![]() | | #121 | ![]() |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,334
| Not Ranked : 0 score
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | Downmented (03-15-2013), sidekick (03-15-2013) |
![]() | | #122 | ![]() |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
| The Following 3 Users Say Thank You to Fobio For This Useful Post: |
![]() | | #123 | ![]() |
| Not Ranked : 0 score What do they consider acceptable oil temperature and do they adjust the ring gaps? Also please ask about the Thermostat, if they are in the 160/170 range they are obviously using a lower temp tstat Zigatapatalka
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk Last edited by Ziggo; 03-15-2013 at 10:06 AM. |
| The Following User Says Thank You to Ziggo For This Useful Post: | Celestspeed3 (03-15-2013) |
![]() | | #124 | ![]() |
Zigatapatalka
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk | |
| The Following 6 Users Say Thank You to Ziggo For This Useful Post: | Celestspeed3 (03-15-2013), Crarrs (03-15-2013), Dano (03-15-2013), NJSPEED3 (03-15-2013), Nliiitend1 (03-15-2013), sidekick (03-15-2013) |
![]() | | #125 | ![]() |
![]() Join Date: Dec 2012 Location: Venice,FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 438
| Not Ranked : 0 score Anyone considered experimenting with a proplyene glycol coolant like Evans? It would be interesting to see someone run it and do some logs. By itself it will not "fix" an undersized cooling system but if the cooling system has some inherent hot spots in the water jackets/localized boiling when you guys see 200+ ECTs it would definitely be of some help considering it has a boiling point of ~375F unpressurized. You might actually see higher temps because it is in effect pulling more heat out of the system, but if this were true you might pick up some more headroom from knock. Just some thoughts, I would absolutely try to get a t-stat that opens up clean at 180 though.
__________________ 2013 MS3 VRM w/Tech -unSure Track RMM//Cobb AP//AT HPFP Internals//HTP 3" Intake//UR Resonated TP//UR CBE//JBR Weighted Shift Knob//JBR Shifter Cage Bushings FlowTuned 2 Gallon E85 blend 307whp/336wtq Last edited by twenty5psi; 03-15-2013 at 10:46 AM. |
![]() | | #126 | ![]() |
![]() Join Date: Feb 2011 Location: Vaughan, Ontario, Canada
Rep Power: 1135 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 977
Groaned at 55 Times in 26 Posts
I wouldn't be surprised if they removed the thermostat altogether. | |
| The Following 2 Users Say Thank You to Celestspeed3 For This Useful Post: | atvfreek (03-15-2013), Easter Bunny (03-15-2013) |
![]() | | #127 | ![]() |
| Not Ranked : 0 score well clearly its just a matter of a bigger radiator and keeping the fans on. since 99% of this forum doesent participate in HPDE type events where you have significant load on the motor for long periods of time (where a bigger radiator would help) then just a fan mad shall suffice for the everyday DD or drag/autoX guys.
![]() | | #128 | ![]() |
| Not Ranked : 0 score Does the AWR rad fit the speed3? That seems like a far more affordable option. Radiator And Fan Assembly - Mazda3 2004-2008 - Competition - AWR Racing Store I emailed them asking a week ago and never heard back. I'd rather not waste an international long distance call being put on hold. |
![]() | | #129 | ![]() |
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,851
Groans: 58
| Not Ranked : 0 score |
| The Following 5 Users Say Thank You to daafisch For This Useful Post: | atvfreek (03-15-2013), Celestspeed3 (03-15-2013), Fobio (03-15-2013), sidekick (03-15-2013), Ziggo (03-15-2013) |
![]() | | #130 | ![]() |
![]() Join Date: Jan 2010 Location: El Cajon, CA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,323
| Not Ranked : 0 score I'm surprised both teams are still using the OEM oil cooler. That is usually the first thing replaced with an air to liquid cooler when fighting oil temps. Fluidyne does not have a bolt in radiator upgrade and Koyo doesn't cover the Pu yet. A Ron Davis radiator even custom fitted would be much less than the quoted $2200 i-Moto radiator. Edit: I just emailed AWR again asking for a Ron Davis core MS3 radiator. Hopefully he responds this time.
