Like Tree35Likes
 Old 04-22-2013, 10:27 AM   #281
Ziggo's Avatar
Posts: 3,843   (View Stats)
I tested mine in a pot of water to confirm that that old thermostat was bad. That's where I was pulling my numbers from.
Zigatapatalka
Ask Me About My:
silvapain (04-22-2013)
 Old 04-22-2013, 12:23 PM   #282
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
Originally Posted by Celestspeed3 View Post
Is that the same spec for the pu ?
yea I'm pretty sure they are still the same. I looked up the 2013 to make sure, and it says the exact same temps. Must still be using the same thermostat.
'08 CWP MS3 w/ T3 3071r
The Following 2 Users Say Thank You to 802MS3 For This Useful Post:
aaron_-01 (04-23-2013), Celestspeed3 (04-22-2013)
 Old 04-27-2013, 09:59 AM   #283
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
One of these vendors could have a hot product if they could make a pug-n-play fan controle unit ..
Some sort of box with a pig tail in/out kinda deal with some type of potentiometer to set the on temp .
I bet they would sell tons of them !!
Maybe someone could tag the all vendors ?? Or if one of you tech heads could design and make one ..
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
Alpha (04-27-2013)
 Old 04-27-2013, 10:23 AM   #284
Posts: 9,484   (View Stats)
ahem...that is already in process I think all is done except the PNP which hopefully isn't that much more work.
@BlueStreak;
BlueStreak (04-28-2013), jracer (04-27-2013)
 Old 04-27-2013, 10:38 AM   #285
timjs's Avatar
Posts: 908   (View Stats)
timjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the world
The PCM has built-in activation functions. With the IDS scan tool, you can activate EGR, the cooling fans, wastegate solenoid, fuel pump, shut off injectors, ect with a click of the mouse.
I'd imagine a module that utilizes this direct functionality would be awesome.
timjs is offline   Reply With Quote
The Following 2 Users Say Thank You to timjs For This Useful Post:
Alpha (04-27-2013), rfinkle2 (04-29-2013)
 Old 04-27-2013, 09:32 PM   #286
dot584's Avatar
Posts: 426   (View Stats)
dot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the world
Groaned at 4 Times in 2 Posts
In atr there is no control for radiator fan I'm pretty sure. If that other scan tool can do it then does that mean Cobb should be able to give us control?
Sent from my Incredible 2 using Tapatalk 2
CP-E TIP and Cai - Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP - Fat Cat Motorsports Coilovers!
dot584 is offline   Reply With Quote
 Old 04-27-2013, 10:35 PM   #287
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
I often let my friend borrow my Dashhawk for his GTO when he goes to the track.
The GM cars have the ability to turn the fans manually ON and OFF right from the dashhawk.
Oh how simple...
www.tunedbynishan.com
The Following 3 Users Say Thank You to ms3blackmica For This Useful Post:
kgb (06-01-2013), rfinkle2 (04-29-2013), silvapain (04-29-2013)
 Old 04-29-2013, 09:09 AM   #288
at that point you are trying to hack your IDS tool to find those functions to then trigger them in the ECU..not sure its worth all that trouble.
external circuit is much easier
 Old 04-29-2013, 09:22 AM   #289
Alpha's Avatar
Posts: 3,711   (View Stats)
Groans: 24
We need a PNP controller, stock connector based "Plug in and drive" solution for all the spoiled, non soldering asses like myself
Who's with me? Haha!
The Following User Says Thank You to Alpha For This Useful Post:
jracer (04-29-2013)
 Old 04-29-2013, 09:46 AM   #290
I haven't looked at the controller to fan connection but IIRC it is not a connector. The harness does plug in to the fan controller but the controller to fan connection is just a couple of wires. The solution entails changing all of that so no complete PNP is possible.
part of Dave's circuit bypasses the controller while it also allows for the OEM controller to function.
Dave can elaborate/correct me if I am wrong.
BlueStreak likes this.
