I don't think it's necessarily power related. Kmac made 600whp on stock block. No chucked rod. No broken ring lands. LOTS of meth (while that doesn't eliminate meth as a factor, it does put one check in the no column), and just generally driving the car as hard as situationally possible. But he's just one case I suppose. |
What I think we want to do is push that time window out by cooling the motor off not decreasing power. That would be step 1 in my book. The next step for guys wanting to stay in an OEM configuration yet optimize it might need to alter the ring gaps to attain more headroom with ring butting. Could be the rings are not doing this in every instance of a failure but it is one thing to eliminate. long term data my indeed show the gen2 piston design as already addressed this entire subject...lol @Lex; do you, or anyone, have any data on a gen2 piston with the oil residue/burning on the exhaust side?? didn't ckmazdaspeed3 send you his PU pistons after he threw his rod? |
1 Attachment(s) Quote:
http://www.mazdaspeedforums.org/foru...1&d=1363452370 |
yes more mileage and data needed on the PU pistons. |
its a ton of labour hours even if I have guys helping me, and I wouldnt want to pull anyone away from the fun during the dyno runs, but would it be worthwhile to this discussion if we pulled my head and pulled the rods and pistons in april? If so, ill grab the one time use parts so we can put it back together. For reference: I have a poo, now with 38k kms (23k miles) with low compression in cylinder 4. Me and my nader brothers did a leak down test, 20% past the rings. Ran 4 time attack events, saw oil temps hit 260 after about 5 laps, did 5-15 laps at 260. Off the shelf stage 2 map + maf cal. Dynoed at 270/310 ish one event I blew couplers off multiple times due to faulty hose clamp |
@SPEED6 KILLAH; |
Great thread... Anyone have a compression tester recommendation (and a good procedure)? I should probably check mine... |
As for the procedure, get car up to temp. Pull one spark plug at a time, attatch comp tester, pin accel pedal while cranking a few seconds, read pressure ASAP. Repeat for each cylinder. |
I pull all the plugs and crank for 10 revolutions on a warmed up motor. |
Pull all plugs so the starter has an easier time turning the motor over. |
I have a question for the people who had Ringland Failures how much boost are you guys running and what was you coolant temp at? |
Mine was 22psi/ coolant temps 225 range after coming off the track 60degree day |
I had just moved up from a 21-22PSI tune to a 26 PSI tune. The timeframe was around August last year and AMB temps were ~100*f. I don't know exactly when mine went nor the exact ECT but I routinely saw 217-220* last summer. My tstat must be broken b/c I see 217 now after a 10-15 minute drive around the city. AMP temps in the 40*f |
I cranked mine 10x's as well. I was within 5 psi on all cilynders, all just above 180 psi. Quote:
1) warm engine to operating temp 2) Pull relay labeled circuit 3) pull all 4 plugs 4) insert compression tester 5) optional : hold gas pedal to floor while testing 6) Crank all cylinders between 5-10 times each 7) AFAIK, you want all 4 cilynders to be within roughly 5% of eachother, in our case, somewhere in the neighborhood of 180-185psi. |
If you pull all the plugs and do the test sometimes the values come out lower. I've had this happen with my leakdown tester. I'm not sure why, just something I've noticed. So I just pull one plug at a time now. |
Sent via smokey turbo. |
Just something I've noticed with my leakdown tester. When I did @breakfasteatre; motor I pulled all the plugs and the I didn't get proper values. |
Are you talking about doing a compression test or a leakdown test? In either case, you should pull all of the plugs. Maybe you need a new guage. My POS harbor freight setup reads 10 psi lower than other guages. Sent via smokey turbo. |
is it possible to diagnose ring/ringlands without pulling motor apart? something like like a camera or something? |
Re: MZR DISI Ringland Failures Quote:
Edit: also have you ever seen a piston with rings seated in a bore? You can't really see the top ring at all. heres a picture i borrowed from another thread. now imagine looking in there with a tiny camera trying to diagnose a cracked ringland with everything black and covered in carbon. http://i142.photobucket.com/albums/r.../HeadStuds.jpg Sent from my Galaxy Nexus using Tapatalk 2 |
A leakdown test will tell you what you need. |
I just did a leak down. It told me I need peepee touch. |
A high leakdown percentage 15-20%+ tells you the motor needs something done internally and needs to come apart anyways. |
got it. edit: is high leak a definite for a crack? can it, in theory, be anything else (if it's leaking past the cylinder, not the valves)? |
My leakdown tester has 40% at the far end of the "low" scale. |
I've never seen a spec for 40% leakdown. Is that from the 80's? lol 20% leakdown is the max spec I have always seen. |
Fuck! That was my anal seepage gauge. |
haha well there's the answer then. If you are leaking 40% its time for surgery. |
If the injector seals are leaking, could you get a shit compression / leakdown reading as well? |
MZR DISI Ringland Failures Still waiting for a diagnosis from pablo guys. Was supposed to get some pictures yesterday of her but nothing yet so as soon as I get some goodies of the possible failure I will update!! |
| All times are GMT -7. The time now is 06:58 AM. |