__________________ www.MOTOIQ.com Beater Titan |
| The Following 4 Users Say Thank You to Todd98SE For This Useful Post: |
![]() | | #131 | ![]() |
| Not Ranked : 0 score Wow, Tony at AWR already wrote back. He is wondering what the difference is between the 2 gens of MS3 radiators? He also wanted to look at one from each gen and he would see what he can do. It sounds like his existing MS6 radiator will work with minimal modification. Anyone in SoCal have a radiator sitting around we can get to AWR? I can drive my Gen2 to him to look but he probably needs one uninstalled. Edit: All he needs is an uninstalled Gen 2 radiator. Anyone have access to one?
| The Following 7 Users Say Thank You to Todd98SE For This Useful Post: | atvfreek (03-15-2013), Celestspeed3 (03-15-2013), Dano (03-15-2013), Downmented (03-15-2013), Fobio (03-15-2013), sidekick (03-15-2013), Ziggo (03-15-2013) |
![]() | | #132 | ![]() |
| Not Ranked : 0 score From what I have gather the hose size is like 1/16" different and the inlet and outlets are in slightly different positions. The fan shroud is different as well. If we get a new rad I could care less if the shroud is the same. So long as it fits I can block off the sides with some sheet metal and some high temp silicone to seal it up. So long as the mounting points are the same it should work. Gen1 Speed3 ![]() More Information for SPECTRA PREMIUM / COOLING DEPOT CU2696 All of the gen1 rads are the same Gen2 Speed3 ![]() More Information for SPECTRA PREMIUM / COOLING DEPOT CU13100 All of the gen2 rads are the same |
![]() | | #133 | ![]() |
(Thread Starter) | Not Ranked : 0 score I personally don't ever see going this far but this is great info for the Stage III guys. So back to Stage I mods: In-fact may not even go with a fan controller and instead go with a simple switch for when I am tuning/running the car hard. I am no circuit expert but I would like to have a relay attached to a timer circuit of sorts. Throw the fan into ON position and if you forget to turn it off [this is me for sure] it will go back to OEM mode after 30 minutes or whatever user selectable setting has expired. no need to cut into the rad hose no need to buy a thermostat and adapter for hose no need to buy the kit @superskaterxes; mr EE...can you make something that can do that? @BlueStreak; what say you...we know you like to make circuits
| The Following 5 Users Say Thank You to Dano For This Useful Post: | atvfreek (03-15-2013), BlueStreak (03-15-2013), NJSPEED3 (03-15-2013), phate (03-15-2013), sidekick (03-15-2013) |
![]() | | #134 | ![]() |
| Not Ranked : 0 score Stock fan control is a strange pain in the ass as David from Cobb mentioned. I think it would be far easier to use a temp switch and a relay to control the fans. Use a double pole double through relay and leave the stock system connected if it makes you feel better. I would just do away with it all together. Than again, I fall in that "stage 3" category. |
![]() | | #135 | ![]() |
Groans: 58
| Not Ranked : 0 score i-MOTO got back to me again. He sent a few separate emails so I'll just summarize. First off, which is what I thought, the engines are OEM sealed from Mazda. The ST class doesn't allow them to tinker with them. They do not run a thermostat. As for max fluid temps: Water - 260°F, Oil 300°F+. The oil that they run is Maxima RS1040 and they don't ever worry about oil related issues. I also linked him to both this and the ring land thread as he wasn't which forum these are coming from. |
| The Following 9 Users Say Thank You to daafisch For This Useful Post: | 802MS3 (03-15-2013), atvfreek (03-15-2013), BlueStreak (03-15-2013), dark_matter (08-26-2013), Lex (03-15-2013), Mauro_Penguin (03-16-2013), Nliiitend1 (03-16-2013), phate (03-15-2013), Tomas (03-18-2013) |
![]() | | #136 | ![]() |
| Not Ranked : 0 score Do we have an idea as to what kind of tune they are running or is engine management prohibited as well? Power/torque? Sealed from Mazda meaning MMD is that different than our factory spec? |
![]() | | #137 | ![]() |
(Thread Starter) | Not Ranked : 0 score SPDT relay will put Power to the fan when the ECU wants to cut the power...right? This is how I wired my WMI failsafe to power an LED when fault is detected causing a cut in power to a sol. ECU wants to cut power more often than give it. seems easy at first glance. Car moving - AC off - ECU turns fans off throwing the SPDT. SPDT powers the fan on as long as the ECU circuit state remains the same. I guess at that point you would need a couple of circuits so that when you stop - ECU powers fan SPTD throws again...argh...like i said me no hablais circuits well. also don't know how to step up the amps for power to the fans. Somebody in here said the fan will blow a 30a fuse. I'll have to get my napkin out and do some DJ sketches.