BlueStreak (04-29-2013), wolly6973 (04-29-2013)
 Old 04-29-2013, 09:46 AM   #291
Voltwings's Avatar
Posts: 3,713   (View Stats)
@BlueStreak;
I've often played with the idea of pulling the factory plastic cover with the fan and just placing two high volume fans in its place. Being that im in South Texas "winter" here is like mid 40's haha so im not too terribly worried about my coolant freezing at a stop, I am however worried about it sky rocketing mid summer in triple digit heat. One of the main reasons I haven't yanked that shit out yet is because I wasn't quite sure how id Frankenstein the factory fan controller into the new fans, but it sounds like I can use Bluestreak's little controller in conjunction for a cleaner install...
On a side / unrelated note, I have also contemplated yanking the coolant feed to the oil cooler mounted on the filter. To me it just doesn't make much sense to have 200* coolant "cooling" my oil ... our car has way too damn many coolant hoses any ways haha.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 04-29-2013, 03:30 PM   #292
rabble rabble
802MS3's Avatar
Groans: 221
NJSPEED3 hacked up his fan shroud to connect a second fan. The fan he used is posted towards the top of the thread.
My HTA3586 build
The Following 4 Users Say Thank You to 802MS3 For This Useful Post:
magicka (04-29-2013), rfinkle2 (04-29-2013), Voltwings (04-29-2013), wolly6973 (04-30-2013)
 Old 05-05-2013, 12:10 PM   #293
MattJackson86's Avatar
Posts: 1,407   (View Stats)
So all this talk of fan controllers etc, how is turning the fan on at a lower temp going to help cool the engine when at speed? Seems to me the fan will help when low speed or stopped, but track days at speed I don't see our fan producing any more cooling power. Are we going down the wrong path trying to get the fan to turn on when in reality a second fan like @NJSPEED3 or a thermostat that cracks fully open sooner would be better?
The Following 2 Users Say Thank You to MattJackson86 For This Useful Post:
802MS3 (05-05-2013), BlueStreak (05-05-2013)
 Old 05-05-2013, 12:12 PM   #294
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
The fan is definitely for low speed or stopped operation.
-06 MS6
-Corn fed 07 MS3 - Sold
BlueStreak (05-05-2013), Easter Bunny (05-06-2013)
 Old 05-05-2013, 01:00 PM   #295
erevlydeux's Avatar
Posts: 120   (View Stats)
erevlydeux has a reputation beyond reputeerevlydeux has a reputation beyond reputeerevlydeux has a reputation beyond reputeerevlydeux has a reputation beyond reputeerevlydeux has a reputation beyond reputeerevlydeux has a reputation beyond reputeerevlydeux has a reputation beyond reputeerevlydeux has a reputation beyond reputeerevlydeux has a reputation beyond reputeerevlydeux has a reputation beyond reputeerevlydeux has a reputation beyond repute
I wouldn't totally agree. Think about Auto-X. You're working the engine and the gearbox HARD but you're doing a lot of turning and aren't getting too much straightaway airflow. Running the fans would help here.
On an actual track, they wouldn't help as much, sure, but again, you're going for consistent cooling. Getting up to 100mph on a back straightaway sure does help for cooling... but what about when you're weaving through chicanes and incline changes and are only going 40 or 50mph? The fans will help for those intermissions.
If the average cooling efficiency is higher from running the fans, then the mod has served its purpose.
dot584 likes this.
erevlydeux is offline   Reply With Quote
The Following User Says Thank You to erevlydeux For This Useful Post:
MattJackson86 (05-05-2013)
 Old 05-05-2013, 03:26 PM   #296
Todd98SE's Avatar
Posts: 1,077   (View Stats)
Todd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the world
I have seen previous research showing that over a certain speed having the fans come on can decrease cooling efficiency. This was on a FWD SR20 engine and each car is different but it's something to keep in mind.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline   Reply With Quote
The Following 2 Users Say Thank You to Todd98SE For This Useful Post:
Easter Bunny (05-06-2013), Nliiitend1 (05-06-2013)
 Old 05-05-2013, 04:47 PM   #297
dot584's Avatar
So fans would help at lower speeds and ducting would work at high speed. Should be able to maximize our radiators efficiency when using both.
