![]() | | #380 | ![]() |
| Not Ranked : 0 score You may loose efficiency with the fan by cutting the should open. If you are going to do that I would suggest removing the AC condenser or at the very least use aluminum tape and cover the sides as well as top and bottom of the condenser to force all of the air through the condenser and the rad. Are you planning to add another fan on the other side?
| The Following User Says Thank You to Celestspeed3 For This Useful Post: | El_Diablo (07-30-2013) |
![]() | | #381 | ![]() |
| Not Ranked : 0 score One thing at a time. the plan of action is this, then switching to a higher concentration of water, then ducting so I can quantify each phase. I'm never in stop and go traffic, but with the 100+ degree temps we see here for quite a few months out of the year, my ECT's will still end up around 195 cruising. In the cooler parts of the year its around 183 cruising, so I'm looking to do what I can to help bring it down in the hotter months. If all I managed to do was fuck up my shroud then oh well, I tried.
![]() | | #382 | ![]() |
(Thread Starter) | Not Ranked : 0 score why worry about 195? if you remove the shroud and don't put in another fan you indeed went backwards.
![]() | | #383 | ![]() |
| Raider is mah Homie ![]() Join Date: Jan 2011 Location: Towson, Maryland
Rep Power: 7524 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54,831
Groans: 2,978
| Not Ranked : 0 score Open is better while the car is moving.......
__________________ ![]() I hugged rfinkle2 |
| The Following User Says Thank You to Easter Bunny For This Useful Post: | 86AmishMs3 (07-31-2013) |
![]() | | #384 | ![]() |
(Thread Starter) | Not Ranked : 0 score yes but do you see the little flappers? guess what they do when you're moving? those were the precursors to Fords, and others "active flappers" on a lot of the newer models. I really assumed he was adding an 8" fan over there.
| The Following 3 Users Say Thank You to Dano For This Useful Post: |
![]() | | #385 | ![]() |
Groans: 2,978
| Not Ranked : 0 score Im stupid. I have had the good fortune to not have a need to pull my shroud out. I take it back should be about the same on the highway
![]() | | #386 | ![]() |
| Not Ranked : 0 score I'm aware of the tiny flappers and their function, but I've literally more than doubled the flow area in that spot now. I'm not worried about 195 ect's, but cooler is always better, so I'd be happy if they stayed in the 180s. adding another fan since I do only highway driving will do little to nothing, so worst case scenario with my mod here is I now have space for one anyways.
| The Following 2 Users Say Thank You to Voltwings For This Useful Post: | 86AmishMs3 (07-31-2013), Boosted Beluga (07-30-2013) |
![]() | | #387 | ![]() |
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 501 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned | |
![]() | | #388 | ![]() |
My understanding of those flaps, was to aid in warm up by keeping heat in the radiator at idle, as well as keeping the car warm in the winter months when the car is not on the throttle... Thats certainly not an issue we have here in Houston anyways so i figured id ditch them and see what happens.
![]() | | #389 | ![]() |
![]() | | #390 | ![]() |
Me and @86azms3; were talking about doing this earlier in this thread if anyone remembers, i happened to have my intake manifold out today so decided to just go for it.
