![]() | | #401 | ![]() |
![]() Join Date: Nov 2010 Location: Benbrook, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,325
Groaned at 18 Times in 14 Posts
| Not Ranked : 0 score
The whole reason we have a coolant overflow reservoir, as you probably know, is because the fluid expands as it heats up. If you didn't have that air in the reservoir then the system would over-pressurize. You need that bit of air to compress and for the cap to be able to control the pressure without spilling coolant all over. The pressure you are releasing is just the pressure accumulation from fluid expansion.
__________________ 2010 MS3 Mica Black Tech Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch ![]() | |
| The Following 2 Users Say Thank You to aggierandy For This Useful Post: | btstarcher (08-01-2013), Voltwings (08-01-2013) |
![]() | | #402 | ![]() |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
| Not Ranked : 0 score By removing the shroud and flaps you have increased mid to high speed cooling (typically when you don't need it) at the expense of low/stop/go/city cooling. I will state the obvious, the flaps open when the pressure from the front of the radiator exceeds that which is flowed through the opening for the fan, the converse is also true, when the fan sucks air through the radiator, the flaps are pulled shut increasing the air being pulled through the radiator core, without the flaps and shroud you might as well remove the fan altogether as its just moving air from the side/back/engine bay around.... modding the shroud for a second fan or getting a better fan assembly with shroud would be much better here, but try it maybe it will work for what you are doing.
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// |
| The Following 4 Users Say Thank You to Yatta For This Useful Post: |
![]() | | #403 | ![]() |
Groans: 79
| Not Ranked : 0 score Coming from a guy who runs a very large fmic and removed the AC condenser.... Life is good in the engine bay, even in 104 degree weather Highest i've seen is 205 while sitting, but it promptly drops to 187 once i start moving, even at only moderate speeds.Life inside the cabin, however..... can get pretty fucking miserable. Lol. It's not too horrible, but I'm definitely not cruising around in the lap of luxury.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following 4 Users Say Thank You to djuosnteisn For This Useful Post: |
![]() | | #404 | ![]() |
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
| Not Ranked : 0 score well I took a 2-3 minute log coming home, only to realize I didn't have ECT checked before I started logging -_-, but i'll give yall a run down. It takes me about 20 minutes to get home from work, so that's the time frame for the below scenario. Basically temps were 105 ambient, coolant temps were 185 (this was the first light I had come up to after leaving work). - Sit at light for 2 minutes ( most of a song on my ipod so im rounding) and temps climb to 195, take off from light and proceed to speed limit of 45 mph with lights every 200-400 yards for a total of 4 lights. -ECT's are hanging around 190, and when I make it onto the stretch of hwy (5 miles, no lights, 60 mph speed limit) coolant temps settle at 190 +/- 1 or 2. -wait at light outside neighborhood for roughly a minute, ECT's climb to 197, and then proceed down neighborhood street. This street is about 1/2 mile long with stop signs every 50-75 yards or so, basically every other street. By the time I was down this street (speed limit 35 mph) I was pulling into my driveway with 198* temps. So basically this mod is a wash I feel, it isn't running "substantially" cooler when moving, but it isn't exactly as detrimental at low speeds as everyone seems to think... I'll try getting a solid log either tomorrow or Saturday for yall.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
![]() | | #405 | ![]() |
![]() ![]() Join Date: Jun 2009 Location: PDX
Rep Power: 5716 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,677
Groans: 90
| Not Ranked : 0 score I installed the CS FMIC shrouds a couple weeks ago (I already have the top radiator plate that I linked to in an earlier post) I got the CS shrouds because I got the rad plate with the vent cutouts and I wanted to block them. After a couple weeks I can say that the CS shrouds do show an improvement in cooling. My temps were normally 187 when cruising on the freeway and rarely dipped below that (except on cool nights). In the last couple weeks since installing the shrouds, my cruising temps drop to the 183 degree mark more often than not - and even hit 181 on cooler nights. I still have a couple large gaps in the top plate, but I'm pretty sure that the CS shrouds help ECTs.
__________________ ![]() [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to hnda etr For This Useful Post: | Voltwings (08-01-2013) |
![]() | | #406 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
| Not Ranked : 0 score I'm fairly surprised none of you getting this deep have boxed the radiator yet...
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
| The Following User Says Thank You to El_Diablo For This Useful Post: | Mauro_Penguin (08-01-2013) |
![]() | | #407 | ![]() |
![]() Join Date: Sep 2011 Location: St. Johns, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,014
Groans: 56
Groaned at 6 Times in 6 Posts
| Not Ranked : 0 score I guess everyone has lost interest in this due to temps dropping off but I figured I'd bring it back to report what I've found... Since installing my FMIC my ECTs have been considerably higher around town; on the highway they settle at ~187 but around town they're usually around 190 and whenever my speed drops below 40 they slowly climb... stopping at a light usually leads up to around 200 and takes quite a while to drop back down once I get moving again. Anyway, today I poured a bottle of generic brand equivalent of Water Wetter in; holy shit what a difference. I was skeptical before but this stuff makes a bigger difference than I ever would have imagined. My ECTs are 181-183 on the highway right now, and the highest I've seen yet is 190 at a light. 15 seconds after moving again it was at 183.
__________________ 2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals Winter Beater: 96 GMC K1500 5 speed 4x4 Needed: Driver mod [SIGPIC][/SIGPIC] |
| The Following 7 Users Say Thank You to BigRedSpecial For This Useful Post: | atvfreek (10-05-2013), blackms3_71 (10-05-2013), Dano (10-05-2013), Easter Bunny (10-06-2013), jm211 (10-06-2013), Mauro_Penguin (10-06-2013), SarcasticOne (10-06-2013) |
![]() | | #408 | ![]() |
![]() Join Date: Feb 2009 Location: Woodland Hills, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 60
| Not Ranked : 0 score So what is this generic water wetter stuff called? Sent from my XT535 using Tapatalk 2
__________________ Sparkling Graphite Metallic E90 330i 6speed ZSP RIP: くろ ひめ BlackMica SPEED3 |
![]() | | #409 | ![]() |
Groans: 56
![]() | | #410 | ![]() |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
| Not Ranked : 0 score i use semen in my radiator, I see about 150F highway temps and about 155 max stopped. Works well. Although the water pump does sound to be working harder.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold |
| The Following 3 Users Say Thank You to 86AmishMs3 For This Useful Post: |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/mzr-disi-heat-management-140135/ | ||||
| Some things I learned after going to the track - Page 9 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 02-27-2014 11:16 AM | |
| Water temp ou Oil temp ? - Mazda 3 Quebec | This thread | Refback | 03-15-2013 04:06 PM | |
| Random MS3 Chat Thread - Page 165 | This thread | Refback | 03-15-2013 12:48 PM | |
| New DISI | CorkSport | Gen2 MS3 General Discussion | 8 | 04-09-2012 08:35 AM |
| MZR 2.3 DISI Rods from cp-e™ | www.cp-e.com | 2010 MS3 - Engine, Transmission & Driveline | 0 | 03-22-2011 12:29 PM |