Sent from my ADR6300 using Tapatalk 2
 Old 05-05-2013, 11:09 PM   #298
Voltwings's Avatar
I actually was thinking of this as i was scrolling down reading. Basically it seems to me that there would come a point where the air would naturally pass through faster on its own than with a fan on, and at that point it would become a "restriction" by just getting in the way and stopping air from passing though? Similar to those Ebay electric superchargers you know?
New Electric Intake supercharger Turbo All Vehicles MPG HP Intake Turbocharger | eBay
Past:
-Sold-
-Sold-
Current:
 Old 05-06-2013, 07:05 AM   #299
aggierandy's Avatar
Posts: 2,241   (View Stats)
aggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the world
Groaned at 18 Times in 14 Posts
Thoughts to increase cooling capacity:
Speed up coolant, remove restrictions to air flow, more water/less antifreeze in coolant, thicker core or a copper/brass radiator (for you rich guys).
2010 MS3 Mica Black Tech
Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals
CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch
aggierandy is offline   Reply With Quote
 Old 05-06-2013, 07:11 AM   #300
erevlydeux's Avatar
I mean, if we're talking about advanced fan controllers and all that type of stuff... you could always turn off the fans once you hit a certain speed and turn them back on against once you're below a certain speed.
 Old 05-06-2013, 07:34 AM   #301
timjs's Avatar
They spin from the air flowing through them anyways..
 Old 05-06-2013, 09:19 AM   #302
Todd98SE's Avatar
Seal up any and all gaps around the radiator to front bumper fascia. Extend the front splitter and seal any gaps between the splitter surface and bumper opening.
www.MOTOIQ.com
Beater Titan
The Following User Says Thank You to Todd98SE For This Useful Post:
aggierandy (05-06-2013)
 Old 05-06-2013, 09:21 AM   #303
aggierandy's Avatar
Just to be clear, are we more concerned with low speed/idle cooling than high speed cooling?
 Old 05-06-2013, 09:45 AM   #304
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
super_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the world
slightly unrelated to current topic, but relevant to thread...
Basic info, but for what its worth, this weekend I did parallel comparisons of running on track with full blast heat and no heat and I saw about 12-14 degree difference (EDIT: in coolant temperatures)...
Its not super hot here in AZ yet, but at least in the dry AZ weather, full blast heat is definitely worth it.
In the city traffic, ive noticed about 8-10 degrees difference as well (though it would be pretty fucking uncomfortable).
super_pablo_ is offline   Reply With Quote
The Following 6 Users Say Thank You to super_pablo_ For This Useful Post:
BlueStreak (05-06-2013), Easter Bunny (05-06-2013), Nliiitend1 (05-06-2013), phate (05-06-2013), Todd98SE (05-06-2013), wolly6973 (05-06-2013)
 Old 05-08-2013, 03:27 PM   #305
Voltwings's Avatar
ok, I have a crazy idea and would just like to guys to run with me for a second...
Chances are most of us are here because we care about removing heat from the engine bay, so we've already done the basics, namely removing the rear weather stripping. What I would like to see (maybe) is some sort of box or enclosure attached to the hood (or block if possible) that went around the turbo and manifold. From there, allow ducting for the heat to be channeled out the rear weather stripping hole, or somehow otherwise out of the engine bay. Being that I have a Gen2, I have thought about rigging up the factory TMIC scoop to purely serve to evacuate the heat from the "manifold box" but since I don't run fog lights, I have also considered running ducting under the car and feeding fresh air to the bottom of the box to better evacuate heat. Maybe the inside of the box could be lined with DEI reflective tape, or the gold tape, or something, and it would basically reduce the heatsoak of the engine bay.
Obviously this is something that will be tricky to do since everyone has different FMIC set ups, as well as turbo and manifold set ups but it may be an idea. Granted too much heat trapped in there may cook the turbo and manifold but if someone can run with this idea id like to see where it may end up.