![]() | | #138 | ![]() |
| Not Ranked : 0 score No i mean using a DPDT to switch between your commanded forced high speed ON and computer control. |
![]() | | #139 | ![]() |
(Thread Starter) | Not Ranked : 0 score O I C anyway this is kinda a derail to the broader view of the topic...lol
| The Following User Says Thank You to Dano For This Useful Post: | BlueStreak (03-15-2013) |
![]() | | #140 | ![]() |
Groans: 58
| The Following User Says Thank You to daafisch For This Useful Post: | atvfreek (03-15-2013) |
![]() | | #141 | ![]() |
Groans: 44
This was a couple of yrs ago...and I was told to forget the discussion that was had...
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- | |
![]() | | #142 | ![]() |
| Not Ranked : 0 score @silvapain; and @MATT DAMOND; were down in Daytona talking to the MS race team. I believe they talked tuning strategies and imposed rules for boost and whatnot. What say ye guys?
| The Following 2 Users Say Thank You to phate For This Useful Post: | Nliiitend1 (03-16-2013), silvapain (03-15-2013) |
![]() | | #143 | ![]() |
![]() Join Date: Sep 2008 Location: Toronto, Ontario, Canada
Rep Power: 2202 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,767
__________________ '07 CWP MS3 Forged. | |
![]() | | #144 | ![]() |
Groans: 189
| Not Ranked : 0 score For a long while I contemplated running a big cfm pusher fan from Jegs on the front of the radiator wired to a switch. It's probably the easiest option as far as "fan control" goes.
__________________ |
![]() | | #145 | ![]() |
__________________ | |
| The Following 4 Users Say Thank You to silvapain For This Useful Post: |
![]() | | #146 | ![]() |
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 03-15-2013 at 04:13 PM. Reason: MSF Database - Automerged Doublepost | ||
| The Following 2 Users Say Thank You to Dano For This Useful Post: | BlueStreak (03-15-2013), Fobio (03-15-2013) |
![]() | | #147 | ![]() |
Groans: 189
| The Following User Says Thank You to Enki For This Useful Post: | sidekick (03-15-2013) |
![]() | | #148 | ![]() |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() | |
| The Following User Says Thank You to sidekick For This Useful Post: | Enki (03-15-2013) |
![]() | | #149 | ![]() |
Groans: 189
| Not Ranked : 0 score Probably room for two of those @ 10 inches.
![]() | | #150 | ![]() |
Groans: 47
| Not Ranked : 0 score Is there no way to allow it to function as normal, but with a switch spliced in somewhere that simply forces it to "ON", regardless of ECU input?
![]() | | #151 | ![]() |
(Thread Starter) | Not Ranked : 0 score between IC and rad no..prap ~1" between IC and bumper, centered, there is 16" of 3.25 clearance with my Genwan and Cobb FMIC After the 16" it closes down fairly rapidly. We already have a fan installed that probably only runs like 20% of the time...lol
![]() | | #152 | ![]() |
Groans: 47
The MS6 guys are ahead here , because we have 2 fans, stock. The AWR/Ron Davis radiator looks like a promising option for us, but there is no proof that it does any better than stock. Is anyone actually running one?
![]() | | #153 | ![]() |
| Eatin' Your Tuna ![]() Join Date: Feb 2008 Location: Nator HQ - San Diego, CA
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,602
Groans: 244
I think having a manual override to the fan would work well for everyone.