| The Following User Says Thank You to Voltwings For This Useful Post: | 86AmishMs3 (07-31-2013) |
![]() | | #391 | ![]() |
![]() | | #392 | ![]() |
![]() Join Date: Jan 2011 Location: vancouver,WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 184
| Not Ranked : 0 score There is something else to consider when running a mix of water and surfactant like water wetter, this mix lack conditioners for seals and gaskets and cleaning agents, I wouldn't run it all of the time and I would do a thorough flush when swapping back to glycol for colder seasons
__________________ 425whp/395ftlbs - GTX3071R .82a/r- 20psi- 92 octane pump fuel |
| The Following 2 Users Say Thank You to Tabasco69 For This Useful Post: | Easter Bunny (07-31-2013), Voltwings (07-31-2013) |
![]() | | #393 | ![]() |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
Basically voltwings is removing the shrouding which should lower the pressure after the radiator helping to create a bigger pressure differential between from and rear of the radiator allowing more ambient air to flow through. In the southern states, I don't think you need to worry about warm up times. The only worry me and volt had was that when stopped it might reduce the efficiency of the fan now that the fan can pull air from the rear of the radiator instead of being forced through. But at speed this should help.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold | |
| The Following 2 Users Say Thank You to 86AmishMs3 For This Useful Post: | Boosted Beluga (07-31-2013), Voltwings (07-31-2013) |
![]() | | #394 | ![]() |
| Not Ranked : 0 score Well either i fail at burping the system or our cars just a bitch. Let the thing idle for a few minutes, Temps got up to about 190 and i decided that was good since there were no bubbles. Well, tonight was our "meet night" so between driving around various places i would check if there was still any air, and son of a bitch, opened that shit 3 times throughout the night and was greeted with a nice sturdy "hiss." I figure the above is what lead to the interesting results below, so im going to jack the bitch up tomorrow and let it idle for like 10 minutes to make sure its fully purged and hopefully have a solid update. So far however, with it being between 85 and 90 tonight with like 90% humidity, the temps were mostly steady at 185 or so ... ok, not much different than before, but they would also tend to bounce as high as 190 and as low as 182. I figure the bouncing is due to the air in the system, because that was like 20 minutes straight at 65 mph, but before the temps would never get that low in this heat so hopefully this did something. Going to try the bleed before my drive to work tomorrow morning ( i go in at 10:30 ) so hopefully i can have a good representation of what we're looking at. I can say though, that just sitting the car did not seem to heat up any faster, granted it wasnt exactly blazing outside.
![]() | | #395 | ![]() |
IMHO, if you don't have detonation issues there is no need to run the engine cooler.
__________________ | |
| The Following 6 Users Say Thank You to silvapain For This Useful Post: | bob^3 (08-01-2013), djuosnteisn (08-01-2013), Easter Bunny (08-01-2013), El_Diablo (08-01-2013), Mauro_Penguin (08-01-2013), sidekick (08-01-2013) |
![]() | | #396 | ![]() |
![]() Join Date: Jun 2008 Location: Tucson, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 752
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score Have you looked at the FSM for how to bleed the air from the coolant system? just tappa it in...
__________________ Wiseco OTS pistons, Eagle Rods, ARP mainstuds, JBR BSD w/ baffle,GT2871R, 51R battery, JBR V1 3.5 aluminum widepath, CP-e Catted DP, custom 3in cat-back, Treadstone TR8L core w/ COBB piping, Damond OCC, HKS SSQV3 (full VTA), autotech HPFP internals, Self tune 33% E85, Grimmspeed EBCS (3port), JBR TM & PM, TRZ Rmm, COBB short shifter, COBB Front/Rear swaybars, Koni STR.T struts, AXIS Circuits 18x8.5 45offset **Old Motor** Best 1/4 -13.19 Stock Turbo/ street tires Best trap speed - 112mph **New Motor** Best 1/4 - 13.35 Stock turbo/ street tires Best trap speed - 112.5 |
![]() | | #397 | ![]() |
| The Following User Says Thank You to aggierandy For This Useful Post: | bob^3 (08-01-2013) |
![]() | | #398 | ![]() |
It is designed to build pressure, and you may be right, but if the water or coolant isnt boiling then whats the "hiss" coming out? Has to be air right? I havent made it out to my car this morning, but ill check on the coolant level after having done it a few times last night.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. Last edited by Voltwings; 08-01-2013 at 08:27 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #399 | ![]() |
Groans: 769
| Not Ranked : 0 score The hiss is the pressure built up by the radiator cap.
| The Following 3 Users Say Thank You to El_Diablo For This Useful Post: |
![]() | | #400 | ![]() |
| Not Ranked : 0 score well... i was kind of hoping air being in the system was the reason for my vastly differing ECT's but i guess i'll just have to spend a few more days watching them to see whats going on.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/mzr-disi-heat-management-140135/ | ||||
| Some things I learned after going to the track - Page 9 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 02-27-2014 11:16 AM | |
| Water temp ou Oil temp ? - Mazda 3 Quebec | This thread | Refback | 03-15-2013 04:06 PM | |
| Random MS3 Chat Thread - Page 165 | This thread | Refback | 03-15-2013 12:48 PM | |
| New DISI | CorkSport | Gen2 MS3 General Discussion | 8 | 04-09-2012 08:35 AM |
| MZR 2.3 DISI Rods from cp-e™ | www.cp-e.com | 2010 MS3 - Engine, Transmission & Driveline | 0 | 03-22-2011 12:29 PM |