Past:
-Sold-
-Sold-
Current:
 Old 05-08-2013, 08:26 PM   #306
Todd98SE's Avatar
It would probably be easier and more effective to manipulate the aero on the car for more efficient cooling. Splitter, undertray, etc.
www.MOTOIQ.com
Beater Titan
Chimmike (05-08-2013), Easter Bunny (05-09-2013)
 Old 05-08-2013, 11:02 PM   #307
Voltwings's Avatar
I get bored at work and fantasize I just appreciate you humoring me haha
Real talk though, I would like to make some sort of rig to block off the radiator and FMIC to channel more flow through.
Past:
-Sold-
-Sold-
Current:
The Following 2 Users Say Thank You to Voltwings For This Useful Post:
TiGraySpeed6 (05-09-2013), Todd98SE (05-08-2013)
 Old 05-09-2013, 04:31 PM   #308
Code Monkey's Avatar
Posts: 7,681   (View Stats)
I ran the K04 as hard as I could with 11.2afr and 12* peak timing on the track and did not have issues with coolant temperature getting excessive, including a 105* day at willow springs this was the tune that was run at forum wars, approx 270 at the wheel. My temperatures didn't get excessive till I slapped the BNRS3 on and was able to rev it out to redline and still make power.
Sorry if I missed it, still reading through the thread, but did you do anything to reduce the temps the BNR generates?
On the k04, I was at 10.8 afr and 9* of peak timing, the BATs would occasionally exceed 160 but there was no KR.
On the BNR, I am at 11.4 afr with 11* peak timing, the BATs are usually above 160, and once they start climbing -- up to 195 -- I get KR.
Next weekend I will add 2 gallons of 104 gas and see whether this helps with the KR. If not, Justin made me a milder map where we start pulling timing once BATs exceed 120 and hopefully this will work. I have two more track weekends before I take a summer break, over the summer I plan to install the AWR radiator.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
atvfreek (05-09-2013), Boosted Beluga (05-09-2013), Ziggo (05-09-2013)
 Old 05-09-2013, 07:59 PM   #309
Ziggo's Avatar
The short answer is I have an FMIC. After seeing BATs getting excessive on the track in CA I got the FMIC, which kept them under control on with the K04. I didn't actively monitor BATS on the track with the BNRS3, but I never got knock, and I never felt a noticeable loss of power, but I was also throwing a couple gallons of 104 in when I filled up just for peace of mind. I also never ran more than 20psi on the BNR on the track.
Ask Me About My:
The Following 6 Users Say Thank You to Ziggo For This Useful Post:
atvfreek (05-09-2013), Code Monkey (05-09-2013), Nliiitend1 (05-10-2013), phate (05-09-2013), super_pablo_ (05-09-2013), wolly6973 (05-10-2013)
 Old 05-21-2013, 07:22 PM   #310
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
Groaned at 6 Times in 6 Posts
Is anyone developing ducting for the sides of the engine bay? Seems like low hanging fruit to make the basic shaped sheets and cut to fit your mods.
 Old 05-30-2013, 07:59 AM   #311
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
Celestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the world
Groaned at 55 Times in 26 Posts
In an effort to understand how much heat this car can take before it breaks. I took some data logging with the Solo on the track. I was at TMP last night for lapping. After 5 laps the car goes from 185 to 215. I decided to see how much I could push it after that. I stayed on track for a 25min session steady. By the end of the 5th lap temps where at 215 again, I stayed on for another 10 laps with temps from 215 to settling out at 230 around lap 10 and steady steady until lap 16. Did a co.pres soon test this morning before I went to work (motor cold) got 180, 185, 185, 185. I'm using stock plugs for reference and I will have to look up the tune details.
Celestspeed3 is offline   Reply With Quote
The Following 11 Users Say Thank You to Celestspeed3 For This Useful Post:
802MS3 (05-30-2013), atvfreek (05-31-2013), Code Monkey (05-30-2013), El_Diablo (06-04-2013), fredricktsang (05-30-2013), MajesticBlueNTO (05-30-2013), Nliiitend1 (05-30-2013), TiGraySpeed6 (05-30-2013), Tomas (05-30-2013), Voltwings (05-31-2013), wolly6973 (05-30-2013)
 Old 05-30-2013, 06:19 PM   #312
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
^^^ Boost, timing, at what rpm you shift, and ambient temps if you could please.