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | ||
| The Following 6 Users Say Thank You to Haltech For This Useful Post: | Boosted Beluga (03-15-2013), Deldran (03-15-2013), Fobio (03-15-2013), kritz (03-15-2013), sidekick (03-15-2013), TiGraySpeed6 (03-15-2013) |
![]() | | #154 | ![]() |
Groans: 47
| The Following 3 Users Say Thank You to sidekick For This Useful Post: |
![]() | | #155 | ![]() |
Groans: 298
| The Following 7 Users Say Thank You to rfinkle2 For This Useful Post: | BlueStreak (03-15-2013), Fobio (03-15-2013), ms3blackmica (03-15-2013), phate (03-15-2013), sidekick (03-15-2013), SLOWHATCH (07-22-2013), wolly6973 (03-15-2013) |
![]() | | #156 | ![]() |
| Not Ranked : 0 score 12psi max is rough. Less boost than stock FTL. I would guess that these guys are putting down a maximum of 270whp so their cooling setup may not be sufficient for guys here. I ran the K04 as hard as I could with 11.2afr and 12* peak timing on the track and did not have issues with coolant temperature getting excessive, including a 105* day at willow springs this was the tune that was run at forum wars, approx 270 at the wheel. My temperatures didn't get excessive till I slapped the BNRS3 on and was able to rev it out to redline and still make power. Zigatapatalka
| The Following 11 Users Say Thank You to Ziggo For This Useful Post: | BlueStreak (03-15-2013), Boosted Beluga (03-15-2013), Dano (03-15-2013), Fobio (03-15-2013), ms3blackmica (03-15-2013), NJSPEED3 (03-15-2013), rfinkle2 (03-15-2013), sidekick (03-15-2013), silvapain (03-16-2013), TiGraySpeed6 (03-15-2013), wolly6973 (03-15-2013) |
![]() | | #157 | ![]() |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| Not Ranked : 0 score Pretty simple and cheap to do. Like mentioned above you will need a bigger fuse I think Cruzito runs a 40amp on his stock fan. So who knows if I'll need more we need to test the fans and see what its drawing out, so far for the lil bit I drive the 30amp I have has been ok. Keep in mind its been freezing up here. the reason why I decided to add the extra fan with the Derale controller was because in the summer my oil temps are just too high for regular driving. I usually see around 200-210 oil temp, which has gotta be a product of my constant 210-220 coolant temps. The set up is finally working well, my dashawk says they came on around 201-203 and shut off around 187 degrees. Essentially my goal is to keep the oil temp as close to 190 as possible. ![]() |
| The Following 9 Users Say Thank You to NJSPEED3 For This Useful Post: | BlueStreak (03-15-2013), daafisch (03-15-2013), Enki (03-16-2013), Fobio (03-15-2013), ms3blackmica (03-15-2013), rfinkle2 (03-15-2013), sidekick (03-15-2013), TiGraySpeed6 (03-15-2013), wolly6973 (03-15-2013) |
![]() | | #158 | ![]() |
Groans: 44
Props...
| The Following 2 Users Say Thank You to Fobio For This Useful Post: | BlueStreak (03-15-2013), NJSPEED3 (03-15-2013) |
![]() | | #159 | ![]() |
Groans: 113
| The Following 3 Users Say Thank You to NJSPEED3 For This Useful Post: |
![]() | | #160 | ![]() |
Groans: 44
...or do you? ![]() ...or am I?...lol...
| The Following 4 Users Say Thank You to Fobio For This Useful Post: |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/mzr-disi-heat-management-140135/ | ||||
| Some things I learned after going to the track - Page 9 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 02-27-2014 11:16 AM | |
| Water temp ou Oil temp ? - Mazda 3 Quebec | This thread | Refback | 03-15-2013 04:06 PM | |
| Random MS3 Chat Thread - Page 165 | This thread | Refback | 03-15-2013 12:48 PM | |
| New DISI | CorkSport | Gen2 MS3 General Discussion | 8 | 04-09-2012 08:35 AM |
| MZR 2.3 DISI Rods from cp-e™ | www.cp-e.com | 2010 MS3 - Engine, Transmission & Driveline | 0 | 03-22-2011 12:29 PM |
