4 Attachment(s) |
Sent via blown passenger side speakers. now Free |
1 Attachment(s) Quote:
RC Engineering STILL doesn't do DI Injectors. We'll be sending mine off to Injector RX for testing to see if #1 injector is cause of this fail. |
I had injector rx clean mine. |
M2 Catless DP AutoTech FP internals COBB SRI/TIP CPE CBE TurboSmart 50/50 Tune: It was just a base tune with afr/throttle adjustments done to it, nothing special at all. commanding 11.6 at WOT. |
Seems like more melted pistons come from cali. Probabaly a result of shit gas, and running lean on OTS maps. Recipe for pre-ignition. |
Cali gas is terrible. I'm glad e85 stations are starting to pop up more frequently out here. |
Hi guys, I would like to ask you, who have rebuilt the motors with cracked ringlands, how badly was the bore damaged? Was it ok and honing was enough, or did you need boring it out? Essentially, did you stay with 87.5 pistons or did you need to go bigger? Thanks. |
Hm, i've read other opinions, that if possible, you should avoid boring, for reasons that you might need to redo it later, it reduces heat management and strength. If I decide to overbore, then I might order the pistons right away. Otherwise, I need to see if I can do with 87.5's. |
word...bores look like a whore's... well you know the rest. :) |
Aaaand he's out. |
It was like reading some old threads, but in real time... What a tease Sent while cleaning my spill valve again... |
Model/Year: 3 MPS 2010 Mileage: 29,000 Compression Results: 170, 170, 197, 170 Cylinders /w Cracked Ringlands: #1 , #3 & #4 Suspected Event Causing Failure, Condition of Affected Cylinder(s) and Other Info: Went WOT to overtake a lorry. Glanced at Cobb to see max boost at 22.63psi on stock MAP. Waiting at next junction, smoke coming from bonnet vent. Pull into car park, car has blown dipstick. Prior to this, when driven hard, the car would have oil dripping from the cone filter. Also, I have been getting a small oil spray from the VVT oil actuator. Pictures: http://img.tapatalk.com/d/14/03/23/na2esygy.jpg http://img.tapatalk.com/d/14/03/23/nype9e8a.jpg http://img.tapatalk.com/d/14/03/23/ru3epahy.jpg #1 http://img.tapatalk.com/d/14/03/23/abe8e4y7.jpg #3 http://img.tapatalk.com/d/14/03/23/5ypy3uhy.jpg #4 Sent from my GT-N7105 using Tapatalk |
Yes Brock. Leak down was 30%, but that's fine, yeah? Lol Sent from my GT-N7105 using Tapatalk |
Translation Below: Quote:
Thanks for translation! Sent from my GT-N7105 using Tapatalk |
HAHA I think we all have watched enough Top Gear UK to understand those terms. |
So that's how they spell lorry. Wondered that for years. |
| All times are GMT -7. The time now is 06:58 AM. |