 Old 05-30-2013, 06:48 PM   #313
breakfasteatre's Avatar
Posts: 308   (View Stats)
breakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the world
oil or coolant temps? @Celestspeed3;
breakfasteatre is offline   Reply With Quote
 Old 05-30-2013, 07:06 PM   #314
YokiMazoku's Avatar
Posts: 320   (View Stats)
YokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the world
Maybe someone talked about this already and i missed it but corksport offers a radiator shroud to replace our stock ducting. Ive been running it for a week. Biggest difference is how quickly the temps drop at lower speeds. High speeds haven't noticed much of a change.
Boobs.....because you can't motorboat a personality.
YokiMazoku is offline   Reply With Quote
 Old 05-30-2013, 09:48 PM   #315
JSmith's Avatar
Groans: 106
Are you talking about this?
CORKSPORT 2007-2009 Mazdaspeed 3 Radiator Shroud
edit: whoops. Meant to PM.
 Old 05-31-2013, 07:23 AM   #316
DSIT995's Avatar
Posts: 1,768   (View Stats)
DSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the world
I just ordered this myself.. At slower speeds my ECT's are always in the 210-217 range.
2 things that I would like to get done this summer for my car:
Ducting for the FMIC and Rad for the lower grille
And a simple fan override switch that would run the fan for however long I want
08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock!
99 Miata NB - Stock for now
Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors
DSIT995 is offline   Reply With Quote
 Old 05-31-2013, 08:31 AM   #317
18psi
12°
6500rpm (7000rpm redline)
Weather details: ~73F, ~80% humidity, ~14.31psi
Alex those are coolant temps.
Last edited by Celestspeed3; 05-31-2013 at 08:35 AM. Reason: weather details added
The Following 2 Users Say Thank You to Celestspeed3 For This Useful Post:
Tomas (05-31-2013), Voltwings (05-31-2013)
 Old 05-31-2013, 11:38 AM   #318
YokiMazoku's Avatar
Yes that is it.
 Old 06-03-2013, 02:58 PM   #319
YokiMazoku's Avatar
When u get this installed you should do some testing. I would but im lazy. I actually did some but i dont think my results are accurate the drop in temp seems to be to high. My coolant temps use to be about the same now with the shroud i dare say they are about 200 -210. With speeds around 20-30mph. will still get up to 220 range if your doing lots of stop and go tho. But will drop much faster. At least that's what i noticed. Definitely made a difference dont be alarmed when u dont hear your fan go off everytime you get out of your car lol.
The Following User Says Thank You to YokiMazoku For This Useful Post:
DSIT995 (06-04-2013)
 Old 06-04-2013, 05:31 AM   #320
DSIT995's Avatar
Good idea.. I'm going to paint the ducting today, so I'll get some logs with the stock TMIC shrouding in place going 20mph 30mph 40mph. At those speeds my ECT's have never dropped always just stay the same or go up..
Will post up the differences after logs are done
Edit: its only mid 60's here now so my tests will have to wait until its hot again..
The Following User Says Thank You to DSIT995 For This Useful Post:
Voltwings (06-04-2013)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/mzr-disi-heat-management-140135/
Some things I learned after going to the track - Page 9 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-27-2014 11:16 AM
Water temp ou Oil temp ? - Mazda 3 Quebec This thread Refback 03-15-2013 04:06 PM
Random MS3 Chat Thread - Page 165 This thread Refback 03-15-2013 12:48 PM
New DISI CorkSport Gen2 MS3 General Discussion 8 04-09-2012 08:35 AM
MZR 2.3 DISI Rods from cp-e™ www.cp-e.com 2010 MS3 - Engine, Transmission & Driveline 0 03-22-2011 12:29 PM
Page generated in 0.63702 seconds with 42 queries
